First post, by vvbee
MB: ASUS B85M-G in a Chieftec CI-02B-OP
RAM: 12 GB DDR3
CPU: Intel Xeon E3-1230 v3 with a passive Thermalright Macho Rev.B
OS1: Linux 64-bit
OS2: Windows 7 64-bit
OS3: Windows XP
OS4: Windows 98 (VM in OS1)
GPU1: AMD Radeon HD 7750 (OS1, OS2, OS3)
GPU2: Matrox G550 PCIe (OS4)
HD1: 250 GB SSD (OS1, OS4)
HD2: 500 GB SSD (OS2, OS3)
The hardware will cost about 100 e (without case and cooler), depending on where you are and what deals and bundles you happen across.
Based on testing many of these parts in other configurations, total system power draw in XP era gaming should be in the 40 W range.
The Radeon HD 7750 was selected after testing about 20 PCIe cards of that era, including the GeForce 700 and 900 series. It has broad Direct3D support all the way to early versions using the AMD iCafe driver in XP. Hassle-free SSAA that looks good and is compatible with just about every old game. A less efficient alternative for better performance in DX10-11 would be the GeForce GTX 560 while still maintaining reasonable backwards compatibility. Obviously details need to be reduced in more demanding later games, but the support is there if needed.
The Matrox G550 PCIe is known as the most backwards-compatible Windows 98 PCIe card. Used here as a passthrough GPU to a Windows 98 guest in QEMU to avoid OS incompatibilities with other hardware. Its role is to run any older game the HD 7750 or later Windows might have issues with, and generally to provide a performance experience similar to a graphics card from ~1998.
The CPU can easily run passive with a large heatsink as the case is an effective wind tunnel. Temperatures in non-heavy gaming should be in the 45 C range with the case fans running at quiet speed. For better XP support in theory you might go with an Ivy Bridge instead of a Haswell.
Linux is here to provide a modern OS with Steam and good passthrough virtualization.
I'm fine with onboard sound but the motherboard has room for a PCIe x1 sound card if you use a single-slot main GPU, or just go with a non-micro motherboard.
The system will be tested further in this thread as time goes on:
1. Efficiency
2. Compatibility
3. Thermals
4. Performance
5. Highlights
6. Vs. a period build, K6-2+/450 with a Voodoo Banshee
Reply 1 of 10, by vvbee
First, total system power draw, efficiency.
Idling on the desktop, XP, 7 and Linux all draw about 40 W. The reading for Windows 98 in its virtual machine I looked at but didn't write down, so we can say 50 W.
Thief 2 (original) pulled just over 40 W in Windows 7 and about 70 W in Windows XP, vsynced at 60. Quake 3 Arena did 55 W in 7 and 65 W in XP. GLQuake in Windows 98 (G550) showed 65 W.
With relatively newer games, Assetto Corsa ate about 100 W in Windows 7 and Spintires in Linux through Proton with amdgpu about 90 W. This is with hyperthreading disabled.
Overall, we can predict the system will do 1995~2015 gaming with a 40-100 W total draw. Probably won't exceed 150 W. For best efficiency you'd favor Windows 7 over XP for older games, maybe install the 32-bit version as well.
Reply 2 of 10, by DarthSun
Great compilation! Win98 can be installed natively on it, it is not necessary to put it in an emulator.
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 3 of 10, by vvbee
I don't know that there's much to be gained from running it natively. CPU and GPU performance should be relatively close to native with KVM and passthrough, plus among other things you get legacy sound emulation and in theory the ability to emulate a slower CPU for the few speed sensitive Windows 9x games. The only downside to emulation I can see is if the G550 loses any performance vs. native, since it's not a fast card to begin with. With passthrough in 98 it's close to native in XP, but I don't know what its performance would be in 98 natively.
There's also an experimental VFIO fork of 86Box that lets you pass through PCIe and PCI devices. It only partially supports the G550 at the moment, but maybe in the future this would be an extra way to go for compatibility. Might also allow for emulation of faster CPUs on this hardware since it doesn't have to emulate the video then.
Reply 4 of 10, by DarthSun
vvbee wrote on 2025-09-06, 15:23:
It also depends on how you look at it, or what your goal is.
For example, the following is impossible to do in an emulator:
The attachment Win98_69164.jpg is no longer available
Reply 5 of 10, by vvbee
I don't immediately see it being impossible, run KVM on the Ryzen and pass through a 7900 GTX. But I found the Nvidia G71 to not have the greatest backwards compatibility in DX. The G550 smokes it, runs much slower but is more period correct if you will.
Reply 6 of 10, by vvbee
Second, compatibility.
I briefly tested 50 Windows games from 1995-2015 (median 1999). All were playable except F1 Racing Simulation, which is sensitive to CPU speed.
Four games needed to be run in software mode to work well: Delta Force 2, Warhammer: Dark Omen, Castrol Honda Superbike World Champions, and Agile Warrior F-111X. Depth glitches in Delta Force 2 in Direct3D mode are common on many systems, in this case the G550 rendered it correctly but only at 15 FPS. Agile Warrior F-111X would freeze after one frame of gameplay on the G550, but I didn't immediately see any glitches.
To support 256-color video modes on the G550 bus mastering has to be disabled. This is relevant to run Windows 98 games in true 256-color software mode. Otherwise bus mastering has to be on for 3D support.
With 98% of the 50 games being playable we can say the system supports DirectX 1-11 and generally will run anything in this range. Games that are speed sensitive will give issues, and the handful of retained mode D3D games may all need to be run in software mode, which the CPU is easily fast enough for.
The HD 7750 also supports Vulkan, useful for DX8+ in Wine and Proton.
Reply 7 of 10, by vvbee
Third, thermals.
