Compaq armada 1750
Reply 200 of 210, by Savior_04
Thermalwrong wrote on 2025-05-28, 00:52:
Savior_04 wrote on 2025-05-27, 13:21:
Thermalwrong wrote on 2025-05-27, 03:08:
Sure, I bumped into the same problem recently. It requires a mod to the CD-ROM caddy connector just like the Toshiba laptops: Pr […]
Sure, I bumped into the same problem recently. It requires a mod to the CD-ROM caddy connector just like the Toshiba laptops: Problem with use of modern ATAPI device in 1990s Toshiba 470cdt / 490xcdt / 530cdt and similar retro laptops
My Armada 1700's CD-ROM drive was useless and failing to read everything, so I tried putting a DVD/CDRW drive in and it did what you describe where the laptop wouldn't boot.
The attachment IMG_6622-crop (Custom).JPG is no longer available
I'm not quite sure of the logic because testing in DOS confirms that the CD-ROM is on the primary IDE channel as a slave device, probably a conflict on the IDE channel causes the laptop to not boot when you fit a regular drive:
The attachment IMG_6629 (Custom).JPG is no longer available
The fix was to put a dot of solder between pins 47 and 45 of the flex cable connector that plugs into the optical drive:
The attachment IMG_6626-crop (Custom).JPG is no longer available
Hope that works for other people, still not quite sure of the logic here since the mod I'm doing should force it to be a master on the IDE channel? But it works for me.
Hi, I too have problems with the player not working as it should and I tried to install a player very similar to yours with the modification you recommended but it didn't work for me, it gets stuck on the Compaq screen and the hdd light stays on all the time.
Yeah now I've posted about it, I'm not entirely sure the fix I've suggested is the one that worked. IT's entirely possible I just kept trying different drives til it worked, but I do seem to recall that the little solder bridge did make a difference.
Ok thanks for the clarification. I should be receiving some DVD players soon, I will try to use several with the bridge you recommended and I will write the results.
Retrò Tech is the best.
Reply 201 of 210, by Sowden
Hey ho guys. I'm chiming back in here after being gone for so long. It's taken me a while for me to get back around to working on this laptop. I'm posting this because my Armada is suffering from bad, brittle plastic, and it is cracking near its hindges. I've bought two Armada 1750s, and it has been happening to both 😭 I'm wondering if anyone else here has had a problem with this and what you did to help remedy it. I have been looking at plastic welding and using staples to help fasten the crack. This won't look pretty, but at least it might work. Or I've also seen people use the thickest of guitar pics and welding those. I'm wondering if anyone here's got any other ideas before I pick it up and start working on it. Thanks guys.
Reply 202 of 210, by Joakim
I think I would start look at the root cause, the hingest being too stiff and lubricate them if needed. also see to that it is screwed properly into the frame and is not loose. Maybe you could try to patch the crack from the inside with some cyanoacrylate glue and baking soda. Usually it becomes pretty strong.
Reply 203 of 210, by Sowden
Joakim wrote on 2025-09-21, 12:09:
I think all of these are good ideas. I will try to apply some WD-40 to the hindges joints and make sure they are screwed in tight. I had to do a transplant (remember I said I've bought two?) of one working monitor to one that was not. So I do know how to open it up. And just doing some quick reading, the cyanoacrylate glue (or super glue) and baking soda seems to be the best way to bond it. I will try it myself before I try any plastic welding. Thanks for your help man. I'll chime back in here with pics when I start on this project.
Reply 204 of 210, by Joakim
how did it go?
Reply 205 of 210, by Yedi
Hi Everyone.
I just boght a 1700 with PII 300, Ati 4MB and 1024x768 screen. No HDD. I just run from SSD (32GB) with WIndows 98SE and its fine.
I have an issue with Audio - just no audio at all - no exclamation mark - like nothing.
I created a disk to enter the BIOS and it seems to be fine - I didnt transfer it to any partition to HDD. Audio seems to be enabled there.
Any suggestions ?
Reply 206 of 210, by marxveix
Where you find these old notebooks, i have seen only newer with good (normal) price.
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : Re: ATi RagePro OpenGL files
Reply 207 of 210, by Joakim
Yedi wrote on 2026-05-11, 20:33:
Hi Everyone. […]
Hi Everyone.
Any suggestions ?
I think you can run some tests via one of the disks. I suppose you have tried installing the audio drivers? I have no idea if they are pnp. Tried them in DOS?
marxveix wrote on 2026-05-12, 15:28:
Mostly from old nerds who outgrew the interest on sites like Tradera. But I rarely see any for sale. I used to be an addict to these sites.
But imho these laptops are really not that usefull anymore, as SBEMU exists you are probably better off with a newer thinkpad. The screen is 800x600 and cpu to fast for some older games. I have an ibm ewuivalent as well. never use either of them anymore. The only retro laptop I use personally is the IBM t42p.
Reply 208 of 210, by Yedi
Not working in DOS.
In Windows98SE I'm able to see the Sound Card now (using Add new Hardware) but no sound and only one entry. There are 2 drivers on Compaq - SP9300 and SP9270 - none of them work correctly.
Reply 210 of 210, by Yedi
Some update - Sound is working both DOS (I made a mistake and choose the wrong driver) and also in Windows (here issue was different - I needed to manually update adress (to 220h and irq) - then Sound just started to work - even for DOS games just out of the box !
