Reply 240 of 259, by y2k se
Joseph_Joestar wrote on 2025-05-13, 11:51:
Also, for use cases when a LiveDrive is present, I definitively recommend using the original driver CD that came with the card. It's easier that way, as the setup program will usually detect the LiveDrive during the installation process, and configure everything automatically.
What was odd to me was the LiveDrive worked the first few days. After that, I never got the headphone port to function. I thought the LiveDrive had failed, but it started working after the OS and driver reinstall. Hopefully it keeps working more than a few days this time. 😀
Tualatin Pentium III-S 1.4, ASUS TUSL2-C, 512MB RAM, GeForce 4 Ti 4200, Voodoo2, SB Live!, 3Com 3C905C, 80GB IDE HDD, Dell 2001FP
P233MMX, Intel LT430TX, 64MB RAM, Sierra Screamin' 3D, Voodoo2, AWE64 Gold, 3Com 3C905B, 40GB IDE HDD, Viewsonic A75f
Reply 241 of 259, by kikendo
Anybody that could help setting the MS-DOS emnulation up?
Seems like my system hangs when loading the DOS driver for the SB-16 emulator.
I don't have anything on IRQ5 that could conflict, that I know of.
I tried turning off and on the PnP OS option form my BIOS
I do have an Ultra-ATA PCI card running the main drive but I don't think that would be conflicting?
As soon as I skip SBINIT.COM on a step-by-step startup, Windows seems to boot fine. I even see the SB16 Emulation device in the Device Manager.
Reply 242 of 259, by P3pperM1nt
boxpressed wrote on 2020-06-07, 17:50:
I finally got around to testing this method with a CT4830 card that I couldn't get working with ANY Live! installation CD, and . […]
Joseph_Joestar wrote on 2020-06-06, 06:52:
I finally got around to testing this method with a CT4830 card that I couldn't get working with ANY Live! installation CD, and ...
IT WORKS PERFECTLY!
Honestly, I don't know why I'm the only other one posting in this thread. This is such a significant development, especially for people running 98SE on motherboards without an ISA slot. And it's such a great solution for people who want high-quality wavetable sound in later DOS games for the low cost of a Live! card.
It would be hard to beat a Live! + non-PNP OPL3 combo. We're talking the best of both worlds for about $30.
Thanks again for such a great guide. It was well-written and easy to follow. My Device Manager looked a little different with the CT4830, but everything works as it should.
Is it OK to delete C:\AU1 now?
The attachment IMG_9849.jpg is no longer available
Hi there,
I know it’s been a while since your original post, but I’ve recently gotten into retro PCs and I'm currently having trouble with a Sound Blaster Live! model CT4830—same as yours, I believe.
Every time I try to install it, the system freezes during the hardware installation of the VxD driver. I’ve even left it for over three hours, but it never progresses past that point.
Would you mind sharing what steps you took to get yours working? Any tips would be greatly appreciated!
Here’s what I’ve tried so far:
1. Disabled onboard audio
2. Disabled all ports (COM, LPT, USB)
3. Performed a clean installation of Windows 98 (retail version)
Thanks in advance for any help you can provide!
Reply 243 of 259, by nuclear7
Great Guide, everything Works smooth.
Excepto I have a problem with two DOS games, which I wanted to play using sound font the most: Tie fighter and dark forces.
I can't get them to work with general Midi running under windows 98, sound test freezes imediatly.
Hell, even daggerfall, the bitchiest Dos game of ALL time Works and I get beautiful music.
Any tip is apreciated.
Reply 244 of 259, by C0deHunter
Many thanks for this effort!
Question:
What about Windows 2000? I have a PC that has this OS on it, and I would like to know if there is a separate/different procedure (or drivers all together) for Windows 2K?
Many thanks in advance!
PIII-800E | Abit BH-6 | GeForce FX 5200 | 64MB SD-RAM PC100 | AWE64 Gold | Sound Canvas 55 MKII | SoftMPU | 16GBGB Transcend CF as C:\ and 64GB Transcend CF D:\ (Games) | OS: MS-DOS 7.1-Win98SE-WinME-Win2K Pro (multi-OS menu Using System Commander 2K)
Reply 245 of 259, by CarvisJocker
Hi, I have a SB Live! SB0060 but I can’t get DOS games ran from Windows 98 to output MIDI to my SC-55, the music just plays through my speakers from the SB Live. However, if I play a .mid file from Windows it does output to my SC-55. Can anyone help me get DOS games working with this? Thanks
Reply 246 of 259, by Joseph_Joestar
C0deHunter wrote on 2025-09-09, 13:15:
For Win2K and WinXP, use the drivers from the installation CD that came with your card. Or download a newer version from Creative's website.
