ATi RagePro drivers and software
First post, by marxveix
What a great old videocards if used with better drivers and software. I have some collection of drivers and software for Rage3 based cards. I mostly use them with Win9x and have 3DCIF/Direct3D/OpenGL/DVD acceleration all together. I personally like Rage XL 8MB AGP cards the most and that has similar compability like older RagePro brother from year 1997. Rage XL has some minor improvements over Rage Pro + lower power consumption. Latest driver that i am working on is based on Ati2ddad.drv and it works already with 5.38.x base + modded 3d files from 5.40.x releases. What ATi software you may use that i know nothing about? I use ATi inspector from 2003 at my Rage3 or do you know that ATi TV out works also in pure DOS. Maybe someone could tell me what ATi software is latest for RagePro cards, like MMC6.30 and ATi Video Player 5.35, i am sure i have missed some more great drivers and software for Rage3, they can be for Rage2 also, Rage3 is Rage2 compatible for the most part i think. RagePro and RageXL are latest 3DCIF cards. What about Argonaut BRender and Criterion RenderWare API for Rage3 or it is Rage2 exlusive, they have all Mach64 core ? ATi DVD had some region changer tool + ATi Rage had 3DCIF demos, that i have found. What about Rage3 bioses and flash tools tha work. If you have some software or fast drivers that you use and it is compatible with Rage3, share it!
Thank you!
Takedasun: Great collection ATi drivers
https://disk.yandex.ru/d/eV600jDAliJ_3w?w=1
Gona: ATI_3D_CIF.
https://gona.mactar.hu/ATI_3D_CIF/
Latest 3DCIF driver for Rage2/Rage3 is now v4.11.2611, its from 5.38.x base and 5.40.x 3d files, works also with Rage XL agp, could someone test it with Rage Mobility agp (Rage3)? Did you know that Rage3 can do 8bit paletted textures out of the box over Direct3D and even OpenGL can be used with 8bit @ software help. 3D Mark99Max@default 800x600x16 score over 2300+ with Rage XL vga mem OC, without any OC its 1750 + and it can be improved. We are talkin about 1997 hardware here and low end card. Bilinear disabled for OpenGL for better performance, can be turned back, OpenGL multituxure can be used for RagePro, best multitexture OpenGL is v1073. Most sensible Celeron/Duron@ 600Mhz setups get 3DMark99Max core without any OC 1500+ points easly.
Not final driver, its 90% done. Rage3 3DCIF/D3D/OpenGL/ATiDVD support, 3Dfx emulation also added and works with small list of 3Dfx games. Try it out and how i can improve it?
Thank you!
First edit: 5.40/2611 and 5.38/2611 drivers added to the first post! (old)
NB! I Recommend you to download 5.40x2611x3D.7z or 5.38x2611x3D.7z drivers and use my software bundle (ATi3DRageProSoftwarebundle.7z)!
ATi3DRageProSoftwarebundle download links:
https://hingetee.ee/library/ATi3DRageProSoftwarebundle.7z
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … re%20bundle?w=1
About 5.40x2611x3D.7z (older)
New 5.40.3 drivers are here + added ATi3DRageProSoftwarebundle.7z
There are some nice tools and programs for Rage2/Rage3, Thank you!
No need to downgrade nothing for 3DCIF/DVD, just for RageXL & DVD
For RagePro newer ATiDVD are working. So far the latest R2/R3 driver
3DCIF/DVD driver of course! Just use ATi DVDcpl to get it going better.
Rage2 tweaker settings changes are working,reduce dithering effect!
Many more things to discover about these old ATiThreeD videocards!
Edit2 (new) Best for multiple (ALL-in-One) 5.40x2611x3Dxx DriveR
ARx2611x3Dx2.7z = 5.40x2611x3Dfx / 5.40x2611x3Dgl - has /CosmoGL/GLUT/Glide2x/
ARx2611x3Dx2.7z download link: download/file.php?id=245130
NB! Latest ARx2611x3Dx2.7z with dgVoodoo 1.31 / Rage23 OpenGL32.dlls
More info: Re: ATi RagePro drivers and software
Download: download/file.php?id=245130
Info about the DriveR: Re: ATi RagePro drivers and software
More info about GLut: Re: ATi RagePro drivers and software
I hope you like it!
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 1 of 150, by marxveix
For Rage2/Rage2c you should downgrade macxdd32.dl_ from dd32/r2latest/5039 folder and overwrite default macxdd32.dl_ 5043 and install it with ConfigSetup normally. With Rage2CAGP i have tested TombRaider (CIF) + Croc:Legend of the Gobbos 1.0 (CIF) + CIF demos and they work as they should. Macxw4.inf has readme inside. Thank you!
Added atifont.co_ (atifont.com) to fix 8x14 fonts with Rage2/Rage3 cards.
Games like Soleau Software's The Mice Men / Classic SimCity works with it.
Keen 4-6 fix Re: Keen 4-5-6 choppy scrolling on EGA card
More info about atifont.com here: https://web.archive.org/web/20021001204226/ht … atifontcom.html
Someone has more Rage2/Rage3 cards add to this list? Updated macxw4.inf
(XL PCI 4752 and probably XC PCI 4753 does not work and they are with ?) .
