Reply 20 of 41, by DustyShinigami
Or not. Can't get any of them to work. 😒 One complains that I shouldn't have HIMEM enabled when it isn't in my config or autoexec files, and the MATS for DOS ones I don't know how to use. 😮
The only one that worked was the Video Memory Test CD/Windows version:
Changing video mode to 640x480x16...OK WARNING: Do not place other windows over program window! INFORMATION: Only one mode can b […]
INFORMATION: Only one mode can be tested now, all others will not match.
[07/10/25 22:48:53] Test started for "Primary Display Driver (NVIDIA RIVA TNT)"...
Trying 16bpp RGB:565 mode...OK
Trying 16bpp RGB:555 mode...NOT MATCH WITH CURRENT
Trying 16bpp BGR:565 mode...NOT MATCH WITH CURRENT
Trying 32bpp RGB:888 mode...NOT MATCH WITH CURRENT
Trying 32bpp BGR:888 mode...NOT MATCH WITH CURRENT
[07/10/25 22:50:53] Pass completed (0 errors found).
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 21 of 41, by asdf53
Go to the VMCE folder, there is a readme that explains the options. You'd have to set "Save test log to file" and "Video memory size" (in extended options). And optionally "Perform small test set" for it to finish faster.
But before continuing with a possibly misbehaving VMCE, why not try the MATS tool that a fellow member suggested. It's a floppy image file, you have to write it to a floppy and then boot from it. "RawWrite" and "WinImage" would be tools for creating the floppy. I can't run the tool myself as I have no Nvidia card installed, it outputs a message that the card is unsupported.
Reply 22 of 41, by DustyShinigami
asdf53 wrote on 2025-10-08, 05:51:
Okay, I'll give that a bash a bit later. Both the small test and the MATS tool. 😀
OS: Windows 98 SE
Reply 23 of 41, by DustyShinigami
Well, it went through the 'simple' test, which still took a good hour, but there was no point in keeping the log. It's just a looooooong list of error after error after error. I'm still not sure it's conclusive or accurate as everything works fine. In Windows and in games. And as I've said already, the Windows/CD version reports no errors. So I'm going to try another utility first and see if that reports anything.
OS: Windows 98 SE
Reply 24 of 41, by DustyShinigami
Nope. Can't get the other utilities (MATS) to work. Just tried extracting the image file to a floppy disk, but nothing works in DOS or Windows. I just get an error. No tests run. 🙁
OS: Windows 98 SE
Reply 25 of 41, by asdf53
What error do you get with MATS? You didn't literally extract the image file onto the disk, right? You need to write it in raw mode (Disk-> Write Disk if using WinImage). For what it's worth, I tested the MATS floppy in an emulated x86box machine and on some motherboards, it crashed with a cryptic error message, so if that happened to you, it could be incompatible with your board.
Reply 26 of 41, by DustyShinigami
asdf53 wrote on 2025-10-08, 15:59:
Yeah, I kinda did. ^^; I can't remember the type of errors I got now, but I think they were exception errors...? I'll have to make a note of them next time. Also, can't seem to write the files to an actual floppy disk. The image totals 1.44MB and my floppies are only 1.38. I do have my flash floppy drive and USB, but I still need to look into how to use USBs in DOS.
EDIT: Yeah, whenever I try and format and set up the floppy in WinImage I keep getting these errors:
The attachment winimage_nW30Y5TBvx.png is no longer available
OS: Windows 98 SE
Reply 27 of 41, by asdf53
Tried RawWrite for writing the image? That's what I usually use. Make sure that your floppy drive type is set to 3.5" 1.44MB in the BIOS.
Reply 28 of 41, by DustyShinigami
asdf53 wrote on 2025-10-08, 17:12:
I haven't, no. I'll give that a try next. Thanks. 😀 And yeah, I believe the floppy drive is set to 3.5" 1.44.
OS: Windows 98 SE
Reply 29 of 41, by DustyShinigami
That tool worked perfectly, so thanks for that. 😁 But sadly, it's still not working. Every time it tries to run it says: ERROR: Start location (0) is greater than end location (0).
OS: Windows 98 SE
Reply 30 of 41, by asdf53
It seems that it's trying to get the starting and ending location of the video memory to test it, but fails. That's interesting because it could be the same problem that causes VMCE to stumble. The readme of VMCE mentions that by default, it's using VBE (BIOS routines of the graphics card) to query these memory locations. Could it be that the video BIOS is corrupt?
Does that MATS error happen with both cards? If yes, then that theory is likely wrong. If it only happens with the defective card, here's another thing you could try, VMCE has an option "Try to get video memory size via PCI routines". See if that makes a difference for the defective card.
Also, VMCE shows "Total video memory" and "Address range" in the info section while the test is running. Does the memory size match with the actual size, and does the Address range have a plausible value?
If your motherboard's BIOS has options such as "Video BIOS Shadow" or "Video BIOS cacheable" (don't remember the exact name), set them to disabled to make sure the tools are accessing the card's BIOS directly.
Reply 31 of 41, by DustyShinigami
asdf53 wrote on 2025-10-08, 19:08:
It seems that it's trying to get the starting and ending location of the video memory to test it, but fails. That's interesting […]
Yeah, I think I enabled a number of those options when I did a custom small test with my TNT. It says the memory is 16,777,216, which is right. Not sure about the Address Ranges though. They're D6000000-D6FFFFFF and the Product Version is A5.
I put the Geforce 4 back in and loaded the MODS test and the test ran. I got a load of blocky colours and then this at the end:
Still can't upload pics here. Thought it might be my VPN, but disabling that makes no difference. 😒
https://postimg.cc/gXbk0hLk
I also have the Video BIOS Shadow option in the BIOS. I've disabled that.
OS: Windows 98 SE
Reply 32 of 41, by asdf53
That's great, it worked! The result is pretty clear, the card has defective memory. If your card has 4 memory chips, one of them is defective. If it has 8, then either one or two are defective. If your card has electrolytic capacitors, there's a very small chance that a failing one near a chip could cause errors - but if the test results don't vary between runs, that's unlikely. Do you plan to repair the card?
Reply 33 of 41, by DustyShinigami
asdf53 wrote on 2025-10-08, 20:32:
Okay. I mean, I was pretty sure that Geforce 4 was knackered anyway. It's just my Riva TNT that's confusing me. The tests give nothing but errors, except the Windows one, and yet everything runs fine. I did encounter a lockup in Nocturne twice when the first line of dialogue was spoken, but I figured it was because the card couldn't handle the game. And it worked fine with the Geforce 4. Until the other night.
I could just do with another test utility to work with this TNT to make double sure if there is something wrong with it. But as for the Geforce 4 - no. There's no point in repairing it. It didn't cost me much and it's just not worth it. I'll try and get a Ti next.
Also, nothing looks out of the ordinary. No capacitors are bulging etc.
The attachment IMG_4948.JPG is no longer available
The attachment IMG_4950.JPG is no longer available
OS: Windows 98 SE
Reply 34 of 41, by DustyShinigami
Decided to run through the VMT with my TNT again and got the log, if anyone's interested.
This is literally what it's like all the way through. Had to chop most of it out as I exceeded my character limit. ^^;
LOG FILE: "1". [8.10.25 20:53:04] Test started... Processing offscreen... Error at [00FF0000] must be FF, but found 0F (bits: 11 […]
LOG FILE: "1".
Error at [00FF0000] must be FF, but found 0F (bits: 11110000)
Error at [00FF0001] must be FF, but found 00 (bits: 11111111)
Error at [00FF0002] must be FF, but found 18 (bits: 11100111)
Error at [00FF0003] must be FF, but found C6 (bits: 00111001)
Error at [00FF0004] must be FF, but found EF (bits: 00010000)
Error at [00FF0005] must be FF, but found 03 (bits: 11111100)
Error at [00FF0006] must be FF, but found EF (bits: 00010000)
Error at [00FF0007] must be FF, but found 03 (bits: 11111100)
Error at [00FF0008] must be FF, but found EF (bits: 00010000)
Error at [00FF0009] must be FF, but found 03 (bits: 11111100)
Error at [00FF000A] must be FF, but found EF (bits: 00010000)
Error at [00FF000B] must be FF, but found 03 (bits: 11111100)
Error at [00FF000C] must be FF, but found EF (bits: 00010000)
Error at [00FF000D] must be FF, but found 03 (bits: 11111100)
Error at [00FF000E] must be FF, but found EF (bits: 00010000)
Error at [00FF000F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0010] must be FF, but found EF (bits: 00010000)
Error at [00FF0011] must be FF, but found 03 (bits: 11111100)
Error at [00FF0012] must be FF, but found EF (bits: 00010000)
Error at [00FF0013] must be FF, but found 03 (bits: 11111100)
Error at [00FF0014] must be FF, but found EF (bits: 00010000)
Error at [00FF0015] must be FF, but found 03 (bits: 11111100)
Error at [00FF0016] must be FF, but found EF (bits: 00010000)
Error at [00FF0017] must be FF, but found 03 (bits: 11111100)
Error at [00FF0018] must be FF, but found EF (bits: 00010000)
Error at [00FF0019] must be FF, but found 03 (bits: 11111100)
Error at [00FF001A] must be FF, but found EF (bits: 00010000)
Error at [00FF001B] must be FF, but found 03 (bits: 11111100)
Error at [00FF001C] must be FF, but found EF (bits: 00010000)
Error at [00FF001D] must be FF, but found 03 (bits: 11111100)
Error at [00FF001E] must be FF, but found EF (bits: 00010000)
Error at [00FF001F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0020] must be FF, but found EF (bits: 00010000)
Error at [00FF0021] must be FF, but found 03 (bits: 11111100)
Error at [00FF0022] must be FF, but found EF (bits: 00010000)
Error at [00FF0023] must be FF, but found 03 (bits: 11111100)
Error at [00FF0024] must be FF, but found EF (bits: 00010000)
Error at [00FF0025] must be FF, but found 03 (bits: 11111100)
Error at [00FF0026] must be FF, but found EF (bits: 00010000)
Error at [00FF0027] must be FF, but found 03 (bits: 11111100)
Error at [00FF0028] must be FF, but found EF (bits: 00010000)
Error at [00FF0029] must be FF, but found 03 (bits: 11111100)
Error at [00FF002A] must be FF, but found EF (bits: 00010000)
Error at [00FF002B] must be FF, but found 03 (bits: 11111100)
Error at [00FF002C] must be FF, but found EF (bits: 00010000)
Error at [00FF002D] must be FF, but found 03 (bits: 11111100)
Error at [00FF002E] must be FF, but found EF (bits: 00010000)
Error at [00FF002F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0030] must be FF, but found EF (bits: 00010000)
Error at [00FF0031] must be FF, but found 03 (bits: 11111100)
Error at [00FF0032] must be FF, but found EF (bits: 00010000)
Error at [00FF0033] must be FF, but found 03 (bits: 11111100)
Error at [00FF0034] must be FF, but found EF (bits: 00010000)
Error at [00FF0035] must be FF, but found 03 (bits: 11111100)
Error at [00FF0036] must be FF, but found EF (bits: 00010000)
Error at [00FF0037] must be FF, but found 03 (bits: 11111100)
Error at [00FF0038] must be FF, but found EF (bits: 00010000)
Error at [00FF0039] must be FF, but found 03 (bits: 11111100)
Error at [00FF003A] must be FF, but found EF (bits: 00010000)
Error at [00FF003B] must be FF, but found 03 (bits: 11111100)
Error at [00FF003C] must be FF, but found 0F (bits: 11110000)
Error at [00FF003D] must be FF, but found 00 (bits: 11111111)
Error at [00FF003E] must be FF, but found 18 (bits: 11100111)
Error at [00FF003F] must be FF, but found C6 (bits: 00111001)
Error at [00FF0040] must be FF, but found EF (bits: 00010000)
Error at [00FF0041] must be FF, but found 03 (bits: 11111100)
Error at [00FF0042] must be FF, but found EF (bits: 00010000)
Error at [00FF0043] must be FF, but found 03 (bits: 11111100)
Error at [00FF0044] must be FF, but found EF (bits: 00010000)
Error at [00FF0045] must be FF, but found 03 (bits: 11111100)
Error at [00FF0046] must be FF, but found EF (bits: 00010000)
Error at [00FF0047] must be FF, but found 03 (bits: 11111100)
Error at [00FF0048] must be FF, but found EF (bits: 00010000)
Error at [00FF0049] must be FF, but found 03 (bits: 11111100)
Error at [00FF004A] must be FF, but found EF (bits: 00010000)
Error at [00FF004B] must be FF, but found 03 (bits: 11111100)
Error at [00FF004C] must be FF, but found EF (bits: 00010000)
Error at [00FF004D] must be FF, but found 03 (bits: 11111100)
Error at [00FF004E] must be FF, but found EF (bits: 00010000)
Error at [00FF004F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0050] must be FF, but found EF (bits: 00010000)
Error at [00FF0051] must be FF, but found 03 (bits: 11111100)
Error at [00FF0052] must be FF, but found EF (bits: 00010000)
Error at [00FF0053] must be FF, but found 03 (bits: 11111100)
Error at [00FF0054] must be FF, but found EF (bits: 00010000)
Error at [00FF0055] must be FF, but found 03 (bits: 11111100)
Error at [00FF0056] must be FF, but found EF (bits: 00010000)
Error at [00FF0057] must be FF, but found 03 (bits: 11111100)
Error at [00FF0058] must be FF, but found EF (bits: 00010000)
Error at [00FF0059] must be FF, but found 03 (bits: 11111100)
Error at [00FF005A] must be FF, but found EF (bits: 00010000)
Error at [00FF005B] must be FF, but found 03 (bits: 11111100)
Error at [00FF005C] must be FF, but found EF (bits: 00010000)
Error at [00FF005D] must be FF, but found 03 (bits: 11111100)
Error at [00FF005E] must be FF, but found EF (bits: 00010000)
Error at [00FF005F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0060] must be FF, but found EF (bits: 00010000)
Error at [00FF0061] must be FF, but found 03 (bits: 11111100)
Error at [00FF0062] must be FF, but found EF (bits: 00010000)
Error at [00FF0063] must be FF, but found 03 (bits: 11111100)
Error at [00FF0064] must be FF, but found EF (bits: 00010000)
Error at [00FF0065] must be FF, but found 03 (bits: 11111100)
Error at [00FF0066] must be FF, but found EF (bits: 00010000)
Error at [00FF0067] must be FF, but found 03 (bits: 11111100)
Error at [00FF0068] must be FF, but found EF (bits: 00010000)
Error at [00FF0069] must be FF, but found 03 (bits: 11111100)
Error at [00FF006A] must be FF, but found EF (bits: 00010000)
Error at [00FF006B] must be FF, but found 03 (bits: 11111100)
Error at [00FF006C] must be FF, but found EF (bits: 00010000)
Error at [00FF006D] must be FF, but found 03 (bits: 11111100)
Error at [00FF006E] must be FF, but found EF (bits: 00010000)
Error at [00FF006F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0070] must be FF, but found EF (bits: 00010000)
Error at [00FF0071] must be FF, but found 03 (bits: 11111100)
Error at [00FF0072] must be FF, but found EF (bits: 00010000)
Error at [00FF0073] must be FF, but found 03 (bits: 11111100)
Error at [00FF0074] must be FF, but found EF (bits: 00010000)
Error at [00FF0075] must be FF, but found 03 (bits: 11111100)
Error at [00FF0076] must be FF, but found EF (bits: 00010000)
Error at [00FF0077] must be FF, but found 03 (bits: 11111100)
Error at [00FF0078] must be FF, but found EF (bits: 00010000)
Error at [00FF0079] must be FF, but found 03 (bits: 11111100)
Error at [00FF007A] must be FF, but found EF (bits: 00010000)
Error at [00FF007B] must be FF, but found 03 (bits: 11111100)
Error at [00FF007C] must be FF, but found EF (bits: 00010000)
Error at [00FF007D] must be FF, but found 03 (bits: 11111100)
Error at [00FF007E] must be FF, but found EF (bits: 00010000)
Error at [00FF007F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0080] must be FF, but found 18 (bits: 11100111)
Error at [00FF0081] must be FF, but found C6 (bits: 00111001)
Error at [00FF0082] must be FF, but found 18 (bits: 11100111)
Error at [00FF0083] must be FF, but found C6 (bits: 00111001)
Error at [00FF0084] must be FF, but found EF (bits: 00010000)
Error at [00FF0085] must be FF, but found 03 (bits: 11111100)
Error at [00FF0086] must be FF, but found EF (bits: 00010000)
Error at [00FF0087] must be FF, but found 03 (bits: 11111100)
Error at [00FF0088] must be FF, but found EF (bits: 00010000)
Error at [00FF0089] must be FF, but found 03 (bits: 11111100)
Error at [00FF008A] must be FF, but found EF (bits: 00010000)
Error at [00FF008B] must be FF, but found 03 (bits: 11111100)
Error at [00FF008C] must be FF, but found EF (bits: 00010000)
Error at [00FF008D] must be FF, but found 03 (bits: 11111100)
Error at [00FF008E] must be FF, but found EF (bits: 00010000)
Error at [00FF008F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0090] must be FF, but found EF (bits: 00010000)
Error at [00FF0091] must be FF, but found 03 (bits: 11111100)
Error at [00FF0092] must be FF, but found EF (bits: 00010000)
Error at [00FF0093] must be FF, but found 03 (bits: 11111100)
Error at [00FF0094] must be FF, but found 18 (bits: 11100111)
Error at [00FF0095] must be FF, but found C6 (bits: 00111001)
Error at [00FF0096] must be FF, but found 18 (bits: 11100111)
Error at [00FF0097] must be FF, but found C6 (bits: 00111001)
Error at [00FF0098] must be FF, but found EF (bits: 00010000)
Error at [00FF0099] must be FF, but found 03 (bits: 11111100)
Error at [00FF009A] must be FF, but found EF (bits: 00010000)
Error at [00FF009B] must be FF, but found 03 (bits: 11111100)
Error at [00FF009C] must be FF, but found EF (bits: 00010000)
Error at [00FF009D] must be FF, but found 03 (bits: 11111100)
Error at [00FF009E] must be FF, but found EF (bits: 00010000)
Error at [00FF009F] must be FF, but found 03 (bits: 11111100)
Error at [00FF00A0] must be FF, but found EF (bits: 00010000)
Error at [00FF00A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF00A2] must be FF, but found EF (bits: 00010000)
Error at [00FF00A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF00A4] must be FF, but found EF (bits: 00010000)
Error at [00FF00A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00A6] must be FF, but found EF (bits: 00010000)
Error at [00FF00A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00A8] must be FF, but found EF (bits: 00010000)
Error at [00FF00A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00AA] must be FF, but found EF (bits: 00010000)
Error at [00FF00AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00AC] must be FF, but found EF (bits: 00010000)
Error at [00FF00AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF00AE] must be FF, but found EF (bits: 00010000)
Error at [00FF00AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF00B0] must be FF, but found EF (bits: 00010000)
Error at [00FF00B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF00B2] must be FF, but found EF (bits: 00010000)
Error at [00FF00B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF00B4] must be FF, but found EF (bits: 00010000)
Error at [00FF00B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00B6] must be FF, but found EF (bits: 00010000)
Error at [00FF00B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00B8] must be FF, but found EF (bits: 00010000)
Error at [00FF00B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00BA] must be FF, but found EF (bits: 00010000)
Error at [00FF00BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00BC] must be FF, but found EF (bits: 00010000)
Error at [00FF00BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF00BE] must be FF, but found EF (bits: 00010000)
