First post, by altarofmelektaus
Anyone have this version in high quality, by chance? I could've swore I once saw it online (reverse image searching seems to be pretty much useless nowadays, go figure) but now it's pretty much lost media. What can be found are the versions with a different starburst/text render, but that's not what I'm after. If anyone would know, I'm sure this would be the place 🤣
Reply 2 of 14, by altarofmelektaus
I couldn't find an official high res scan of this logo (if any of you have the mousepad it was printed on, please scan it!) so here's my attempt at upscaling and redrawing parts. I think it's as good as it will get:
Reply 5 of 14, by rasteri
Given that it's rendered in 3D, one could presumably extract the geometry from the driver and make an arbitrary-res version in blender or whatever
Reply 6 of 14, by H3nrik V!
altarofmelektaus wrote on 2025-09-26, 11:49:
Absolutely beautyful!
Should be posted in the background wallpaper thread!
[edit] background->wallpaper
Reply 7 of 14, by nali
To build my Arduino thing, I used a good definition video I found.
First download the video.
https://github.com/yt-dlp/yt-dlp
Quote: "By default, yt-dlp tries to download the best available quality if you don't pass any options. "
$ yt-dlp https://www.youtube.com/watch?v=_8UvDRc_rdo
$ mkdir pictures
$ ffmpeg -i The\ Classic\ 3DFX\ logo\ \(in\ HQ\)\ \[_8UvDRc_rdo\].mp4 pictures/animation3dfx%d.png # ( or jpg, bmp, etc)
$ ls pictures/ | wc -l
443
Congratulations ! Now you have 443 frames extracted from the video in the directory "pictures" , with a 1280x720 size. Of course, this is just the image size, not sure we can't find better definition. But I doubt the original spining logo was in 4k.
The final logo is about image 340.
The image in the first post is better quality than the ones I got with this method.
Reply 8 of 14, by B24Fox
altarofmelektaus wrote on 2025-09-25, 11:38:
I had this on my HDD.
It's higher res than your original picture, but it's only the text.
Maybe you could overlap it over your image(slightly zoomed-in to match perfectly), and then try another upscale with possibly even better and more acurate results.
The attachment old Logo.jpg is no longer available
L.E.
And also found this online in PNG format.
Text seems to be the same size; just has more "white" around it. Probably it's the original, and mine was just cropped.
The attachment 3dfx.png is no longer available
Reply 9 of 14, by darry
FWIW, here's the new logo animation.
EDIT: Through a Windows game capture of Dgvoodoo2 output
The attachment 3dfx_new_logo.zip is no longer available
Reply 10 of 14, by darry
And here's what I believe is the old logo animation.
EDIT: I know the Gamma is off, but I can't set it properly when capturing and I'm really tired now. Maybe I'll give it another go later.
The attachment 3dfx_old_logo.zip is no longer available
Reply 11 of 14, by darry
Here's another attempt with better levels.
EDIT : A bit blown out, I think. For some reason, I can't eyeball it (not having a color managed workflow for video doesn't help).
The attachment 3dfx_old_logo_b.zip is no longer available
Reply 12 of 14, by darry
nali wrote on 2025-09-27, 16:50:
To build my Arduino thing, I used a good definition video I found. […]
$ mkdir pictures
443
That's from a video capture of the logo animation 3dfxSpl2.dll from dosbox-2010-03-22-custom-glide.zip as rendered by an oldish version of NGlide being used by Glquake (through 3Dfx's minigl). I could not get the newer versions of NGlide to capture using Windows' game capture.
AFAIK, that 3dfxSpl2.dll only works with NGLide. I could not get it work with anything else. Maybe this will give someone an idea as to how to get better results than mine.
The attachment logo.png is no longer available
Reply 13 of 14, by altarofmelektaus
B24Fox wrote on 2025-09-28, 00:41:
I had this on my HDD. It's higher res than your original picture, but it's only the text. Maybe you could overlap it over your […]
L.E.
This looks to be the original digital file for it supplied to consumers or for marketing purposes. Thank you! I wonder if anyone possibly has the original render file though, as I've seen a photo of a mousepad with the high resolution old logo. That is probably long gone and in Nvidia's vault somewhere, I imagine
Reply 14 of 14, by altarofmelektaus
rasteri wrote on 2025-09-27, 13:33:
That's a good point. This would probably be the cleanest way to go about things, if only I didn't dread using Blender.
