First post, by AlessandroB
Currently, as a modern computer with Windows 10, I use an Asrock N68-S with an Athlon II X2 250 to connect everything: IDE drives, floppy disks, SCSI drives, Zip on parallel, etc. It has DOS6, Windows XP and Windows 10 installed but is not compatible with Win 11. It has all the ports I need to communicate with all my retrocomputers. Is there something faster and that perhaps accepts Win 11 without patches that I then have to keep up with to correct, update, etc.?
Reply 1 of 32, by jakethompson1
As you suspect, floppy is the limitation, because you can't add a "native" ISA bus floppy controller via a PCIe card.
There are a few later ASRocks like N68-GS4 USB3 FX, and 980DE3-U3S3. You have to be careful with revision number to ensure it has floppy. Neither of these have UEFI so Windows 11 without hacks is impossible even without the CPU/TPM limitations.
I'm not personally sure how far you can go on the Intel side, but suspect it's Sandy/Ivy Bridge, and perhaps you would be more likely to have UEFI there.
Even if you got it working somehow, something in the works is x86_64 v1, v2, v3, and v4. v2 goes back pretty far, but I suspect when Windows (and bleeding edge Linux distros like Fedora) bump to v3, it's going to be like the SSE2 situation with later Windows XP updates.
Reply 2 of 32, by Shponglefan
Some quick searching on Retroweb lists a number of LGA1156 motherboards with both IDE and FDD connectors.
They also list four LGA1155 motherboards that have an IDE connector, but don't have FDD connectors.
Pentium 4 Multi-OS Build
486 DX-33 with 5 sound cards
Reply 3 of 32, by dionb
Shponglefan wrote on 2025-09-10, 18:04:
They won't have TPM 2.0 though, so are just as unlikely to run Windows 11 as OP's current system.
I'd say you have three choices here:
- stick with current hardware, purchase W10 extended support
- stick with current hardware, run Linux on it instead (no TPM 2.0 requirement for current versions)
- upgrade to newer hardware, use USB floppy & IDE adapters instead of native.
Reply 4 of 32, by Shponglefan
dionb wrote on 2025-09-10, 18:27:
Oh of course. I was more curious about when things like FDD and IDE controllers were getting dropped from motherboards.
Even looking at industrial board options, it seems those features were getting dropped around the same time.
Reply 5 of 32, by AlessandroB
Ok then let's focus on two alternatives:
1) a system that has floppy disk and IDE and is compatible with win11 (if it exists)
2) a system that has floppy disk and IDE and is compatible with Windows 10 (nit win11) but is much faster than my current one
Reply 6 of 32, by dionb
AlessandroB wrote on 2025-09-10, 20:18:
Again, use USB floppy and IDE adapter and this works fine. My Ryzen runs Win11 and works fine with an IBM USB floppy and some old generic USB IDE thing.
Take a look at Shponglefan's suggestions. They're still well over a decade old at this point, but will be noticeably faster than an Athlon X2 (or even a Phenom X4 on the same board). Still, it doesn't solve the main issue...
What's wrong with the Linux suggestion? Linux is great with I/O and it's not as if this sounds like your MS Office, Adobe or main game PC.
Reply 7 of 32, by jakethompson1
I understand wanting to keep USB out of the equation. There are PCIe cards with IDE interfaces on them, so set that aside.
My experience has long been that USB floppy drives work when the disk is 100% perfect, and quickly go awry when it is not. However, perhaps Greaseweazle is a better long term solution than trying to stick to motherboards with onboard floppy (I have the 980DE3-U3S3 though). There are also USB adapters to let you hook an internal floppy drive up to USB, if you don't want to use an external drive.
Reply 8 of 32, by Shponglefan
I think the question that needs to be answered is what is the real goal here.
Is it to just push the limits of having older storage interfaces (IDE, FDD) on more modern hardware? Or is the goal to be able to manage legacy storage devices from a modern PC?
If the goal is the latter then I would just look to adapters like the Greaseweazle for floppy disks and USB-to-IDE for hard drives.
Reply 9 of 32, by Nexxen
jakethompson1 wrote on 2025-09-10, 20:58:
If I'm not mistaken 7 to 900 series do not support FDD via SB, but have an external chip to do that (added by manufacturer).
And support only 1 FDD IIRC, not a dual 3.5 + 5.25 (which is handy for floppy imaging).
I've been there and fastest cpu/ram + native FDD/IDE/COM/LPT + SCSI card, isn't easy to achieve.
Of the 3 usb fdd units I have, only internal could read difficult disks.