Error at [00FF00BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF00C0] must be FF, but found EF (bits: 00010000)
Error at [00FF00C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF00C2] must be FF, but found EF (bits: 00010000)
Error at [00FF00C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF00C4] must be FF, but found EF (bits: 00010000)
Error at [00FF00C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00C6] must be FF, but found EF (bits: 00010000)
Error at [00FF00C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00C8] must be FF, but found EF (bits: 00010000)
Error at [00FF00C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00CA] must be FF, but found EF (bits: 00010000)
Error at [00FF00CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00CC] must be FF, but found EF (bits: 00010000)
Error at [00FF00CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF00CE] must be FF, but found EF (bits: 00010000)
Error at [00FF00CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF00D0] must be FF, but found EF (bits: 00010000)
Error at [00FF00D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF00D2] must be FF, but found EF (bits: 00010000)
Error at [00FF00D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF00D4] must be FF, but found EF (bits: 00010000)
Error at [00FF00D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00D6] must be FF, but found EF (bits: 00010000)
Error at [00FF00D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00D8] must be FF, but found EF (bits: 00010000)
Error at [00FF00D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00DA] must be FF, but found EF (bits: 00010000)
Error at [00FF00DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00DC] must be FF, but found EF (bits: 00010000)
Error at [00FF00DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF00DE] must be FF, but found EF (bits: 00010000)
Error at [00FF00DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF00E0] must be FF, but found 18 (bits: 11100111)
Error at [00FF00E1] must be FF, but found C6 (bits: 00111001)
Error at [00FF00E2] must be FF, but found 18 (bits: 11100111)
Error at [00FF00E3] must be FF, but found C6 (bits: 00111001)
Error at [00FF00E4] must be FF, but found EF (bits: 00010000)
Error at [00FF00E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00E6] must be FF, but found EF (bits: 00010000)
Error at [00FF00E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00E8] must be FF, but found EF (bits: 00010000)
Error at [00FF00E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00EA] must be FF, but found EF (bits: 00010000)
Error at [00FF00EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00EC] must be FF, but found 0F (bits: 11110000)
Error at [00FF00ED] must be FF, but found 00 (bits: 11111111)
Error at [00FF00EE] must be FF, but found 18 (bits: 11100111)
Error at [00FF00EF] must be FF, but found C6 (bits: 00111001)
Error at [00FF00F0] must be FF, but found EF (bits: 00010000)
Error at [00FF00F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF00F2] must be FF, but found EF (bits: 00010000)
Error at [00FF00F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF00F4] must be FF, but found EF (bits: 00010000)
Error at [00FF00F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF00F6] must be FF, but found EF (bits: 00010000)
Error at [00FF00F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF00F8] must be FF, but found EF (bits: 00010000)
Error at [00FF00F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF00FA] must be FF, but found EF (bits: 00010000)
Error at [00FF00FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF00FC] must be FF, but found EF (bits: 00010000)
Error at [00FF00FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF00FE] must be FF, but found EF (bits: 00010000)
Error at [00FF00FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0100] must be FF, but found EF (bits: 00010000)
Error at [00FF0101] must be FF, but found 03 (bits: 11111100)
Error at [00FF0102] must be FF, but found EF (bits: 00010000)
Error at [00FF0103] must be FF, but found 03 (bits: 11111100)
Error at [00FF0104] must be FF, but found EF (bits: 00010000)
Error at [00FF0105] must be FF, but found 03 (bits: 11111100)
Error at [00FF0106] must be FF, but found EF (bits: 00010000)
Error at [00FF0107] must be FF, but found 03 (bits: 11111100)
Error at [00FF0108] must be FF, but found EF (bits: 00010000)
Error at [00FF0109] must be FF, but found 03 (bits: 11111100)
Error at [00FF010A] must be FF, but found EF (bits: 00010000)
Error at [00FF010B] must be FF, but found 03 (bits: 11111100)
Error at [00FF010C] must be FF, but found EF (bits: 00010000)
Error at [00FF010D] must be FF, but found 03 (bits: 11111100)
Error at [00FF010E] must be FF, but found EF (bits: 00010000)
Error at [00FF010F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0110] must be FF, but found 18 (bits: 11100111)
Error at [00FF0111] must be FF, but found C6 (bits: 00111001)
Error at [00FF0112] must be FF, but found 18 (bits: 11100111)
Error at [00FF0113] must be FF, but found C6 (bits: 00111001)
Error at [00FF0114] must be FF, but found EF (bits: 00010000)
Error at [00FF0115] must be FF, but found 03 (bits: 11111100)
Error at [00FF0116] must be FF, but found EF (bits: 00010000)
Error at [00FF0117] must be FF, but found 03 (bits: 11111100)
Error at [00FF0118] must be FF, but found EF (bits: 00010000)
Error at [00FF0119] must be FF, but found 03 (bits: 11111100)
Error at [00FF011A] must be FF, but found EF (bits: 00010000)
Error at [00FF011B] must be FF, but found 03 (bits: 11111100)
Error at [00FF011C] must be FF, but found EF (bits: 00010000)
Error at [00FF011D] must be FF, but found 03 (bits: 11111100)
Error at [00FF011E] must be FF, but found EF (bits: 00010000)
Error at [00FF011F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0120] must be FF, but found EF (bits: 00010000)
Error at [00FF0121] must be FF, but found 03 (bits: 11111100)
Error at [00FF0122] must be FF, but found EF (bits: 00010000)
Error at [00FF0123] must be FF, but found 03 (bits: 11111100)
Error at [00FF0124] must be FF, but found EF (bits: 00010000)
Error at [00FF0125] must be FF, but found 03 (bits: 11111100)
Error at [00FF0126] must be FF, but found EF (bits: 00010000)
Error at [00FF0127] must be FF, but found 03 (bits: 11111100)
Error at [00FF0128] must be FF, but found EF (bits: 00010000)
Error at [00FF0129] must be FF, but found 03 (bits: 11111100)
Error at [00FF012A] must be FF, but found EF (bits: 00010000)
Error at [00FF012B] must be FF, but found 03 (bits: 11111100)
Error at [00FF012C] must be FF, but found EF (bits: 00010000)
Error at [00FF012D] must be FF, but found 03 (bits: 11111100)
Error at [00FF012E] must be FF, but found EF (bits: 00010000)
Error at [00FF012F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0130] must be FF, but found EF (bits: 00010000)
Error at [00FF0131] must be FF, but found 03 (bits: 11111100)
Error at [00FF0132] must be FF, but found EF (bits: 00010000)
Error at [00FF0133] must be FF, but found 03 (bits: 11111100)
Error at [00FF0134] must be FF, but found EF (bits: 00010000)
Error at [00FF0135] must be FF, but found 03 (bits: 11111100)
Error at [00FF0136] must be FF, but found EF (bits: 00010000)
Error at [00FF0137] must be FF, but found 03 (bits: 11111100)
Error at [00FF0138] must be FF, but found EF (bits: 00010000)
Error at [00FF0139] must be FF, but found 03 (bits: 11111100)
Error at [00FF013A] must be FF, but found EF (bits: 00010000)
Error at [00FF013B] must be FF, but found 03 (bits: 11111100)
Error at [00FF013C] must be FF, but found EF (bits: 00010000)
Error at [00FF013D] must be FF, but found 03 (bits: 11111100)
Error at [00FF013E] must be FF, but found EF (bits: 00010000)
Error at [00FF013F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0140] must be FF, but found EF (bits: 00010000)
Error at [00FF0141] must be FF, but found 03 (bits: 11111100)
Error at [00FF0142] must be FF, but found EF (bits: 00010000)
Error at [00FF0143] must be FF, but found 03 (bits: 11111100)
Error at [00FF0144] must be FF, but found EF (bits: 00010000)
Error at [00FF0145] must be FF, but found 03 (bits: 11111100)
Error at [00FF0146] must be FF, but found EF (bits: 00010000)
Error at [00FF0147] must be FF, but found 03 (bits: 11111100)
Error at [00FF0148] must be FF, but found EF (bits: 00010000)
Error at [00FF0149] must be FF, but found 03 (bits: 11111100)
Error at [00FF014A] must be FF, but found EF (bits: 00010000)
Error at [00FF014B] must be FF, but found 03 (bits: 11111100)
Error at [00FF014C] must be FF, but found EF (bits: 00010000)
Error at [00FF014D] must be FF, but found 03 (bits: 11111100)
Error at [00FF014E] must be FF, but found EF (bits: 00010000)
Error at [00FF014F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0150] must be FF, but found EF (bits: 00010000)
Error at [00FF0151] must be FF, but found 03 (bits: 11111100)
Error at [00FF0152] must be FF, but found EF (bits: 00010000)
Error at [00FF0153] must be FF, but found 03 (bits: 11111100)
Error at [00FF0154] must be FF, but found EF (bits: 00010000)
Error at [00FF0155] must be FF, but found 03 (bits: 11111100)
Error at [00FF0156] must be FF, but found EF (bits: 00010000)
Error at [00FF0157] must be FF, but found 03 (bits: 11111100)
Error at [00FF0158] must be FF, but found EF (bits: 00010000)
Error at [00FF0159] must be FF, but found 03 (bits: 11111100)
Error at [00FF015A] must be FF, but found EF (bits: 00010000)
Error at [00FF015B] must be FF, but found 03 (bits: 11111100)
Error at [00FF015C] must be FF, but found 18 (bits: 11100111)
Error at [00FF015D] must be FF, but found C6 (bits: 00111001)
Error at [00FF015E] must be FF, but found 18 (bits: 11100111)
Error at [00FF015F] must be FF, but found C6 (bits: 00111001)
Error at [00FF0160] must be FF, but found EF (bits: 00010000)
Error at [00FF0161] must be FF, but found 03 (bits: 11111100)
Error at [00FF0162] must be FF, but found EF (bits: 00010000)
Error at [00FF0163] must be FF, but found 03 (bits: 11111100)
Error at [00FF0164] must be FF, but found EF (bits: 00010000)
Error at [00FF0165] must be FF, but found 03 (bits: 11111100)
Error at [00FF0166] must be FF, but found EF (bits: 00010000)
Error at [00FF0167] must be FF, but found 03 (bits: 11111100)
Error at [00FF0168] must be FF, but found EF (bits: 00010000)
Error at [00FF0169] must be FF, but found 03 (bits: 11111100)
Error at [00FF016A] must be FF, but found EF (bits: 00010000)
Error at [00FF016B] must be FF, but found 03 (bits: 11111100)
Error at [00FF016C] must be FF, but found EF (bits: 00010000)
Error at [00FF016D] must be FF, but found 03 (bits: 11111100)
Error at [00FF016E] must be FF, but found EF (bits: 00010000)
Error at [00FF016F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0170] must be FF, but found 18 (bits: 11100111)
Error at [00FF0171] must be FF, but found C6 (bits: 00111001)
Error at [00FF0172] must be FF, but found 18 (bits: 11100111)
Error at [00FF0173] must be FF, but found C6 (bits: 00111001)
Error at [00FF0174] must be FF, but found EF (bits: 00010000)
Error at [00FF0175] must be FF, but found 03 (bits: 11111100)
Error at [00FF0176] must be FF, but found EF (bits: 00010000)
Error at [00FF0177] must be FF, but found 03 (bits: 11111100)
Error at [00FF0178] must be FF, but found EF (bits: 00010000)
Error at [00FF0179] must be FF, but found 03 (bits: 11111100)
Error at [00FF017A] must be FF, but found EF (bits: 00010000)
Error at [00FF017B] must be FF, but found 03 (bits: 11111100)
Error at [00FF017C] must be FF, but found EF (bits: 00010000)
Error at [00FF017D] must be FF, but found 03 (bits: 11111100)
Error at [00FF017E] must be FF, but found EF (bits: 00010000)
Error at [00FF017F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0180] must be FF, but found EF (bits: 00010000)
Error at [00FF0181] must be FF, but found 03 (bits: 11111100)
Error at [00FF0182] must be FF, but found EF (bits: 00010000)
Error at [00FF0183] must be FF, but found 03 (bits: 11111100)
Error at [00FF0184] must be FF, but found EF (bits: 00010000)
Error at [00FF0185] must be FF, but found 03 (bits: 11111100)
Error at [00FF0186] must be FF, but found EF (bits: 00010000)
Error at [00FF0187] must be FF, but found 03 (bits: 11111100)
Error at [00FF0188] must be FF, but found EF (bits: 00010000)
Error at [00FF0189] must be FF, but found 03 (bits: 11111100)
Error at [00FF018A] must be FF, but found EF (bits: 00010000)
Error at [00FF018B] must be FF, but found 03 (bits: 11111100)
Error at [00FF018C] must be FF, but found EF (bits: 00010000)
Error at [00FF018D] must be FF, but found 03 (bits: 11111100)
Error at [00FF018E] must be FF, but found EF (bits: 00010000)
Error at [00FF018F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0190] must be FF, but found EF (bits: 00010000)
Error at [00FF0191] must be FF, but found 03 (bits: 11111100)
Error at [00FF0192] must be FF, but found EF (bits: 00010000)
Error at [00FF0193] must be FF, but found 03 (bits: 11111100)
Error at [00FF0194] must be FF, but found EF (bits: 00010000)
Error at [00FF0195] must be FF, but found 03 (bits: 11111100)
Error at [00FF0196] must be FF, but found EF (bits: 00010000)
Error at [00FF0197] must be FF, but found 03 (bits: 11111100)
Error at [00FF0198] must be FF, but found EF (bits: 00010000)
Error at [00FF0199] must be FF, but found 03 (bits: 11111100)
Error at [00FF019A] must be FF, but found EF (bits: 00010000)
Error at [00FF019B] must be FF, but found 03 (bits: 11111100)
Error at [00FF019C] must be FF, but found 0F (bits: 11110000)
Error at [00FF019D] must be FF, but found 00 (bits: 11111111)
Error at [00FF019E] must be FF, but found 18 (bits: 11100111)
Error at [00FF019F] must be FF, but found C6 (bits: 00111001)
Error at [00FF01A0] must be FF, but found EF (bits: 00010000)
Error at [00FF01A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01A2] must be FF, but found EF (bits: 00010000)
Error at [00FF01A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01A4] must be FF, but found EF (bits: 00010000)
Error at [00FF01A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01A6] must be FF, but found EF (bits: 00010000)
Error at [00FF01A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01A8] must be FF, but found EF (bits: 00010000)
Error at [00FF01A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01AA] must be FF, but found EF (bits: 00010000)
Error at [00FF01AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01AC] must be FF, but found EF (bits: 00010000)
Error at [00FF01AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF01AE] must be FF, but found EF (bits: 00010000)
Error at [00FF01AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF01B0] must be FF, but found EF (bits: 00010000)
Error at [00FF01B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01B2] must be FF, but found EF (bits: 00010000)
Error at [00FF01B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01B4] must be FF, but found EF (bits: 00010000)
Error at [00FF01B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01B6] must be FF, but found EF (bits: 00010000)
Error at [00FF01B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01B8] must be FF, but found EF (bits: 00010000)
Error at [00FF01B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01BA] must be FF, but found EF (bits: 00010000)
Error at [00FF01BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01BC] must be FF, but found EF (bits: 00010000)
Error at [00FF01BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF01BE] must be FF, but found EF (bits: 00010000)
Error at [00FF01BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF01C0] must be FF, but found EF (bits: 00010000)
Error at [00FF01C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01C2] must be FF, but found EF (bits: 00010000)
Error at [00FF01C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01C4] must be FF, but found EF (bits: 00010000)
Error at [00FF01C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01C6] must be FF, but found EF (bits: 00010000)
Error at [00FF01C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01C8] must be FF, but found EF (bits: 00010000)
Error at [00FF01C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01CA] must be FF, but found EF (bits: 00010000)
Error at [00FF01CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01CC] must be FF, but found EF (bits: 00010000)
Error at [00FF01CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF01CE] must be FF, but found EF (bits: 00010000)
Error at [00FF01CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF01D0] must be FF, but found EF (bits: 00010000)
Error at [00FF01D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01D2] must be FF, but found EF (bits: 00010000)
Error at [00FF01D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01D4] must be FF, but found EF (bits: 00010000)
Error at [00FF01D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01D6] must be FF, but found EF (bits: 00010000)
Error at [00FF01D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01D8] must be FF, but found EF (bits: 00010000)
Error at [00FF01D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01DA] must be FF, but found EF (bits: 00010000)
Error at [00FF01DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01DC] must be FF, but found EF (bits: 00010000)
Error at [00FF01DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF01DE] must be FF, but found EF (bits: 00010000)
Error at [00FF01DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF01E0] must be FF, but found EF (bits: 00010000)
Error at [00FF01E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01E2] must be FF, but found EF (bits: 00010000)
Error at [00FF01E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01E4] must be FF, but found EF (bits: 00010000)
Error at [00FF01E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01E6] must be FF, but found EF (bits: 00010000)
Error at [00FF01E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01E8] must be FF, but found EF (bits: 00010000)
Error at [00FF01E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01EA] must be FF, but found EF (bits: 00010000)
Error at [00FF01EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01EC] must be FF, but found EF (bits: 00010000)
Error at [00FF01ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF01EE] must be FF, but found EF (bits: 00010000)
Error at [00FF01EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF01F0] must be FF, but found EF (bits: 00010000)
Error at [00FF01F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF01F2] must be FF, but found EF (bits: 00010000)
Error at [00FF01F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF01F4] must be FF, but found EF (bits: 00010000)
Error at [00FF01F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF01F6] must be FF, but found EF (bits: 00010000)
Error at [00FF01F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF01F8] must be FF, but found EF (bits: 00010000)
Error at [00FF01F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF01FA] must be FF, but found EF (bits: 00010000)
Error at [00FF01FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF01FC] must be FF, but found EF (bits: 00010000)
Error at [00FF01FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF01FE] must be FF, but found EF (bits: 00010000)
Error at [00FF01FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0200] must be FF, but found EF (bits: 00010000)
Error at [00FF0201] must be FF, but found 03 (bits: 11111100)
