Battle of the platforms: socket 754!
Reply 80 of 860, by AlexZ
I have Arctic Cooling Freezer 64 Pro. It's a great cooler for benchmarking as it can cool many CPUs comfortably and fits s754 as well as AM3+. I also have that stock heatpipe AMD cooler but I don't use it. I would recommend to get either, they are super cheap these days and fit many boards.
My s754 build uses Thermaltake Max Orb, full copper version. Fan runs at 1300 rpm. https://www.techpowerup.com/review/thermaltak … -max-orb/3.html
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 81 of 860, by Archer57
Nice that you have identical cards. I do have both pci-e and AGP 1950pro too, but pci-e one is 256MB while AGP one is 512MB and from my testing on s939 the difference between them is quite significant, making comparison pointless...
Regarding h264 - software is the issue. Even on HD2000 cards. Yes, hardware support is there, but it is limited in certain ways which make it not usable with modern players while old, period correct, players often did not have hardware decoding support at all.
Similar issues with GF7 - partial decoding acceleration is there, but actually using it is nearly impossible.
AthlonXP 2200+,ECS K7VTA3 V8.0,1GB,GF FX5900XT 128MB,Audigy 2 ZS
AthlonXP 3200+,Epox EP-8RDA3I,2GB,GF 7600GT 256MB,Audigy 4
Athlon64 x2 4800+,Asus A8N32-SLI Deluxe,4GB,GF 8800GT 1GB,Audigy 4
Core2Duo E8600,ECS G31T-M3,4GB,GF GTX660 2GB,Realtek ALC662
Reply 82 of 860, by nd22
6. Storage devices: as much as I would liked to use SSD half of the boards refused outright to run with a SSD connected! In fact only 2 out of 4 accepted a SSD. On VIA K8T800 PRO with the VT8237 there is a known problem when only SATA 150 drives are accepted or SATA 300 that can be jumpered to SATA 1.5 speed. On nforce3 despite trying multiple brands no SSD worked. Unfortunately I do not have a Sand force based SSD so I could not trick the boards into accepting flash based storage!
Reply 83 of 860, by nd22
For that reason and because I wanted to see if a classic hard drive runs OK and with max speed I choose the WD raptor 150gb ADFD version as the standard drive for benchmarks on all systems. It is the fastest SATA 150 drive manufactured and the capacity is more than OK for the software that I installed.
The 2 boards that accepted SSD’s got as secondary drives WD raptors and all storage tests have been performed on that drive!
Reply 84 of 860, by nd22
7. Optical drive: I put in whatever DVD-RW I had laying around. The only mention is the K8T00 chipset where I had to use an IDE drive because no SATA DVD is accepted by the infamous VT8327.
Reply 85 of 860, by nd22
8. Power supply: socket 754 has an enormous advantage: the ability to use modern power supplies. You are no longer bound to some old/specific PSU with good 5V rail; you can safely use your modern PSU with it. All the boards have the auxiliary power connector and some even have the 24 pin connector.
Reply 86 of 860, by nd22
9. Case: I used the cooler master force 500 case because it allows mounting the PSU on top and has both 5.25 and 3.5 inch bays! It is a no frills black case just the way I like it - no RGB, pure black - but still provides options for 2 120 mm fans – 1 installed in the back from the factory and 1 by me on the side panel! Ventilation is excellent despite the low end nature of the case.
Reply 87 of 860, by nd22
10. Floppy drive: GOTEK all the way.
Reply 88 of 860, by marxveix
Archer57 wrote on 2025-10-06, 07:14:
I use GF7600 h264 acceleration and i am sure i can use x1950 acceleration as well, i have one screenshot. Wait, i look for it.
it was some random h264@720p and Media Player Classic Home Cinema+PowerDVD7 codec under its skin (DXVA working)
Here it is, look here: Re: ATi Radeon 9550/9600/9600 PRO RV351 Die Shrink - 110nm chips
Direct screenshot link: download/file.php?id=203298&mode=view
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / GLUT / DVD : ATi RagePro drivers and software
33+MiniGL / OpenGL Win 9x dll files for all ATi-Rage3 based cards : ATi RagePro OpenGL files
Reply 89 of 860, by nd22
As all the boards used are from Abit so you will see again a “few” of them – all from my collection.
First is the one based on nforce3! Abit NF8 series encompass several models; all with the same basic chipset: nforce3 250. Coming after a resounding victory in the socket 462 comparative, nforce3 has the first chance to win the performance crown!
Several basic variations with the same PCB are available:
1. NF8-V2 with the basic nforce3 250 and 100 MB onboard LAN
2. NF8-V with the nforce3 250GB chipset; gigabit LAN frees up precious CPU resources.
3. NF8 with nforce3 250GB and fire wire controller that nobody is interested in!
4. NF8-V PRO with nforce3 250GB and optical inputs and outputs that nobody uses!
5. NF8 PRO with nforce3 250GB and everything of the above!
Reply 90 of 860, by nd22
Left to right:
NF8 PRO - the full version with all the bells and whistles; NF8-V PRO - with S/PDIF that I never seen used; NV8-V - all you ever need from a nforce3 board!
Reply 91 of 860, by nd22
Notice the 24 pin ATX connector - useful if you have some low end power supply that will not let you detach 4 pin from the main ATX connector! You can clearly see the Winbond controller used for monitoring temperatures and voltages.
Reply 92 of 860, by nd22
Typical for all nforce3 boards, the SATA connectors are in the middle of the board frustrating any attempt of cable management! The chipset found under the blue heatsink gets pretty toasty even after thermal paste replacement so good case cooling is necessary!
Reply 93 of 860, by nd22
Memory compatibility, NVidia style: each of the 3 boards accepts only specific kits from certain manufacturers, in this case Kingston. Corsair also works but anything else is a no go! The cooler is more than adequate for any socket 754 CPU!
Reply 94 of 860, by nd22
BIOS: minimum voltages for minimum temperatures; AGP aperture size is 256 MB on all the systems!
Reply 95 of 860, by nd22
Memory timings are all on AUTO, that means 3-3-3-8 with CR 1T - yes, the board automatically sets command rate to 1T using AUTO settings with ALL CPU's!
Reply 96 of 860, by nd22
BIOS has been set for maximum performance: anything not needed is disabled such as floppy controller, serial and parallel ports, IDE ports, cool and quiet and so on. Temperatures are pretty good even after long benchmarking sessions!
Reply 97 of 860, by nd22
As you guessed from the photos above the processor installed is Athlon 64 3400 Clawhammer; it will be the first to go through the benchmarks suite. SATA DVD works without a hitch, but no SSD.
CPU-Z legacy shows most of the details:
Reply 98 of 860, by nd22
..but misses a crucial one:
Reply 99 of 860, by Archer57
nd22 wrote on 2025-10-07, 05:51:
In this case nvidia has nothing to do with memory though, memory controller is in the CPU and is made by AMD. And yes, from my experience with s939 it can be even worse than nforce2 memory controller. At least with unbuffered memory - i've had much better success with registered memory.
