mouse dosbox
First post, by stfark
:happy:I have Win XP Pro, SP2, using dosbox with a microsoft Fortran program and using the debug workbench program called "CodeViw". All seems to work fine with dosbox except for one thing, when I first start the program, the mouse pointer on the screen works properly, moves with the mouse movement. However, when I "click" on any item, "pull-down" menu, etc., the mouse pointer goes away, I can no longer use the mouse. It was suggested that this is because the command "AutoLock" was false, I set it to true and the same thing happend. Anybody have any ideas why this is happening? please let me know, Sid Kraft. 😀
Reply 1 of 4, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
Press ctrl+F10 to get it back.
1+1=10
Reply 2 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
if you mean the problem that the mouse becomes unusable inside because the cursor is missing,
We would have to debug that program of yours as I already indicated in the emails you send.
Water flows down the stream
Reply 3 of 4, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 4 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
I fixed the problem btw
008-08-03 17:52  qbix79
* src/ints/mouse.cpp: Make the mouse struct a bit smaller. ignore
mouse.page in text mode, always use current page. Fixes CV RENUM.
