Broadcom GigE NIC - DOS drivers & poor speeds
Reply 40 of 64, by DaveDDS
The MAC address should be pre-programmed (permanent) - every NIC should have a unique one, it's the lowest level of
ID on a network.. FF:FF:FF:FF:FF:FF is definitely NOT the right MAC address, this is the broadcast mac address, which all
NICs should receive, but no NIC will actually have that as an address.
If you want to know your actual MAC address, assuming you can make it send some network traffic, any packet "sniffer" (like
my DOS "sniff") should be able to see it - unless you are using an old-style hub, you will need to to send a broadcast so that
everything on a switch would see it. (not usually a problem - after reboot, and during most connection attemps at least
one broadcast will be sent).
https://dunfield.themindfactory.com ; "Daves Old Computers" ; SW dev addict best known:
ImageDisk: rd/wr ANY floppy PChw can ; Micro-C: compiler for DOS+ManySmallCPU ; DDLINK: simple/small filetransfer(w/o netSW)via Lan/Lpt/Com
Reply 41 of 64, by Grzyb
I'm curious how that "FF:FF:FF:FF:FF:FF" card is seen from the outside - run "arp" on the other computer, and see what's the MAC for the problematic laptop's IP.
In 2003, I voted in favour of joining the European Union. However, due to later developments - especially the restrictions on cash usage - I have withdrawn my support. DOWN WITH THE EU!
Reply 42 of 64, by megatron-uk
The NVRAM and the VPD memory on this NIC are definitely faulty. The B57UDIAG utility fails every write test to those areas, though tests on the normal (RAM), BCM registers, MII interface and similar all seemingly pass without issue.
Since I'd guess that the MAC address is loaded into NVRAM (based on the commands that the B57DIAG tool has available to programme it) my guess is that is why it is showing/set as FF:FF:FF:FF:FF:FF - though the Thinkpad BIOS screen also claims it to be 00:00:00:00:00:00 ... I think both are just symptoms of the fact that it cannot actually be read, and whatever is there is gibberish.
Though.... as Grzyb suggest, running arp on the Linux machine I connect to the laptop with using Filezilla does indeed show:
Address HWtype HWaddress Flags Mask Iface
192.168.1.232 ether ff:ff:ff:ff:ff:ff C enp3s0
It's dead, Jim.
https://www.target-earth.net
Reply 43 of 64, by megatron-uk
DaveDDS wrote on 2025-09-12, 18:09:
Although set with one by default, the diagnostic tool for the Broadcom chips absolutely can set the MAC address to anything you want - it's definitely not permanent since it's in writeable (eep)ROM and/or RAM areas in the NIC (which the diagnostic tools can write to)... though you have to write a relatively comprehensive 'EEPROM' definition file first. Something I've not looked at yet.... and quite honestly since the diag tests seem to fail when writing to those areas... I think that's why it has the symptoms it does.
Reply 44 of 64, by Grzyb
So, the packets sent to that NIC are indeed broadcast packets.
It's likely that the switch limits broadcast traffic - effectively limiting that laptop's download rate, but not upload.
If it's a managed switch, it may be worth looking if there are some options related to broadcast limiting...
Reply 45 of 64, by weedeewee
megatron-uk wrote on 2025-09-12, 20:24:
Can you post a screenshot of this diag test showing the failing to write ?
anyway, fist time I ran into an issue like this, I just filled the eeprom with consecutive hex numbers, then booted the device, figured out which numbers were the mac and wrote the mac address that was on the physical label in the eeprom. Mostly ignoring the other data that could be of consequence, ie I just filled the rest with zeroes. This was on a mainboard with two integrated nics and both had lost their eeprom contents. The eeprom was just a 1 kilobyte, maybe 4, chip and actually lived on the shared i²c/smbus on the mainboard, which is likely the reason it somehow got zeroed out, and was also helpful in getting some data back in it without desoldering using linux.
VPD... does that stand for vital product data? the mac address seems pretty vital for a network interface, although setting it with software should be available & viable.
Also... is this on just one laptop or is it on all of them ? ( Dell Latitude X1, Toshiba Portege R200, IBM Thinkpad T43 )
Do not ask Why !
Reply 46 of 64, by weedeewee
Grzyb wrote on 2025-09-12, 20:34:
No.
Fixing the faulty mac address is the way to go.
Do not ask Why !
Reply 47 of 64, by Grzyb
Also, I've just tried to add the following line:
NodeAddress="000102030405"
...to the [B57] section of PROTOCOL.INI
And it works as expected - the other side shows "00:01:02:03:04:05" in the ARP table...
Edit:
But can't get it to work for ODI - adding the following to NET.CFG :
Node Address 021122334455
The "locally administered" bit is set.
Without that bit, the ODI driver complains when loading.
With that bit, it loads normally, but doesn't change the MAC.
Oh well, I guess it's not implemented in this driver - use NDIS instead!
Reply 48 of 64, by DaveDDS
Kinda suprising ... the MAC is supposed to be unique .. vendors are assigned range which they must set their card to in
production.
If you provide a tool to allow an end-user to set the MAC to an arbitrary value, you violate this.
The reason they must be unique is that two NICs with the same MAC address can't talk to each other,
and cause confusion in local network/switch addressing. Originally this was envisuned as being the
"network address", but as networking methods progressed, routable protocols were developed which
separate the endpoint MAC address from the network address. This (among other things) allows network
addresses to be reassigned to different systems (which have different MACs)
In practice, given how many NICs there are in the world, the chances of two changed to the same address
being on the same local network are very minimal... In fact there is an OUI prefix reserved for "locally
unique only" MACs which are set within an organization.