"3D RAGE LT PCI (4C54)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C54&SUBSYS_4C541002, PCI\VEN_1002&DEV_4C54
"3D RAGE LTG PCI (4C47)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C47&SUBSYS_4C471002, PCI\VEN_1002&DEV_4C47
"3D RAGE II PCI (4754)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4754&SUBSYS_47541002, PCI\VEN_1002&DEV_4754
"3D RAGE II+DVD PCI (4755)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4755&SUBSYS_47551002, PCI\VEN_1002&DEV_4755
"RAGE IIC AGP (4757)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_47571002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (4757/0040)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_00401002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (4757/0048)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_00481002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (4757/0080)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_00801002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (4757/0084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_00841002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (4757/0088)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4757&SUBSYS_00881002, PCI\VEN_1002&DEV_4757
"RAGE IIC AGP (475A)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_475A1002, PCI\VEN_1002&DEV_475A
"RAGE IIC AGP (475A/0040)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_00401002, PCI\VEN_1002&DEV_475A
"RAGE IIC AGP (475A/0048)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_00481002, PCI\VEN_1002&DEV_475A
"RAGE IIC AGP (475A/0080)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_00801002, PCI\VEN_1002&DEV_475A
"RAGE IIC AGP (475A/0084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_00841002, PCI\VEN_1002&DEV_475A
"RAGE IIC AGP (475A/0088)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_475A&SUBSYS_00881002, PCI\VEN_1002&DEV_475A
"RAGE IIC PCI (4756)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_47561002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4756/0040)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_00401002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4756/0048)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_00481002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4756/0080)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_00801002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4756/0084)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_00841002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4756/0088)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4756&SUBSYS_00881002, PCI\VEN_1002&DEV_4756
"RAGE IIC PCI (4759)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4759&SUBSYS_47591002, PCI\VEN_1002&DEV_4759
"3D RAGE PRO AGP (4744)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4744&SUBSYS_47441002, PCI\VEN_1002&DEV_4744
"3D RAGE PRO AGP (4744/0080)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4744&SUBSYS_00801002, PCI\VEN_1002&DEV_4744
"3D RAGE PRO AGP 2X (4742)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_47421002, PCI\VEN_1002&DEV_4742
"3D RAGE PRO AGP 2X (4742/0080)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00801002, PCI\VEN_1002&DEV_4742
"3D RAGE PRO PCI (4749)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4749&SUBSYS_47491002, PCI\VEN_1002&DEV_4749
"3D RAGE PRO PCI (4750)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_47501002, PCI\VEN_1002&DEV_4750
"3D RAGE PRO PCI (4751)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4751&SUBSYS_47511002, PCI\VEN_1002&DEV_4751
"All-in-Wonder PCI (4755)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4755&SUBSYS_00791002, PCI\VEN_1002&DEV_4755
"All-in-Wonder PRO AGP 2X (4742)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_47421002, PCI\VEN_1002&DEV_4742
"All-in-Wonder PRO AGP 2X (4742/0061)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00611002, PCI\VEN_1002&DEV_4742
"All-in-Wonder PRO AGP 2X (4742/0062)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00621002, PCI\VEN_1002&DEV_4742
"All-in-Wonder PRO AGP 2X (4742/0063)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00631002, PCI\VEN_1002&DEV_4742
"All-in-Wonder PRO PCI (4749)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4749&SUBSYS_47491002, PCI\VEN_1002&DEV_4749
"All-in-Wonder PRO PCI (4749/0061)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4749&SUBSYS_00611002, PCI\VEN_1002&DEV_4749
"All-in-Wonder PRO PCI (4749/0062)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4749&SUBSYS_00621002, PCI\VEN_1002&DEV_4749
"All-in-Wonder PRO PCI (4749/0063)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4749&SUBSYS_00631002, PCI\VEN_1002&DEV_4749
"3D RAGE PRO AGP 2X (4747)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4747&SUBSYS_47471002, PCI\VEN_1002&DEV_4747
"RAGE PRO TURBO AGP 2X (4742)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_47421002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/0040)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00401002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/0044)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00441002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/0080)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00801002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/0084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00841002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/464A)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_464A8086, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/0082)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00821028, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/4082)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_40821028, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/4152)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_41528086, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/8082)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_80821028, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/C082)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_C0821028, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/8001)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_80011002, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP 2X (4742/8023)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_80231033, PCI\VEN_1002&DEV_4742
