Reply 30180 of 31030, by tehsiggi
zuldan wrote on 2025-09-23, 19:16:
tehsiggi wrote on 2025-09-23, 17:40:
Found a possible memory tester for R200 based cards. Will verify tomorrow and if successful, add the notes on the usage into the repair collection thread. I'll test a 9100, 9000 and 9200. We'll see..
This would be awesome. I think R6MEMID does older cards than the R300.
It in fact does. I just collected some info and did some testing on it:
Re: VGA Repair report collection
So if anyone needs to memory test R200/RV250/RV280 cards, there is a good way to do it.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30181 of 31030, by TheAbandonwareGuy
Is Betrayal At Krondor one of those DOS games that simply doesn't work under Win9x DOS?
I keep getting "Not Enough Memory". Tried EMS and XMS.
Reply 30182 of 31030, by DarthSun
TheAbandonwareGuy wrote on 2025-09-24, 18:58:
Loew limitmem for config.sys ?
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 30183 of 31030, by dominusprog
Connect the line-out of the AWE64 (MB_PRO) to AUX input of the Diamond MX300. I've used tree jumper wires (L/R and one ground) and use a connector of CD-ROM audio cable for one end (the AUX input).
The attachment IMG_20250925_142808.jpg is no longer available
Reply 30184 of 31030, by NeoG_
dominusprog wrote on 2025-09-25, 11:10:
Love to see it, I wish more cards had headers for internal connections
98/DOS Rig: BabyAT AladdinV, K6-2+/550, V3 2000, 128MB PC100, 20GB HDD, 128GB SD2IDE, SB Live!, SB16-SCSI, PicoGUS, WP32 McCake, iNFRA CD, ZIP100
XP Rig: Lian Li PC-10 ATX, Gigabyte X38-DQ6, Core2Duo E6850, ATi HD5870, 2GB DDR2, 2TB HDD, X-Fi XtremeGamer
Reply 30185 of 31030, by dominusprog
NeoG_ wrote on 2025-09-25, 12:16:
Yes, it's great. You can also can connect the header to an amplifier and an internal speaker.
Reply 30186 of 31030, by fsinan
Opened this non-used, brand new viking edo-ram package for my new 5x86 rig.
They seem to be 60ns and working at tightest timings at 40Mhz bus.
I recommend, if you find one of them, buy them, they are of highest quality.
System:1
Cyrix 5x86-120GP & X5-160ADZ
Lucky Star LS-486E
System:2
Intel DX4-WB & AMDDX4-120
PcChips M912 V1.7
System:3
AMD K6-2-475 & Cyrix 6x86MX PR-233
Asus P5A-B
System:4
UMC U5S-40
486UL-P101
System:5
P3 Coppermine 800EB
Gigabyte GA-6BX7
Reply 30187 of 31030, by Thermalwrong
tehsiggi wrote on 2025-09-24, 10:33:
It in fact does. I just collected some info and did some testing on it: […]
Thanks for documenting it 😀 I do have a couple of Radeon 9200 type cards to test so a proper memory tester will help a great deal with that.
In regards to card repair, I've been trying to fix a Radeon HD 4650 AGP that had two resistors knocked off of the back. The pictures online are all not great but I found that the two transistors near the back of the AGP connector connect to the last pin, the VREFGC pin. I think that's for detecting the type of AGP slot its connected to and I have a Sapphire HD 1950 which uses the same AGP to PCI-E bridge. Then I worked out that the transistors and resistors are hooked up just the same on that and the HD4650 to work out that I was missing a resistor marked 17A (147 ohms) and a teeny tiny one at 200 ohms. Gotta test that card out soon, haven't got a good test setup right now for AGP cards.
I've been trying to get my Sony PRD-650 working better, I have awful luck with these. They're really cool tiny SCSI CD-ROM drives but it seems like the laser is always cooked on them, see my attempts to repair a PRD-250: Re: What retro activity did you get up to today?
Got frustrated with that and did some scanning / archiving of documents I've got that aren't online anywhere. I've done this before but was using LibreOffice Draw to make PDF files and didn't know how to optimise the images for PDF usage, so I've been learning how to process the images as 1-bit PNG files and automate the creation of PDF files from those images with OCR. A mix of img2pdf and ocrmypdf have done a fantastic job of putting together space efficient PDF files without manual intervention, once all the images are processed and in the right order. Going over my previous PDFs I was able to get the size of one that was 10MB down to less than 1MB with searchable text and with lossless compression.