Error at [00FF0202] must be FF, but found EF (bits: 00010000)
Error at [00FF0203] must be FF, but found 03 (bits: 11111100)
Error at [00FF0204] must be FF, but found EF (bits: 00010000)
Error at [00FF0205] must be FF, but found 03 (bits: 11111100)
Error at [00FF0206] must be FF, but found EF (bits: 00010000)
Error at [00FF0207] must be FF, but found 03 (bits: 11111100)
Error at [00FF0208] must be FF, but found EF (bits: 00010000)
Error at [00FF0209] must be FF, but found 03 (bits: 11111100)
Error at [00FF020A] must be FF, but found EF (bits: 00010000)
Error at [00FF020B] must be FF, but found 03 (bits: 11111100)
Error at [00FF020C] must be FF, but found EF (bits: 00010000)
Error at [00FF020D] must be FF, but found 03 (bits: 11111100)
Error at [00FF020E] must be FF, but found EF (bits: 00010000)
Error at [00FF020F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0210] must be FF, but found EF (bits: 00010000)
Error at [00FF0211] must be FF, but found 03 (bits: 11111100)
Error at [00FF0212] must be FF, but found EF (bits: 00010000)
Error at [00FF0213] must be FF, but found 03 (bits: 11111100)
Error at [00FF0214] must be FF, but found EF (bits: 00010000)
Error at [00FF0215] must be FF, but found 03 (bits: 11111100)
Error at [00FF0216] must be FF, but found EF (bits: 00010000)
Error at [00FF0217] must be FF, but found 03 (bits: 11111100)
Error at [00FF0218] must be FF, but found EF (bits: 00010000)
Error at [00FF0219] must be FF, but found 03 (bits: 11111100)
Error at [00FF021A] must be FF, but found EF (bits: 00010000)
Error at [00FF021B] must be FF, but found 03 (bits: 11111100)
Error at [00FF021C] must be FF, but found EF (bits: 00010000)
Error at [00FF021D] must be FF, but found 03 (bits: 11111100)
Error at [00FF021E] must be FF, but found EF (bits: 00010000)
Error at [00FF021F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0220] must be FF, but found EF (bits: 00010000)
Error at [00FF0221] must be FF, but found 03 (bits: 11111100)
Error at [00FF0222] must be FF, but found EF (bits: 00010000)
Error at [00FF0223] must be FF, but found 03 (bits: 11111100)
Error at [00FF0224] must be FF, but found EF (bits: 00010000)
Error at [00FF0225] must be FF, but found 03 (bits: 11111100)
Error at [00FF0226] must be FF, but found EF (bits: 00010000)
Error at [00FF0227] must be FF, but found 03 (bits: 11111100)
Error at [00FF0228] must be FF, but found EF (bits: 00010000)
Error at [00FF0229] must be FF, but found 03 (bits: 11111100)
Error at [00FF022A] must be FF, but found EF (bits: 00010000)
Error at [00FF022B] must be FF, but found 03 (bits: 11111100)
Error at [00FF022C] must be FF, but found EF (bits: 00010000)
Error at [00FF022D] must be FF, but found 03 (bits: 11111100)
Error at [00FF022E] must be FF, but found EF (bits: 00010000)
Error at [00FF022F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0230] must be FF, but found EF (bits: 00010000)
Error at [00FF0231] must be FF, but found 03 (bits: 11111100)
Error at [00FF0232] must be FF, but found EF (bits: 00010000)
Error at [00FF0233] must be FF, but found 03 (bits: 11111100)
Error at [00FF0234] must be FF, but found EF (bits: 00010000)
Error at [00FF0235] must be FF, but found 03 (bits: 11111100)
Error at [00FF0236] must be FF, but found EF (bits: 00010000)
Error at [00FF0237] must be FF, but found 03 (bits: 11111100)
Error at [00FF0238] must be FF, but found EF (bits: 00010000)
Error at [00FF0239] must be FF, but found 03 (bits: 11111100)
Error at [00FF023A] must be FF, but found EF (bits: 00010000)
Error at [00FF023B] must be FF, but found 03 (bits: 11111100)
Error at [00FF023C] must be FF, but found 18 (bits: 11100111)
Error at [00FF023D] must be FF, but found C6 (bits: 00111001)
Error at [00FF023E] must be FF, but found 18 (bits: 11100111)
Error at [00FF023F] must be FF, but found C6 (bits: 00111001)
Error at [00FF0240] must be FF, but found EF (bits: 00010000)
Error at [00FF0241] must be FF, but found 03 (bits: 11111100)
Error at [00FF0242] must be FF, but found EF (bits: 00010000)
Error at [00FF0243] must be FF, but found 03 (bits: 11111100)
Error at [00FF0244] must be FF, but found EF (bits: 00010000)
Error at [00FF0245] must be FF, but found 03 (bits: 11111100)
Error at [00FF0246] must be FF, but found EF (bits: 00010000)
Error at [00FF0247] must be FF, but found 03 (bits: 11111100)
Error at [00FF0248] must be FF, but found EF (bits: 00010000)
Error at [00FF0249] must be FF, but found 03 (bits: 11111100)
Error at [00FF024A] must be FF, but found EF (bits: 00010000)
Error at [00FF024B] must be FF, but found 03 (bits: 11111100)
Error at [00FF024C] must be FF, but found EF (bits: 00010000)
Error at [00FF024D] must be FF, but found 03 (bits: 11111100)
Error at [00FF024E] must be FF, but found EF (bits: 00010000)
Error at [00FF024F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0250] must be FF, but found 0F (bits: 11110000)
Error at [00FF0251] must be FF, but found 00 (bits: 11111111)
Error at [00FF0252] must be FF, but found 18 (bits: 11100111)
Error at [00FF0253] must be FF, but found C6 (bits: 00111001)
Error at [00FF0254] must be FF, but found EF (bits: 00010000)
Error at [00FF0255] must be FF, but found 03 (bits: 11111100)
Error at [00FF0256] must be FF, but found EF (bits: 00010000)
Error at [00FF0257] must be FF, but found 03 (bits: 11111100)
Error at [00FF0258] must be FF, but found EF (bits: 00010000)
Error at [00FF0259] must be FF, but found 03 (bits: 11111100)
Error at [00FF025A] must be FF, but found EF (bits: 00010000)
Error at [00FF025B] must be FF, but found 03 (bits: 11111100)
Error at [00FF025C] must be FF, but found EF (bits: 00010000)
Error at [00FF025D] must be FF, but found 03 (bits: 11111100)
Error at [00FF025E] must be FF, but found EF (bits: 00010000)
Error at [00FF025F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0260] must be FF, but found EF (bits: 00010000)
Error at [00FF0261] must be FF, but found 03 (bits: 11111100)
Error at [00FF0262] must be FF, but found EF (bits: 00010000)
Error at [00FF0263] must be FF, but found 03 (bits: 11111100)
Error at [00FF0264] must be FF, but found EF (bits: 00010000)
Error at [00FF0265] must be FF, but found 03 (bits: 11111100)
Error at [00FF0266] must be FF, but found EF (bits: 00010000)
Error at [00FF0267] must be FF, but found 03 (bits: 11111100)
Error at [00FF0268] must be FF, but found EF (bits: 00010000)
Error at [00FF0269] must be FF, but found 03 (bits: 11111100)
Error at [00FF026A] must be FF, but found EF (bits: 00010000)
Error at [00FF026B] must be FF, but found 03 (bits: 11111100)
Error at [00FF026C] must be FF, but found EF (bits: 00010000)
Error at [00FF026D] must be FF, but found 03 (bits: 11111100)
Error at [00FF026E] must be FF, but found EF (bits: 00010000)
Error at [00FF026F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0270] must be FF, but found EF (bits: 00010000)
Error at [00FF0271] must be FF, but found 03 (bits: 11111100)
Error at [00FF0272] must be FF, but found EF (bits: 00010000)
Error at [00FF0273] must be FF, but found 03 (bits: 11111100)
Error at [00FF0274] must be FF, but found EF (bits: 00010000)
Error at [00FF0275] must be FF, but found 03 (bits: 11111100)
Error at [00FF0276] must be FF, but found EF (bits: 00010000)
Error at [00FF0277] must be FF, but found 03 (bits: 11111100)
Error at [00FF0278] must be FF, but found EF (bits: 00010000)
Error at [00FF0279] must be FF, but found 03 (bits: 11111100)
Error at [00FF027A] must be FF, but found EF (bits: 00010000)
Error at [00FF027B] must be FF, but found 03 (bits: 11111100)
Error at [00FF027C] must be FF, but found EF (bits: 00010000)
Error at [00FF027D] must be FF, but found 03 (bits: 11111100)
Error at [00FF027E] must be FF, but found EF (bits: 00010000)
Error at [00FF027F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0280] must be FF, but found EF (bits: 00010000)
Error at [00FF0281] must be FF, but found 03 (bits: 11111100)
Error at [00FF0282] must be FF, but found EF (bits: 00010000)
Error at [00FF0283] must be FF, but found 03 (bits: 11111100)
Error at [00FF0284] must be FF, but found EF (bits: 00010000)
Error at [00FF0285] must be FF, but found 03 (bits: 11111100)
Error at [00FF0286] must be FF, but found EF (bits: 00010000)
Error at [00FF0287] must be FF, but found 03 (bits: 11111100)
Error at [00FF0288] must be FF, but found EF (bits: 00010000)
Error at [00FF0289] must be FF, but found 03 (bits: 11111100)
Error at [00FF028A] must be FF, but found EF (bits: 00010000)
Error at [00FF028B] must be FF, but found 03 (bits: 11111100)
Error at [00FF028C] must be FF, but found EF (bits: 00010000)
Error at [00FF028D] must be FF, but found 03 (bits: 11111100)
Error at [00FF028E] must be FF, but found EF (bits: 00010000)
Error at [00FF028F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0290] must be FF, but found EF (bits: 00010000)
Error at [00FF0291] must be FF, but found 03 (bits: 11111100)
Error at [00FF0292] must be FF, but found EF (bits: 00010000)
Error at [00FF0293] must be FF, but found 03 (bits: 11111100)
Error at [00FF0294] must be FF, but found EF (bits: 00010000)
Error at [00FF0295] must be FF, but found 03 (bits: 11111100)
Error at [00FF0296] must be FF, but found EF (bits: 00010000)
Error at [00FF0297] must be FF, but found 03 (bits: 11111100)
Error at [00FF0298] must be FF, but found EF (bits: 00010000)
Error at [00FF0299] must be FF, but found 03 (bits: 11111100)
Error at [00FF029A] must be FF, but found EF (bits: 00010000)
Error at [00FF029B] must be FF, but found 03 (bits: 11111100)
Error at [00FF029C] must be FF, but found 18 (bits: 11100111)
Error at [00FF029D] must be FF, but found C6 (bits: 00111001)
Error at [00FF029E] must be FF, but found 18 (bits: 11100111)
Error at [00FF029F] must be FF, but found C6 (bits: 00111001)
Error at [00FF02A0] must be FF, but found EF (bits: 00010000)
Error at [00FF02A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF02A2] must be FF, but found EF (bits: 00010000)
Error at [00FF02A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF02A4] must be FF, but found EF (bits: 00010000)
Error at [00FF02A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF02A6] must be FF, but found EF (bits: 00010000)
Error at [00FF02A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF02A8] must be FF, but found EF (bits: 00010000)
Error at [00FF02A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02AA] must be FF, but found EF (bits: 00010000)
Error at [00FF02AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02AC] must be FF, but found EF (bits: 00010000)
Error at [00FF02AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF02AE] must be FF, but found EF (bits: 00010000)
Error at [00FF02AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF02B0] must be FF, but found 18 (bits: 11100111)
Error at [00FF02B1] must be FF, but found C6 (bits: 00111001)
Error at [00FF02B2] must be FF, but found 18 (bits: 11100111)
Error at [00FF02B3] must be FF, but found C6 (bits: 00111001)
Error at [00FF02B4] must be FF, but found EF (bits: 00010000)
Error at [00FF02B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF02B6] must be FF, but found EF (bits: 00010000)
Error at [00FF02B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF02B8] must be FF, but found EF (bits: 00010000)
Error at [00FF02B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02BA] must be FF, but found EF (bits: 00010000)
Error at [00FF02BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02BC] must be FF, but found EF (bits: 00010000)
Error at [00FF02BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF02BE] must be FF, but found EF (bits: 00010000)
Error at [00FF02BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF02C0] must be FF, but found EF (bits: 00010000)
Error at [00FF02C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF02C2] must be FF, but found EF (bits: 00010000)
Error at [00FF02C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF02C4] must be FF, but found EF (bits: 00010000)
Error at [00FF02C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF02C6] must be FF, but found EF (bits: 00010000)
Error at [00FF02C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF02C8] must be FF, but found EF (bits: 00010000)
Error at [00FF02C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02CA] must be FF, but found EF (bits: 00010000)
Error at [00FF02CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02CC] must be FF, but found EF (bits: 00010000)
Error at [00FF02CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF02CE] must be FF, but found EF (bits: 00010000)
Error at [00FF02CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF02D0] must be FF, but found EF (bits: 00010000)
Error at [00FF02D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF02D2] must be FF, but found EF (bits: 00010000)
Error at [00FF02D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF02D4] must be FF, but found EF (bits: 00010000)
Error at [00FF02D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF02D6] must be FF, but found EF (bits: 00010000)
Error at [00FF02D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF02D8] must be FF, but found EF (bits: 00010000)
Error at [00FF02D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02DA] must be FF, but found EF (bits: 00010000)
Error at [00FF02DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02DC] must be FF, but found EF (bits: 00010000)
Error at [00FF02DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF02DE] must be FF, but found EF (bits: 00010000)
Error at [00FF02DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF02E0] must be FF, but found EF (bits: 00010000)
Error at [00FF02E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF02E2] must be FF, but found EF (bits: 00010000)
Error at [00FF02E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF02E4] must be FF, but found EF (bits: 00010000)
Error at [00FF02E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF02E6] must be FF, but found EF (bits: 00010000)
Error at [00FF02E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF02E8] must be FF, but found EF (bits: 00010000)
Error at [00FF02E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02EA] must be FF, but found EF (bits: 00010000)
Error at [00FF02EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02EC] must be FF, but found EF (bits: 00010000)
Error at [00FF02ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF02EE] must be FF, but found EF (bits: 00010000)
Error at [00FF02EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF02F0] must be FF, but found EF (bits: 00010000)
Error at [00FF02F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF02F2] must be FF, but found EF (bits: 00010000)
Error at [00FF02F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF02F4] must be FF, but found 18 (bits: 11100111)
Error at [00FF02F5] must be FF, but found C6 (bits: 00111001)
Error at [00FF02F6] must be FF, but found 18 (bits: 11100111)
Error at [00FF02F7] must be FF, but found C6 (bits: 00111001)
Error at [00FF02F8] must be FF, but found EF (bits: 00010000)
Error at [00FF02F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF02FA] must be FF, but found EF (bits: 00010000)
Error at [00FF02FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF02FC] must be FF, but found EF (bits: 00010000)
Error at [00FF02FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF02FE] must be FF, but found EF (bits: 00010000)
Error at [00FF02FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0300] must be FF, but found 0F (bits: 11110000)
Error at [00FF0301] must be FF, but found 00 (bits: 11111111)
Error at [00FF0302] must be FF, but found 18 (bits: 11100111)
Error at [00FF0303] must be FF, but found C6 (bits: 00111001)
Error at [00FF0304] must be FF, but found EF (bits: 00010000)
Error at [00FF0305] must be FF, but found 03 (bits: 11111100)
Error at [00FF0306] must be FF, but found EF (bits: 00010000)
Error at [00FF0307] must be FF, but found 03 (bits: 11111100)
Error at [00FF0308] must be FF, but found EF (bits: 00010000)
Error at [00FF0309] must be FF, but found 03 (bits: 11111100)
Error at [00FF030A] must be FF, but found EF (bits: 00010000)
Error at [00FF030B] must be FF, but found 03 (bits: 11111100)
Error at [00FF030C] must be FF, but found EF (bits: 00010000)
Error at [00FF030D] must be FF, but found 03 (bits: 11111100)
Error at [00FF030E] must be FF, but found EF (bits: 00010000)
Error at [00FF030F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0310] must be FF, but found EF (bits: 00010000)
Error at [00FF0311] must be FF, but found 03 (bits: 11111100)
Error at [00FF0312] must be FF, but found EF (bits: 00010000)
Error at [00FF0313] must be FF, but found 03 (bits: 11111100)
Error at [00FF0314] must be FF, but found EF (bits: 00010000)
Error at [00FF0315] must be FF, but found 03 (bits: 11111100)
Error at [00FF0316] must be FF, but found EF (bits: 00010000)
Error at [00FF0317] must be FF, but found 03 (bits: 11111100)
Error at [00FF0318] must be FF, but found EF (bits: 00010000)
Error at [00FF0319] must be FF, but found 03 (bits: 11111100)
Error at [00FF031A] must be FF, but found EF (bits: 00010000)
Error at [00FF031B] must be FF, but found 03 (bits: 11111100)
Error at [00FF031C] must be FF, but found EF (bits: 00010000)
Error at [00FF031D] must be FF, but found 03 (bits: 11111100)
Error at [00FF031E] must be FF, but found EF (bits: 00010000)
Error at [00FF031F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0320] must be FF, but found EF (bits: 00010000)
Error at [00FF0321] must be FF, but found 03 (bits: 11111100)
Error at [00FF0322] must be FF, but found EF (bits: 00010000)
Error at [00FF0323] must be FF, but found 03 (bits: 11111100)
Error at [00FF0324] must be FF, but found EF (bits: 00010000)
Error at [00FF0325] must be FF, but found 03 (bits: 11111100)
Error at [00FF0326] must be FF, but found EF (bits: 00010000)
Error at [00FF0327] must be FF, but found 03 (bits: 11111100)
Error at [00FF0328] must be FF, but found EF (bits: 00010000)
Error at [00FF0329] must be FF, but found 03 (bits: 11111100)
Error at [00FF032A] must be FF, but found EF (bits: 00010000)
Error at [00FF032B] must be FF, but found 03 (bits: 11111100)
Error at [00FF032C] must be FF, but found EF (bits: 00010000)
Error at [00FF032D] must be FF, but found 03 (bits: 11111100)
Error at [00FF032E] must be FF, but found EF (bits: 00010000)
Error at [00FF032F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0330] must be FF, but found EF (bits: 00010000)
Error at [00FF0331] must be FF, but found 03 (bits: 11111100)
Error at [00FF0332] must be FF, but found EF (bits: 00010000)
Error at [00FF0333] must be FF, but found 03 (bits: 11111100)
Error at [00FF0334] must be FF, but found EF (bits: 00010000)
Error at [00FF0335] must be FF, but found 03 (bits: 11111100)
Error at [00FF0336] must be FF, but found EF (bits: 00010000)
Error at [00FF0337] must be FF, but found 03 (bits: 11111100)
Error at [00FF0338] must be FF, but found EF (bits: 00010000)
Error at [00FF0339] must be FF, but found 03 (bits: 11111100)
Error at [00FF033A] must be FF, but found EF (bits: 00010000)
Error at [00FF033B] must be FF, but found 03 (bits: 11111100)
Error at [00FF033C] must be FF, but found EF (bits: 00010000)
Error at [00FF033D] must be FF, but found 03 (bits: 11111100)
Error at [00FF033E] must be FF, but found EF (bits: 00010000)
Error at [00FF033F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0340] must be FF, but found EF (bits: 00010000)
