Exploring the performance of the Matrox G550
Reply 80 of 96, by dr.zeissler
G400 SD 128Bit / G450 DDR 64Bit / G550 DDR 64Bit. G4x/5x have working vSync in D3D but not in OpenGL.
G400/450 works in EMBM G550 does not work in Expandable, don't know if it works in others.
G550 has an additional Texture-Unit, but the performance is only slightly better.
Reply 81 of 96, by appiah4
It would be interesting to add the G450 to this comparison.
Reply 82 of 96, by The Serpent Rider
G550 PCIe is that slow even while running native? I was thinking about grabbing one for fun, but G200 level of performance is underwhelming.
Reply 83 of 96, by dr.zeissler
Running native? Ithought it has a bridgechip or am i wrong here?
Reply 84 of 96, by vvbee
It looks to be slow due to low vertex throughput, slightly higher fillrate than the G400. Passable for older games and may be the most compatible PCIe card you can find for these games. Probably also a strong GUI accelerator like the original G550, has snappy VM performance in any case.
Reply 85 of 96, by vvbee
The VFIO enabled fork of 86Box, https://github.com/richardg867/86Box, looks to not have worked with the G550 PCIe at all until about three months ago with commit 6c72fc2. It's a nice one with 1600 files changed so not possible to figure out which change fixed it. But looking at the code I can see there's some VFIO workarounds for certain ATI, Nvidia and Trident cards, so the gist may be that the Matrox needs a workaround as well for artifact free rendering. But implementing it would require specialist knowledge, or just luck.
Could be useful to have passthrough for the G550 in 86Box. It works with QEMU/KVM but any speed sensitive game is going to give trouble with the overly fast CPU.
Reply 86 of 96, by vvbee
Tested to see if the G550 PCIe can work in a Windows 3 VM. Someone said the G450 OS/2 driver works with the G550, but that's not the case, so can't use Windows 3 through Win-OS/2. I combined the Windows 3 driver from the G450 OS/2 driver set with the G400 driver set for native Windows 3, but again it's not compatible with the G550. Maybe for the G450 it would work, but that's not a PCIe card.
Reply 87 of 96, by vvbee
PCIe vs. AGP version of the G550 in vertex throughput. Showing FPS ratio of the PCIe to the AGP on Y, triangle count on X. Rendering a static textured mesh using Direct3D 7 in Windows 98.
The attachment 39c87b4bec5b.png is no longer available
So the PCIe version starts off at 80% of the speed of the AGP version, makes sense since it's clocked at 80%. But with anything more than 500 triangles it takes a massive extra hit. I can't imagine the PCI bus being this gimped vs. AGP so it's more likely the bridge chip, the TI XIO2000. But then I don't know.
In this particular test the PCIe version tops out at about 300000 triangles per second, the AGP version does just over a million.
So the PCIe version should do relatively well in low poly games, and suffer more in games with poor visibility culling. But from what I've seen the polycount probably isn't the only factor.
Reply 88 of 96, by dr.zeissler
Could be that I made a mistake on that win3 compatibility, I have to recheck it.
G400 offers native Win3x drivers. G450 does not work with these, but G450 OS2 drivers work with winos2, So you can get high-true-color and hires support on win3(within OS2 of course) with g450. The G550 works with the g450 driver in OS2, but if it really supports Winos2 as well...I am not sure about it anymore. It has to be retested. I removed my G550 card, because it get's too hot in my E600. In the E600 advertisement from FSC there is only the G450 DVI listed as suitable option, not the G550. Also the G450 offers EMBM (expendable), the G550 refuses this. There must be more differences than just an additional TMU on that G550. compared to the G450.
Reply 89 of 96, by vvbee
Warp 4 wasn't compatible with the G550, not with the PCIe version passed through to a VM.
Approximating from the earlier data the PCIe version could hang within about 20% of the AGP version up to about 200000 triangles per second, presumably the bridge chip or whatever starts saturating beyond that. At that rate 3000 triangles per frame gets you about 60 FPS, so games like Thief 1 or Quake 2 might run comfortably and see these two cards perform relatively close. That's ignoring various other factors, but a first guess.
Reply 90 of 96, by The Serpent Rider
So in other words G550 PCIe is just a gimped even further PCI G550. I wonder if AGP G550 without GART driver (i.e. PCI 66 mode) behaves in similar manner or it's unique interaction with PCI-PCIe bridge.
Reply 91 of 96, by vvbee
You brought the pessimism but not the data. The PCI version uses a bridge chip also but an older design, so I'll give the PCIe version the benefit of the doubt. It's the more useful version of the two in any case.
Reply 92 of 96, by vvbee
I was intending to test earlier drivers with the passthrough PCIe G550 in Windows 98 but looks like they didn't support it. 6.50 boots into a blank screen and 6.71 (first official driver for the G550) doesn't have 3D acceleration at least by default. There are potential performance benefits for certain games in older drivers for the AGP card, but at least the newest drivers works.
Reply 93 of 96, by vvbee
GLQuake:
The attachment ec825de9932d.png is no longer available
Data for the G450 and Voodoo3 from vgamuseum.info.
The G550 PCIe takes the smallest hit from doubling the resolution, so it's the least fill rate limited. At 1024 x 768 it's on par with the G400, Voodoo3 etc. Keeping in mind it's running in a VM so let's say 10% slower than direct native, and has about 20% lower clocks compared to the G550 AGP.
A few other games:
The attachment 0e6b00dcee7b.png is no longer available
The PCIe's FPS is as my napkin calculations predicted but even in these lower poly games the AGP version is far ahead. Again the PCIe version isn't primarily limited by fill rate. If it's the bridge chip then patterns of data access could play into it and not just the amount of data.
Reply 94 of 96, by appiah4
vvbee wrote on 2025-09-03, 23:45:
GLQuake: […]
GLQuake:
A few other games:
My experience with G450 is that it has quite good GLQuake performance but it has driver bugs that absolutely destroy its performance in Quake2 unless you disable dynamic lighting.
Reply 95 of 96, by vvbee
Phil's recent video had some benchmark numbers for GLQuake with the G550 PCIe in Windows 98. Essentially identical numbers to what I got with passthrough in a VM, so we can assume performance in a VM is essentially identical to native in this case.
Reply 96 of 96, by DEAT
dr.zeissler wrote on 2025-09-02, 06:21:
Sort of false - if you don't install any monitor timings during the driver installation, you can get 1152x864 resolution to work fine with a G450 on a LCD/OSSC capture. You could probably get the other resolutions working if you can figure out the monitor timings that the G450 wants to behave properly.
win16.page | Twitch
