Reply 30240 of 30247, by H3nrik V!
aspiringnobody wrote on Today, 04:18:
My upgraded V2 found its forever home today!
The attachment IMG_7765.jpeg is no longer available
Nice! What are the specs?
Reply 30241 of 30247, by bakemono
I was going to try fixing up some 40 year old PCB from a car, but there is something weird about it. Unsoldering a component released some unusually unpleasant fumes, and I found that the old solder joints repelled any attempt to add new solder which would just ball up and roll away. Can't remember having this problem before.
GBAJAM 2024 submission on itch: https://90soft90.itch.io/wreckage
Reply 30242 of 30247, by dominusprog
Recapped this VIBRA16 sound card.
The attachment IMG_20251007_125024.jpg is no longer available
Reply 30243 of 30247, by DarthSun
Asus A6R: I didn't think it would be such a great retro, I liked it, it's good that my friend called to ask if it was necessary, or he would throw it away.
I plugged it into the test bench monitor via DSub, so it fits FHD as needed, and now fulltrack/3DM99:
The attachment AsusA6R_99_Full.jpg is no longer available
The attachment AsusA6R_Sum_FHD.jpg is no longer available
The attachment 1SBK_CL.jpg is no longer available
The attachment 1A6R_FR.jpg is no longer available
The 3 body problems cannot be solved, neither for future quantum computers, even for the remainder of the universe. The Proton 2D is circling a planet and stepping back to the quantum size in 11 dimensions.
Reply 30244 of 30247, by DarthSun
Under DOS I knew it would bite:
The attachment 1_LM2_A6R.jpg is no longer available
The attachment 1_Shiny_A6R.jpg is no longer available
The attachment 1_3DB_A6R.jpg is no longer available
The attachment SSTIMG07.jpg is no longer available
SBEmu - sound is also ok:
The attachment 1_SBEmu_A6R.jpg is no longer available
I haven't tried the LPT and PCMCIA ports. SD reader ok. DVDRW ok - IDE interface.
Perfect working and nice condition, good thing it didn't end up in the trash.
Reply 30245 of 30247, by BitWrangler
bakemono wrote on Today, 07:51:
I am gonna guess the board is maybe a phenolic type which when overheated gets a bit formaldehyde-y. Then the solder might be a low tin, maybe even silver solder which is higher temperature and doesn't form tin whiskers in low temperatures. Might have to look out SAE or military specs for solder from that era. I remember also that GM somehow managed to make some PCBs in the late 80s that had steel leads on some components and steel bus bars, some of which were rivetted and welded to each other rather than soldered. So test with magnet that you're not trying to desolder a weld, and if it's broke, you may need a different flux to put solder on it, cooking oil may work.
Reply 30246 of 30247, by andrea
DarthSun wrote on Today, 10:47:
You should be able to upgrade the cpu to a T7200 or some sort of Merom-2M of for less than 5€, it may be worth it especially considering the notebook looks practically brand new.
Don't bother with high end stuff (T7400 or higher) as they cost way too much for what they are and the single channel memory controller would hold it back somewhat.
Even if you use it only for single threaded programs, you get more cache, speedstep and better IPC. Just upgrade the bios first.
Reply 30247 of 30247, by DarthSun
andrea wrote on Today, 18:35:
You should be able to upgrade the cpu to a T7200 or some sort of Merom-2M of for less than 5€, it may be worth it especially con […]
Thanks for the info! I think I have all kinds of models in my CPU collection. There are 1000 of them at the moment. I don't even have to spend money on expansion 😀