"RAGE PRO TURBO AGP (4744)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4744&SUBSYS_47441002, PCI\VEN_1002&DEV_4744
"RAGE PRO TURBO AGP (4744/406F)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4744&SUBSYS_406F1028, PCI\VEN_1002&DEV_4744
"3D RAGE PRO PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_47501002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_47501002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750/0040)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00401002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750/0044)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00441002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750/0080)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00801002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750/0084)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00841002, PCI\VEN_1002&DEV_4750
"RAGE PRO TURBO PCI (4750/0088)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00881002, PCI\VEN_1002&DEV_4750
"XPERT XL AGP 2X (4742/0088)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00881002, PCI\VEN_1002&DEV_4742
"XPERT XL AGP 2X (4742/0048)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00481002, PCI\VEN_1002&DEV_4742
"XPERT XL PCI (4750/0088)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00881002, PCI\VEN_1002&DEV_4750
"XPERT XL PCI (4750/0048)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00481002, PCI\VEN_1002&DEV_4750
"XPERT LCD AGP 2X"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_00441002, PCI\VEN_1002&DEV_4C42
"XPERT@PLAY AGP 2X"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00401002, PCI\VEN_1002&DEV_4742
"XPERT@WORK AGP 2X"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00801002, PCI\VEN_1002&DEV_4742
"XPERT LCD PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_00441002, PCI\VEN_1002&DEV_4C49
"XPERT@PLAY PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00401002, PCI\VEN_1002&DEV_4750
"XPERT@WORK PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00801002, PCI\VEN_1002&DEV_4750
"XPERT98D AGP 2X (4742)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_41528086, PCI\VEN_1002&DEV_4742
"XPERT98 AGP 2X (4742)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4742&SUBSYS_00841002, PCI\VEN_1002&DEV_4742
"XPERT98 AGP 2X (474D/0084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_00841002, PCI\VEN_1002&DEV_474D
"XPERT98 AGP 2X (474D/8084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_80841002, PCI\VEN_1002&DEV_474D
"XPERT98 RXL 2X AGP (474D/0004)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_00041002, PCI\VEN_1002&DEV_474D
"XPERT98 RXL 2X AGP (474D/0008)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_00081002, PCI\VEN_1002&DEV_474D
"XPERT98 RXL 2X AGP (474D/8004)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_80041002, PCI\VEN_1002&DEV_474D
"XPERT98 RXL 2X AGP (474D/8008)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_80081002, PCI\VEN_1002&DEV_474D
"XPERT98 AGP"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_4C4D1002, PCI\VEN_1002&DEV_4C4D
"XPERT98 PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4750&SUBSYS_00801002, PCI\VEN_1002&DEV_4750
"eOne AGP"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_314F109F, PCI\VEN_1002&DEV_474D
"Logan AGP"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_00041002, PCI\VEN_1002&DEV_4C42
"Logan PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_00041002, PCI\VEN_1002&DEV_4C49
"Profile PCI"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_0004107B, PCI\VEN_1002&DEV_4C49
"RAGE LT PRO AGP (4C44)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C44&SUBSYS_4C441002, PCI\VEN_1002&DEV_4C44
"RAGE LT PRO AGP 2X (4C42)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_4C421002, PCI\VEN_1002&DEV_4C42
"RAGE LT PRO AGP 2X (4C42/0044)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_00441002, PCI\VEN_1002&DEV_4C42
"RAGE LT PRO AGP 2X (4C42/0040)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_00401002, PCI\VEN_1002&DEV_4C42
"RAGE LT PRO AGP 2X (4C42/8001)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C42&SUBSYS_80011002, PCI\VEN_1002&DEV_4C42
"RAGE LT PRO PCI (4C51)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C51&SUBSYS_4C511002, PCI\VEN_1002&DEV_4C51
"RAGE LT PRO PCI (4C50)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C50&SUBSYS_4C501002, PCI\VEN_1002&DEV_4C50
"RAGE LT PRO PCI (4C49)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_4C491002, PCI\VEN_1002&DEV_4C49
"RAGE LT PRO PCI (4C49/0044)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_00441002, PCI\VEN_1002&DEV_4C49
"RAGE LT PRO PCI (4C49/0040)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_00401002, PCI\VEN_1002&DEV_4C49
"RAGE LT PRO PCI (4C49/0004)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C49&SUBSYS_00041002, PCI\VEN_1002&DEV_4C49
"RAGE XL AGP (474D)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_474D1002, PCI\VEN_1002&DEV_474D
"RAGE XL AGP (474D/806A)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_806A1033, PCI\VEN_1002&DEV_474D
"RAGE XL AGP 2X (474D/107C)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_107C10CF, PCI\VEN_1002&DEV_474D
"RAGE XL AGP 2X (474D/806A)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474D&SUBSYS_806A1002, PCI\VEN_1002&DEV_474D