Error at [00FF0341] must be FF, but found 03 (bits: 11111100)
Error at [00FF0342] must be FF, but found EF (bits: 00010000)
Error at [00FF0343] must be FF, but found 03 (bits: 11111100)
Error at [00FF0344] must be FF, but found EF (bits: 00010000)
Error at [00FF0345] must be FF, but found 03 (bits: 11111100)
Error at [00FF0346] must be FF, but found EF (bits: 00010000)
Error at [00FF0347] must be FF, but found 03 (bits: 11111100)
Error at [00FF0348] must be FF, but found EF (bits: 00010000)
Error at [00FF0349] must be FF, but found 03 (bits: 11111100)
Error at [00FF034A] must be FF, but found EF (bits: 00010000)
Error at [00FF034B] must be FF, but found 03 (bits: 11111100)
Error at [00FF034C] must be FF, but found EF (bits: 00010000)
Error at [00FF034D] must be FF, but found 03 (bits: 11111100)
Error at [00FF034E] must be FF, but found EF (bits: 00010000)
Error at [00FF034F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0350] must be FF, but found EF (bits: 00010000)
Error at [00FF0351] must be FF, but found 03 (bits: 11111100)
Error at [00FF0352] must be FF, but found EF (bits: 00010000)
Error at [00FF0353] must be FF, but found 03 (bits: 11111100)
Error at [00FF0354] must be FF, but found EF (bits: 00010000)
Error at [00FF0355] must be FF, but found 03 (bits: 11111100)
Error at [00FF0356] must be FF, but found EF (bits: 00010000)
Error at [00FF0357] must be FF, but found 03 (bits: 11111100)
Error at [00FF0358] must be FF, but found EF (bits: 00010000)
Error at [00FF0359] must be FF, but found 03 (bits: 11111100)
Error at [00FF035A] must be FF, but found EF (bits: 00010000)
Error at [00FF035B] must be FF, but found 03 (bits: 11111100)
Error at [00FF035C] must be FF, but found EF (bits: 00010000)
Error at [00FF035D] must be FF, but found 03 (bits: 11111100)
Error at [00FF035E] must be FF, but found EF (bits: 00010000)
Error at [00FF035F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0360] must be FF, but found EF (bits: 00010000)
Error at [00FF0361] must be FF, but found 03 (bits: 11111100)
Error at [00FF0362] must be FF, but found EF (bits: 00010000)
Error at [00FF0363] must be FF, but found 03 (bits: 11111100)
Error at [00FF0364] must be FF, but found EF (bits: 00010000)
Error at [00FF0365] must be FF, but found 03 (bits: 11111100)
Error at [00FF0366] must be FF, but found EF (bits: 00010000)
Error at [00FF0367] must be FF, but found 03 (bits: 11111100)
Error at [00FF0368] must be FF, but found 18 (bits: 11100111)
Error at [00FF0369] must be FF, but found C6 (bits: 00111001)
Error at [00FF036A] must be FF, but found 18 (bits: 11100111)
Error at [00FF036B] must be FF, but found C6 (bits: 00111001)
Error at [00FF036C] must be FF, but found EF (bits: 00010000)
Error at [00FF036D] must be FF, but found 03 (bits: 11111100)
Error at [00FF036E] must be FF, but found EF (bits: 00010000)
Error at [00FF036F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0370] must be FF, but found EF (bits: 00010000)
Error at [00FF0371] must be FF, but found 03 (bits: 11111100)
Error at [00FF0372] must be FF, but found EF (bits: 00010000)
Error at [00FF0373] must be FF, but found 03 (bits: 11111100)
Error at [00FF0374] must be FF, but found EF (bits: 00010000)
Error at [00FF0375] must be FF, but found 03 (bits: 11111100)
Error at [00FF0376] must be FF, but found EF (bits: 00010000)
Error at [00FF0377] must be FF, but found 03 (bits: 11111100)
Error at [00FF0378] must be FF, but found EF (bits: 00010000)
Error at [00FF0379] must be FF, but found 03 (bits: 11111100)
Error at [00FF037A] must be FF, but found EF (bits: 00010000)
Error at [00FF037B] must be FF, but found 03 (bits: 11111100)
Error at [00FF037C] must be FF, but found EF (bits: 00010000)
Error at [00FF037D] must be FF, but found 03 (bits: 11111100)
Error at [00FF037E] must be FF, but found EF (bits: 00010000)
Error at [00FF037F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0380] must be FF, but found EF (bits: 00010000)
Error at [00FF0381] must be FF, but found 03 (bits: 11111100)
Error at [00FF0382] must be FF, but found EF (bits: 00010000)
Error at [00FF0383] must be FF, but found 03 (bits: 11111100)
Error at [00FF0384] must be FF, but found EF (bits: 00010000)
Error at [00FF0385] must be FF, but found 03 (bits: 11111100)
Error at [00FF0386] must be FF, but found EF (bits: 00010000)
Error at [00FF0387] must be FF, but found 03 (bits: 11111100)
Error at [00FF0388] must be FF, but found EF (bits: 00010000)
Error at [00FF0389] must be FF, but found 03 (bits: 11111100)
Error at [00FF038A] must be FF, but found EF (bits: 00010000)
Error at [00FF038B] must be FF, but found 03 (bits: 11111100)
Error at [00FF038C] must be FF, but found EF (bits: 00010000)
Error at [00FF038D] must be FF, but found 03 (bits: 11111100)
Error at [00FF038E] must be FF, but found EF (bits: 00010000)
Error at [00FF038F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0390] must be FF, but found EF (bits: 00010000)
Error at [00FF0391] must be FF, but found 03 (bits: 11111100)
Error at [00FF0392] must be FF, but found EF (bits: 00010000)
Error at [00FF0393] must be FF, but found 03 (bits: 11111100)
Error at [00FF0394] must be FF, but found EF (bits: 00010000)
Error at [00FF0395] must be FF, but found 03 (bits: 11111100)
Error at [00FF0396] must be FF, but found EF (bits: 00010000)
Error at [00FF0397] must be FF, but found 03 (bits: 11111100)
Error at [00FF0398] must be FF, but found EF (bits: 00010000)
Error at [00FF0399] must be FF, but found 03 (bits: 11111100)
Error at [00FF039A] must be FF, but found EF (bits: 00010000)
Error at [00FF039B] must be FF, but found 03 (bits: 11111100)
Error at [00FF039C] must be FF, but found EF (bits: 00010000)
Error at [00FF039D] must be FF, but found 03 (bits: 11111100)
Error at [00FF039E] must be FF, but found EF (bits: 00010000)
Error at [00FF039F] must be FF, but found 03 (bits: 11111100)
Error at [00FF03A0] must be FF, but found EF (bits: 00010000)
Error at [00FF03A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF03A2] must be FF, but found EF (bits: 00010000)
Error at [00FF03A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF03A4] must be FF, but found EF (bits: 00010000)
Error at [00FF03A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03A6] must be FF, but found EF (bits: 00010000)
Error at [00FF03A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03A8] must be FF, but found EF (bits: 00010000)
Error at [00FF03A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03AA] must be FF, but found EF (bits: 00010000)
Error at [00FF03AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03AC] must be FF, but found EF (bits: 00010000)
Error at [00FF03AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF03AE] must be FF, but found EF (bits: 00010000)
Error at [00FF03AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF03B0] must be FF, but found 0F (bits: 11110000)
Error at [00FF03B1] must be FF, but found 00 (bits: 11111111)
Error at [00FF03B2] must be FF, but found 18 (bits: 11100111)
Error at [00FF03B3] must be FF, but found C6 (bits: 00111001)
Error at [00FF03B4] must be FF, but found EF (bits: 00010000)
Error at [00FF03B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03B6] must be FF, but found EF (bits: 00010000)
Error at [00FF03B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03B8] must be FF, but found EF (bits: 00010000)
Error at [00FF03B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03BA] must be FF, but found EF (bits: 00010000)
Error at [00FF03BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03BC] must be FF, but found EF (bits: 00010000)
Error at [00FF03BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF03BE] must be FF, but found EF (bits: 00010000)
Error at [00FF03BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF03C0] must be FF, but found EF (bits: 00010000)
Error at [00FF03C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF03C2] must be FF, but found EF (bits: 00010000)
Error at [00FF03C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF03C4] must be FF, but found EF (bits: 00010000)
Error at [00FF03C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03C6] must be FF, but found EF (bits: 00010000)
Error at [00FF03C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03C8] must be FF, but found EF (bits: 00010000)
Error at [00FF03C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03CA] must be FF, but found EF (bits: 00010000)
Error at [00FF03CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03CC] must be FF, but found EF (bits: 00010000)
Error at [00FF03CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF03CE] must be FF, but found EF (bits: 00010000)
Error at [00FF03CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF03D0] must be FF, but found EF (bits: 00010000)
Error at [00FF03D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF03D2] must be FF, but found EF (bits: 00010000)
Error at [00FF03D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF03D4] must be FF, but found EF (bits: 00010000)
Error at [00FF03D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03D6] must be FF, but found EF (bits: 00010000)
Error at [00FF03D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03D8] must be FF, but found EF (bits: 00010000)
Error at [00FF03D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03DA] must be FF, but found EF (bits: 00010000)
Error at [00FF03DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03DC] must be FF, but found EF (bits: 00010000)
Error at [00FF03DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF03DE] must be FF, but found EF (bits: 00010000)
Error at [00FF03DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF03E0] must be FF, but found EF (bits: 00010000)
Error at [00FF03E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF03E2] must be FF, but found EF (bits: 00010000)
Error at [00FF03E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF03E4] must be FF, but found EF (bits: 00010000)
Error at [00FF03E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03E6] must be FF, but found EF (bits: 00010000)
Error at [00FF03E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03E8] must be FF, but found EF (bits: 00010000)
Error at [00FF03E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03EA] must be FF, but found EF (bits: 00010000)
Error at [00FF03EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03EC] must be FF, but found EF (bits: 00010000)
Error at [00FF03ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF03EE] must be FF, but found EF (bits: 00010000)
Error at [00FF03EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF03F0] must be FF, but found EF (bits: 00010000)
Error at [00FF03F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF03F2] must be FF, but found EF (bits: 00010000)
Error at [00FF03F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF03F4] must be FF, but found EF (bits: 00010000)
Error at [00FF03F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF03F6] must be FF, but found EF (bits: 00010000)
Error at [00FF03F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF03F8] must be FF, but found EF (bits: 00010000)
Error at [00FF03F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF03FA] must be FF, but found EF (bits: 00010000)
Error at [00FF03FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF03FC] must be FF, but found EF (bits: 00010000)
Error at [00FF03FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF03FE] must be FF, but found EF (bits: 00010000)
Error at [00FF03FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0400] must be FF, but found EF (bits: 00010000)
Error at [00FF0401] must be FF, but found 03 (bits: 11111100)
Error at [00FF0402] must be FF, but found EF (bits: 00010000)
Error at [00FF0403] must be FF, but found 03 (bits: 11111100)
Error at [00FF0404] must be FF, but found EF (bits: 00010000)
Error at [00FF0405] must be FF, but found 03 (bits: 11111100)
Error at [00FF0406] must be FF, but found EF (bits: 00010000)
Error at [00FF0407] must be FF, but found 03 (bits: 11111100)
Error at [00FF0408] must be FF, but found EF (bits: 00010000)
Error at [00FF0409] must be FF, but found 03 (bits: 11111100)
Error at [00FF040A] must be FF, but found EF (bits: 00010000)
Error at [00FF040B] must be FF, but found 03 (bits: 11111100)
Error at [00FF040C] must be FF, but found EF (bits: 00010000)
Error at [00FF040D] must be FF, but found 03 (bits: 11111100)
Error at [00FF040E] must be FF, but found EF (bits: 00010000)
Error at [00FF040F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0410] must be FF, but found EF (bits: 00010000)
Error at [00FF0411] must be FF, but found 03 (bits: 11111100)
Error at [00FF0412] must be FF, but found EF (bits: 00010000)
Error at [00FF0413] must be FF, but found 03 (bits: 11111100)
Error at [00FF0414] must be FF, but found EF (bits: 00010000)
Error at [00FF0415] must be FF, but found 03 (bits: 11111100)
Error at [00FF0416] must be FF, but found EF (bits: 00010000)
Error at [00FF0417] must be FF, but found 03 (bits: 11111100)
Error at [00FF0418] must be FF, but found EF (bits: 00010000)
Error at [00FF0419] must be FF, but found 03 (bits: 11111100)
Error at [00FF041A] must be FF, but found EF (bits: 00010000)
Error at [00FF041B] must be FF, but found 03 (bits: 11111100)
Error at [00FF041C] must be FF, but found EF (bits: 00010000)
Error at [00FF041D] must be FF, but found 03 (bits: 11111100)
Error at [00FF041E] must be FF, but found EF (bits: 00010000)
Error at [00FF041F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0420] must be FF, but found 18 (bits: 11100111)
Error at [00FF0421] must be FF, but found C6 (bits: 00111001)
Error at [00FF0422] must be FF, but found 18 (bits: 11100111)
Error at [00FF0423] must be FF, but found C6 (bits: 00111001)
Error at [00FF0424] must be FF, but found EF (bits: 00010000)
Error at [00FF0425] must be FF, but found 03 (bits: 11111100)
Error at [00FF0426] must be FF, but found EF (bits: 00010000)
Error at [00FF0427] must be FF, but found 03 (bits: 11111100)
Error at [00FF0428] must be FF, but found EF (bits: 00010000)
Error at [00FF0429] must be FF, but found 03 (bits: 11111100)
Error at [00FF042A] must be FF, but found EF (bits: 00010000)
Error at [00FF042B] must be FF, but found 03 (bits: 11111100)
Error at [00FF042C] must be FF, but found EF (bits: 00010000)
Error at [00FF042D] must be FF, but found 03 (bits: 11111100)
Error at [00FF042E] must be FF, but found EF (bits: 00010000)
Error at [00FF042F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0430] must be FF, but found EF (bits: 00010000)
Error at [00FF0431] must be FF, but found 03 (bits: 11111100)
Error at [00FF0432] must be FF, but found EF (bits: 00010000)
Error at [00FF0433] must be FF, but found 03 (bits: 11111100)
Error at [00FF0434] must be FF, but found 18 (bits: 11100111)
Error at [00FF0435] must be FF, but found C6 (bits: 00111001)
Error at [00FF0436] must be FF, but found 18 (bits: 11100111)
Error at [00FF0437] must be FF, but found C6 (bits: 00111001)
Error at [00FF0438] must be FF, but found EF (bits: 00010000)
Error at [00FF0439] must be FF, but found 03 (bits: 11111100)
Error at [00FF043A] must be FF, but found EF (bits: 00010000)
Error at [00FF043B] must be FF, but found 03 (bits: 11111100)
Error at [00FF043C] must be FF, but found EF (bits: 00010000)
Error at [00FF043D] must be FF, but found 03 (bits: 11111100)
Error at [00FF043E] must be FF, but found EF (bits: 00010000)
Error at [00FF043F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0440] must be FF, but found EF (bits: 00010000)
Error at [00FF0441] must be FF, but found 03 (bits: 11111100)
Error at [00FF0442] must be FF, but found EF (bits: 00010000)
Error at [00FF0443] must be FF, but found 03 (bits: 11111100)
Error at [00FF0444] must be FF, but found EF (bits: 00010000)
Error at [00FF0445] must be FF, but found 03 (bits: 11111100)
Error at [00FF0446] must be FF, but found EF (bits: 00010000)
Error at [00FF0447] must be FF, but found 03 (bits: 11111100)
Error at [00FF0448] must be FF, but found EF (bits: 00010000)
Error at [00FF0449] must be FF, but found 03 (bits: 11111100)
Error at [00FF044A] must be FF, but found EF (bits: 00010000)
Error at [00FF044B] must be FF, but found 03 (bits: 11111100)
Error at [00FF044C] must be FF, but found EF (bits: 00010000)
Error at [00FF044D] must be FF, but found 03 (bits: 11111100)
Error at [00FF044E] must be FF, but found EF (bits: 00010000)
Error at [00FF044F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0450] must be FF, but found EF (bits: 00010000)
Error at [00FF0451] must be FF, but found 03 (bits: 11111100)
Error at [00FF0452] must be FF, but found EF (bits: 00010000)
Error at [00FF0453] must be FF, but found 03 (bits: 11111100)
Error at [00FF0454] must be FF, but found EF (bits: 00010000)
Error at [00FF0455] must be FF, but found 03 (bits: 11111100)
Error at [00FF0456] must be FF, but found EF (bits: 00010000)
Error at [00FF0457] must be FF, but found 03 (bits: 11111100)
Error at [00FF0458] must be FF, but found EF (bits: 00010000)
Error at [00FF0459] must be FF, but found 03 (bits: 11111100)
Error at [00FF045A] must be FF, but found EF (bits: 00010000)
Error at [00FF045B] must be FF, but found 03 (bits: 11111100)
Error at [00FF045C] must be FF, but found EF (bits: 00010000)
Error at [00FF045D] must be FF, but found 03 (bits: 11111100)
Error at [00FF045E] must be FF, but found EF (bits: 00010000)
Error at [00FF045F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0460] must be FF, but found 0F (bits: 11110000)
Error at [00FF0461] must be FF, but found 00 (bits: 11111111)
Error at [00FF0462] must be FF, but found 18 (bits: 11100111)
Error at [00FF0463] must be FF, but found C6 (bits: 00111001)
Error at [00FF0464] must be FF, but found EF (bits: 00010000)
Error at [00FF0465] must be FF, but found 03 (bits: 11111100)
Error at [00FF0466] must be FF, but found EF (bits: 00010000)
Error at [00FF0467] must be FF, but found 03 (bits: 11111100)
Error at [00FF0468] must be FF, but found EF (bits: 00010000)
Error at [00FF0469] must be FF, but found 03 (bits: 11111100)
Error at [00FF046A] must be FF, but found EF (bits: 00010000)
Error at [00FF046B] must be FF, but found 03 (bits: 11111100)
Error at [00FF046C] must be FF, but found EF (bits: 00010000)
Error at [00FF046D] must be FF, but found 03 (bits: 11111100)
Error at [00FF046E] must be FF, but found EF (bits: 00010000)
Error at [00FF046F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0470] must be FF, but found EF (bits: 00010000)
Error at [00FF0471] must be FF, but found 03 (bits: 11111100)
Error at [00FF0472] must be FF, but found EF (bits: 00010000)
Error at [00FF0473] must be FF, but found 03 (bits: 11111100)
Error at [00FF0474] must be FF, but found EF (bits: 00010000)
Error at [00FF0475] must be FF, but found 03 (bits: 11111100)
Error at [00FF0476] must be FF, but found EF (bits: 00010000)
Error at [00FF0477] must be FF, but found 03 (bits: 11111100)
Error at [00FF0478] must be FF, but found EF (bits: 00010000)
Error at [00FF0479] must be FF, but found 03 (bits: 11111100)
Error at [00FF047A] must be FF, but found EF (bits: 00010000)
Error at [00FF047B] must be FF, but found 03 (bits: 11111100)
Error at [00FF047C] must be FF, but found EF (bits: 00010000)
Error at [00FF047D] must be FF, but found 03 (bits: 11111100)
Error at [00FF047E] must be FF, but found EF (bits: 00010000)