I don't use them that much, but are 1st test to avoid using another machine. I'm lazy when possible 😀
I use https://www.gigabyte.com/Motherboard/GA-MA785 … -UD3H-rev-10#ov and it works well but needs connectors as everything has headers (lpt, com)
My 2 cents.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 10 of 32, by AncapDude
I use an AM3+ Board for broadband testing which has floppy Port. But be aware that most modern BIOSes only support one floppy. For a Build with two Floppies you will propably Stuck at So939 or 775 for consumer boards.
Reply 11 of 32, by jakethompson1
AncapDude wrote on 2025-09-10, 23:25:
If it were just the BIOS, you could get around it through Linux; I believe the later Super I/Os multiplexed the pins needed for a second floppy drive
Reply 12 of 32, by Major Jackyl
I just installed W10 to a temporary drive on my M3A78-M (for testing) and have noticed something absolutely as ugly as it sounds (literally). The floppy drive aggressively checks/reads whenever a USB device is installed/removed. It made a whole ruckus during the install, too. After I connected internet, it sits there, slapping the drive around every couple of minutes now. Must phone home my floppy drive. Reformatting this when I'm done, 🤣 W10 is very slow on this compared to XP
The attachment Floppy.png is no longer available
The attachment NoW11.png is no longer available
Daily Units:
ASUS P55TVP4, P-MMX233, Matrox2064W, CT2770
ABIT IS7, P43.2(SL7E6), PNY6600GTS, Audigy(0090)
ASUS M2N-SLI, A64X2-5600+, EVGA 8600GTx2, Audigy2(0240)
ASUS ST-990FX, FX-8350, MSI GTX760x2, SB X-Fi(0460)
MSI Z690, i9-12900K, MSI RTX3090, SB AE-7
Reply 13 of 32, by CharlieFoxtrot
Shponglefan wrote on 2025-09-10, 21:27:
I agree. Also, if you only need 1.44MB/720kB floppy, you can go and purchase USB floppy drive that supports both formats. They are still easy to find. And if you only need 1.44MB, you can still get new ones.
To me this seems quite a hassle for a problem that is relatively easily solved. With greaseweazle you can connect 5.25 drives and it can also read/write formats for other systems.
Reply 14 of 32, by zyga64
I have ACER B75H2-AM motherboard (s.1155) with i5 3470s which has working floppy connector. But I don't think it natively supports Windows 11.
Anyway it's 3rd generation Core motherboard...
8088@8 /640k /Genoa CGA /TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 15 of 32, by dionb
CharlieFoxtrot wrote on 2025-09-11, 05:19:
And if you needed anything else, it wouldn't have been supported on last-gen floppy systems like that AM3 board anyway. They only did 1.44MB 3.5" drives.
That's the serious option of course. Question is whether OP needs anything over and above the basic 1.44MB PC format.
Reply 16 of 32, by AlessandroB
My requests to have everything native were because from times to restore, read, write images, use some diagnostic software having everything integrated natively I noticed that it worked better, especially the floppies. I had USB floppies but in addition to reading less than the old ones, as soon as they find a disk that dirty the heads they are to be thrown away and are unopenable, while in the old drives you can clean the heads and in any case I have a box full of spare parts.
Reply 18 of 32, by AlessandroB
OK, I'll consider these two solutions, even though I had some problems with a PCIe-IDE card I bought on Amazon. Which one would you recommend? Are there any better performing chips?
Reply 19 of 32, by Dhigan
Major Jackyl wrote on 2025-09-11, 02:46:
As seen here, just disable/enable the floppy drive on demand in Device Manager. And, to make it easier, create a small .bat file that does the job, then just run it from a shortcut on the desktop.
:TurnOff
PNPUTIL /disable-device "USBSTOR\SFLOPPY&VEN_TEAC&PROD_USB_UF000X&REV_0.00\aaaaaaaaaaaa"
POWERSHELL (New-Object -ComObject Wscript.Shell).Popup("""Floppy Disk Drive turned OFF""",4,"""Floppy Disk Drive""",0x10)
goto :Bye
:TurnOn
PNPUTIL /enable-device "USBSTOR\SFLOPPY&VEN_TEAC&PROD_USB_UF000X&REV_0.00\aaaaaaaaaaaa"
POWERSHELL (New-Object -ComObject Wscript.Shell).Popup("""Floppy Disk Drive turned ON""",4,"""Floppy Disk Drive""",0x30)
:Bye
if "%2"=="on" DEVMGMT.MSC
exit
Win 3.1 : HP Omnibook 425 + Toshiba T2130CT
Win 9x : Dell Latitude Cpx H500GT + Dell GX1
Win XP64 : Asus P5B Xeon