"RAGE XL PCI-66 (474F)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_474F&SUBSYS_474F1002, PCI\VEN_1002&DEV_474F
"RAGE XL PCI? (4752)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4752&SUBSYS_47521002, PCI\VEN_1002&DEV_4752
"RAGE XL PCI? (4752/0008)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4752&SUBSYS_00081002, PCI\VEN_1002&DEV_4752
"RAGE XL PCI? (4752/HPTC)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4752&SUBSYS_80081002, PCI\VEN_1002&DEV_4752
"RAGE XC AGP (474E)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474E&SUBSYS_474E1002, PCI\VEN_1002&DEV_474E
"RAGE XC AGP (474E/0084)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_474E&SUBSYS_00841002, PCI\VEN_1002&DEV_474E
"RAGE XC PCI (4C50)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C50&SUBSYS_4C501002, PCI\VEN_1002&DEV_4C50
"RAGE XC PCI-66 (474C)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_474C&SUBSYS_474C1002, PCI\VEN_1002&DEV_474C
"RAGE XC PCI? (4753)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4753&SUBSYS_47531002, PCI\VEN_1002&DEV_4753
"ATI RAGE MOBILITY AGP (4C4D/B160)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_B1600E11, PCI\VEN_1002&DEV_4C4D
"ATI RAGE MOBILITY AGP (4C4D/B111)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_B1110E11, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-P AGP (4C4D/009E)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_009E1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-P AGP (4C4D/009F)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_009F1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-P AGP (4C4D/0085)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00851028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/AA)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00AA1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/AB)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00AB1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/BB)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00BB1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/BC)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00BC1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/DC)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00DC1028, PCI\VEN_1002&DEV_4C4D
"RAGE MOBILITY-M1 AGP 2X (4C4D/DD)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_00DD1028, PCI\VEN_1002&DEV_4C4D
"MOBILITY P/M AGP 2X (4C4D)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4D&SUBSYS_4C4D1002, PCI\VEN_1002&DEV_4C4D
"MOBILITY-L AGP 2X (4C4E)"= MACXW4_AGP_ENU, PCI\VEN_1002&DEV_4C4E&SUBSYS_4C4E1002, PCI\VEN_1002&DEV_4C4E
"RAGE MOBILITY-L PCI (4C53)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C53&SUBSYS_4C531002, PCI\VEN_1002&DEV_4C53
"RAGE MOBILITY P/M PCI (4C52)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C52&SUBSYS_4C521002, PCI\VEN_1002&DEV_4C52
"RAGE MOBILITY P/M PCI (4C52/B111)"= MACXW4_PCI_ENU, PCI\VEN_1002&DEV_4C52&SUBSYS_B1110E11, PCI\VEN_1002&DEV_4C52
Reply 2 of 150, by donluca4
Hi, I have tried your drivers with my Thinkpad X20 which has a Radeon Mobility M (Rage 3, 4MB).
Regarding games supporting ATI CIF:
Tomb Raider: crash at startup
Croc: severe texture corruption
I'll be testing some D3D games and OpenGL after that and report back.
Reply 3 of 150, by donluca4
Shipwreckers! (also known as Overboard!) works perfectly at 800x600, albeit with some tiny hiccups that happen at regular intervals (maybe it's trying to access the CD ROM for audio?)
Thief: The Dark Age works beautifully without any stutters at high settings and 800x600
I'll test some OpenGL games next.
Reply 4 of 150, by marxveix
donluca4 wrote on 2025-05-10, 15:18:
Hi, I have tried your drivers with my Thinkpad X20 which has a Radeon Mobility M (Rage 3, 4MB). […]
Thank you! So with this driver it could bring back Rage XL AGP and Rage XC AGP and 3DCIF with 4.11.2611 driver, but not Mobility.
donluca4 wrote on 2025-05-10, 16:37:
For OpenGL use ConfigNo3Dfx.bat to gain OpenGL performance and same goes with Config3Dfx.bat and now some glide/ultrahle n64 games should also work. I have used NFS2SE @ Glide with it. Not perfect, but its playable. ATi DVD3.2/ ATi MMC6.3 for DVD should work well for Rage3. Thank you!
From XGL200 readme
Games:
Perfect:
None 😀
Almost perfect:
MadTrax
Croc - Legend of the Gobbos
Need for Speed 2
Outlaws
UltraHLE /w Mario 64
UltraHLE /w Quake 64
UltraHLE /w Zelda 64
UltraHLE /w Bomberman Hero
Very playable:
UltraHLE /w Doom 64 (very dark)
UltraHLE /w StarFox
UltraHLE /w WaveRace
UltraHLE /w Banjo Kazooie
UltraHLE /w Tetris 64
Playable, but a little slow:
UltraHLE /w Goldeneye
UltraHLE /w Mario Kart
UltraHLE /w Rampage World Tour
Playable, but ugly:
NBA Live 98
Pandemonium 2
Unreal
These are the only games I have to try it with, but let me know if you have different results!
D3D 8bit paletted textures should work out of the box and OpenGL 8bit paletted textures workround is is here if you need or want to try.
ATi Rage3 paletted textures with OpenGL possible with GLDirect. For me, best worked GLDirect 3.0.0 CAD Driver + Disable Mipmapping.
Re: ATi RagePro OpenGL files
https://www.vogonsdrivers.com/wrappers/files/ … irect-3.0.0.exe
Reply 5 of 150, by donluca4
Hexen II (in OpenGL) works as well just with the drivers supplied, without any modification (and by deleting opengl32.dll in the Hexen folder)
Reply 6 of 150, by marxveix
donluca4 wrote on 2025-05-12, 18:18:
Thank you for testing! I have used glquake and quake2 myself, both are good. 👍
OpenGL version is 4.12.1.1091, click bat file and it copies atidbg.ini to c:\windows.
Reply 7 of 150, by marxveix
Rage XL / Rage Pro:
ATi DVD Player 3.10
Engine 1.0.28.5034
Reply 8 of 150, by marxveix
What xvid/divx codecs are fastest to use with Win9x and ATi Video Player? Quickly tested FFDSHOW, they are working.
ATi DVD 3.1 that i added before works with my 4.11.2611 driver and Rage3 for sure, like this latest ATi Video Player 5.35.