Error at [00FF047F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0480] must be FF, but found 18 (bits: 11100111)
Error at [00FF0481] must be FF, but found C6 (bits: 00111001)
Error at [00FF0482] must be FF, but found 18 (bits: 11100111)
Error at [00FF0483] must be FF, but found C6 (bits: 00111001)
Error at [00FF0484] must be FF, but found EF (bits: 00010000)
Error at [00FF0485] must be FF, but found 03 (bits: 11111100)
Error at [00FF0486] must be FF, but found EF (bits: 00010000)
Error at [00FF0487] must be FF, but found 03 (bits: 11111100)
Error at [00FF0488] must be FF, but found EF (bits: 00010000)
Error at [00FF0489] must be FF, but found 03 (bits: 11111100)
Error at [00FF048A] must be FF, but found EF (bits: 00010000)
Error at [00FF048B] must be FF, but found 03 (bits: 11111100)
Error at [00FF048C] must be FF, but found EF (bits: 00010000)
Error at [00FF048D] must be FF, but found 03 (bits: 11111100)
Error at [00FF048E] must be FF, but found EF (bits: 00010000)
Error at [00FF048F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0490] must be FF, but found EF (bits: 00010000)
Error at [00FF0491] must be FF, but found 03 (bits: 11111100)
Error at [00FF0492] must be FF, but found EF (bits: 00010000)
Error at [00FF0493] must be FF, but found 03 (bits: 11111100)
Error at [00FF0494] must be FF, but found 18 (bits: 11100111)
Error at [00FF0495] must be FF, but found C6 (bits: 00111001)
Error at [00FF0496] must be FF, but found 18 (bits: 11100111)
Error at [00FF0497] must be FF, but found C6 (bits: 00111001)
Error at [00FF0498] must be FF, but found EF (bits: 00010000)
Error at [00FF0499] must be FF, but found 03 (bits: 11111100)
Error at [00FF049A] must be FF, but found EF (bits: 00010000)
Error at [00FF049B] must be FF, but found 03 (bits: 11111100)
Error at [00FF049C] must be FF, but found EF (bits: 00010000)
Error at [00FF049D] must be FF, but found 03 (bits: 11111100)
Error at [00FF049E] must be FF, but found EF (bits: 00010000)
Error at [00FF049F] must be FF, but found 03 (bits: 11111100)
Error at [00FF04A0] must be FF, but found EF (bits: 00010000)
Error at [00FF04A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04A2] must be FF, but found EF (bits: 00010000)
Error at [00FF04A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04A4] must be FF, but found EF (bits: 00010000)
Error at [00FF04A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04A6] must be FF, but found EF (bits: 00010000)
Error at [00FF04A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04A8] must be FF, but found EF (bits: 00010000)
Error at [00FF04A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF04AA] must be FF, but found EF (bits: 00010000)
Error at [00FF04AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF04AC] must be FF, but found EF (bits: 00010000)
Error at [00FF04AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF04AE] must be FF, but found EF (bits: 00010000)
Error at [00FF04AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF04B0] must be FF, but found EF (bits: 00010000)
Error at [00FF04B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04B2] must be FF, but found EF (bits: 00010000)
Error at [00FF04B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04B4] must be FF, but found EF (bits: 00010000)
Error at [00FF04B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04B6] must be FF, but found EF (bits: 00010000)
Error at [00FF04B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04B8] must be FF, but found EF (bits: 00010000)
Error at [00FF04B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF04BA] must be FF, but found EF (bits: 00010000)
Error at [00FF04BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF04BC] must be FF, but found EF (bits: 00010000)
Error at [00FF04BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF04BE] must be FF, but found EF (bits: 00010000)
Error at [00FF04BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF04C0] must be FF, but found EF (bits: 00010000)
Error at [00FF04C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04C2] must be FF, but found EF (bits: 00010000)
Error at [00FF04C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04C4] must be FF, but found EF (bits: 00010000)
Error at [00FF04C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04C6] must be FF, but found EF (bits: 00010000)
Error at [00FF04C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04C8] must be FF, but found EF (bits: 00010000)
Error at [00FF04C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF04CA] must be FF, but found EF (bits: 00010000)
Error at [00FF04CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF04CC] must be FF, but found EF (bits: 00010000)
Error at [00FF04CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF04CE] must be FF, but found EF (bits: 00010000)
Error at [00FF04CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF04D0] must be FF, but found EF (bits: 00010000)
Error at [00FF04D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04D2] must be FF, but found EF (bits: 00010000)
Error at [00FF04D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04D4] must be FF, but found EF (bits: 00010000)
Error at [00FF04D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04D6] must be FF, but found EF (bits: 00010000)
Error at [00FF04D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04D8] must be FF, but found 18 (bits: 11100111)
Error at [00FF04D9] must be FF, but found C6 (bits: 00111001)
Error at [00FF04DA] must be FF, but found 18 (bits: 11100111)
Error at [00FF04DB] must be FF, but found C6 (bits: 00111001)
Error at [00FF04DC] must be FF, but found EF (bits: 00010000)
Error at [00FF04DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF04DE] must be FF, but found EF (bits: 00010000)
Error at [00FF04DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF04E0] must be FF, but found EF (bits: 00010000)
Error at [00FF04E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04E2] must be FF, but found EF (bits: 00010000)
Error at [00FF04E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04E4] must be FF, but found EF (bits: 00010000)
Error at [00FF04E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04E6] must be FF, but found EF (bits: 00010000)
Error at [00FF04E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04E8] must be FF, but found EF (bits: 00010000)
Error at [00FF04E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF04EA] must be FF, but found EF (bits: 00010000)
Error at [00FF04EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF04EC] must be FF, but found EF (bits: 00010000)
Error at [00FF04ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF04EE] must be FF, but found EF (bits: 00010000)
Error at [00FF04EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF04F0] must be FF, but found EF (bits: 00010000)
Error at [00FF04F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF04F2] must be FF, but found EF (bits: 00010000)
Error at [00FF04F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF04F4] must be FF, but found EF (bits: 00010000)
Error at [00FF04F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF04F6] must be FF, but found EF (bits: 00010000)
Error at [00FF04F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF04F8] must be FF, but found EF (bits: 00010000)
Error at [00FF04F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF04FA] must be FF, but found EF (bits: 00010000)
Error at [00FF04FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF04FC] must be FF, but found EF (bits: 00010000)
Error at [00FF04FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF04FE] must be FF, but found EF (bits: 00010000)
Error at [00FF04FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0500] must be FF, but found EF (bits: 00010000)
Error at [00FF0501] must be FF, but found 03 (bits: 11111100)
Error at [00FF0502] must be FF, but found EF (bits: 00010000)
Error at [00FF0503] must be FF, but found 03 (bits: 11111100)
Error at [00FF0504] must be FF, but found EF (bits: 00010000)
Error at [00FF0505] must be FF, but found 03 (bits: 11111100)
Error at [00FF0506] must be FF, but found EF (bits: 00010000)
Error at [00FF0507] must be FF, but found 03 (bits: 11111100)
Error at [00FF0508] must be FF, but found EF (bits: 00010000)
Error at [00FF0509] must be FF, but found 03 (bits: 11111100)
Error at [00FF050A] must be FF, but found EF (bits: 00010000)
Error at [00FF050B] must be FF, but found 03 (bits: 11111100)
Error at [00FF050C] must be FF, but found EF (bits: 00010000)
Error at [00FF050D] must be FF, but found 03 (bits: 11111100)
Error at [00FF050E] must be FF, but found EF (bits: 00010000)
Error at [00FF050F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0510] must be FF, but found 0F (bits: 11110000)
Error at [00FF0511] must be FF, but found 00 (bits: 11111111)
Error at [00FF0512] must be FF, but found 18 (bits: 11100111)
Error at [00FF0513] must be FF, but found C6 (bits: 00111001)
Error at [00FF0514] must be FF, but found EF (bits: 00010000)
Error at [00FF0515] must be FF, but found 03 (bits: 11111100)
Error at [00FF0516] must be FF, but found EF (bits: 00010000)
Error at [00FF0517] must be FF, but found 03 (bits: 11111100)
Error at [00FF0518] must be FF, but found EF (bits: 00010000)
Error at [00FF0519] must be FF, but found 03 (bits: 11111100)
Error at [00FF051A] must be FF, but found EF (bits: 00010000)
Error at [00FF051B] must be FF, but found 03 (bits: 11111100)
Error at [00FF051C] must be FF, but found EF (bits: 00010000)
Error at [00FF051D] must be FF, but found 03 (bits: 11111100)
Error at [00FF051E] must be FF, but found EF (bits: 00010000)
Error at [00FF051F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0520] must be FF, but found EF (bits: 00010000)
Error at [00FF0521] must be FF, but found 03 (bits: 11111100)
Error at [00FF0522] must be FF, but found EF (bits: 00010000)
Error at [00FF0523] must be FF, but found 03 (bits: 11111100)
Error at [00FF0524] must be FF, but found 18 (bits: 11100111)
Error at [00FF0525] must be FF, but found C6 (bits: 00111001)
Error at [00FF0526] must be FF, but found 18 (bits: 11100111)
Error at [00FF0527] must be FF, but found C6 (bits: 00111001)
Error at [00FF0528] must be FF, but found EF (bits: 00010000)
Error at [00FF0529] must be FF, but found 03 (bits: 11111100)
Error at [00FF052A] must be FF, but found EF (bits: 00010000)
Error at [00FF052B] must be FF, but found 03 (bits: 11111100)
Error at [00FF052C] must be FF, but found EF (bits: 00010000)
Error at [00FF052D] must be FF, but found 03 (bits: 11111100)
Error at [00FF052E] must be FF, but found EF (bits: 00010000)
Error at [00FF052F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0530] must be FF, but found EF (bits: 00010000)
Error at [00FF0531] must be FF, but found 03 (bits: 11111100)
Error at [00FF0532] must be FF, but found EF (bits: 00010000)
Error at [00FF0533] must be FF, but found 03 (bits: 11111100)
Error at [00FF0534] must be FF, but found EF (bits: 00010000)
Error at [00FF0535] must be FF, but found 03 (bits: 11111100)
Error at [00FF0536] must be FF, but found EF (bits: 00010000)
Error at [00FF0537] must be FF, but found 03 (bits: 11111100)
Error at [00FF0538] must be FF, but found 18 (bits: 11100111)
Error at [00FF0539] must be FF, but found C6 (bits: 00111001)
Error at [00FF053A] must be FF, but found 18 (bits: 11100111)
Error at [00FF053B] must be FF, but found C6 (bits: 00111001)
Error at [00FF053C] must be FF, but found EF (bits: 00010000)
Error at [00FF053D] must be FF, but found 03 (bits: 11111100)
Error at [00FF053E] must be FF, but found EF (bits: 00010000)
Error at [00FF053F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0540] must be FF, but found EF (bits: 00010000)
Error at [00FF0541] must be FF, but found 03 (bits: 11111100)
Error at [00FF0542] must be FF, but found EF (bits: 00010000)
Error at [00FF0543] must be FF, but found 03 (bits: 11111100)
Error at [00FF0544] must be FF, but found EF (bits: 00010000)
Error at [00FF0545] must be FF, but found 03 (bits: 11111100)
Error at [00FF0546] must be FF, but found EF (bits: 00010000)
Error at [00FF0547] must be FF, but found 03 (bits: 11111100)
Error at [00FF0548] must be FF, but found EF (bits: 00010000)
Error at [00FF0549] must be FF, but found 03 (bits: 11111100)
Error at [00FF054A] must be FF, but found EF (bits: 00010000)
Error at [00FF054B] must be FF, but found 03 (bits: 11111100)
Error at [00FF054C] must be FF, but found EF (bits: 00010000)
Error at [00FF054D] must be FF, but found 03 (bits: 11111100)
Error at [00FF054E] must be FF, but found EF (bits: 00010000)
Error at [00FF054F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0550] must be FF, but found EF (bits: 00010000)
Error at [00FF0551] must be FF, but found 03 (bits: 11111100)
Error at [00FF0552] must be FF, but found EF (bits: 00010000)
Error at [00FF0553] must be FF, but found 03 (bits: 11111100)
Error at [00FF0554] must be FF, but found EF (bits: 00010000)
Error at [00FF0555] must be FF, but found 03 (bits: 11111100)
Error at [00FF0556] must be FF, but found EF (bits: 00010000)
Error at [00FF0557] must be FF, but found 03 (bits: 11111100)
Error at [00FF0558] must be FF, but found EF (bits: 00010000)
Error at [00FF0559] must be FF, but found 03 (bits: 11111100)
Error at [00FF055A] must be FF, but found EF (bits: 00010000)
Error at [00FF055B] must be FF, but found 03 (bits: 11111100)
Error at [00FF055C] must be FF, but found EF (bits: 00010000)
Error at [00FF055D] must be FF, but found 03 (bits: 11111100)
Error at [00FF055E] must be FF, but found EF (bits: 00010000)
Error at [00FF055F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0560] must be FF, but found EF (bits: 00010000)
Error at [00FF0561] must be FF, but found 03 (bits: 11111100)
Error at [00FF0562] must be FF, but found EF (bits: 00010000)
Error at [00FF0563] must be FF, but found 03 (bits: 11111100)
Error at [00FF0564] must be FF, but found EF (bits: 00010000)
Error at [00FF0565] must be FF, but found 03 (bits: 11111100)
Error at [00FF0566] must be FF, but found EF (bits: 00010000)
Error at [00FF0567] must be FF, but found 03 (bits: 11111100)
Error at [00FF0568] must be FF, but found EF (bits: 00010000)
Error at [00FF0569] must be FF, but found 03 (bits: 11111100)
Error at [00FF056A] must be FF, but found EF (bits: 00010000)
Error at [00FF056B] must be FF, but found 03 (bits: 11111100)
Error at [00FF056C] must be FF, but found EF (bits: 00010000)
Error at [00FF056D] must be FF, but found 03 (bits: 11111100)
Error at [00FF056E] must be FF, but found EF (bits: 00010000)
Error at [00FF056F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0570] must be FF, but found EF (bits: 00010000)
Error at [00FF0571] must be FF, but found 03 (bits: 11111100)
Error at [00FF0572] must be FF, but found EF (bits: 00010000)
Error at [00FF0573] must be FF, but found 03 (bits: 11111100)
Error at [00FF0574] must be FF, but found EF (bits: 00010000)
Error at [00FF0575] must be FF, but found 03 (bits: 11111100)
Error at [00FF0576] must be FF, but found EF (bits: 00010000)
Error at [00FF0577] must be FF, but found 03 (bits: 11111100)
Error at [00FF0578] must be FF, but found EF (bits: 00010000)
Error at [00FF0579] must be FF, but found 03 (bits: 11111100)
Error at [00FF057A] must be FF, but found EF (bits: 00010000)
Error at [00FF057B] must be FF, but found 03 (bits: 11111100)
Error at [00FF057C] must be FF, but found EF (bits: 00010000)
Error at [00FF057D] must be FF, but found 03 (bits: 11111100)
Error at [00FF057E] must be FF, but found EF (bits: 00010000)
Error at [00FF057F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0580] must be FF, but found EF (bits: 00010000)
Error at [00FF0581] must be FF, but found 03 (bits: 11111100)
Error at [00FF0582] must be FF, but found EF (bits: 00010000)
Error at [00FF0583] must be FF, but found 03 (bits: 11111100)
Error at [00FF0584] must be FF, but found 18 (bits: 11100111)
Error at [00FF0585] must be FF, but found C6 (bits: 00111001)
Error at [00FF0586] must be FF, but found 18 (bits: 11100111)
Error at [00FF0587] must be FF, but found C6 (bits: 00111001)
Error at [00FF0588] must be FF, but found EF (bits: 00010000)
Error at [00FF0589] must be FF, but found 03 (bits: 11111100)
Error at [00FF058A] must be FF, but found EF (bits: 00010000)
Error at [00FF058B] must be FF, but found 03 (bits: 11111100)
Error at [00FF058C] must be FF, but found EF (bits: 00010000)
Error at [00FF058D] must be FF, but found 03 (bits: 11111100)
Error at [00FF058E] must be FF, but found EF (bits: 00010000)
Error at [00FF058F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0590] must be FF, but found EF (bits: 00010000)
Error at [00FF0591] must be FF, but found 03 (bits: 11111100)
Error at [00FF0592] must be FF, but found EF (bits: 00010000)
Error at [00FF0593] must be FF, but found 03 (bits: 11111100)
Error at [00FF0594] must be FF, but found EF (bits: 00010000)
Error at [00FF0595] must be FF, but found 03 (bits: 11111100)
Error at [00FF0596] must be FF, but found EF (bits: 00010000)
Error at [00FF0597] must be FF, but found 03 (bits: 11111100)
Error at [00FF0598] must be FF, but found EF (bits: 00010000)
Error at [00FF0599] must be FF, but found 03 (bits: 11111100)
Error at [00FF059A] must be FF, but found EF (bits: 00010000)
Error at [00FF059B] must be FF, but found 03 (bits: 11111100)
Error at [00FF059C] must be FF, but found EF (bits: 00010000)
Error at [00FF059D] must be FF, but found 03 (bits: 11111100)
Error at [00FF059E] must be FF, but found EF (bits: 00010000)
Error at [00FF059F] must be FF, but found 03 (bits: 11111100)
Error at [00FF05A0] must be FF, but found EF (bits: 00010000)
Error at [00FF05A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF05A2] must be FF, but found EF (bits: 00010000)
Error at [00FF05A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF05A4] must be FF, but found EF (bits: 00010000)
Error at [00FF05A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05A6] must be FF, but found EF (bits: 00010000)
Error at [00FF05A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05A8] must be FF, but found EF (bits: 00010000)
Error at [00FF05A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05AA] must be FF, but found EF (bits: 00010000)
Error at [00FF05AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05AC] must be FF, but found EF (bits: 00010000)
Error at [00FF05AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF05AE] must be FF, but found EF (bits: 00010000)
Error at [00FF05AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF05B0] must be FF, but found EF (bits: 00010000)
Error at [00FF05B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF05B2] must be FF, but found EF (bits: 00010000)
Error at [00FF05B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF05B4] must be FF, but found EF (bits: 00010000)
Error at [00FF05B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05B6] must be FF, but found EF (bits: 00010000)
Error at [00FF05B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05B8] must be FF, but found EF (bits: 00010000)
Error at [00FF05B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05BA] must be FF, but found EF (bits: 00010000)
Error at [00FF05BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05BC] must be FF, but found EF (bits: 00010000)
Error at [00FF05BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF05BE] must be FF, but found EF (bits: 00010000)
