First post, by renejr902
Hi! i made a big mistake i was sleepy, i cant believe i did that, i put a agp geforce 4 mx 440 backward ( wrong way ) in a 440bx motherboard pentium ii motherboard and i turn on the psu, nothing turn on, but i tried 3 times and wait a few seconds. After that i saw my error. i tried it again with the geforce in right way, power supply turn on, but black screen only, no beep.
After that i tried several others agp card they are all wirking correctly and boots and play doa games. the geforce 4 mx440 was jot test by me before, but i believe and trust the guy that sold it to me and said it was working and tested for 10$ dollar because its a friend. he sold me the 440bx motherboard that wirk great.
Did i fried the geforce 4 440mx ?
I dont see any damage on it. But the nvidia gf4mx440 chip is hot after 30 seconds, not to be burn my finger, but its very hot. I touched the back of the card where the chip is.
Do have any idea to help me to get it working ?
I was happy to have this card. Thanks for help.
Reply 1 of 34, by myne
If it works in another board, it isn't dead.
If it didn't work, you fried something.
I built:
Reply 2 of 34, by renejr902
myne wrote on 2025-09-03, 03:58:
I tried it in my Pentium III motherboard Apollo pro 133a Asus P3V4X and it doesnt work 🙁
Do you have any idea for testing the card, could it be only a capacitor ? Do you know what could be fried ? Thanks
Reply 3 of 34, by myne
https://old.pinouts.ru/Slots/agp_pinout.shtml
You put it in backwards.
It could be anything.
Fairly likely some high voltage went the wrong way through the core or memory and literally burnt it out.
I built:
Reply 4 of 34, by renejr902
myne wrote on 2025-09-03, 04:22:
https://old.pinouts.ru/Slots/agp_pinout.shtml […]
Thanks for your answer and pinout
Reply 5 of 34, by MikeSG
Is this a joke...
Reply 6 of 34, by Major Jackyl
MikeSG wrote on 2025-09-03, 12:28:
Is this a joke...
Yoooo, 🤣 That's what I was thinking.
Bench parts can definitely be inserted wrong... F56 You'd have to be pretty messed up to screw that one up, 🤣
Here's proof of the operation:
The attachment 20250903_212740.jpg is no longer available
Main Loadout (daily drivers):
Intel TE430VX, Pentium Sy022 (133), Cirrus Logic 5440, SB16 CT1740
ECS K7S5A, A-XP1600+, MSI R9550
ASUS M2N-E, A64X2-4600+, PNY GTX670, SB X-Fi Elite Pro
MSI Z690, Intel 12900K, MSI RTX3090, SB AE-7
Reply 7 of 34, by RetroLizard
Correct me if I'm wrong, but wouldn't the card only be fried if the system is turned on while it's plugged in backwards?
Reply 8 of 34, by renejr902
RetroLizard wrote on 2025-09-04, 04:52:
it seems so 🤣 mine is fried
Reply 9 of 34, by dionb
Yes:
Reply 10 of 34, by renejr902
Major Jackyl wrote on 2025-09-04, 02:32:
Yoooo, XD That's what I was thinking. […]
Is this a joke...
yeah it fit perfectly like mine. it was a funny error, i was really sleepy, i should have go to bed. First time in 30-35 years i inserted a card the wrong way LoL. Time to laugh 🤣. i paid just 10$ its ok.
Reply 11 of 34, by renejr902
dionb wrote on 2025-09-04, 06:21:
Yes:
But still nothing happen, i'm still surprised it fried the card. i didnt see the psu turn on at all
Reply 12 of 34, by renejr902
Is this a joke...
no unfortunately, i was sleepy a lot 🥱😵😵‍💫
still very funny 🤣
Reply 13 of 34, by Errius
I've done this with ISA cards before.
The rule is: for PCI/AGP the components face down. For ISA they face up.
ETA: Unless you're dealing with BTX. Then PCI/AGP face up same as ISA.
Is this too much voodoo?
Reply 14 of 34, by maxtherabbit
how about the rule is "install slot brackets"
Reply 15 of 34, by renejr902
my father is back from vacation. he thinks that is just a fried diode and nothing else serious, he will ckeck it and try to repair it soon, i will let you know
Reply 16 of 34, by RetroLizard
renejr902 wrote on 2025-09-04, 06:24:
Yes:
Very likely the power supply is/was triggering its OCP and refusing to turn on.
Reply 17 of 34, by DaveDDS
RetroLizard wrote on 2025-09-05, 02:45:
OverCurrentProtection can still allow things to fry, and in some cases is kinda a bad sign...
If your supply can provide 20A and OCPs .. that means at least 20A did pass through the board...
The fact that it wouldn't "turn on" over several tries means that something simple didn't fry/open
(and hence stop drawing power) .. and fixing the card position still not letting it turn on means
that something fried enough to develop a fairy serious short on the power rail (assuming it's didn't
just pop a fuse/breaker in the supply).
You really need to do some analysis to see where the power draw is.
If it powers up without the card, but not with it - something on the card ... start tracing power
rails and testing components on the card. Less likely that the mainboard would have been damaged
since power to it's components was not reversed (but still possible due to the high currenet draw, but
it that case more likely something simple).
- Dave ; https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChardware can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small FileTrans(w/o netSW)via Lan/Lpt/Serial
Reply 18 of 34, by Living
how...? in 30 years i never installed a card in the wrong way, the backplate prevents that
Reply 19 of 34, by CharlieFoxtrot
Living wrote on 2025-09-05, 05:32:
While you are Mr. Perfect, absolutely nothing prevents inserting cards wrong way especially on the bench. If something would, this wouldn't haven't happened to OP.
I don't get it why some people need to start high hatting about honest mistakes. Totally unnecessary and it doesn't help OP one single bit if the card can still be revived.
Shit happens. For example I've installed MB AT power connectors wrong way although I very well know how they should be installed. That was goodbye for that nice 486 PCI board. And I've probably made dozens of similar stupid rookie mistakes with retro hardware, just with less painful consequences.
