Reply 40 of 67, by Grzyb
- l33t
Half-Saint wrote on 2025-09-17, 10:44:The difference between type 17 and stason is just landing zone 977 vs. nothing. I switched to using type 17.
It doesn't matter - MR535 uses voice-coil = auto-park.
I did as you guys suggested and managed to boot from a floppy into DOS. Was surprised to see that I can access C: fine. I don't know why the system won't boot. I tried running sys a: c: and despite DOS saying "System transferred", it still says "Non-system disk or disk error replace and strike any key when ready" at boot.
"SYS A: C:" only affects the C: partition.
There may still be some garbage in the MBR - you can try "FDISK /MBR", and make sure the partition is set Active.
Nie rzucim ziemi, skąd nasz root!
