Reply 1121 of 1134, by red-ray
lolo799 wrote on 2025-08-13, 18:08:
I'll test the new version when I can, in a week or 10 days from now.
I have just released SIV V5.83 Beta-08 which further improves the Windows NT V4.00 SP2 + PowerPC support so please use that.
Reply 1122 of 1134, by lolo799
Sorry, it took a while.
The iBook hdd is having problems coldstarting.
The attachment SIV_IBOOKG3.png is no longer available
Reply 1123 of 1134, by red-ray
lolo799 wrote on 2025-09-06, 16:44:
Thank you and I guess this is down to the age of the system. I had to replace the disk in my Motorola PowerStack as there were a vast number of bad blocks, I hope the replacement keeps working.
Since your last run I changed SIV to read the TB (mftbu+mftb) but the returned values are not what I expected which is why the speed is reported as 133 MHz, what speeds are reported when the system posts?
For PowerPC 604 I need to scale the value by 8 and wonder if I need to scale it by 30 for PowerPC 750cx, but feel I need to see what happens with a few other CPUs to figure out what is needed. Looking at http://www.cap-lore.com/code/TB/ it specifies scaling by 16.
Reply 1124 of 1134, by lolo799
red-ray wrote on 2025-09-06, 17:59:
The G3 cpu in my iBook is a 500MHz model, with a bus speed of 66MHz.
There's no such thing as a Post screen with system info on a new world mac (there is the Open Firmware shell but it doesn't show up by default) and the NT loader screen only shows the ram available.
You can see what the NT4 setup process looks like using Wack0's fork of the dingusppc emulator, here for example:
https://virtuallyfun.com/2024/07/22/a-quick-v … macintosh-0-05/
Reply 1125 of 1134, by red-ray
lolo799 wrote on 2025-09-07, 09:10:
I have been looking into what is happening and it seems that the TB register is not derived from the CPU speed, but rather the FSB speed.
file.php?id=226380
After discovering this I have been pondering how to get the FSB to CPU speed ratio, on recent x32/x64 systems (PentiumPro and later) it's quite easy as it's in a MSR, but for PowerPC this is not the case.
I have just uploaded SIV32P V5.83 Beta-09 which should work, please will you try it and post new save files?
Below is what I got in testing, you should get similar, but with a x7.5 rather than a x2 multiplier. The code should also work when the FSB is 100 MHz, etc., but I don't have a system I can test this on.
file.php?id=226381
Reply 1126 of 1134, by lolo799
Here you go:
Reply 1127 of 1134, by red-ray
lolo799 wrote on 2025-09-08, 17:58:
Here you go:
Thank you, the ratio calculation worked as I hoped it would. I have just uploaded SIV32P V5.83 Beta-10 which includes a few more improvements, it really needs to be validated with a few more CPU types/speeds though.
file.php?id=226489
Above is using the Tahoma font, below is what happens when it's not installed.
file.php?id=226392
Reply 1128 of 1134, by lolo799
I tried with the Tahoma font, it's not working too well:
The attachment SIV_IBOOKG3-tahoma.png is no longer available
The attachment SIV_IBOOKG3-system.png is no longer available
Reply 1129 of 1134, by red-ray
lolo799 wrote on 2025-09-11, 19:57:
In what aspect? Looking in the save file at Menu->Machine->SIV Setup then Arial is reported, I need to see the bottom line of [About] to be sure what font is being displayed.
My system @ 8: English - Font: Tahoma (Proportional Western) Weight 400 Point Size 8 Cell Size 6×13 Line Height 14.5
My system @ 9: English - Font: Tahoma (Proportional Western) Weight 400 Point Size 9 Cell Size 7×14 Line Height 15.75
Old Save File: English - Font: Tahoma (Proportional Western) Weight 400 Point Size 8 Cell Size 8×16 Line Height 18 - Note: Tahoma was not installed
New Save File: English - Font: Arial (Proportional Western) Weight 400 Point Size 8 Cell Size 6×14 Line Height 15.75
With a point size of 8 the Arial cells are about the same size as Tahoma with a point size of 9. You could use Menu->Tools->Font to set Tahoma with a point size of 9
Original
file.php?id=226392
Tahoma 8 point
file.php?id=226554
Tahoma 9 point
file.php?id=226579
System - Arial I suspect
file.php?id=226555
Reply 1130 of 1134, by lolo799
I had made the save local report while using the Arial font.
Tried Tahoma with a 9 font size:
The attachment SIV_IBOOKG3-tahoma9.png is no longer available
Reply 1131 of 1134, by red-ray
red-ray wrote on 2025-09-12, 08:32:
In what aspect?
lolo799 wrote on 2025-09-12, 11:19:
Tried Tahoma with a 9 point font size:
Thank you, I am still unclear as to why you feel "it's not working too well".
Using 8 point Ariel I expect many of the SIV screens will to too wide to fit on your screen
Reply 1132 of 1134, by lolo799
red-ray wrote on 2025-09-12, 14:23:
The text is cut off in many places, for example on the left side, Chips without the number, below CPU-0 with a missing half, the FSB MHz missing the Hz.
Reply 1133 of 1134, by red-ray
lolo799 wrote on 2025-09-12, 15:01:
Thank you, I am unsure where the issue is as when the panel is rendered on this system there is no truncation.
The CPU-0 + GPU-0 cells are 7 characters wide so should not get truncated.
file.php?id=226579
file.php?id=226605
I felt I should try Windows XP @ 1024 x 786 and again there is no truncation.
file.php?id=226606
I suspect the truncation may be down to the graphics driver.
Reply 1134 of 1134, by red-ray
After pondering I adjusted the width of a few columns for pre Windows 2000 systems so the SIV V5.83 release should have less truncation, how does it do on your system please?
file.php?id=226676