Making these PDFs manually is something I've done before but when a document is over 200 pages long, that takes quite a while and has a lot of room for errors to occur.
So now I've shared two new documents I've got that I'm not aware of being online at all til now, those are:
Kapok 6200A (6200AT / 6200AD) user manual, which covers the MMX models and how to set all the voltage / CPU dip switch settings: https://archive.org/details/6200at-user-guide
Toshiba PORTABLE SERVICE BOOKLET - I got this a few years ago on the bay and it's a small handbook covering specs, disassembly and memory maps of Toshiba laptops up to around 1995. I had thought that the maintenance manuals covered all this information already so didn't bother scanning it, til I was fixing a Toshiba T1800 and found that the images showing the screw locations / lengths are all missing from the maintenance manuals.
240 pages covering all these models: T100X, T200 series, T1800, T1850 series, T1900 series, T1900S, T1910 series, T1950 series (same as T1960 series), T2100 series, T2150CD series, T2200SX, T2400 series, T2450CT
https://archive.org/details/toshiba-portable- … e-booklet-vol-1
This is just volume one, Volume Two is longer and covers all these ones: T3300SL, T3400CT, T4400 series, T4500 series, T4600 series, T4700CT, T4800CT, T4850CT, T4900CT, T6400 series and T6600C
I wish I knew how to add bookmark information into these PDF files.
EDIT: Ooh, I can *fix* the maintenance manuals and put those on the Internet Archive too 😁 Just done the Toshiba T1800 maintenance manual successfully which has all the original graphics.
The process is pretty arcane but it works - get the scans from toshiba ATLAS 95, use Irfanview batch convert to make them into PNG because they're crazy fax encoded TIF files. Then use ImageMagick to convert them to 1-bit PNG at the correct DPI, then use img2pdf and ocrmypdf to make a PDF of those. Now to figure out bookmarks!
Reply 30188 of 31030, by Muckrake
Did some troubleshooting with my IBM PCjrs, one of which has trouble with the monitor display, and the other with the monitor speaker. The display shows about half its colors too dark, and the contrast knob doesn't work. Every so often, the display will suddenly start showing all the colors correctly, then stay that way for a few months before going dark again (for the colors in question). The trouble with the monitor speaker is it sometimes cuts out the PC beeper, so it comes through the CPU speaker, and not the monitor speaker like it should. Turning up the volume seems to fix it, at least temporarily. Not sure why. Got no solutions yet.
Reply 30189 of 31030, by tehsiggi
Thermalwrong wrote on 2025-09-25, 15:15:
The VREFGC and VREFCG pins are used for the reference voltages of the AGP I/O. In spec it's meant to help with offsets in ground voltages. Therefore the graphics card generates a reference voltage it sends to the mainboard (VREFGC) so the board knows the cards reference voltage. Vice-versa the Mainboard sends a reference voltage as well via the VREFCG to the graphics card.
Some mainboards use this, some don't.
The reference voltage should be VDDQ/2 if AGP is not version 3.0. If it is AGP 3.0, the voltage is supposed to be VDDQ*0.233.
Without it, the system basically doesn't know the threshold value between high and low and the data communication is not working.
Glad you got your card fixed!
Attached some reference schematic from one of my projects..
Reply 30190 of 31030, by Standard Def Steve
I'm just playing with an old Pentium II-300 before it hits the autumn garage sale scene. The hard drive has Windows XP on it of all things! Because the software allows me to do so, I've connected it to my network to play high res FLAC audio just to satisfy some raging curiosity.
~3200 kb/s, 24 bit, 96 KHz stereo audio uses roughly 10% of the CPU
~5600 kb/s, 24 bit, 192 KHz stereo audio uses roughly 18% of the CPU
~8400 kb/s, 24 bit, 96 KHz 5.1-ch audio uses roughly 44% of the CPU
Honestly, I thought it would do worse! The files all played thru fine, and I could even multitask whilst listening to the stereo tracks (the 5.1 jittered a little when I tried starting other programs).
