CGA game on option ROM
First post, by Predator99
After my success with the IBM ROM Basic...
IBM ROM Basic - option ROM for PC clones
...I made another ROM. This time it contains a CGA game I played for hours when I was young 😉 I had this game as copy of a copy-protected 360kb-floppy. This floppy needed to be booted, therefore no DOS-functions are used, only BIOS-calls.
Later I found a version on the internet where the copy-protection was removed and you could run the game from DOS. I saw its size is only 61 kb.
Therefore I took the chance and put it on a ROM to turn your PC in an arcade machine. As it doesnt run directly from ROM the loader copies its content to RAM 1000:0 (therefore not much RAM needed) and executes afterwards.
The game is fun, maybe some of you dont know it 😉
If there is some interest I can also include some kind of selector so the ROM is only started when e.g. a key is pressed.
File is provided as a single 64 KB image or 32 KB HI/LO images.
The attachment jb.rar is no longer available
Reply 1 of 25, by reenigne
WinRAR is reporting an archive that is damaged or in unknown format (I don't think it's a download glitch as I tried twice with different browsers). What's the game?
Reply 2 of 25, by Predator99
Strange..just tried and it works for me 😕
Anyway, again as ZIP.
The attachment jb.zip is no longer available
Reply 3 of 25, by bakemono
Is there by chance a PC emulator that allows configuring arbitrary ROMs that you are using to test these? I was thinking about trying some random things with option ROMs but the process of removing a chip, programming it, and reinstalling it would be too laborius.
Reply 4 of 25, by Predator99
Indeed good question, that would speed the debugging up. PCem doesnt support this as far as I know, its only possible to implement the XT-IDE.
I have to Lo-tech ISA ROM board, but this doesnt work as expected.
As I need the ROM on the ethernet card to boot with XT-IDE the best option for me is currently to use the spare ROM sockets on this 286 board (HI/LO) which is hardwired to E000:0.
Re: Suntac 80286 Mainboards
Reply 5 of 25, by Tronix
Game uses int21h calls for load or create SCORE file. AMI 286 BIOS fill all unused interrupts with dummy calls, but some XT's BIOSes - not. So, if add dummy int21h handler to loader, game start on XT very well. I tested with PCem. ROM start from D000:0000.
The attachment jbird.png is no longer available
https://github.com/Tronix286/
Reply 6 of 25, by Predator99
Oh shit you inspected my code 🤣 It is not nice but I wrote this in debug.exe and it worked on the 1st try 😉
This...
db 09ah
dw 6,01000h
...is just a far call to 1000:6 where you copied the ROM to. Entry point is at offset 6, found this out by debugging the orginal EXE-Loader.
Now the interesting question: How did you get this running with PCem...? And how did you find out about the int21? I only tested in my AMI-286 so far. Think never would have found out that the int21 is the reason why it crashes on other machines...
Reply 7 of 25, by digger
Ah, J-Bird. That was a fun game, indeed. 😀 Supposedly, the game supported Tandy/PCJr graphics and sound, but I couldn't get the game to work in that mode in DOSBox. It would only show 4 color CGA and play one-voice internal speaker sound. Perhaps PCem would be more successful in that regard, given its more accurate hardware emulation of specific systems, such as the Tandy 1000.
Reply 8 of 25, by Tronix
I made minor changes to the old (ver 12) PCem source code and recompile it with mingw32. Most edits in mem.c :
uint8_t romext[65536];    // was 32768
static void mem_load_xtide_bios()
FILE *f;
// f=romfopen("roms/ide_xt.bin","rb");
f=romfopen("roms/jb.bin","rb"); // load 64K of jb.bin instead XT-IDE opt rom
if (f)
pclog("found jb.bin\n");
fread(romext,65536,1,f);
fclose(f);
uint8_t mem_read_romext(uint32_t addr, void *priv)
return romext[addr & 0xffff]; // was & 0x3fff
uint16_t mem_read_romextw(uint32_t addr, void *priv)
return *(uint16_t *)&romext[addr & 0xffff]; // was & 0x3fff
uint32_t mem_read_romextl(uint32_t addr, void *priv)
return *(uint32_t *)&romext[addr & 0xffff]; // was & 0x3fff
void mem_init()
....skip ....
mem_mapping_add(&romext_mapping, 0xd0000, 0x10000, mem_read_romext, mem_read_romextw, mem_read_romextl, NULL, NULL, NULL, romext, 0, NULL);
void mem_resize()
.... skip ....