Error at [00FF05BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF05C0] must be FF, but found 0F (bits: 11110000)
Error at [00FF05C1] must be FF, but found 00 (bits: 11111111)
Error at [00FF05C2] must be FF, but found 18 (bits: 11100111)
Error at [00FF05C3] must be FF, but found C6 (bits: 00111001)
Error at [00FF05C4] must be FF, but found EF (bits: 00010000)
Error at [00FF05C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05C6] must be FF, but found EF (bits: 00010000)
Error at [00FF05C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05C8] must be FF, but found EF (bits: 00010000)
Error at [00FF05C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05CA] must be FF, but found EF (bits: 00010000)
Error at [00FF05CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05CC] must be FF, but found EF (bits: 00010000)
Error at [00FF05CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF05CE] must be FF, but found EF (bits: 00010000)
Error at [00FF05CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF05D0] must be FF, but found EF (bits: 00010000)
Error at [00FF05D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF05D2] must be FF, but found EF (bits: 00010000)
Error at [00FF05D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF05D4] must be FF, but found EF (bits: 00010000)
Error at [00FF05D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05D6] must be FF, but found EF (bits: 00010000)
Error at [00FF05D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05D8] must be FF, but found EF (bits: 00010000)
Error at [00FF05D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05DA] must be FF, but found EF (bits: 00010000)
Error at [00FF05DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05DC] must be FF, but found EF (bits: 00010000)
Error at [00FF05DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF05DE] must be FF, but found EF (bits: 00010000)
Error at [00FF05DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF05E0] must be FF, but found EF (bits: 00010000)
Error at [00FF05E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF05E2] must be FF, but found EF (bits: 00010000)
Error at [00FF05E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF05E4] must be FF, but found EF (bits: 00010000)
Error at [00FF05E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05E6] must be FF, but found EF (bits: 00010000)
Error at [00FF05E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05E8] must be FF, but found EF (bits: 00010000)
Error at [00FF05E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05EA] must be FF, but found EF (bits: 00010000)
Error at [00FF05EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05EC] must be FF, but found EF (bits: 00010000)
Error at [00FF05ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF05EE] must be FF, but found EF (bits: 00010000)
Error at [00FF05EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF05F0] must be FF, but found EF (bits: 00010000)
Error at [00FF05F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF05F2] must be FF, but found EF (bits: 00010000)
Error at [00FF05F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF05F4] must be FF, but found EF (bits: 00010000)
Error at [00FF05F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF05F6] must be FF, but found EF (bits: 00010000)
Error at [00FF05F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF05F8] must be FF, but found EF (bits: 00010000)
Error at [00FF05F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF05FA] must be FF, but found EF (bits: 00010000)
Error at [00FF05FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF05FC] must be FF, but found EF (bits: 00010000)
Error at [00FF05FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF05FE] must be FF, but found EF (bits: 00010000)
Error at [00FF05FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0600] must be FF, but found EF (bits: 00010000)
Error at [00FF0601] must be FF, but found 03 (bits: 11111100)
Error at [00FF0602] must be FF, but found EF (bits: 00010000)
Error at [00FF0603] must be FF, but found 03 (bits: 11111100)
Error at [00FF0604] must be FF, but found EF (bits: 00010000)
Error at [00FF0605] must be FF, but found 03 (bits: 11111100)
Error at [00FF0606] must be FF, but found EF (bits: 00010000)
Error at [00FF0607] must be FF, but found 03 (bits: 11111100)
Error at [00FF0608] must be FF, but found EF (bits: 00010000)
Error at [00FF0609] must be FF, but found 03 (bits: 11111100)
Error at [00FF060A] must be FF, but found EF (bits: 00010000)
Error at [00FF060B] must be FF, but found 03 (bits: 11111100)
Error at [00FF060C] must be FF, but found EF (bits: 00010000)
Error at [00FF060D] must be FF, but found 03 (bits: 11111100)
Error at [00FF060E] must be FF, but found EF (bits: 00010000)
Error at [00FF060F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0610] must be FF, but found EF (bits: 00010000)
Error at [00FF0611] must be FF, but found 03 (bits: 11111100)
Error at [00FF0612] must be FF, but found EF (bits: 00010000)
Error at [00FF0613] must be FF, but found 03 (bits: 11111100)
Error at [00FF0614] must be FF, but found EF (bits: 00010000)
Error at [00FF0615] must be FF, but found 03 (bits: 11111100)
Error at [00FF0616] must be FF, but found EF (bits: 00010000)
Error at [00FF0617] must be FF, but found 03 (bits: 11111100)
Error at [00FF0618] must be FF, but found EF (bits: 00010000)
Error at [00FF0619] must be FF, but found 03 (bits: 11111100)
Error at [00FF061A] must be FF, but found EF (bits: 00010000)
Error at [00FF061B] must be FF, but found 03 (bits: 11111100)
Error at [00FF061C] must be FF, but found EF (bits: 00010000)
Error at [00FF061D] must be FF, but found 03 (bits: 11111100)
Error at [00FF061E] must be FF, but found EF (bits: 00010000)
Error at [00FF061F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0620] must be FF, but found EF (bits: 00010000)
Error at [00FF0621] must be FF, but found 03 (bits: 11111100)
Error at [00FF0622] must be FF, but found EF (bits: 00010000)
Error at [00FF0623] must be FF, but found 03 (bits: 11111100)
Error at [00FF0624] must be FF, but found EF (bits: 00010000)
Error at [00FF0625] must be FF, but found 03 (bits: 11111100)
Error at [00FF0626] must be FF, but found EF (bits: 00010000)
Error at [00FF0627] must be FF, but found 03 (bits: 11111100)
Error at [00FF0628] must be FF, but found EF (bits: 00010000)
Error at [00FF0629] must be FF, but found 03 (bits: 11111100)
Error at [00FF062A] must be FF, but found EF (bits: 00010000)
Error at [00FF062B] must be FF, but found 03 (bits: 11111100)
Error at [00FF062C] must be FF, but found EF (bits: 00010000)
Error at [00FF062D] must be FF, but found 03 (bits: 11111100)
Error at [00FF062E] must be FF, but found EF (bits: 00010000)
Error at [00FF062F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0630] must be FF, but found EF (bits: 00010000)
Error at [00FF0631] must be FF, but found 03 (bits: 11111100)
Error at [00FF0632] must be FF, but found EF (bits: 00010000)
Error at [00FF0633] must be FF, but found 03 (bits: 11111100)
Error at [00FF0634] must be FF, but found EF (bits: 00010000)
Error at [00FF0635] must be FF, but found 03 (bits: 11111100)
Error at [00FF0636] must be FF, but found EF (bits: 00010000)
Error at [00FF0637] must be FF, but found 03 (bits: 11111100)
Error at [00FF0638] must be FF, but found EF (bits: 00010000)
Error at [00FF0639] must be FF, but found 03 (bits: 11111100)
Error at [00FF063A] must be FF, but found EF (bits: 00010000)
Error at [00FF063B] must be FF, but found 03 (bits: 11111100)
Error at [00FF063C] must be FF, but found 18 (bits: 11100111)
Error at [00FF063D] must be FF, but found C6 (bits: 00111001)
Error at [00FF063E] must be FF, but found 18 (bits: 11100111)
Error at [00FF063F] must be FF, but found C6 (bits: 00111001)
Error at [00FF0640] must be FF, but found EF (bits: 00010000)
Error at [00FF0641] must be FF, but found 03 (bits: 11111100)
Error at [00FF0642] must be FF, but found EF (bits: 00010000)
Error at [00FF0643] must be FF, but found 03 (bits: 11111100)
Error at [00FF0644] must be FF, but found EF (bits: 00010000)
Error at [00FF0645] must be FF, but found 03 (bits: 11111100)
Error at [00FF0646] must be FF, but found EF (bits: 00010000)
Error at [00FF0647] must be FF, but found 03 (bits: 11111100)
Error at [00FF0648] must be FF, but found EF (bits: 00010000)
Error at [00FF0649] must be FF, but found 03 (bits: 11111100)
Error at [00FF064A] must be FF, but found EF (bits: 00010000)
Error at [00FF064B] must be FF, but found 03 (bits: 11111100)
Error at [00FF064C] must be FF, but found EF (bits: 00010000)
Error at [00FF064D] must be FF, but found 03 (bits: 11111100)
Error at [00FF064E] must be FF, but found EF (bits: 00010000)
Error at [00FF064F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0650] must be FF, but found 18 (bits: 11100111)
Error at [00FF0651] must be FF, but found C6 (bits: 00111001)
Error at [00FF0652] must be FF, but found 18 (bits: 11100111)
Error at [00FF0653] must be FF, but found C6 (bits: 00111001)
Error at [00FF0654] must be FF, but found EF (bits: 00010000)
Error at [00FF0655] must be FF, but found 03 (bits: 11111100)
Error at [00FF0656] must be FF, but found EF (bits: 00010000)
Error at [00FF0657] must be FF, but found 03 (bits: 11111100)
Error at [00FF0658] must be FF, but found EF (bits: 00010000)
Error at [00FF0659] must be FF, but found 03 (bits: 11111100)
Error at [00FF065A] must be FF, but found EF (bits: 00010000)
Error at [00FF065B] must be FF, but found 03 (bits: 11111100)
Error at [00FF065C] must be FF, but found EF (bits: 00010000)
Error at [00FF065D] must be FF, but found 03 (bits: 11111100)
Error at [00FF065E] must be FF, but found EF (bits: 00010000)
Error at [00FF065F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0660] must be FF, but found EF (bits: 00010000)
Error at [00FF0661] must be FF, but found 03 (bits: 11111100)
Error at [00FF0662] must be FF, but found EF (bits: 00010000)
Error at [00FF0663] must be FF, but found 03 (bits: 11111100)
Error at [00FF0664] must be FF, but found EF (bits: 00010000)
Error at [00FF0665] must be FF, but found 03 (bits: 11111100)
Error at [00FF0666] must be FF, but found EF (bits: 00010000)
Error at [00FF0667] must be FF, but found 03 (bits: 11111100)
Error at [00FF0668] must be FF, but found EF (bits: 00010000)
Error at [00FF0669] must be FF, but found 03 (bits: 11111100)
Error at [00FF066A] must be FF, but found EF (bits: 00010000)
Error at [00FF066B] must be FF, but found 03 (bits: 11111100)
Error at [00FF066C] must be FF, but found EF (bits: 00010000)
Error at [00FF066D] must be FF, but found 03 (bits: 11111100)
Error at [00FF066E] must be FF, but found EF (bits: 00010000)
Error at [00FF066F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0670] must be FF, but found 0F (bits: 11110000)
Error at [00FF0671] must be FF, but found 00 (bits: 11111111)
Error at [00FF0672] must be FF, but found 18 (bits: 11100111)
Error at [00FF0673] must be FF, but found C6 (bits: 00111001)
Error at [00FF0674] must be FF, but found EF (bits: 00010000)
Error at [00FF0675] must be FF, but found 03 (bits: 11111100)
Error at [00FF0676] must be FF, but found EF (bits: 00010000)
Error at [00FF0677] must be FF, but found 03 (bits: 11111100)
Error at [00FF0678] must be FF, but found EF (bits: 00010000)
Error at [00FF0679] must be FF, but found 03 (bits: 11111100)
Error at [00FF067A] must be FF, but found EF (bits: 00010000)
Error at [00FF067B] must be FF, but found 03 (bits: 11111100)
Error at [00FF067C] must be FF, but found EF (bits: 00010000)
Error at [00FF067D] must be FF, but found 03 (bits: 11111100)
Error at [00FF067E] must be FF, but found EF (bits: 00010000)
Error at [00FF067F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0680] must be FF, but found EF (bits: 00010000)
Error at [00FF0681] must be FF, but found 03 (bits: 11111100)
Error at [00FF0682] must be FF, but found EF (bits: 00010000)
Error at [00FF0683] must be FF, but found 03 (bits: 11111100)
Error at [00FF0684] must be FF, but found EF (bits: 00010000)
Error at [00FF0685] must be FF, but found 03 (bits: 11111100)
Error at [00FF0686] must be FF, but found EF (bits: 00010000)
Error at [00FF0687] must be FF, but found 03 (bits: 11111100)
Error at [00FF0688] must be FF, but found EF (bits: 00010000)
Error at [00FF0689] must be FF, but found 03 (bits: 11111100)
Error at [00FF068A] must be FF, but found EF (bits: 00010000)
Error at [00FF068B] must be FF, but found 03 (bits: 11111100)
Error at [00FF068C] must be FF, but found EF (bits: 00010000)
Error at [00FF068D] must be FF, but found 03 (bits: 11111100)
Error at [00FF068E] must be FF, but found EF (bits: 00010000)
Error at [00FF068F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0690] must be FF, but found EF (bits: 00010000)
Error at [00FF0691] must be FF, but found 03 (bits: 11111100)
Error at [00FF0692] must be FF, but found EF (bits: 00010000)
Error at [00FF0693] must be FF, but found 03 (bits: 11111100)
Error at [00FF0694] must be FF, but found EF (bits: 00010000)
Error at [00FF0695] must be FF, but found 03 (bits: 11111100)
Error at [00FF0696] must be FF, but found EF (bits: 00010000)
Error at [00FF0697] must be FF, but found 03 (bits: 11111100)
Error at [00FF0698] must be FF, but found EF (bits: 00010000)
Error at [00FF0699] must be FF, but found 03 (bits: 11111100)
Error at [00FF069A] must be FF, but found EF (bits: 00010000)
Error at [00FF069B] must be FF, but found 03 (bits: 11111100)
Error at [00FF069C] must be FF, but found EF (bits: 00010000)
Error at [00FF069D] must be FF, but found 03 (bits: 11111100)
Error at [00FF069E] must be FF, but found EF (bits: 00010000)
Error at [00FF069F] must be FF, but found 03 (bits: 11111100)
Error at [00FF06A0] must be FF, but found EF (bits: 00010000)
Error at [00FF06A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF06A2] must be FF, but found EF (bits: 00010000)
Error at [00FF06A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF06A4] must be FF, but found EF (bits: 00010000)
Error at [00FF06A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF06A6] must be FF, but found EF (bits: 00010000)
Error at [00FF06A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF06A8] must be FF, but found EF (bits: 00010000)
Error at [00FF06A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06AA] must be FF, but found EF (bits: 00010000)
Error at [00FF06AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06AC] must be FF, but found EF (bits: 00010000)
Error at [00FF06AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF06AE] must be FF, but found EF (bits: 00010000)
Error at [00FF06AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF06B0] must be FF, but found EF (bits: 00010000)
Error at [00FF06B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF06B2] must be FF, but found EF (bits: 00010000)
Error at [00FF06B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF06B4] must be FF, but found EF (bits: 00010000)
Error at [00FF06B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF06B6] must be FF, but found EF (bits: 00010000)
Error at [00FF06B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF06B8] must be FF, but found EF (bits: 00010000)
Error at [00FF06B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06BA] must be FF, but found EF (bits: 00010000)
Error at [00FF06BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06BC] must be FF, but found EF (bits: 00010000)
Error at [00FF06BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF06BE] must be FF, but found EF (bits: 00010000)
Error at [00FF06BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF06C0] must be FF, but found EF (bits: 00010000)
Error at [00FF06C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF06C2] must be FF, but found EF (bits: 00010000)
Error at [00FF06C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF06C4] must be FF, but found EF (bits: 00010000)
Error at [00FF06C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF06C6] must be FF, but found EF (bits: 00010000)
Error at [00FF06C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF06C8] must be FF, but found EF (bits: 00010000)
Error at [00FF06C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06CA] must be FF, but found EF (bits: 00010000)
Error at [00FF06CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06CC] must be FF, but found EF (bits: 00010000)
Error at [00FF06CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF06CE] must be FF, but found EF (bits: 00010000)
Error at [00FF06CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF06D0] must be FF, but found EF (bits: 00010000)
Error at [00FF06D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF06D2] must be FF, but found EF (bits: 00010000)
Error at [00FF06D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF06D4] must be FF, but found EF (bits: 00010000)
Error at [00FF06D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF06D6] must be FF, but found EF (bits: 00010000)
Error at [00FF06D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF06D8] must be FF, but found EF (bits: 00010000)
Error at [00FF06D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06DA] must be FF, but found EF (bits: 00010000)
Error at [00FF06DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06DC] must be FF, but found EF (bits: 00010000)
Error at [00FF06DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF06DE] must be FF, but found EF (bits: 00010000)
Error at [00FF06DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF06E0] must be FF, but found 18 (bits: 11100111)
Error at [00FF06E1] must be FF, but found C6 (bits: 00111001)
Error at [00FF06E2] must be FF, but found 18 (bits: 11100111)
Error at [00FF06E3] must be FF, but found C6 (bits: 00111001)
Error at [00FF06E4] must be FF, but found EF (bits: 00010000)
Error at [00FF06E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF06E6] must be FF, but found EF (bits: 00010000)
Error at [00FF06E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF06E8] must be FF, but found EF (bits: 00010000)
Error at [00FF06E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06EA] must be FF, but found EF (bits: 00010000)
Error at [00FF06EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06EC] must be FF, but found EF (bits: 00010000)
Error at [00FF06ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF06EE] must be FF, but found EF (bits: 00010000)
Error at [00FF06EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF06F0] must be FF, but found EF (bits: 00010000)
Error at [00FF06F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF06F2] must be FF, but found EF (bits: 00010000)
Error at [00FF06F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF06F4] must be FF, but found 18 (bits: 11100111)
Error at [00FF06F5] must be FF, but found C6 (bits: 00111001)
Error at [00FF06F6] must be FF, but found 18 (bits: 11100111)
Error at [00FF06F7] must be FF, but found C6 (bits: 00111001)
Error at [00FF06F8] must be FF, but found EF (bits: 00010000)
Error at [00FF06F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF06FA] must be FF, but found EF (bits: 00010000)
Error at [00FF06FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF06FC] must be FF, but found EF (bits: 00010000)
Error at [00FF06FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF06FE] must be FF, but found EF (bits: 00010000)
Error at [00FF06FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0700] must be FF, but found EF (bits: 00010000)
