Reply 20 of 35, by gonzo
Successful delidding of a Ryzen 5 5600G having this ugly metal like the Phenom 980, too: SUCCESSFUL DELIDDING of AMD-CPUs (so. 754-AM4) by modding of an Intel-Core-delidding-tool available on the market
I did the test just because to see, if a Ryzen can be delidded at this way. I did not expect to find the same metal under the lid. The CPU-core goes NOT broken.
I LOVE CPUs RUNNING IN [GonzoHz]
Reply 21 of 35, by Nemo1985
The question is, under the ihs what is going to be used? Some other thermal paste? Then in years it will dry again or liquid metal? Is it safe to use between core and ihs?
Reply 22 of 35, by The Serpent Rider
Liquid metal is not safe to use with pure copper. If IHS has exposed copper inside, don't try.
Reply 23 of 35, by AlexZ
You would just use MX-6. Since the die is quite large, you could go bare die. It would work as long as the cooler doesn't need the original plastic frame and you can apply pressure from both sides simultaneously.
Liquid metal is rarely needed. I have AMD Ryzen 9 7945HX in laptop and I got rid of the liquid metal as it has too short lifespan. It may give you 2'C lower temperature, but that typically isn't enough. A more powerful cooling system is more useful than liquid metal.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Athlon 64 3400+,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2 ZS
Phenom II X4 955,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 24 of 35, by gonzo
The Serpent Rider wrote on 2025-10-06, 13:17:
That's correct! To make it easy, you can delid another CPU (e.g. a much cheaper or a defective one) from the same generation having just thermal grase and without pure copper on the lid, and use this lid instead of the original lid. Of course, in this case, the CPU-model shown on the lid will be wrong...
Reply 25 of 35, by gonzo
AlexZ wrote on 2025-10-06, 13:32:
.....liquid metal as it has too short lifespan. It may give you 2'C lower temperature....
To be honest, I do not agree - liquid metal gives you compared to thermal grease about 15-20 degrees Celsius less temperature. But yes, a good cooling system is still needed.
Reply 26 of 35, by wierd_w
I am reading that indium will alloy with gallium if both are made liquid first, and that the resulting alloy has an even lower melting point than pure gallium.
That suggests the die can maybe be cleaned with a tiny amount of liquid metal conduction medium (which is mostly gallium), and gentle heating at a hot air workstation.
Once it's alloyed, the Indium-Gallium complex is supposed to stay liquid at room temp, so a suction tube, and a quality paper towel should get you a nice clean die afterward.
At least in theory.
Indium is not really safe to handle though. Please use appropriate precautions. (While the metal form is generally nontoxic, any salts made from it, through exposure to active cations, are quite unpleasant. )
Reply 27 of 35, by Ozzuneoj
This is a serious question, not trying to be negative... but, what is the purpose of the delidding that is going on in this thread? Especially with newer CPUs, Ryzen, etc. there is almost nothing gained even by lowering temperatures. These chips are pushed near the absolute maximum from the factory and the binning processes have become so good that there is very little left for enthusiasts to do aside from undervolting with curves\PBO2 tuning.
Here is a good example:
https://www.youtube.com/watch?v=y_jaS_FZcjI
Der8auer delidded a 7900X and used liquid metal for direct die cooling and managed a 3% performance improvement in Cinebench with all cores pegged at 5.5Ghz (a minor increase over stock cooling) despite lowering temps 18-20C at peak load. The crazy thing is that the 7000 series is known for deliberately pushing chips to high temperature limits to achieve the highest clock speeds, so if any modern architecture should benefit from cooling mods like this, you'd think this one would. Of course, you can manually jack up the voltages more now that there is more thermal head room. How long these chips will last in those circumstances, however, I don't know.
I can use negative core offsets on my 5800X3D to bring temps and power consumption down while having a slight gain in performance and I can run all of the fans in my PC so that they are inaudible at idle and barely audible during a heavy gaming load. No hardware modifications were needed to achieve this. Just good air cooling and somewhat decent thermal paste.
If the goal is to try to preserve these chips by keeping them at lower temperatures, I guess that's an admirable goal, I just don't know if there will be real world benefits. Personally, I'd trust an untouched CPU to still work properly 20-30 years from now versus one that was delidded part way through its lifespan.
