Voodoo 2 TMU Broken Pin
First post, by aspiringnobody
Hello all,
I bought a broken (as-is) V2 from eBay expecting to need to replace the TMU. However now that it’s here, I’ve been able to inspect the damage and I’ve found that the only pin that’s actually broken is pin 27, which I believe is VCC.
Anyone have any thoughts on just disconnecting that pin entirely? Assuming I can get the pin out from behind pin 28 (it’s wedged behind it) without breaking pin 28, do you think missing one VCC connection will cause any damage?
I’ve ordered a TMU just to have one in stock, but if I can avoid the micro-soldering I would prefer to, since changing the TMU is IMO very risky.
The attachment IMG_7766.jpeg is no longer available
The attachment IMG_7768.jpeg is no longer available
Reply 1 of 5, by aspiringnobody
It's not salvageable. It has the same (creative only?) issue where the legs move even though the solder is still attached (aka the solder has gone soft). Since all the legs are bent massively, the instant you try to reflow them they all move off their pad. A lot of pads are lifted in the damaged area. I tried pushing them back for maybe a half hour, but I needed to "lift" the legs above the pad, otherwise the leg just pushed the pad out of the way.
It was a mess. I tried to remove it with hot air but whatever solder creative used is so corroded it wouldn't flow properly -- I ended up having to use low-melt solder.
I decided to remove the chip before one of the pads broke off. They're all still there, thankfully. Hopefully I'll be able to attach a new chip. I'm not quite sure how I'm going to do that since neither of my go-to methods will work here (can't use hot air, can't drag solder). It will be interesting.
Reply 2 of 5, by Postman5
Broken pins can be repaired. It's not difficult at all.
Reply 3 of 5, by aspiringnobody
Postman5 wrote on 2025-10-04, 23:44:
I did try this once a few years ago, without much success -- but I do have much better gear now than I did then...
I thought about attempting the repair, but the broken pin wasn't really the problem (I actually went so far as to get a tiny carbide burr put in my dremel). It was the 6 or so pins to the right of the broken pin that were both bent and had soft solder. As soon as I touched the first one with the iron to try to reflow the bad creative solder it took off into the next pin over. All of the pads were loose from the impact damage so I got the distinct impression that the longer I messed with it the more likely I was to break a pad -- and the next four after the broken pin all went UNDER the chip.
I decided I had better quit while I was ahead and pull the chip while the pads were mostly where they belonged. I put some UV solder mask down to try to hold it and I'll give it a go throwing a new TMU on it when it arives.
Reply 4 of 5, by nali
There's a lot of video about those fix on Youtube.
See "vswitchzero" and "Bits und Bolts".
Reply 5 of 5, by aspiringnobody
This is fixed! New framebuffer transplanted into this board and she’s back in action! Interestingly, I never noticed until I did this that the framebuffer has a lot more pins than the TMUs. That’s probably why I had such a hard time the last time I tried to fix a broken leg. I bet it’s much easier on the TMU…
The attachment IMG_7777.jpeg is no longer available
