First post, by Linoleum
- Member
Everyone knows the only reason to build a 386 machine is to play Links386, right? But I’m running into a frustrating issue: whenever I move the mouse, parts of the screen either get erased or leave behind weird artifacts.
I’m using a Trident TVGA 8900D with 1MB of VRAM. It supports VESA 1.2 natively, so I figured I was good to go. I even tried Trident’s own VESA driver—no surprise, it didn’t help. UNIVBE was a bust too; no version I tried could detect the card. I swapped in a TVGA 8900CL just to test, and got the exact same results.
So… is this card just hot garbage for Links386, or is there some obscure fix out there that I haven’t found?
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