Reply 49 of 64, by DaveDDS
Btw, I often see FF:FF:FF:FF:FF:FF reported as the MAC address for a non-working/mis addressed card.
There are a few packet drivers which don't detect that a card is not responding correctly, and these often
report FF:FF:FF:FF:FF:FF (more often than 00:00:00:00:00:00) when the NIC just "isn't there".
Reply 50 of 64, by DaveDDS
... It's likely that the switch limits broadcast traffic - effectively limiting that laptop's download rate, but not upload.
Almost all networking will stop working if you prevent broadcast on those nodes.
And "flooding" broadcast will bog-down and confuse networks.
There are reasons we use broadcast, and also why we limit broadcast traffic.
The only case where I can envision that this "might" work is on a dedicated hub with no other nodes.
and even then most network software would get confused by excessive unexpected broadcasts and data
packets addressed as broadcast ...
I don't think even DDLINK would work, it only uses one broadcast by the client to find the server,
then uses directed MACs only ... but it's been >10 years since I wrote it, and don't recall if it checks to
see/ignore broadcast packets during that transfer (probably does as broadcasts could still come from
the other end if running under a multi-thread OS)
Easy to test -- DosBox can simulate an NE2000 NIC, and you can set what its MAC address is...
Reply 51 of 64, by Jo22
Hi, please everyone note that some emulators don't do ethernet protocol emulation but rather use pass-through to host. I vaguely remember reading about this.
So it won't work with WiFi connection, for example. The physical LAN connection must be same ethernet.
Reply 52 of 64, by jmarsh
DOSBox does not have NE2000 emulation, that would be a fork of some sort.
Reply 53 of 64, by megatron-uk
Grzyb wrote on 2025-09-12, 20:57:
Also, I've just tried to add the following line: […]
Edit:
🤣 ... it only damn works...
$ arp
192.168.1.232 ether 00:0d:b6:00:00:01 C enp3s0
Speeds are now largely symmetrical - around ~13-14 Megabytes/sec both up and down when using Filezilla on my Linux desktop to the MTCP ftpsrv server.
Using the MTCP ftp client against vsftpd it is showing ~7-8 Megabytes/sec.
This is using B57.DOS v11.0.8 - I've not tried any others. And, of course, this doesn't fix the underlying issue of the NIC NVRAM/EEPROM being totally busted - since the Linux driver relies on those things (I guess the Win9x/NT/XP drivers probably do too). But, it is a pretty cool workaround for DOS!
Reply 54 of 64, by megatron-uk
Using a large ISO (~560MB) I now see that the transfer rates using Filezilla against ftpsrv are more or less identical using the different versions of B57.DOS:
B57.DOS v11.0.8
B57.DOS v15.0.1
B57.DOS v16.0.2
All versions of the driver get within +/- a few hundred kilobytes of each other, and those figures are ~14.8 megabytes download and ~12.5 megabytes upload, so the NIC is definitely working at above Fast Ethernet speeds (though depending on your metrics - just barely 🤣).
Reply 55 of 64, by Grzyb
Nice.
And good luck fixing the root cause!
Such problems are pretty common - after 20 years, it's perfectly normal for Non-Volatile RAM to become very volatile...
Reply 56 of 64, by megatron-uk
You could say it is now fitted with VNVRAM...
Reply 57 of 64, by Grzyb
Hehe...
I have a very similar problem...
Once upon a time, I bought a new-in-box D-Link NIC for ISA - probably based on RTL8019.
At first, it worked fine - but then the transfer suddenly hanged.
After reset, the diagnostics utility detected some problem with EEPROM - and even fixed it, but obviously not fully...
The MAC address looks weird now - but at least it's still unicast.
And after loading the driver, there's some delay before it actually links - first DHCP attempts always fail - as if there was some problem with RJ45/BNC autoselect.
But later on, it seems to work normally.
Note to self to fix it sometime...
Reply 58 of 64, by megatron-uk
I've had a 3c509 with something similar to that RTL8019; it wouldn't bring up a link with whatever settings were programmed into it when I bought it - but fortunately the 3Com config utility was able to rewrite the settings in the eeprom back to defaults and it worked again.
With the Broadcom NIC, it just looks like the NVRAM part has failed due to age, or possibly some firmware update in the past has bricked it. The laptop was a recent purchase and sold as "unknown condition"... required a replacement screen due to a failing CCFL and a new fan due to seized bearings. I guess the NIC is another thing to add to the list. But with the various workarounds (the NDIS MAC spoof or the reboot to Linux with the Cardbus slots) it's no dealbreaker.
Reply 59 of 64, by DaveDDS
jmarsh wrote on 2025-09-13, 01:50:
Yes, I tend to forget ... DosBox does have NE2000 emulation implemented in it's code, it just turned off.
I mostly use an ancient version of DosBox originally called "MegaBuild 6" - it's basically a recompile of SVN with
various options normally OFF turned ON. Does everything I want, newer forks don't seem to improve compatibility
(and have less "normal" looking 80x25 text mode screens), and haven't fixed a command line bug I fixed in my
edition which caused me be to loose entire files fairly frequently... 1 Line patch to fix autocomplete bug
Btw, DosBox gets very confused if it sees it's own MAC address on the network, giving:
"FATAL: Memory Block Error" Re: DOSBox NE2000 on Windows 10 with win10pcap