But ugh...all those bits per second sounded rather ugly thanks to the grit and tizz injected by the Sound Blaster Live Value card. I had honestly forgotten just how noisy computers used to be, just how much crud our poor ears dealt with!
Of course, when this machine was in daily use, websites were still presenting us with choices of 28k, 56K, and "hi-speed" 128K listening options--all with relatively shite codecs to boot. I suppose the grit wouldn't have mattered as much back then; we had other problems!
"A little sign-in here, a touch of WiFi there..."
Reply 30191 of 31030, by NeoG_
I find my CT4830 SB Live! Value quite pleasant to listen to haha, as long as it's not a shoutcast radio stream
Reply 30192 of 31030, by H3nrik V!
Hopefully I rescued a Slot 1 Celeron 300A SL32A.
Wouldn't boot - but reason was kinda obvious. So I started scraping solder resist of the traces, but found that the dent was deep. Looks like there is copper underneath too. Hopefully it's just a ground or power plane (would make sense from a general layout point of view).
So I had to route the new connections a little more out of harm's way. Hoping that it's not really critical impedance wise - and that the stub on one trace doesn't mess up too much. I'd like to run at at 450 😁
Originally I didn't think I could be bothered with fixing it, rather buying another one ... Then I saw the 'bay prices ...
Reply 30193 of 31030, by GigAHerZ
GigAHerZ wrote on 2024-07-23, 11:09:
I was trying to figure out, what mechanism i could have to attach SLOT1 coolers to the CPUs. I think i figured it out. You'll ne […]
You'll need:
* M3 screws with length of about 25mm (16mm is very uncomfortable to work with)
* M3 nuts
* 4mm wide and 5mm long springs
* Nylong/plastic washers for M3 with outer diameter of 6mm.
I think this is very workable solution.
Depending on the cooler, you may or may not need a washer there. (on picture, the holes were too big for the springs)
So long, mf-ing plastic "plugs" or whatever!
So, some time has passed and i was able to use my (improved) technique on re-attaching SLOT 1 heatsinks to processors.
Reply 30194 of 31030, by PD2JK
That looks good with those springs, there's no core crushing that way.
i386 16 ⇒ i486 DX4 100 ⇒ Pentium MMX 200 ⇒ Athlon Pluto 700 ⇒ AthlonXP 1700+ ⇒ Opteron 165 ⇒ Dual Opteron 856
Reply 30195 of 31030, by bjwil1991
Diagnosed the IBM 5150 to see why it won't turn on. Capacitors are shot, so I ordered some off of Amazon so I can recap the motherboard, video card, and floppy controller.
My plan is to use the 1.44MB floppy drive in the system using the XT-FDC card from my dead Compaq Portable XT in the system and I need to get a dual 5.25" drive adapter to make it as a full one with the hard drive bracket that has the LED on it so I can connect it to my XT-CF card.
Once I get the motherboard recapped along with the video card and original floppy controller, I'll make a BIOS ROM that has the latest version so I can upgrade the RAM on my AST SixPakPlus SPK-384 to 576K RAM and have 640K entirely.
Reply 30196 of 31030, by PcBytes
Repaired a Voodoo 3 that I got for cheap. 3000 AGP model.
And.. had to trash a few cooked-beyond-any-repair R350s.
Reply 30197 of 31030, by Living
GigAHerZ wrote on 2025-09-27, 08:40:
You'll need:
* M3 nuts
its a nice long term solution if you dont mess too much with it, otherwise i would preffer the nuts on the outside or zip ties
Reply 30198 of 31030, by StriderTR
Was looking over a Game Gear a family member found to see if it worked so they could sell it. Powers on. LED works. Screen works. Backlight works. But... dead.
Seems the caps inside leaked, but did little to no damage. I'm 85% sure that's the problem, it's a known issue with these units. Inside of it's storage case was full of crystalized residue.
Could replace them all for about $9 and a couple hours of work to see....but they decided to just sell it off as-is for someone else to fix since it's not guaranteed to work after the recap.
Would have been a fun repair. 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 30199 of 31030, by dominusprog
Since the power supply I'm using (A-Open ATX-250GT) has one connector for a 3.5" floppy drive and I want to install two drivers, I've made this. I'll replace the jumper wires with a real connector later.
The attachment IMG_20250927_212646.jpg is no longer available