The case has one 140 mm fan at the front and one 120 mm at the back, connected with a Y splitter to the motherboard's CPU fan header. From the BIOS I've set fan management of this header to silent, or whatever the lowest option was. The case has negative pressure as I prefer, I've covered the top vent so most of the passive intake is through the side panel for the benefit of the two GPUs behind it. The CPU cooler has no fan so the third and last fan in the system is the HD 7750's. I have a custom curve for it in Afterburner, 10% below 50 C and 30-40% at 60 C, something like that.
Idling on the desktop with an ambient of 24 C the GPU is at 40 C and the CPU at 34 C, fans barely audible. Ten minutes of Prime95 (hyperthreading off) has the CPU at 60 C and the VRM at 70 C, fans audible but not loud. Exiting Prime95 brings the CPU to 40 C within a second or two and to 34 C at some point in the next minute or two, the fans immediately go quiet.
Ten minutes of Quake 3 with 8xSSAA has the GPU at 51 C, fans barely audible. Ten minutes of Project CARS at medium settings has the GPU at 64 C, the CPU at 50 C and the VRM at 64 C.
Since it's a high-efficiency low-power system you expect it to have good thermals and low noise levels, and it does.
Reply 8 of 10, by vvbee
Fourth, performance in 14 Windows games from 1995-2015.
1995, Destruction Derby. Win98. Using the ViRGE version with my S3d-to-software wrapper. Runs without issues at the game's 23 FPS cap using the better-quality rasterizer.
1996, Monster Truck Madness. Win98. Max settings. Average 100 FPS in chase view, 35 FPS in cockpit. No visual glitches.
1997, Redline Racer. Win98. Max settings. Average 100 FPS. No visual glitches.
1998, Thief. WinXP. Max settings, 1024 x 768, 8xSSAA. Average 230 FPS. No visual glitches.
1999, Quake 3. WinXP. Max settings, 1600 x 1200, 8xSSAA. Average 130 FPS. No visual glitches.
2000, Need for Speed 5. WinXP. Max settings, 1024 x 768, 8xSSAA. Average 65 FPS. Some Z fighting in the background.
2001, Operation Flashpoint. WinXP. Max settings, 1024 x 768, 8xSSAA. Average 80 FPS. No visual glitches apart from a pixel-thin line at the left edge of the screen.
2002, Gothic 2. WinXP. Max settings, 1024 x 768, 8xSSAA. Average 90 FPS. No visual glitches. Using my DDRAW.DLL passthrough wrapper to pre-allocate 200 MB of VRAM to fix a Radeon driver bug in WinXP that results in the game running at 20 FPS. This was fixed in Windows 7.
2003, Star Wars: Knights of the Old Republic. WinXP. Max settings, 1024 x 768, 8-sample AA. Average 70 FPS. No visual glitches. Had to set "Disable Vertex Buffer Objects=0" in the INI or camera movement would stutter. This is a GOG release, originals may not have that setting in the first place.
2004, Far Cry. WinXP. Max settings, 1920 x 1080. Average 140 FPS. No visual glitches.
2008, Race Driver: GRID. WinXP. Max settings, medium shadows, level 1 AA, 1920 x 1080. Average 60 FPS. No visual glitches besides a small texture hiccup on the steering wheel in cockpit view.
2010, Just Cause 2. Win7. High settings without SSAO, 1920 x 1080. Average 65 FPS. No visual glitches.
2014, Assetto Corsa. Win7. High/medium settings without post-processing, 1920 x 1080, 2xAA. Average 75 FPS in bumper view, 48 FPS in cockpit. No visual glitches.
2015, DiRT Rally. Win7. High/medium settings, 1920 x 1080. Average 65 FPS in bumper view, 55 FPS in cockpit. No visual glitches.
When it's said there were no visual glitches it means I saw none during brief gameplay.
Overall the system supports two decades of gaming with acceptable FPS and clean rendering. The XP era runs comfortably, the 9x era is supported well enough, and the Windows 7 era is accessible.
Reply 9 of 10, by vvbee
Fifth, some highlights in practice.
High compatibility in Windows 98 under Direct3D. Clean HUD in Colin McRae Rally. Proper depth sorting in Delta Force 2. Fog and 16-bit dithering in Thief 2. Texture transparency in Rainbow Six.
The attachment 1fa1b1e30348.jpg is no longer available
Broad compatibility in Windows XP. F1 2000 for example is a problem on many systems, but here we can skip the third-party workarounds and wiki browsing.
The attachment 5b59219008f0.jpg is no longer available
Playability from Windows 98 to Windows 7. DiRT Rally from 2015 is enjoyable at 1080p.
The attachment 68a9f02a24d2.jpg is no longer available
The CPU is comfortable with retro rendering in both Windows 98 and NT environments.
The attachment f32434bbf356.gif is no longer available
Reply 10 of 10, by vvbee
Sixth, vs. a period build, K6-2+/450 with a Voodoo Banshee.
FPS recorded in Windows 98 at a certain point in gameplay, timedemo average for GLQuake:
                    Period	This
GLQuake 76 112
Thief 35 98
Thief 2 40 87
Homeworld 39 80
TOCA 2 35 29
F-22 Lightning 3 36 24
For 2-3 times the cost the period build offers only half the performance. The tests were run in 640 x 480, the G550 has the edge in fill rate so even in the two games where it was slower it would likely catch up at higher resolutions. The HD 7750 in Windows XP will of course run any compatible game from this era at about 1000 FPS.
Beyond nostalgia period builds like that have no clear benefit over this one for Windows 98 gaming. In theory older builds are more compatible with games of their era but in this case this build is already competitive in that space. At the same time Windows 98 in this build has a relative period-correct level of performance vs. running the games on much faster hardware.
