Another method is to use Rufus, change the image to MS-DOS and it will create the boot sector and copy DOS 6.22 files to the drive. Then just replace everything on the drive with your copy.
The requirements are:
Partition marked active
Boot sector (newer operating systems don't create the correct boot sector or partition ID)
And the system files: io.sys, msdos.sys, command.com
What FDISK does is install that boot sector and mark the partition active. Rufus can do that for you.
I have done this several times when replacing the old hard drives on our test systems (DOS, 95,98, NT) with compactflash at work.
If you are doing it this way because your floppy drive is not working or you do not have the ability to make floppies anyway, toss in a gotek drive.
Having said that:
If you have the possibility (meaning you have a way of doing it directly on the system - floppy, CDROM, etc..), that is the best approach.
If you are installing the OS on a completely different system (in my case, it is the same system) then it is better to just install from the target machine.
However, if there is special installed software you need from the original installation and you do not have the installation media and/or don't have the specific configuration details of that software, dealing with resolving the driver issues is a smaller problem.
Be mindful of your partition size limits. Use one of free partition manager tools to resize and align the drive after rufus is done.
I agree with the above responses that very best way is to do it all on the target system, but wanted to give you a direct answer to your question in case the above scenario is your reason for doing it the way you intend. That is why I have had to do it that way. This is NOT the best or even easiest way. It is just sometimes a necessary method.
If you do have at least the means to boot and use fidsk and sys the disk on the target machine, at least do that and then copy over your backed up drive. No rufus or partition manager involved.
