First post, by Gelip
Hi. I installed Win95 OSR2 on the Asus P8H61-M LE R2 motherboard. There is one PCI slot in which I use the Sound Blaster Live! sound card (CT4830).
I installed drivers from the Live! Install CD.iso that I downloaded from this forum:
https://www.vogonsdrivers.com/getfile.php?fileid=512
Sometimes I have a problem that at the start of the Win95 system, the sound stuck like a video:
https://youtu.be/30KuX0Zc7JE
A similar situation is when watching DivX or MP4 video in VLC 0.8.6f and also when playing MIDI files, e.g. on an external MIDI device. I note that this happens only sometimes.
I tried other drivers but there is the same problem.
When the problem appears, I have to reset the computer several times using RESET button on case and it often helps.