Reply 9 of 150, by marxveix
Updated my OpenGL package for Rage3, download link here: https://hingetee.ee/library/ati-rage3gl-win9x.7z
Rage3GL Win9x
MiniGL (Opengl32.dll)
1 ) 4.10.1005 Beta1
2 ) 4.10.1010 Beta2
3 ) 4.10.1021 Beta3
4 ) 4.10.1036
OpenGL (Atoglrp9.dl_)
5 ) 4.10.1045
6 ) 4.11.1049
7 ) 4.11.1051
8 ) 4.11.1058
9 ) 4.11.1060
10) 4.11.1062
11) 4.11.1065
12) 4.11.1068
13) 4.11.1073
14) 4.11.1076
15) 4.11.1077
16) 4.11.1079
17) 4.11.1084
18) 4.11.1085
19) 4.12.1088
20) 4.11.1091
21) 4.12.1091
22) 4.11.1094
23) 4.12.1094
24) 4.12.1095
25) 4.12.1096
26) 4.12.1100
27) 4.12.1103
28) 4.12.1104
29) 4.12.1106
30) 4.12.1107 V1
31) 4.12.1107 V2
Downloaded from
https://hingetee.ee/ftp/ati-rage3gl-win9x.7z
Vogons forum topic
Missing Win9x Rage3 OpenGL versions are 1071 and 1087.
Rage3=Rage Pro/Rage Pro Turbo/LTPRO/XL/XC/Mobility-P/M
MiniGL you can try out, just replace Opengl32.dll file
inside your Game folder, probably works with Quake1/2.
Rage3 based cards and OpenGL works only in 16 bit mode!
Rename Atoglrp9.dl_ OpenGL file if needed and overwrite
and install it with your unpacked Win9x graphics driver.
Autoexec.bat added for easy OpenGL version quick change,
without computer restart, packed/unpacked Atoglrp9.dll.
OpenGL can be named Atio9xad.dll or Atio9xae.dll &other.
Usually biggest file in your driver folder, easy to see.
GLQuake fix > from OpenGL 4.12.1095 up to 4.12.1107 add
gl_ztrick "0" to quake/id1 autoexec.cfg or open glquake
console and type gl_strick 0 to fix missing bottom hud
(status bar) and screen flickerings before your gaming.
Edited autoexec.cfg works also with older OGL versions.
Return to Castle Wofenstein likes sometimes Safe Mode
and dont use 107x or older OpenGL versions @this game.
Oni game also dont work with OpenGL 107x or older and
newer Seroius Sam game does not work @ v1091 or older.
Some Games require newer or older OpenGL versions that
work better, newer OpenGL should have more bugs fixed.
I use maximum AGP Aperature on my board for combapility
reduce AGP Aperture setting in the BIOS to 32MB or less,
may help in some situations for flickering or glitches.
Rage3 @AGP + 8MB are also faster than PCI or 4MB cards,
but we can improve OpenGL performance @atidbg settings.
Not all OpenGL ATIDBG settings works best for every OGL
version, some OGL settings work for newer versions only.
My atidbg.ini settings, you can change them at any time.
C:\WINDOWS\atidbg.ini - the location where it should be.
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UsePioDraw=0
Max fps settings probably fastest if installing atidbg.
Use Autoexec.bat and install atidbg.ini to get Max fps.
For easy use All/Max/Fast/Normal atidbg settings added.
Multitexture+Bilinear filtering disabled-Max fps
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=0
Copy or edit atidbg.ini @ C:\WINDOWS\atidbg.ini
Multitexture + Bilinear filtering enabled-Fast fps
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=1
Multitexture disabled/Bilinear filtering enabled-Normal
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=1
Other atidbg.ini settings (0 to 1 to change off/on)
These settings will change speed and how it looks.
SkipFlipWaitIdle works from OpenGL v1084 and newer,
if your Game is laggy & makes strange keyboard and
mouse movements,disable it with SkipFlipWaitIdle=0
SkipFlipWaitIdle=1 works best only with benchmarks,
real gaming experience can be bad, not reccomended.
Some examples, change 0 to 1 or 1 to 0
[OPENGL]
BreakPageFlipping=0 or 1
[Kelvin]
Alpha=0 or 1
TexMap=0 or 1
[Performance]
SkipFlipWaitIdle=0 or 1
UsePioDraw=0 or 1
All settings
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UseAsmDraw=1
UsePioDraw=0
UseAsm=1
UseGen=1
BMPad=1
Performance and stability of each ICD is different.
To recommend specific OpenGL is not easy, you should
see what suits your Games, use any of available ones.
I would use: 4.11.1091 version for my starting point.
Also it is easy to change OpenGL and ATIDBG settings.
Best ones for me are: old 1073, middle 1091,new 1107.
Any OpenGL version 4.11&4.12 should work,just try it.
Use 4.11.1091/4.12.1091 exit Quake1/Quake2 without
getting stuck at exit, 4.11.1094/4.12.1094 has this
behavior sometimes. Are all other OpenGL games same
boat with OpenGL 4.11.1094/4.12.1094 @ game exiting
crash? Maybe it is related to the ATi driver or is
this with all driver versions and for everybody?
I use 4.11.1091/4.12.1091 more at the moment,
than i use 4.11.1094/4.12.1094.