EDIT: It's hard to convey the tone of this post, but it is not combative or trying to tell you not to delid CPUs. I am just genuinely curious what the goal is.
Reply 28 of 35, by swaaye
The last one I bothered to delid was a 8600K and only because Intel had switched from solder to thermal paste which is just awful if you want to try to overclock. I replaced the paste with Coollaboratory Liquid Ultra. Though yes even with a very substantial drop in load temp it still hit a wall at around 4.8 GHz. It is kind of silly to even try to push further because the power consumption multiplies. And with Alder Lake and newer the heat flux is more or less unmanageable.
Reply 29 of 35, by nfraser01
Ozzuneoj wrote on 2025-10-05, 05:02:
My googles are failing me. Do you know of any articles or posts that delve into this and show results of before and after applying new TIM under the IHS of an old CPU to lower temps? All I'm finding are people either delidding new (unsoldered) chips to apply liquid metal under the IHS or running them with a bare die. Both are just done to decrease temps for extreme overclocking.
Athlon 64 overheat issue
Reply 30 of 35, by The Serpent Rider
Yeah, desktop Intel CPUs after Sandy Bridge had paste for a while, which is a pain to deal with after using CPU for 5+ years.
Reply 31 of 35, by swaaye
Oh yeah a few years ago I had a Socket 939 Opteron 180 (equivalent to an Athlon 64 X2) that had thermal paste that was not performing anymore and it would overheat very easily. I don't know how common that might be but I have a number of other Socket 939 CPUs that are ok.
Reply 32 of 35, by Grem Five
I just retired my I7 8700k this year and even though I thought about deliding it but for over 7+ years it never suffered from any temp increase and had no problem running at 5.0 to 5.1 Ghz. That machine had daily use for the entire time with the same original AIO I had on it too.
Reply 33 of 35, by gonzo
Ozzuneoj wrote on 2025-10-06, 17:00:
...what is the purpose of the delidding that is going on in this thread? Especially with newer CPUs, Ryzen, etc. there is almost nothing gained even by lowering temperatures.
Well, I initially started last week with delidding of an Opteron 185, as it goes simply too hot (= unstable) with the thermal grase by factory under the lid at a frequency of about 3 GHz - this was the mean reason for me to delid an AMD-CPU (as I've never done this before).
Now, using liquid metal, it can reach 3047 GHz (FSB 277 MHz x 11,0 and 1,55 VCore) at temperatures of about 48 degrees Celsius using a Zalman CNPS9700 (after 1 hour stress-test in Aida64).
Even more than that - an Opteron 180 (I have too) can reach the same frequency at the same conditions (I can upload some pictures, if desired). So my focus was on socket 939 only.
After the delidding of the Opteron, I just asked myself, if other models/generations of AMD-CPUs can be delidded, too, as I was able to adopt the tool for delidding of Intel-CPUs offered by "Der8Auer" - so this modification could have a wider range of use (e.g. if someone decides to change its old AMD-generation with a newer one). So the efforts for the modification of the Intel-tool will be more effective -that's all.
Of course, the OC-potential of some CPU-generations is not big (or: it variies by the CPU-model).
The other problem is - it seems to be so, that there is missing information (missing list) of the AMD-CPUs having this STIM-application under the lid (and so they do not really benefit from a delidding and from using of liquid metal).
About the Ryzen: the main reason for OCing of a Ryzen could be in case of a slower/cheaper CPU with thermal grease used inside (BTW as for any other CPU-generation, too).
Reply 34 of 35, by Ozzuneoj
gonzo wrote on 2025-10-07, 08:32:
Well, I initially started last week with delidding of an Opteron 185, as it goes simply too hot (= unstable) with the thermal gr […]
Thanks for explaining. 🙂
It might be interesting to make a dedicated "what TIM do different AMD CPUs use" thread, with a list in the first post stating which thermal interface materials are found within the various chips you have delidded, and with contributes added based on the comments of others. It seems this information is a bit scattered around the internet.
Of course, having a clear distinction between the different types of TIM that are actually used would be important. Like, I think indium solder is the standard these days for soldered chips but I have no idea how far back that goes.
Reply 35 of 35, by gonzo
Ozzuneoj wrote on 2025-10-07, 16:08:
I agree with you, sadly I do not have much more CPUs for delidding (there are just a few).
It will be by far not enough for such a topic (thread)....
