Doubt I can add much... I still have a running P200MMX system, some might
find it's story interesting:
It's on one of my favorite mainboards for DOS - When I got one, I liked
it so much I bought a second board as a spare.
It wasn't a gaming machine, It was the system upon which I developed
ImageDisk... and the reason it's one of my favorites is that it has one of
the BESTS floppy disk controllers I've encountered in a PC - I've had the
best luck reading many formats of non-DOS diskettes. It does single-density,
odd sector sizes/layouts better that most of the other systems I tested.
In recent years/downsizing I sold off the original ImageDisk system, and
so many people have wanted me to continuing supporting ImageDisk that I
dug out the other board (was still in box) and not having a spare AT case, built
it up on a piece of wood!
You can see it here: Re: Windows 95 on a Breadboard
The motherboard is an Aopen AP5T - an older AT style, 4-30 pin ram slots
plus 2-DDR , 4 PCI + 3 ISA. It has on-board serialx2 and parallel as well
as IDE - but no on-board video.
I like to work from a RamDisk a lot, so it has a 256m DDR stick in it.
Not needing super-video, I just use an old ATI XL-24 ISA card in it.
It also has a NE2000 compatible network card, under DOS I use a "packet
driver" and DDLINK to move images (and other stuff) on/off of it.
In my case it has a 3.5" floppy drive A: with a modified cable which puts
B: at the end - which comes out so I can easily attach other drives (5.25"
or 8" are most common).
Case will depend on the board (AT or ATX) - horizontal/tower/size will depend
on where/how you plan to use it (I usually prefer minitowers)
I like the AP5T - but it's old and not going to be available anywhere - you really going
to have to go with whatever you can find.
RAM will likely not be a problen unless it's a type that's hard to get.
For DOS/Win9x reqirements are usually quite low and you are likely to find
sticks of more than you need.
Your power requirement will mostly depend of what video card you use.
For most anything "normal" a 250w should be enough.
Unless you're into floppies (ie: want to use original distribution diskettes,
or have a good supply of your own diskettes), you might want to skip floppies
(diskettes are getting hardish to find) - consider going with something like
the GoTek floppy drive emulator - lets you use a USB stick - to get images on
to "virtual floppies", you can move images to the system using network, and
something like my Xdisk or ImageDisk to write then via the GoTek.
SATA will be a lot easier to find/replace ... but if the board wants IDE and
you have a spare one - why not go ahead and use it. You can always mess with
IDE->SATA adapter later if you need to replace it at some point.
I've always used and had good luck with "Sound Blaster" audio cards,
most of my DOS system have the old SBpro or SB16.
I'm one of the oddballs who still uses DOS5 on most of my DOS systems,
always worked well for me, never really found a reason to go new/bigger
(and never really got into long-filenames under DOS)
I never had brand based problems with CRTs. I think you would want at least
1024x768, possibly 1920x1080 if you have stuff that supports it.
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