GLDirect v3 and v5 included + some Quake1/2/3 tweaks.
Also RageProTweaker 1.2 here to change easly D3D/OGL.
GLDirect. For me best worked GLDirect 3.00 CAD Driver
+ Disable Mipmapping and tested @ Quake2+screenshots.
D3DDX6/OpenGL1.1 Fog City bencmark/GLDemo added here.
(Files collected and readme created by MarxVeix)
Reply 10 of 150, by marxveix
Somebody can test this game with 8MB Video ram? Phils Computer Lab has problems at the moment with his Rage Pro 4MB AGP in this game. Other games so far are working with CIF/D3D/OGL.
Edit: Now quick tested it myself with Rage3 8mb and 4mb, 8mb card did not have this black figures, but 4mb one did with 4.11.2611 driver.
If you uncheck Detail Dexturing (slower) options,then it works also with 4mb cards, thanks to PhilsComputerLab for checking the settings.
Further checking i released that ATi Rage Pro had this also with 8MB, but ATi RageXL does not have it, its the same driver for both ATi cards.
Driver 4.11.2628 has same issue,its maximum (latest) driver component base that i can use,probably cant fix it,i update my 4.11.2611 soon.
Reply 11 of 150, by marxveix
Rage XL PCI (4752) 3DCIF testing driver (3DCIF demos work): Re: Chinese Rage XL PCI mods, improved compatibility and looking for a good overclock.
Reply 12 of 150, by B24Fox
marxveix wrote on 2025-08-09, 04:51:
Updated my OpenGL package for Rage3, download link here: https://hingetee.ee/library/ati-rage3gl-win9x.7z […]
Rage3GL Win9x
1 ) 4.10.1005 Beta1
2 ) 4.10.1010 Beta2
3 ) 4.10.1021 Beta3
4 ) 4.10.1036
5 ) 4.10.1045
6 ) 4.11.1049
7 ) 4.11.1051
8 ) 4.11.1058
9 ) 4.11.1060
10) 4.11.1062
11) 4.11.1065
12) 4.11.1068
13) 4.11.1073
14) 4.11.1076
15) 4.11.1077
16) 4.11.1079
17) 4.11.1084
18) 4.11.1085
19) 4.12.1088
20) 4.11.1091
21) 4.12.1091
22) 4.11.1094
23) 4.12.1094
24) 4.12.1095
25) 4.12.1096
26) 4.12.1100
27) 4.12.1103
28) 4.12.1104
29) 4.12.1106
30) 4.12.1107 V1
31) 4.12.1107 V2
Downloaded from
Vogons forum topic
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UsePioDraw=0
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=0
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=1
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=1
[OPENGL]
[Kelvin]
Alpha=0 or 1
TexMap=0 or 1
[Performance]
UsePioDraw=0 or 1
All settings
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UseAsmDraw=1
UsePioDraw=0
UseAsm=1
UseGen=1
BMPad=1
Unfortunately both these links are dead. Can you reupload please?
And thank you VERY much for all your work! I'm planing to build an Ati RAGE-based rig in the future, and this will be absolutely invaluable! 😄
Reply 13 of 150, by marxveix
B24Fox wrote on 2025-09-13, 01:30:
Rage3GL Win9x
1 ) 4.10.1005 Beta1
2 ) 4.10.1010 Beta2
3 ) 4.10.1021 Beta3
4 ) 4.10.1036
5 ) 4.10.1045
6 ) 4.11.1049
7 ) 4.11.1051
8 ) 4.11.1058
9 ) 4.11.1060
10) 4.11.1062
11) 4.11.1065
12) 4.11.1068
13) 4.11.1073
14) 4.11.1076
15) 4.11.1077
16) 4.11.1079
17) 4.11.1084
18) 4.11.1085
19) 4.12.1088
20) 4.11.1091
21) 4.12.1091
22) 4.11.1094
23) 4.12.1094
24) 4.12.1095
25) 4.12.1096
26) 4.12.1100
27) 4.12.1103
28) 4.12.1104
29) 4.12.1106
30) 4.12.1107 V1
31) 4.12.1107 V2
Downloaded from
Vogons forum topic
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UsePioDraw=0
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=0
[OPENGL]
EnableMTSGI=1
EnableMTARB=1
[Kelvin]
Bilinear=1
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
[Kelvin]
Bilinear=1
[OPENGL]
[Kelvin]
Alpha=0 or 1
TexMap=0 or 1
[Performance]
UsePioDraw=0 or 1
All settings
[OPENGL]
EnableMTSGI=0
EnableMTARB=0
BreakPageFlipping=1
[Kelvin]
Bilinear=0
Alpha=1
TexMap=1
[Performance]
SkipFlipWaitIdle=0
UseAsmDraw=1
UsePioDraw=0
UseAsm=1
UseGen=1
BMPad=1
B24Fox: Now it works, added two more OpenGLs versions (v1087 and v1102 new in the package).
33 w9x MiniGL/OpenGL versions collected already:
More Rage3 OGL stuff: ATi RagePro OpenGL files
Reply 14 of 150, by marxveix
I have similar, but newer driver than 538x3d2611, that also should work with Rage2 PCI/AGP up to Rage XL AGP and 3DCIF supported, its 540x3d2611.
