Reply 820 of 843, by PC@LIVE
- Oldbie
As for the M725, I noticed that it does not differ much from the M729, in fact it looks like the same motherboard, with some different chips, but both the appearance and the main chips, seem to be the same, looking at my M725 motherboard, and the scrap board that I have, the latter seems to be actually an M729, on the back HW in the BIOS section, you can find in addition to the BIOS of the M729, some BIOS of origin M725, it is clear therefore that the differences are only in detail, and mainly in the renamed chips, here maybe they have simulated the output of a new motherboard, using renamed chipsets, The reality is that those chipsets are exactly the same as before.
Https://theretroweb.com/motherboards/s/ ... -m729#bios
However, to the human eye they will not have appeared, as a clear improvement, in fact they were very cheap cards, and in those years, the quality cost a lot. They were cards used on super cheap PCs, or for updates, the AT format was still ️ quite common, a similar motherboard, could represent a nice step forward, without having to change the entire PC, it was possible to reuse, VGA AGP RAM power supply, ISA or PCI cards, all things that added up cost more than the motherboard.
In the M725 I will initially use a VGA PCI, only later I will switch to a VGA AGP, but not only, I have to recover the Intel PII-300 CPU, which I still have on a Soyo SY-6BA+IV, which I should update to a P!!!-500, in short I will have to deal with several motherboards at the same time.
AMD 286-16 287-10 4MB HD 45MB VGA 256KB
AMD 386DX-40 Intel 387 8MB HD 81MB VGA 256KB
Cyrix 486DLC-40 IIT387-40 8MB VGA 512KB
AMD 5X86-133 16MB VGA VLB CL5428 2MB and many others
AMD K62+ 550 SOYO 5EMA+ and many others