CarvisJocker wrote on 2025-09-14, 00:11:
It's not possible. Creative hardcoded this limitation into their drivers.
My retro builds
Reply 247 of 259, by mtest001
I noticed that zDoom is able to properly route the Midi through the Windows 98 subsystem and the music plays from my SC-55ST. That is the only example of game that does this to my knowledge. It works with my SB32 PnP, I have not tried with my SB Live!
/me love my P200MMX@225 Mhz + Voodoo Banshee + SB32 PnP + Sound Canvas SC-55ST = unlimited joy !
Reply 248 of 259, by Falcosoft
mtest001 wrote on 2025-09-14, 16:23:
zDoom is not a DOS game. Native Windows programs/games have no such restrictions, they can use any Midi Out ports available on the system.
Website, Youtube
VST Midi Driver Midi Mapper
Reply 249 of 259, by mbguy1
Everything worked for me except in step 7. I went trough to this step into the folders
7.2 C:\Progra~1\Creative\DOSDrv\sbemixer.exe
and got this error
MIX0014: SBEINIT.COM not loaded
Then I tried typing SBEINIT.com and got this error
ERROR: Config file is incomplete.
SBPort
Creative SB16 Emulation Driver not loading.
Not sure if it matters but the rest worked.
Reply 250 of 259, by mbguy1
Joseph_Joestar wrote on 2020-06-02, 14:40:
0.0 Disclaimer: […]
0.0 Disclaimer:
This guide is provided "as is" and free of charge. There is no warranty or support of any kind. By using this guide, you acknowledge and agree that you do so at your sole risk. The author is not liable for any damages and claims arising from the use of this guide.
0.1 Introduction:
This guide will help you install VxD drivers for Sound Blaster Live! cards under Windows 98SE or Windows ME, including proper support for DOS gaming. I have personally tested this method with a Sound Blaster Live! 5.1 (model SB0100). Later on, other people have tested it with additional SBLive models as well, and all information about that has been summarized in this post. For reference, by using this guide, you get the following features from your SBLive card under Win9x:
  • EAX 1 and 2 support for Win9x games
  • Sound Blaster 16 emulation for DOS games
  • FM Synthesis emulation for DOS games
  • General MIDI emulation for DOS games
  • Soundfont support for DOS games running under Windows 98SE
Note that soundfonts only work when DOS games are running from within Windows 98/ME. If you go to pure DOS (by choosing Start > Shutdown > Restart in MS-DOS mode) then the card will use the (worse sounding) ECW sets instead. To my knowledge, there is no way to use .SF2 based soundfonts in pure DOS with an SBLive card.
Lastly, this guide and the modified driver pack that it uses are tailored to the US English version of Windows 98SE or Windows ME. Installing these drivers on a non-English system may cause the volume control screen (and possibly other aspects of the OS) to appear in English.
1.Hardware and software requirements:
Before proceeding to the next section of this guide, make sure that the following hardware and software requirements are met. If they are not, the driver installation may fail.