I have had not time to test it with new Windows 98 installation yet, i may do it soon, before i release it. Still no good 3DCIF driver@RageXLPCI (4752).
Driver base components are from ATI2DDAD 5.40 driver release and added Rage2 / XL AGP CIF support there, ati3dcif.dll naming hexedit was needed.
Tiny update pump to 538x3d2611 earlier driver release, just added atifont.com and updated macxw4.inf with more Rage2 and Rage3 card inf inside it.
Also here: https://hingetee.ee/library/mach64w9x538x3d2611.zip
Reply 15 of 150, by B24Fox
THANK YOU!!! 🥂
Reply 16 of 150, by marxveix
PhilsComputerLab made one video about older socet370 motherboard and later on he used my 538/2611 driver there.
https://www.youtube.com/watch?v=Y3qFSOKyyCU
This week i will release 540/2611 driver with similar compability!
5.40.3.2611x3D driver did get base driver upgrade, R3 D3D part is the same, R2/R3 D3D downgrade works and some older D3D may work better with some older games.I have used R3 DX5 4.10.4002 for DX5 testing and R3 DX6@4.11.4033 as usual. Whats the best D3D for Rage2? 540.3.2611x3D i have used R2 D3D 4.10.2774 at the moment and i want to go past R3 D3D with 4.11.4033 if possible in the future with 3DCIF driver.
I would like ATi MMC 6.30 to get going out of the box, but DVD 6.2 (3.2) part is not working, ATi DVD 3.10 works perfectly. I have installed MMC 6.30 and installed DVD 3.10 after MMC6.30 and ATiDVD 3.10 starts and works well also directly at MMC6.30 menu, so basicly its not that bad overall.
edit:
Already found mmc 630 without dvd and found bit newer ati dvd that also works, now mmc + dvd combo bit better solution, also tested atidvd mpeg1/mpeg2 cpu utilisation and its has lower cpu usage than ordinary mpeg1/mpeg2 software dvd players, better than any other, also much better than any ati video player or other media player that ati integrated also with mmc 6.30, maybe there exist older MMC 6.0, 6.1 6.2 versions anybody? For CPU usage i used Win9x version of Process Explorer.
Turok1 game has no fog@dx6 d3d files or not correct fog or background, but fog works bit better with some dx5 ones, like 4.10.4002. 3DCIF is ok no matter what D3D version is used.
Turok1 and ATi Rage Pro (CIF driver) has lower performance than D3D
to get it going bit faster with fog@D3D, downgrade to 4.10.4002 D3D
T1 without fog and D3D 4.11.4033 is faster and 3DCIF version has fog!
Re: What game are you playing now?
To get to chooce CIF or D3D launch Turok1 with -alldrivers
"C:\Games\Turok Dinosaur Hunter\Turok.exe" -alldrivers
Turok1 Benchmark with alldrivers
"C:\Games\Turok Dinosaur Hunter\Turok.exe" -benchmark -alldrivers
Turok2 has no fog problems and its D3D only.
Please remember if you are using ATi Rage XL AGP and probably same with Rage XC AGP and you are starting some rare CIF games, like NFS3/Turok1 or any other, sometimes you have to change screen resolution or color bit depth to get 3DCIF running, it does not happen with Rage Pro / Rage Pro Turbo / Rage LT Pro. Most 3DCIF games start normally with both cards, let it be Rage Pro or XL.
How to start NFS3/NFS4 with 3DCIF:
Re: 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D)
Turok screenshots also added + DVD is working - here it is just black / Computer sceenshots does not capture real life situations. 😀
Reply 17 of 150, by marxveix
B24Fox wrote on 2025-09-20, 21:29:
THANK YOU!!! 🥂
Thank you, Now even newer driver and greater Software bundle. Check it out. 😀
3DCIF/DVD driver of course, just use ATi DVDcpl to get it going better.
Rage2 tweaker settings changes are working reduce dithering effect just tested with Turok. 😀
Difference is quite big and it went to better direction. I had Rage2 Tweaker long time, just it
missed two files that i recently download from the internet. Turok1 test card was Rage XL AGP.
Of course i used my drivers for testing. I have made long nights to get the driver more recent.
I am not suprised, if this Rage2 tool works also with Rage128, but its different beast already.
ATi driver was at 15bit so real 16bit maybe even bit better, not gona make new screenshots.
Reply 18 of 150, by marxveix
Starting from ATi Driver v4.11.2598 and with my 4.11.2611 driver also, some table fog starts to show up in the games with RageXL cards.
Not 100% correct@Win9x yet. 😀
Older screenshot with RageXL and newer ATi Win9x drivers is here
Re: Table Fog & 8-bit Paletted Textures
download/file.php?id=166667&mode=view
Someone has Macxmc12.dl_ (Macxmc12.dll) file, but dont download it from my Mach64w9x538x3D2611 driver, there its taken from 5.40 build, i would like to get original file. Macxdd16.dll and Macxdd32.dll 5039 has Macxmc12.dll written inside those files. Driver where i did get 5039, there it did not exist, they are from 5.38.3 NEC driver. Its ATi MC12.
MC12 Motion Compensation Format ATI Technologies Proprietary format used by ATI in MPEG decoding.