Error at [00FF0701] must be FF, but found 03 (bits: 11111100)
Error at [00FF0702] must be FF, but found EF (bits: 00010000)
Error at [00FF0703] must be FF, but found 03 (bits: 11111100)
Error at [00FF0704] must be FF, but found EF (bits: 00010000)
Error at [00FF0705] must be FF, but found 03 (bits: 11111100)
Error at [00FF0706] must be FF, but found EF (bits: 00010000)
Error at [00FF0707] must be FF, but found 03 (bits: 11111100)
Error at [00FF0708] must be FF, but found EF (bits: 00010000)
Error at [00FF0709] must be FF, but found 03 (bits: 11111100)
Error at [00FF070A] must be FF, but found EF (bits: 00010000)
Error at [00FF070B] must be FF, but found 03 (bits: 11111100)
Error at [00FF070C] must be FF, but found EF (bits: 00010000)
Error at [00FF070D] must be FF, but found 03 (bits: 11111100)
Error at [00FF070E] must be FF, but found EF (bits: 00010000)
Error at [00FF070F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0710] must be FF, but found EF (bits: 00010000)
Error at [00FF0711] must be FF, but found 03 (bits: 11111100)
Error at [00FF0712] must be FF, but found EF (bits: 00010000)
Error at [00FF0713] must be FF, but found 03 (bits: 11111100)
Error at [00FF0714] must be FF, but found EF (bits: 00010000)
Error at [00FF0715] must be FF, but found 03 (bits: 11111100)
Error at [00FF0716] must be FF, but found EF (bits: 00010000)
Error at [00FF0717] must be FF, but found 03 (bits: 11111100)
Error at [00FF0718] must be FF, but found EF (bits: 00010000)
Error at [00FF0719] must be FF, but found 03 (bits: 11111100)
Error at [00FF071A] must be FF, but found EF (bits: 00010000)
Error at [00FF071B] must be FF, but found 03 (bits: 11111100)
Error at [00FF071C] must be FF, but found EF (bits: 00010000)
Error at [00FF071D] must be FF, but found 03 (bits: 11111100)
Error at [00FF071E] must be FF, but found EF (bits: 00010000)
Error at [00FF071F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0720] must be FF, but found 0F (bits: 11110000)
Error at [00FF0721] must be FF, but found 00 (bits: 11111111)
Error at [00FF0722] must be FF, but found 18 (bits: 11100111)
Error at [00FF0723] must be FF, but found C6 (bits: 00111001)
Error at [00FF0724] must be FF, but found EF (bits: 00010000)
Error at [00FF0725] must be FF, but found 03 (bits: 11111100)
Error at [00FF0726] must be FF, but found EF (bits: 00010000)
Error at [00FF0727] must be FF, but found 03 (bits: 11111100)
Error at [00FF0728] must be FF, but found EF (bits: 00010000)
Error at [00FF0729] must be FF, but found 03 (bits: 11111100)
Error at [00FF072A] must be FF, but found EF (bits: 00010000)
Error at [00FF072B] must be FF, but found 03 (bits: 11111100)
Error at [00FF072C] must be FF, but found EF (bits: 00010000)
Error at [00FF072D] must be FF, but found 03 (bits: 11111100)
Error at [00FF072E] must be FF, but found EF (bits: 00010000)
Error at [00FF072F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0730] must be FF, but found EF (bits: 00010000)
Error at [00FF0731] must be FF, but found 03 (bits: 11111100)
Error at [00FF0732] must be FF, but found EF (bits: 00010000)
Error at [00FF0733] must be FF, but found 03 (bits: 11111100)
Error at [00FF0734] must be FF, but found EF (bits: 00010000)
Error at [00FF0735] must be FF, but found 03 (bits: 11111100)
Error at [00FF0736] must be FF, but found EF (bits: 00010000)
Error at [00FF0737] must be FF, but found 03 (bits: 11111100)
Error at [00FF0738] must be FF, but found EF (bits: 00010000)
Error at [00FF0739] must be FF, but found 03 (bits: 11111100)
Error at [00FF073A] must be FF, but found EF (bits: 00010000)
Error at [00FF073B] must be FF, but found 03 (bits: 11111100)
Error at [00FF073C] must be FF, but found EF (bits: 00010000)
Error at [00FF073D] must be FF, but found 03 (bits: 11111100)
Error at [00FF073E] must be FF, but found EF (bits: 00010000)
Error at [00FF073F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0740] must be FF, but found EF (bits: 00010000)
Error at [00FF0741] must be FF, but found 03 (bits: 11111100)
Error at [00FF0742] must be FF, but found EF (bits: 00010000)
Error at [00FF0743] must be FF, but found 03 (bits: 11111100)
Error at [00FF0744] must be FF, but found EF (bits: 00010000)
Error at [00FF0745] must be FF, but found 03 (bits: 11111100)
Error at [00FF0746] must be FF, but found EF (bits: 00010000)
Error at [00FF0747] must be FF, but found 03 (bits: 11111100)
Error at [00FF0748] must be FF, but found EF (bits: 00010000)
Error at [00FF0749] must be FF, but found 03 (bits: 11111100)
Error at [00FF074A] must be FF, but found EF (bits: 00010000)
Error at [00FF074B] must be FF, but found 03 (bits: 11111100)
Error at [00FF074C] must be FF, but found EF (bits: 00010000)
Error at [00FF074D] must be FF, but found 03 (bits: 11111100)
Error at [00FF074E] must be FF, but found EF (bits: 00010000)
Error at [00FF074F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0750] must be FF, but found EF (bits: 00010000)
Error at [00FF0751] must be FF, but found 03 (bits: 11111100)
Error at [00FF0752] must be FF, but found EF (bits: 00010000)
Error at [00FF0753] must be FF, but found 03 (bits: 11111100)
Error at [00FF0754] must be FF, but found EF (bits: 00010000)
Error at [00FF0755] must be FF, but found 03 (bits: 11111100)
Error at [00FF0756] must be FF, but found EF (bits: 00010000)
Error at [00FF0757] must be FF, but found 03 (bits: 11111100)
Error at [00FF0758] must be FF, but found EF (bits: 00010000)
Error at [00FF0759] must be FF, but found 03 (bits: 11111100)
Error at [00FF075A] must be FF, but found EF (bits: 00010000)
Error at [00FF075B] must be FF, but found 03 (bits: 11111100)
Error at [00FF075C] must be FF, but found EF (bits: 00010000)
Error at [00FF075D] must be FF, but found 03 (bits: 11111100)
Error at [00FF075E] must be FF, but found EF (bits: 00010000)
Error at [00FF075F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0760] must be FF, but found EF (bits: 00010000)
Error at [00FF0761] must be FF, but found 03 (bits: 11111100)
Error at [00FF0762] must be FF, but found EF (bits: 00010000)
Error at [00FF0763] must be FF, but found 03 (bits: 11111100)
Error at [00FF0764] must be FF, but found EF (bits: 00010000)
Error at [00FF0765] must be FF, but found 03 (bits: 11111100)
Error at [00FF0766] must be FF, but found EF (bits: 00010000)
Error at [00FF0767] must be FF, but found 03 (bits: 11111100)
Error at [00FF0768] must be FF, but found 18 (bits: 11100111)
Error at [00FF0769] must be FF, but found C6 (bits: 00111001)
Error at [00FF076A] must be FF, but found 18 (bits: 11100111)
Error at [00FF076B] must be FF, but found C6 (bits: 00111001)
Error at [00FF076C] must be FF, but found EF (bits: 00010000)
Error at [00FF076D] must be FF, but found 03 (bits: 11111100)
Error at [00FF076E] must be FF, but found EF (bits: 00010000)
Error at [00FF076F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0770] must be FF, but found EF (bits: 00010000)
Error at [00FF0771] must be FF, but found 03 (bits: 11111100)
Error at [00FF0772] must be FF, but found EF (bits: 00010000)
Error at [00FF0773] must be FF, but found 03 (bits: 11111100)
Error at [00FF0774] must be FF, but found EF (bits: 00010000)
Error at [00FF0775] must be FF, but found 03 (bits: 11111100)
Error at [00FF0776] must be FF, but found EF (bits: 00010000)
Error at [00FF0777] must be FF, but found 03 (bits: 11111100)
Error at [00FF0778] must be FF, but found EF (bits: 00010000)
Error at [00FF0779] must be FF, but found 03 (bits: 11111100)
Error at [00FF077A] must be FF, but found EF (bits: 00010000)
Error at [00FF077B] must be FF, but found 03 (bits: 11111100)
Error at [00FF077C] must be FF, but found EF (bits: 00010000)
Error at [00FF077D] must be FF, but found 03 (bits: 11111100)
Error at [00FF077E] must be FF, but found EF (bits: 00010000)
Error at [00FF077F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0780] must be FF, but found EF (bits: 00010000)
Error at [00FF0781] must be FF, but found 03 (bits: 11111100)
Error at [00FF0782] must be FF, but found EF (bits: 00010000)
Error at [00FF0783] must be FF, but found 03 (bits: 11111100)
Error at [00FF0784] must be FF, but found EF (bits: 00010000)
Error at [00FF0785] must be FF, but found 03 (bits: 11111100)
Error at [00FF0786] must be FF, but found EF (bits: 00010000)
Error at [00FF0787] must be FF, but found 03 (bits: 11111100)
Error at [00FF0788] must be FF, but found EF (bits: 00010000)
Error at [00FF0789] must be FF, but found 03 (bits: 11111100)
Error at [00FF078A] must be FF, but found EF (bits: 00010000)
Error at [00FF078B] must be FF, but found 03 (bits: 11111100)
Error at [00FF078C] must be FF, but found EF (bits: 00010000)
Error at [00FF078D] must be FF, but found 03 (bits: 11111100)
Error at [00FF078E] must be FF, but found EF (bits: 00010000)
Error at [00FF078F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0790] must be FF, but found EF (bits: 00010000)
Error at [00FF0791] must be FF, but found 03 (bits: 11111100)
Error at [00FF0792] must be FF, but found EF (bits: 00010000)
Error at [00FF0793] must be FF, but found 03 (bits: 11111100)
Error at [00FF0794] must be FF, but found EF (bits: 00010000)
Error at [00FF0795] must be FF, but found 03 (bits: 11111100)
Error at [00FF0796] must be FF, but found EF (bits: 00010000)
Error at [00FF0797] must be FF, but found 03 (bits: 11111100)
Error at [00FF0798] must be FF, but found EF (bits: 00010000)
Error at [00FF0799] must be FF, but found 03 (bits: 11111100)
Error at [00FF079A] must be FF, but found EF (bits: 00010000)
Error at [00FF079B] must be FF, but found 03 (bits: 11111100)
Error at [00FF079C] must be FF, but found EF (bits: 00010000)
Error at [00FF079D] must be FF, but found 03 (bits: 11111100)
Error at [00FF079E] must be FF, but found EF (bits: 00010000)
Error at [00FF079F] must be FF, but found 03 (bits: 11111100)
Error at [00FF07A0] must be FF, but found EF (bits: 00010000)
Error at [00FF07A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF07A2] must be FF, but found EF (bits: 00010000)
Error at [00FF07A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF07A4] must be FF, but found EF (bits: 00010000)
Error at [00FF07A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07A6] must be FF, but found EF (bits: 00010000)
Error at [00FF07A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07A8] must be FF, but found EF (bits: 00010000)
Error at [00FF07A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07AA] must be FF, but found EF (bits: 00010000)
Error at [00FF07AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07AC] must be FF, but found 18 (bits: 11100111)
Error at [00FF07AD] must be FF, but found C6 (bits: 00111001)
Error at [00FF07AE] must be FF, but found 18 (bits: 11100111)
Error at [00FF07AF] must be FF, but found C6 (bits: 00111001)
Error at [00FF07B0] must be FF, but found EF (bits: 00010000)
Error at [00FF07B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF07B2] must be FF, but found EF (bits: 00010000)
Error at [00FF07B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF07B4] must be FF, but found EF (bits: 00010000)
Error at [00FF07B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07B6] must be FF, but found EF (bits: 00010000)
Error at [00FF07B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07B8] must be FF, but found EF (bits: 00010000)
Error at [00FF07B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07BA] must be FF, but found EF (bits: 00010000)
Error at [00FF07BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07BC] must be FF, but found EF (bits: 00010000)
Error at [00FF07BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF07BE] must be FF, but found EF (bits: 00010000)
Error at [00FF07BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF07C0] must be FF, but found EF (bits: 00010000)
Error at [00FF07C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF07C2] must be FF, but found EF (bits: 00010000)
Error at [00FF07C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF07C4] must be FF, but found EF (bits: 00010000)
Error at [00FF07C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07C6] must be FF, but found EF (bits: 00010000)
Error at [00FF07C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07C8] must be FF, but found EF (bits: 00010000)
Error at [00FF07C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07CA] must be FF, but found EF (bits: 00010000)
Error at [00FF07CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07CC] must be FF, but found EF (bits: 00010000)
Error at [00FF07CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF07CE] must be FF, but found EF (bits: 00010000)
Error at [00FF07CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF07D0] must be FF, but found 0F (bits: 11110000)
Error at [00FF07D1] must be FF, but found 00 (bits: 11111111)
Error at [00FF07D2] must be FF, but found 18 (bits: 11100111)
Error at [00FF07D3] must be FF, but found C6 (bits: 00111001)
Error at [00FF07D4] must be FF, but found EF (bits: 00010000)
Error at [00FF07D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07D6] must be FF, but found EF (bits: 00010000)
Error at [00FF07D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07D8] must be FF, but found EF (bits: 00010000)
Error at [00FF07D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07DA] must be FF, but found EF (bits: 00010000)
Error at [00FF07DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07DC] must be FF, but found EF (bits: 00010000)
Error at [00FF07DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF07DE] must be FF, but found EF (bits: 00010000)
Error at [00FF07DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF07E0] must be FF, but found EF (bits: 00010000)
Error at [00FF07E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF07E2] must be FF, but found EF (bits: 00010000)
Error at [00FF07E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF07E4] must be FF, but found EF (bits: 00010000)
Error at [00FF07E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07E6] must be FF, but found EF (bits: 00010000)
Error at [00FF07E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07E8] must be FF, but found EF (bits: 00010000)
Error at [00FF07E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07EA] must be FF, but found EF (bits: 00010000)
Error at [00FF07EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07EC] must be FF, but found EF (bits: 00010000)
Error at [00FF07ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF07EE] must be FF, but found EF (bits: 00010000)
Error at [00FF07EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF07F0] must be FF, but found EF (bits: 00010000)
Error at [00FF07F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF07F2] must be FF, but found EF (bits: 00010000)
Error at [00FF07F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF07F4] must be FF, but found EF (bits: 00010000)
Error at [00FF07F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF07F6] must be FF, but found EF (bits: 00010000)
Error at [00FF07F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF07F8] must be FF, but found EF (bits: 00010000)
Error at [00FF07F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF07FA] must be FF, but found EF (bits: 00010000)
Error at [00FF07FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF07FC] must be FF, but found EF (bits: 00010000)
Error at [00FF07FD] must be FF, but found 03 (bits: 11111100)
Error at [00FF07FE] must be FF, but found EF (bits: 00010000)
Error at [00FF07FF] must be FF, but found 03 (bits: 11111100)
Error at [00FF0800] must be FF, but found EF (bits: 00010000)
Error at [00FF0801] must be FF, but found 03 (bits: 11111100)
Error at [00FF0802] must be FF, but found EF (bits: 00010000)
Error at [00FF0803] must be FF, but found 03 (bits: 11111100)
Error at [00FF0804] must be FF, but found EF (bits: 00010000)
Error at [00FF0805] must be FF, but found 03 (bits: 11111100)
Error at [00FF0806] must be FF, but found EF (bits: 00010000)
Error at [00FF0807] must be FF, but found 03 (bits: 11111100)
Error at [00FF0808] must be FF, but found EF (bits: 00010000)
Error at [00FF0809] must be FF, but found 03 (bits: 11111100)
Error at [00FF080A] must be FF, but found EF (bits: 00010000)
Error at [00FF080B] must be FF, but found 03 (bits: 11111100)
Error at [00FF080C] must be FF, but found EF (bits: 00010000)
Error at [00FF080D] must be FF, but found 03 (bits: 11111100)
Error at [00FF080E] must be FF, but found EF (bits: 00010000)
Error at [00FF080F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0810] must be FF, but found EF (bits: 00010000)
Error at [00FF0811] must be FF, but found 03 (bits: 11111100)
Error at [00FF0812] must be FF, but found EF (bits: 00010000)
Error at [00FF0813] must be FF, but found 03 (bits: 11111100)
Error at [00FF0814] must be FF, but found EF (bits: 00010000)
Error at [00FF0815] must be FF, but found 03 (bits: 11111100)
Error at [00FF0816] must be FF, but found EF (bits: 00010000)
Error at [00FF0817] must be FF, but found 03 (bits: 11111100)
Error at [00FF0818] must be FF, but found EF (bits: 00010000)
Error at [00FF0819] must be FF, but found 03 (bits: 11111100)
Error at [00FF081A] must be FF, but found EF (bits: 00010000)
Error at [00FF081B] must be FF, but found 03 (bits: 11111100)
Error at [00FF081C] must be FF, but found EF (bits: 00010000)
Error at [00FF081D] must be FF, but found 03 (bits: 11111100)
Error at [00FF081E] must be FF, but found EF (bits: 00010000)
Error at [00FF081F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0820] must be FF, but found EF (bits: 00010000)
Error at [00FF0821] must be FF, but found 03 (bits: 11111100)
Error at [00FF0822] must be FF, but found EF (bits: 00010000)
Error at [00FF0823] must be FF, but found 03 (bits: 11111100)
Error at [00FF0824] must be FF, but found EF (bits: 00010000)
Error at [00FF0825] must be FF, but found 03 (bits: 11111100)
Error at [00FF0826] must be FF, but found EF (bits: 00010000)
Error at [00FF0827] must be FF, but found 03 (bits: 11111100)
Error at [00FF0828] must be FF, but found EF (bits: 00010000)
Error at [00FF0829] must be FF, but found 03 (bits: 11111100)
Error at [00FF082A] must be FF, but found EF (bits: 00010000)
Error at [00FF082B] must be FF, but found 03 (bits: 11111100)
Error at [00FF082C] must be FF, but found EF (bits: 00010000)
Error at [00FF082D] must be FF, but found 03 (bits: 11111100)
Error at [00FF082E] must be FF, but found EF (bits: 00010000)
Error at [00FF082F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0830] must be FF, but found EF (bits: 00010000)
Error at [00FF0831] must be FF, but found 03 (bits: 11111100)
Error at [00FF0832] must be FF, but found EF (bits: 00010000)
Error at [00FF0833] must be FF, but found 03 (bits: 11111100)
Error at [00FF0834] must be FF, but found EF (bits: 00010000)
Error at [00FF0835] must be FF, but found 03 (bits: 11111100)
Error at [00FF0836] must be FF, but found EF (bits: 00010000)
Error at [00FF0837] must be FF, but found 03 (bits: 11111100)
Error at [00FF0838] must be FF, but found EF (bits: 00010000)
Error at [00FF0839] must be FF, but found 03 (bits: 11111100)
Error at [00FF083A] must be FF, but found EF (bits: 00010000)
Error at [00FF083B] must be FF, but found 03 (bits: 11111100)
Error at [00FF083C] must be FF, but found EF (bits: 00010000)
Error at [00FF083D] must be FF, but found 03 (bits: 11111100)
Error at [00FF083E] must be FF, but found EF (bits: 00010000)
