Reply 40 of 59, by Nelson68k
- Newbie
PC@LIVE wrote on 2025-01-24, 23:36:Having the pin connection scheme, you can have the board made, and then you have to solder all the necessary components, maybe 🤔 who has a too damaged board, could make it work again with a new PCB.
For example, I kept an old 386DX from the late 80s, maybe 🤔 it could be repaired with a lot of (a lot of) work, but having a new PCB made, ultimately could be the easiest solution, because you don't have to go in search of traces interrupted by corrosion.
This board with the chipset can only handle 286 CPUs. But I have also created a 386SX board. This uses a 386SX CPU. A different chipset is required for DX. It also has more address lines.
