Reply 100 of 927, by nd22
- l33t
At this moment most of you will jump: are you out of your mind??? but CO revision with command rate 1T is impossible!!! Period correct reviews mentioned the need for CG revision in order to set CR 1T!!
Even Phil says so in this video and all from Intel versus AMD season 1:
https://www.youtube.com/watch?v=rGWUfpzjaBw&l … 7DrGus&index=67
I am fully aware that Phil is a god in the retro world and I am just a nobody! However Phil used a board with integrated graphics and I got an Abit. You will also see that some of my results do not align with Phil's and i will explain later why.