1.1 Certain chipsets have compatibility issues with VxD drivers and Creative's SB16 emulation. If you have a motherboard based on an Nvidia nForce chipset or an Intel ICH10+ chipset, then your system might not be compatible with this guide. Additionally, certain motherboards based on VIA chipsets may have compatibility issues with SBLive cards. For better stability on VIA systems, I recommend using an Audigy 2 or ZS card instead of a SBLive, and following this guide
1.2 Upon booting up your system, enter the BIOS and disable all COM and LPT ports in order to free up additional resources. If your motherboard has an integrated sound card, network card or any other integrated device that you are not using, disable it in the BIOS as well. Lastly, if you are not using USB, disable that too
1.3 During the driver installation process, the SBLive should be the only sound card in your system. Using a second sound card may cause the driver installation to fail
1.4 This guide has only been tested on Windows 98SE and Windows ME. A clean install of Windows must be performed before attempting the driver installation procedure. Do not use any "unofficial service packs". Only install the drivers for your motherboard and graphics card until you complete all the steps in this guide
1.5 A Sound Blaster Live! requires one free IRQ for the card itself. The value assigned to this IRQ varies from system to system, but it should not be the same as the IRQ assigned to the SB16 emulation device. Additionally, the SB16 emulation device requires three I/O ports, one IRQ and two DMA channels. The default values are: I/O ports 220, 330 and 388, IRQ 5, DMA 1 and DMA 5. If any of those resources are not free, the driver installation may fail. To determine if your system has enough free resources, under Windows 98SE click Start > Programs > Accessories > System Tools > System Information > Hardware Resources and check the IRQ, DMA and I/O sections
2. Preparation:
2.1 Download the modified SBLive driver CD image, and burn it to a disc
2.2 Place the disc in the CD-ROM drive on your Win98SE/ME machine, and cancel the autorun installer in case it starts
2.3 This guide assumes that your CD-ROM drive resides at D: (default location). If it's using a different letter, simply substitute that letter each time you come across D: in this guide
3. Windows Driver Installation
3.1 Run D:\CTShared\LaunchApp\SysInfo\Setup.exe which will install the Creative System Information utility and update the InstallShield Engine (important later)
3.2 Run D:\DirectX\dxsetup.exe which will install DirectX 9.0a and restart your computer (if you already have a newer version installed, skip this step)
3.3 Run D:\Audio\Drivers\CTZAPXX.exe and select "Driver Installation" and "VXD Drivers" then click Ok
3.4 Driver installation will take several minutes, don't interrupt the process until you are prompted to Restart then click Ok
3.5 After the restart, wait until the installer finishes, then go to Start > Settings > Control Panel > Multimedia > Audio > Playback > Advanced Properties > Performance > Sample Rate Conversion Quality > move the slider to "Best"
3.6 Start > Run > sndvol32.exe > Ok. Note that all the volume sliders are currently at 50% which is fairly quiet. You might want to move the sliders to a higher value and also mute any unused inputs
4. Installing Creative Utilities
4.1 Run D:\Audio\AudioHQ\Setup.exe and install Creative AudioHQ (if you get an InstallShield Engine error here, repeat step 3.1)
4.2 Run D:\Audio\Diagnose\Setup.exe and install Creative Diagnostics
4.3 Run D:\Audio\Restore\Setup.exe and install Creative Restore Defaults
4.4 Run D:\Audio\SurMix2\Setup.exe and install Creative Surround Mixer
4.5 Start > Programs > Creative > Creative AudioHQ > Speaker and select the speaker setup that you are using, then click "Test" (in the screenshot below I'm using 5.1 speakers)
The attachment Speakers.jpg is no longer available
5. DOS Driver Installation
5.1 Run D:\DOSDRV\Setup.exe and restart when prompted
5.2 Wait until the Creative SB16 Emulation drivers are fully installed (this may take a few minutes)
5.3 During the boot process you might see a "Config file incomplete" error. Restart your computer one more time and it should disappear
If the installation was successful, you should now have the following under Device Manager:
The attachment 002.png is no longer available
6. Using a higher quality soundfont
6.1 Go to the D:\DOSDRV\SF2 folder and copy all the .SF2 files from there to C:\WINDOWS\SYSTEM
6.2 Go to the D:\DOSDRV\ECW folder and copy all the .ECW files from there to C:\WINDOWS\SYSTEM
6.3 Start > Programs > Creative > Creative AudioHQ > SoundFont
6.4 Click on "Configure Bank" then click on the default soundfont (2GMGSMT Rev N++) to select it, then click Replace, select C:\WINDOWS\SYSTEM\CT8MGM.SF2 wait a few seconds until it loads then click Ok > Close
6.5 Open C:\WINDOWS\CTSYN.INI in Notepad and change this line: Waveset=C:\WINDOWS\SYSTEM\default.ecw to this: Waveset=C:\WINDOWS\SYSTEM\EAPCI8M.ECW
6.6 Save the changes you just made to CTSYN.INI then restart your computer
6.7 Run your favorite DOS game and in setup choose General MIDI for music
The attachment AudioHQ_SoundFont.jpg is no longer available
For reference, here's how your games will sound with Creative's CT8MGM soundfont. Essentially, with this step complete, you can now select any soundfont that you like for General MIDI playback in DOS games. For example, if you want to use a soundfont which more closely resembles a Roland Sound Canvas see this post. Alternatively, if you want to play games which use GS instruments, see this post.
