Reply 1060 of 1075, by mbandalauk
snipe3687 wrote on 2025-07-16, 15:11:vanfanel wrote on 2025-07-15, 07:25:Thanks! There are some other issues with the BOM: some of the parts seem to be "out of stock" or have wrong identifiers. I'm att […]
snipe3687 wrote on 2025-07-14, 20:53:thanks for hanging in there. also sorry to Rasteri for hijacking this thread a little bit.
that being said, I made the adjustments and uploaded to github. try it again. you shouldn't have any issues now 😀Thanks! There are some other issues with the BOM: some of the parts seem to be "out of stock" or have wrong identifiers.
I'm attaching a modified BOM XML so you can see for yourself, in case you can also adjust that.
I specially fear for the CS4237B availability (that was why I was trying to order it time ago), and I believe the SOM304RD-VI should be removed from the BOM since it should be provided by us the final users.The CS4237b is going to be old stock but you can still buy them from places like UTsource. sorry I usually dont have them built so im sure there's some errors. will get back to you!
Thanks for the great work, snipe3687! I’ve been closely following your progress and am really looking forward to seeing your Weecee version with the RPi module underneath. No pressure at all—take your time!