5.38.3 Original driver link.
https://support.nec-lavie.jp/driver/detail?module_no=720
edit
Found out that ATI2DRAB and ATI2DRAE drivers are using ATIMIAAB.DLL or ATIMIAAE.DLL file for DVD Authendication Driver @ Rage XL/XC/Mobility,
maybe thats the reason my ATi Rage XL is litle picky about the ATiDVD version and older ATiDVD does not use it, doesnt care. Rage Pro DVD just works.
Very old ATI2DRAB dirvers do not use this and they do not use ATIMCRAB.dll and newer ATIMCRAB/AE.dll files are missing ATID16AB/AE inf from dlls.
About 5.40/2611 driver, reduce dithering effect works with Rage3 cards, Rage2 needs testing or needs other ATiD3D version change.
Great tools for Rage2 and Rage3: Rage2Dev, Rage2 Tweaker, Rage Pro Tweakers 1.0,1.1 and 1.2, thanks Neil Banfield for making them.
In week or two i make small update to to the driver and i will find out Rage2C dithering, at quick testing it did not work for Rage2C card.
Removed numbers from cards inf file naming and made them bit shorter. I hope its ok to add Rage2 Dev tool to to the driver by now? 😀
My latest drivers and software bundle package files also available here
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … ge-MarxVeix?w=1
Recommended latest: mach64w9x538x3d2611.zip and 5.40x2611x3D
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … x3d2611.zip?w=1
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … x2611x3D.7z?w=1
Recommended: ATi3D RagePro Software bundle package,what inside 7z
More earlier 3DCIF tryouts, i recommend the latest ones, these are old!
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … 82582en.zip?w=1
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … e-3dcif.zip?w=1
https://disk.yandex.ru/d/eV600jDAliJ_3w/Tweak … XL_Beta.zip?w=1
Thank you Takedasun for sharing my package and drivers, Thank you!
Macxw4 and Ati2ddad driver gets small changes in this weekend, nothing major.
Do i change driver at top post, its gets downloaded the most and its older driver?
This is latest at the moment from Vogons site with direct download link:
5.40x2611x3D - download/file.php?id=227500
Ati2drab 3dcif driver is in the making, some 3dcif games already working @rage.
Tested already with clean w9x install and only ati2drab drivers where installed. 😀
Anyone has ati2drab.dr_ (ati2drab.drv) drivers from 4.11.1028 up to 4.10.2018?
Reply 19 of 150, by marxveix
5.38/2611 and 5.40/2611 drivers together in one package and changed and added some small stuff, they are bit different still very similar. 5.40/2611 the latest and greatest, but if someone needs testing with older driver files then 538/2611 is handy, both are good for 3DCIF to DVD and all between. Did you know that these drivers are maybe the latest that still supports multitexture with OpenGL and i must say that all of you should use Fast or Max OpenGL settings and Benchmark is only for Demo or Bencmark, gaming can be hard @Benc. To my knowledge Multitexture hangs with ati2drab/ati2drae drivers or somebody can test more these drivers and turn my text over and i would be more than glad.
There are many more settings, but for the beginning Fast and Max are good, you can use Default or delete Atidbg.ini, but you miss a lot of Performance by not using Fast or Max.ATI2DDAD drivers have less driver versions and i am trying next to integrate Ati2drab and Ati2drae stuff into Ati2ddad if possible. Both are very good drivers and inside OpenGL folder@540/2611 driver you can find bat files with quick settings changes for OpenGL and bundle have even more OpenGL settings and OpenGL files. Maybe only Wirl.iso was not good choice for my package bundle, it also needs Netscape Navigator old browser to use it or use it properly as i remember.
https://archive.org/details/netscape-navigator-4.0.4
Latest game that i have used with Rage3 is GTA Vice City / vga ram requirement removed and max is at 640x480x16, its playable, specially if you OC you Rage XL/Rage Pro 8MB.Use AGP if you can, i have used here my 5.40/2611 drivers and the game needs DirectX9, i had DirectX9c installed. Small glitches, nothing major, dithering changed 0 thing in this GTA game, Turok still works at dithering settings off and on. Maybe DX9 has some other settings or what D3D / 3DCIF game is good to test more at this dithering?
Anybody can give feedback, dont be shy! I know many want RageXL PCI (4752) support for CIF, but it have not happened yet and yes i have Ati2drab 3DCIF working driver, but its in the making so far and its not fully functional at all levels, i mean 3DCIF/D3D/OpenGL/DVD for all cards and its missing multitexture at OpenGL and not all R3 cards are working and its only up to 4.11.1027 ati2drab.drv, but there are good things also, its the driver where newer d3d works and it has better options at ATi Control Panel than Macxw4/Ati2ddad drv-s. Many things can be better if we can combine some parts of the Ati2drab/ae + Macxw4/Ati2ddad together. Ati2drab 4.11.1xxx cant work with Rage XL PCI (4752), only 4.11.2xxx if i talk about Ati2drab driver.
Ok shut up talking, bit updated 2xdriver bundle here
Rage2 and Rage3 5.38x2611 and 5.40x2611 together
https://hingetee.ee/library/ATiRage2611x3Dx2.7z