7. Getting MT-32 compatibility in pure DOS (optional for Win98SE, not applicable for WinME)
7.1 Start > Shutdown > Restart in MS-DOS mode
7.3 Make sure that the MT-32 option is checked, then click Save and press ESC to exit
7.4 Run your favorite DOS game that supports MT-32 (like Monkey Island for example)
Note that MT-32 emulation doesn't sound too great on this card, but I'm including it for completeness sake.
That said, these drivers also allow your SBLive to emulate FM Synthesis, should you want that. Of course, this sounds different from a genuine OPL3 chip, but it may still be somewhat usable, depending on the game that you're playing.
and got this error
SBPort
Reply 251 of 259, by Joseph_Joestar
mbguy1 wrote on 2025-09-21, 15:47:
Whether the drivers will work in pure DOS depends mostly on your motherboard, specifically the chipset that it uses.
While SB16 emulation from within Win9x will work fine on most chipsets up to around Intel ICH9, pure DOS is a different story. This is especially true for OEM systems.
My retro builds
Reply 252 of 259, by SoryuDragon
Thank you Joseph Jouster, your guide helped. I installed my CT4830 and followed your guide, everything worked as expected.
Strange how after all these years nobody has been able to find and post the original drivers/CD for this card. Well at least, not that I have found.
Cheers, eh?
Reply 253 of 259, by Joseph_Joestar
SoryuDragon wrote on 2025-10-28, 01:07:
Cheers, eh?
Glad the guide worked out well for you. Enjoy!
My retro builds
Reply 254 of 259, by Siran
I have an original driver CD for that card and there's also one here https://www.vogonsdrivers.com/index.php?catid … menustate=60,53. I believe there were different versions of the CT4830, and I once gave my driver CD to another user with a CT4830, but it didn't work for his card. My CT4830 is a "SB Live! 1024" card:
The attachment 20230407_120202.jpg is no longer available
The attachment 20230603_223546.jpg is no longer available
Even though I have the original driver CD for my card which works, I prefer this guide here as it ensures the best compatibility and you don't get any bloatware like you do when installing from the driver CD.
Reply 255 of 259, by Yancakes
Also chiming in from the future to say this was a big help - not only on my own computer, but on a computer I'm setting up for a friend that just wants to play Duke Nukem 3d and Doom 🤣 😀 Full music and SFX in both!
I actually printed this guide out and tucked it in with my Win98 essentials case!
Reply 256 of 259, by Joseph_Joestar
Yancakes wrote on 2025-11-16, 18:56:
Always good to hear success stories like this. Have fun gaming! 😄
My retro builds
Reply 257 of 259, by fabiensanglard
I have a SB0100 and almost everything works. I am not able to bring up the SB16 emulation settings tab. It looks like this.
The attachment sblive_zombi.png is no longer available
I have seen screenshots where there is a Settings tag, where I can see what IRQ is used for DOS. I don't have that tab and I have no idea why. Without these info I cannot run the setup for DUKE3D.EXE 😒 !
The attachment sb_live_dos_emualtion.webp is no longer available
Anybody else has encountered this issue?
Reply 258 of 259, by NeoG_
fabiensanglard wrote on 2026-01-16, 02:22:
The settings tab depends on the driver version, it's a bit more convenient informational readout only. You can see and adjust the IRQ/DMA/Addresses used in the Resources tab.
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 259 of 259, by fabiensanglard
Thank you so much @NeoG it had not made the connection, I saw an address range there without making the connection with DMA. I was indeed able to see everything in the resource tab. I immediately noticed that the IRQ 9 was not selectable in Duke3d's setup.exe.
The attachment irq.png is no longer available
I had to switch to manual mode but I was able to find an IRQ not used by Windows.
The attachment irq_change.png is no longer available
After that, all my DOS games are working like a charm!
The attachment irq_change_success.png is no longer available
I am still wondering why the GUI is different? Is it a different driver version? I tried with two cards, a SB0100 and a CT4830 with the same result. Perhaps we need to install a different driver to get the nice UI?
