First post, by RobertM
Good day, sorry for my English. I am not nature speaker.
I try to play in DosBox 0.74-3 old game Warlords 2.
1) When I use DosBox on Windows10 Pro (last update) and run Warlords 2 mouse work. CTRL+F10 work correctly too.
2) When i use DosBox on Windows11 Pro 24H2 and run Warlords 2 again and mouse not working. CTRL+F10 dont work too.
Somebody know where is problem? Somebody know any solution?
Reply 1 of 1, by ux-3
I just ran into the same problem using dosbox 0.74-3 on a win 11 machine for Warlords 2. It was my first candidate to set up again, so I don't even know if this is a general problem. It runs fine on the 486, so it isn't a broken game.
Edit1: I found the solution for my problem. I had to rerun the install.exe. While I could only configure sound (which worked fine anyway), this also made the mouse work.
Hope this helps the next guy.
Retro PC warning: The things you own end up owning you.
