VGA Repair report collection
Reply 40 of 49, by The Serpent Rider
I assume the PCB also had all the necessary caps preinstalled?
Reply 41 of 49, by dm-
yes, all components were in place.
a good news is that gddr3 has termination on die, there is no "hundreds of resistors" around the chip, like in case of ddr1
Reply 42 of 49, by dm-
got this BFG7800GS from scrap.
The attachment 7800.jpg is no longer available
with a little problem: does not start.
checking HSI bridge chip and some pci-e lines were lost + cracked smd capacitor in pci-e line.
HSI chip reflow and connection to pci-e has been restored.
[attachment=-1]7800-2.jpeg[/attachment]
Reply 43 of 49, by tehsiggi
Glad to see that card back in action. They're in the top of the line region for AGP. And it's always fascinating to see how different the approach of rialto vs. HSI design was back in the day.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 44 of 49, by tehsiggi
Gainward Ti4600 - No signal when booting into Windows [FIXED] - A repair of a Geforce 4 Ti4600 - screen going blank under 3d and later on even under windows, underclocking did not yield an results. No visible damage. Recapping (especially) C1263, C1267 and C1271 solved the issue. Card is fully functional. Caps where looking okay, but one had severely degraded capacitance. Done by zuldan
Reply 45 of 49, by dm-
got this blue FX5900 Turbo (and not so turbo) for repair.
The attachment photo_2025-10-13_06-32-51.jpg is no longer available
missing VMEM, ripped memory pads...
The attachment photo_2025-10-13_06-32-54.jpg is no longer available
The attachment photo_2025-10-13_06-33-08.jpg is no longer available
The attachment photo_2025-10-13_06-33-14.jpg is no longer available
but it is alive and working!
The attachment photo_2025-10-13_06-32-48.jpg is no longer available
Reply 47 of 49, by tehsiggi
A successful repair of a Radeon 9700 Pro: ATI 9700 Pro Broken [FIXED]
Starting the card in a system directly prompted full screen artefacting, though it appears like a repeating pattern, indicating memory issues. After running R3MEMID in a automated fashion (so that the display issues don't matter) revealed errors on all four memory channels (MDA, MDB, MDC and MDD). This lead to the measurement of all power rails on the card, revealing that MVDDQ (used for memory I/O by both the memory ICs and the GPU) is not up to the desired voltage (1.13V instead of 2.8V). The rail resistance measured normal (card disconnected from the system), leading to the conclusion that the power delivery of the rail appears faulty. An attempt was made to investigate the ISL6522 is in overcurrent protection. During the process the dual FET of the rail got disconnected from the board. Replacing it fixed the power rail and fixed the whole card.
Repair done by zuldan
Reply 48 of 49, by dm-
not a report but a conversion to pc version of ATI Radeon 9800XT Mac edition.
Found this piece another day on scrapyard:
The attachment xt01.jpg is no longer available
tried to use in my Asus P3c-D -)))
The attachment xt02.jpg is no longer available
Reflashed to x86 Radeon XT firmware and made a cut in AGP pro connector on the card to be able to fit regular Agp 8x.
An external 6-pin power connector has been attached to the board to provide external 12v power supply.
The attachment xt03.jpg is no longer available
Unfortunately, only vga output is available.
Lower connector is a proprietary Apple ADC connector which is required a special ADC-DVI converter,
and the upper one in MAC version is using external SIL transceiver which is not available in PC card version bios.
The attachment xt04.jpg is no longer available