Error at [00FF083F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0840] must be FF, but found EF (bits: 00010000)
Error at [00FF0841] must be FF, but found 03 (bits: 11111100)
Error at [00FF0842] must be FF, but found EF (bits: 00010000)
Error at [00FF0843] must be FF, but found 03 (bits: 11111100)
Error at [00FF0844] must be FF, but found 00 (bits: 11111111)
Error at [00FF0845] must be FF, but found 00 (bits: 11111111)
Error at [00FF0846] must be FF, but found 18 (bits: 11100111)
Error at [00FF0847] must be FF, but found C6 (bits: 00111001)
Error at [00FF0848] must be FF, but found EF (bits: 00010000)
Error at [00FF0849] must be FF, but found 03 (bits: 11111100)
Error at [00FF084A] must be FF, but found EF (bits: 00010000)
Error at [00FF084B] must be FF, but found 03 (bits: 11111100)
Error at [00FF084C] must be FF, but found EF (bits: 00010000)
Error at [00FF084D] must be FF, but found 03 (bits: 11111100)
Error at [00FF084E] must be FF, but found EF (bits: 00010000)
Error at [00FF084F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0850] must be FF, but found EF (bits: 00010000)
Error at [00FF0851] must be FF, but found 03 (bits: 11111100)
Error at [00FF0852] must be FF, but found EF (bits: 00010000)
Error at [00FF0853] must be FF, but found 03 (bits: 11111100)
Error at [00FF0854] must be FF, but found EF (bits: 00010000)
Error at [00FF0855] must be FF, but found 03 (bits: 11111100)
Error at [00FF0856] must be FF, but found EF (bits: 00010000)
Error at [00FF0857] must be FF, but found 03 (bits: 11111100)
Error at [00FF0858] must be FF, but found 18 (bits: 11100111)
Error at [00FF0859] must be FF, but found C6 (bits: 00111001)
Error at [00FF085A] must be FF, but found 18 (bits: 11100111)
Error at [00FF085B] must be FF, but found C6 (bits: 00111001)
Error at [00FF085C] must be FF, but found EF (bits: 00010000)
Error at [00FF085D] must be FF, but found 03 (bits: 11111100)
Error at [00FF085E] must be FF, but found EF (bits: 00010000)
Error at [00FF085F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0860] must be FF, but found EF (bits: 00010000)
Error at [00FF0861] must be FF, but found 03 (bits: 11111100)
Error at [00FF0862] must be FF, but found EF (bits: 00010000)
Error at [00FF0863] must be FF, but found 03 (bits: 11111100)
Error at [00FF0864] must be FF, but found EF (bits: 00010000)
Error at [00FF0865] must be FF, but found 03 (bits: 11111100)
Error at [00FF0866] must be FF, but found EF (bits: 00010000)
Error at [00FF0867] must be FF, but found 03 (bits: 11111100)
Error at [00FF0868] must be FF, but found EF (bits: 00010000)
Error at [00FF0869] must be FF, but found 03 (bits: 11111100)
Error at [00FF086A] must be FF, but found EF (bits: 00010000)
Error at [00FF086B] must be FF, but found 03 (bits: 11111100)
Error at [00FF086C] must be FF, but found EF (bits: 00010000)
Error at [00FF086D] must be FF, but found 03 (bits: 11111100)
Error at [00FF086E] must be FF, but found EF (bits: 00010000)
Error at [00FF086F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0870] must be FF, but found EF (bits: 00010000)
Error at [00FF0871] must be FF, but found 03 (bits: 11111100)
Error at [00FF0872] must be FF, but found EF (bits: 00010000)
Error at [00FF0873] must be FF, but found 03 (bits: 11111100)
Error at [00FF0874] must be FF, but found EF (bits: 00010000)
Error at [00FF0875] must be FF, but found 03 (bits: 11111100)
Error at [00FF0876] must be FF, but found EF (bits: 00010000)
Error at [00FF0877] must be FF, but found 03 (bits: 11111100)
Error at [00FF0878] must be FF, but found EF (bits: 00010000)
Error at [00FF0879] must be FF, but found 03 (bits: 11111100)
Error at [00FF087A] must be FF, but found EF (bits: 00010000)
Error at [00FF087B] must be FF, but found 03 (bits: 11111100)
Error at [00FF087C] must be FF, but found EF (bits: 00010000)
Error at [00FF087D] must be FF, but found 03 (bits: 11111100)
Error at [00FF087E] must be FF, but found EF (bits: 00010000)
Error at [00FF087F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0880] must be FF, but found 0F (bits: 11110000)
Error at [00FF0881] must be FF, but found 00 (bits: 11111111)
Error at [00FF0882] must be FF, but found 18 (bits: 11100111)
Error at [00FF0883] must be FF, but found C6 (bits: 00111001)
Error at [00FF0884] must be FF, but found EF (bits: 00010000)
Error at [00FF0885] must be FF, but found 03 (bits: 11111100)
Error at [00FF0886] must be FF, but found EF (bits: 00010000)
Error at [00FF0887] must be FF, but found 03 (bits: 11111100)
Error at [00FF0888] must be FF, but found EF (bits: 00010000)
Error at [00FF0889] must be FF, but found 03 (bits: 11111100)
Error at [00FF088A] must be FF, but found EF (bits: 00010000)
Error at [00FF088B] must be FF, but found 03 (bits: 11111100)
Error at [00FF088C] must be FF, but found EF (bits: 00010000)
Error at [00FF088D] must be FF, but found 03 (bits: 11111100)
Error at [00FF088E] must be FF, but found EF (bits: 00010000)
Error at [00FF088F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0890] must be FF, but found EF (bits: 00010000)
Error at [00FF0891] must be FF, but found 03 (bits: 11111100)
Error at [00FF0892] must be FF, but found EF (bits: 00010000)
Error at [00FF0893] must be FF, but found 03 (bits: 11111100)
Error at [00FF0894] must be FF, but found EF (bits: 00010000)
Error at [00FF0895] must be FF, but found 03 (bits: 11111100)
Error at [00FF0896] must be FF, but found EF (bits: 00010000)
Error at [00FF0897] must be FF, but found 03 (bits: 11111100)
Error at [00FF0898] must be FF, but found EF (bits: 00010000)
Error at [00FF0899] must be FF, but found 03 (bits: 11111100)
Error at [00FF089A] must be FF, but found EF (bits: 00010000)
Error at [00FF089B] must be FF, but found 03 (bits: 11111100)
Error at [00FF089C] must be FF, but found EF (bits: 00010000)
Error at [00FF089D] must be FF, but found 03 (bits: 11111100)
Error at [00FF089E] must be FF, but found EF (bits: 00010000)
Error at [00FF089F] must be FF, but found 03 (bits: 11111100)
Error at [00FF08A0] must be FF, but found EF (bits: 00010000)
Error at [00FF08A1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08A2] must be FF, but found EF (bits: 00010000)
Error at [00FF08A3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08A4] must be FF, but found EF (bits: 00010000)
Error at [00FF08A5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08A6] must be FF, but found EF (bits: 00010000)
Error at [00FF08A7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08A8] must be FF, but found EF (bits: 00010000)
Error at [00FF08A9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08AA] must be FF, but found EF (bits: 00010000)
Error at [00FF08AB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08AC] must be FF, but found EF (bits: 00010000)
Error at [00FF08AD] must be FF, but found 03 (bits: 11111100)
Error at [00FF08AE] must be FF, but found EF (bits: 00010000)
Error at [00FF08AF] must be FF, but found 03 (bits: 11111100)
Error at [00FF08B0] must be FF, but found EF (bits: 00010000)
Error at [00FF08B1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08B2] must be FF, but found EF (bits: 00010000)
Error at [00FF08B3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08B4] must be FF, but found EF (bits: 00010000)
Error at [00FF08B5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08B6] must be FF, but found EF (bits: 00010000)
Error at [00FF08B7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08B8] must be FF, but found EF (bits: 00010000)
Error at [00FF08B9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08BA] must be FF, but found EF (bits: 00010000)
Error at [00FF08BB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08BC] must be FF, but found EF (bits: 00010000)
Error at [00FF08BD] must be FF, but found 03 (bits: 11111100)
Error at [00FF08BE] must be FF, but found EF (bits: 00010000)
Error at [00FF08BF] must be FF, but found 03 (bits: 11111100)
Error at [00FF08C0] must be FF, but found EF (bits: 00010000)
Error at [00FF08C1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08C2] must be FF, but found EF (bits: 00010000)
Error at [00FF08C3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08C4] must be FF, but found EF (bits: 00010000)
Error at [00FF08C5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08C6] must be FF, but found EF (bits: 00010000)
Error at [00FF08C7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08C8] must be FF, but found EF (bits: 00010000)
Error at [00FF08C9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08CA] must be FF, but found EF (bits: 00010000)
Error at [00FF08CB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08CC] must be FF, but found EF (bits: 00010000)
Error at [00FF08CD] must be FF, but found 03 (bits: 11111100)
Error at [00FF08CE] must be FF, but found EF (bits: 00010000)
Error at [00FF08CF] must be FF, but found 03 (bits: 11111100)
Error at [00FF08D0] must be FF, but found EF (bits: 00010000)
Error at [00FF08D1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08D2] must be FF, but found EF (bits: 00010000)
Error at [00FF08D3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08D4] must be FF, but found EF (bits: 00010000)
Error at [00FF08D5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08D6] must be FF, but found EF (bits: 00010000)
Error at [00FF08D7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08D8] must be FF, but found EF (bits: 00010000)
Error at [00FF08D9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08DA] must be FF, but found EF (bits: 00010000)
Error at [00FF08DB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08DC] must be FF, but found EF (bits: 00010000)
Error at [00FF08DD] must be FF, but found 03 (bits: 11111100)
Error at [00FF08DE] must be FF, but found EF (bits: 00010000)
Error at [00FF08DF] must be FF, but found 03 (bits: 11111100)
Error at [00FF08E0] must be FF, but found EF (bits: 00010000)
Error at [00FF08E1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08E2] must be FF, but found EF (bits: 00010000)
Error at [00FF08E3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08E4] must be FF, but found EF (bits: 00010000)
Error at [00FF08E5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08E6] must be FF, but found EF (bits: 00010000)
Error at [00FF08E7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08E8] must be FF, but found EF (bits: 00010000)
Error at [00FF08E9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08EA] must be FF, but found EF (bits: 00010000)
Error at [00FF08EB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08EC] must be FF, but found EF (bits: 00010000)
Error at [00FF08ED] must be FF, but found 03 (bits: 11111100)
Error at [00FF08EE] must be FF, but found EF (bits: 00010000)
Error at [00FF08EF] must be FF, but found 03 (bits: 11111100)
Error at [00FF08F0] must be FF, but found EF (bits: 00010000)
Error at [00FF08F1] must be FF, but found 03 (bits: 11111100)
Error at [00FF08F2] must be FF, but found EF (bits: 00010000)
Error at [00FF08F3] must be FF, but found 03 (bits: 11111100)
Error at [00FF08F4] must be FF, but found EF (bits: 00010000)
Error at [00FF08F5] must be FF, but found 03 (bits: 11111100)
Error at [00FF08F6] must be FF, but found EF (bits: 00010000)
Error at [00FF08F7] must be FF, but found 03 (bits: 11111100)
Error at [00FF08F8] must be FF, but found EF (bits: 00010000)
Error at [00FF08F9] must be FF, but found 03 (bits: 11111100)
Error at [00FF08FA] must be FF, but found EF (bits: 00010000)
Error at [00FF08FB] must be FF, but found 03 (bits: 11111100)
Error at [00FF08FC] must be FF, but found 18 (bits: 11100111)
Error at [00FF08FD] must be FF, but found C6 (bits: 00111001)
Error at [00FF08FE] must be FF, but found 18 (bits: 11100111)
Error at [00FF08FF] must be FF, but found C6 (bits: 00111001)
Error at [00FF0900] must be FF, but found EF (bits: 00010000)
Error at [00FF0901] must be FF, but found 03 (bits: 11111100)
Error at [00FF0902] must be FF, but found EF (bits: 00010000)
Error at [00FF0903] must be FF, but found 03 (bits: 11111100)
Error at [00FF0904] must be FF, but found EF (bits: 00010000)
Error at [00FF0905] must be FF, but found 03 (bits: 11111100)
Error at [00FF0906] must be FF, but found EF (bits: 00010000)
Error at [00FF0907] must be FF, but found 03 (bits: 11111100)
Error at [00FF0908] must be FF, but found EF (bits: 00010000)
Error at [00FF0909] must be FF, but found 03 (bits: 11111100)
Error at [00FF090A] must be FF, but found EF (bits: 00010000)
Error at [00FF090B] must be FF, but found 03 (bits: 11111100)
Error at [00FF090C] must be FF, but found EF (bits: 00010000)
Error at [00FF090D] must be FF, but found 03 (bits: 11111100)
Error at [00FF090E] must be FF, but found EF (bits: 00010000)
Error at [00FF090F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0910] must be FF, but found 18 (bits: 11100111)
Error at [00FF0911] must be FF, but found C6 (bits: 00111001)
Error at [00FF0912] must be FF, but found 18 (bits: 11100111)
Error at [00FF0913] must be FF, but found C6 (bits: 00111001)
Error at [00FF0914] must be FF, but found EF (bits: 00010000)
Error at [00FF0915] must be FF, but found 03 (bits: 11111100)
Error at [00FF0916] must be FF, but found EF (bits: 00010000)
Error at [00FF0917] must be FF, but found 03 (bits: 11111100)
Error at [00FF0918] must be FF, but found EF (bits: 00010000)
Error at [00FF0919] must be FF, but found 03 (bits: 11111100)
Error at [00FF091A] must be FF, but found EF (bits: 00010000)
Error at [00FF091B] must be FF, but found 03 (bits: 11111100)
Error at [00FF091C] must be FF, but found EF (bits: 00010000)
Error at [00FF091D] must be FF, but found 03 (bits: 11111100)
Error at [00FF091E] must be FF, but found EF (bits: 00010000)
Error at [00FF091F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0920] must be FF, but found EF (bits: 00010000)
Error at [00FF0921] must be FF, but found 03 (bits: 11111100)
Error at [00FF0922] must be FF, but found EF (bits: 00010000)
Error at [00FF0923] must be FF, but found 03 (bits: 11111100)
Error at [00FF0924] must be FF, but found EF (bits: 00010000)
Error at [00FF0925] must be FF, but found 03 (bits: 11111100)
Error at [00FF0926] must be FF, but found EF (bits: 00010000)
Error at [00FF0927] must be FF, but found 03 (bits: 11111100)
Error at [00FF0928] must be FF, but found EF (bits: 00010000)
Error at [00FF0929] must be FF, but found 03 (bits: 11111100)
Error at [00FF092A] must be FF, but found EF (bits: 00010000)
Error at [00FF092B] must be FF, but found 03 (bits: 11111100)
Error at [00FF092C] must be FF, but found EF (bits: 00010000)
Error at [00FF092D] must be FF, but found 03 (bits: 11111100)
Error at [00FF092E] must be FF, but found EF (bits: 00010000)
Error at [00FF092F] must be FF, but found 03 (bits: 11111100)
Error at [00FF0930] must be FF, but found 0F (bits: 11110000)
Error at [00FF0931] must be FF, but found 00 (bits: 11111111)
Error at [00FF0932] must be FF, but found 18 (bits: 11100111)
Error at [00FF0933] must be FF, but found C6 (bits: 00111001)
Error at [00FF0934] must be FF, but found EF (bits: 00010000)
Error at [00FF0935] must be FF, but found 03 (bits: 11111100)
Error at [00FF0936] must be FF, but found EF (bits: 00010000)
Error at [00FF0937] must be FF, but found 03 (bits: 11111100)
Error at [00FF0938] must be FF, but found EF (bits: 00010000)
Error at [00FF0939] must be FF, but found 03 (bits: 11111100)
Error at [00FF093A] must be FF, but found EF (bits: 00010000)
Error at [00FF093B] must be FF, but found 03 (bits: 11111100)
Error at [00FF093C] must be FF, but found EF (bits: 00010000)
Error at [00FF093D] must be FF, but found 03 (bits: 11111100)
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: 30GB - IDE 3; 40GB - IDE 3; 80GB - IDE 4
Reply 35 of 41, by asdf53
If it marks every single byte as corrupted, but the card is working fine in Windows, then it's likely not physical damaged chips, but it's reading and writing to the wrong memory locations. You mentioned in an earlier post that the address range was D6000000-D6FFFFFF, but in the log you just posted, it's starting at 00FF0000. It would be interesting if the reported address range changes when you enable the "Try to get video memory size via PCI routines" option in VMCE. In Windows, the memory test uses the graphics driver to access the memory instead of the BIOS routines, which could explain the different result.
When you're in Windows, open the device manager, go to the properties of the Riva TNT, and click the resources tab. Does it show the address range of the memory that's assigned to it? Write it down and compare it to the range that VMCE is trying to use.
Reply 36 of 41, by DustyShinigami
asdf53 wrote on Yesterday, 04:45:
Ahhh, I see. That does makes sense. But yes, I enabled 'Try to get video memory size via PCI routines' when I ran the test. And yes, the figures are vastly different in the Device Manager from the test.
Memory Range 000A0000 - 000AFFFF
Memory Range 000B0000 - 000BFFFF
Input/Output Range 03B0 - 03BB
Input/Output Range 03C0 - 03DF
Interrupt Request - 09
Memory Range D4000000 - D4FFFFFF
Memory Range D6000000 - D6FFFFFF
Memory Range 000C0000 - 000C7FFF
Memory Range D5000000 - D500FFFF
EDIT: Yeah, so with and without the 'try to get video memory size via PCI routines' option, it still lists 00FF0000.
OS: Windows 98 SE
Reply 37 of 41, by asdf53
Then it's definitely accessing a memory area that doesn't belong to the card at all. Your card has 16 MB, and it has been assigned two 16 MB areas: D4000000 - D4FFFFFF and D6000000 - D6FFFFFF. I don't know why it's assigned twice, but I noticed that many newer cards do that. One of these areas should be where VMCE is supposed to begin testing the memory, and it doesn't for whatever reason. Maybe it's a FreeDOS problem (VMCE uses this). You could find a DOS tool that can enumerate PCI devices and their memory areas, and then compare the output between MS-DOS and FreeDOS. It's probably just a software bug and your card is fine.
Edit: Hwinfo for DOS can do that: Info > Mainboard Info > Bus Type: PCI > Bus 0 > Select graphics card > Memory Base address. See if that also has the bad address.
You could also go to the device manager in Windows and select PCI bus under System Components, then Settings, and choose BIOS instead of hardware enumeration, then reboot. If this causes resource problems with the graphics card, or the system to not boot at all, then your BIOS could also be the culprit, because it handles resource assignment until Windows is loaded.
Reply 38 of 41, by DustyShinigami
asdf53 wrote on Yesterday, 14:10:
Thanks for all your help with this. It's appreciated. 😀 And thanks for the suggestions. I've give those a look over and see what's what. You could be right regarding the FreeDOS thing. It does the same thing with the Geforce 4, though neither the TNT and Geforce 4 are particularly new cards now.
OS: Windows 98 SE
Reply 39 of 41, by DustyShinigami
Okay. In my case the BUS type is AGP and the Memory Base Addresses are D4000000 - D4FFFFFF and D6000000 - 07000007. That last one is different to what it says in the Device Manager. I'll try changing it from hardware to BIOS next and see what happens.
EDIT: Setting it from Hardware Enumeration to DOS worked fine. No crashes. But still get the same results with all of those errors. I also tried manually adding the address in the extended options, but it always says 'can not set environment variable 'CMDLINE'. Environment full?' And it still proceeds to set it to D6000000 - D6FFFFFF.
OS: Windows 98 SE