// pclog("Mem resize %i %i\n",mem_size,c);
mem_a20_key = 2;
mem_a20_recalc();
To search int 21h calls I used HIEW32. Load JBIRD.OVL, F7 (search) then F7 - search by assembler command - enter "int 21h" and look at search result:
The attachment hiew32.png is no longer available
Reply 9 of 25, by Tronix
And now 32Kb version! 😊
For compression i use great LZ4 program lz4_8088 by Trixter. So, original JBIRD.OVL compressed to 25795 bytes. Then insert in STUB.ASM LZ4 faster decompress and here we are! 27С256 EPROM can be used instead of 27C512.
Reply 10 of 25, by Predator99
Wow great improvements!!! 😎
Just tested in my new 386...
...on the Lo-Tech ROM Board: Works with 32kb!!!
With this you also run it in most ISA Ethernet cards...mine only accept up to 32KB ROMs.
Good work! 😎
Also good idea with the int21. I think the crackers must have introduced this while porting to DOS. As written, the original was on a copy protected floppy withou DOS.
Regarding PCem: Too complicated to me to mess with the source...also more fun with a real PC.
Reply 11 of 25, by Tronix
BTW, almost all early XT/PC games can be ported to EPROM. For example, this is digger 32Kb in attachment. Original .COM file compressed with LZ4_8088, added STUB for uncompressing and move to RAM memory at 1000h:0100h. Offset is 0100h, because digger want PSP data area.
I think its possible to convert Paratrooper, Arcade Volleyboll, and so on....
UPD: And "Planet Zoom"
Reply 12 of 25, by Predator99
Yes indeed. But not possible for games that use DOS functions. The loader is quite generic, only the entry offset maybe different
Was just a proof of concept for me, did somebody do that before?
Maybe its also possible to put the IBM Basic on a 32KB ROM with compression, maybe I try later...
Reply 13 of 25, by Tronix
Easy -)
Reply 14 of 25, by Predator99
Tronix wrote:
Easy -)
Hmmm...no 😉 This doesnt work on real hardware.
But for the IBM ROM its not neccessary to copy to RAM anyway. It can directly be run from ROM. Not possible with the compression of course. But if you like to run BASIC/BASICA from DOS you need to have it in ROM. But I think nobody needs this...
Reply 15 of 25, by Tronix
I wrote a small utility - COM2ROM.
Using:
- download LZ4_8088 archiver by Trixter here: http://www.oldskool.org/pc/lz4_8088/LZ4_8088.ZIP
- go in Win32 folder and run "compress.bat <game-name.com> . You got <game-name.com.LZ4> compressed file.
- run COM2ROM <game-name.com.LZ4> <output.bin> .
- Burn <output.bin> in EEPROM or flash.
Sources are included in /src folder.
Reply 16 of 25, by Predator99
Predator99 wrote:
Tronix wrote:
Easy -)
Hmm, loaded your ROM in Turbo Debugger and tried to find the error but I didnt find anything wrong. Then tried to switch the ROM adress from E000 to C800...now it works. Strange. So everything OK with your file, good work!
Reply 17 of 25, by analog_programmer
I'm sorry for the resurrection of this thread, but I don't see any point to make a new one with the same or very similar topic.
This may be useful, if software in OpROM starts only when no-bootable drive is found. Like Predator99 made an OpROM for ROM Basic: IBM ROM Basic - option ROM for PC clones Is this impossible to be done for software in OpROM?
The word Idiot refers to a person with many ideas, especially stupid and harmful ideas.
This world goes south since everything's run by financiers and economists.
This isn't voice chat, yet some people overusing online communications talk and hear voices.
Reply 18 of 25, by digger
I guess the next cool thing to do with this would be to implement a game cartridge slot in a drive bay.
According to a quick search on-line, an Atari 2600 cartridge (a nice nostalgic form factor to reuse, why reinvent the wheel) is 0.75 inches thick, which means that a cartridge slot for that should fit in a 3.5 inch drive bay, since those are 1 inch in hight.
It shouldn't be hard to repurpose a ribbon cable from a floppy drive to wire such a cartridge slot in a drive bay to an option ROM ISA card similar to this one.
Then have your game image flashed to an EPROM, slot that EPROM into a socket on a game cartridge and presto, we have turned the old IBM PC platform into a game console. 😄
Reply 19 of 25, by analog_programmer
analog_programmer wrote on 2025-09-13, 07:36:
I asked a question. Then acted. And finally got the answer: Yes, it can be done and I did it: Re: IBM ROM Basic - option ROM for PC clones
For convenience (and for the experiment) I may also convert Tronix's compressed games to OpROMs with Predator99's boot loader, 'cause... let's not turn the XT-PC into an 100% arcade machine, but play some old game if it doesn't boot 😀
