First post, by B24Fox
This thread is dedicated to sharing/discussing the Pinouts, wiring and/or design of adapters that came bundled (or compatible replacements) for hardware like Mice, Keyboards, Game Controllers & more; and allowed them to be connected to one or more types of ports (i.e. PS/2 Mouse -to- Serial PC Port, Gameport Joystick -to- USB PC Port, and so on..)
This thread is a work in progress, and I encourage everyone that can contribute, to please do so! 😀
Hopefully it will earn it's place as a "Sticky".
I will try to keep the first few posts constantly up to date, so that all the fresh info is always easily accessible.
!!!IMPORTANT!!! Connectors numbering standard/consensus:
(so we won't get our "signals" mixed 😜)
SERIAL:
The attachment RS-232_DE-9_Connector_Pinouts.png is no longer available
PS/2:
The attachment PS2 Pinout.png is no longer available
If you do not have a PS/2 Mouse socket mounted on your AT Motherboard, you can actually create one! 🥳
From 486 boards to Super Socket 7, they usually come with PS/2 pins (or pin connectors) on the board. You just need the cable adapter, to plug it in and mount on the case.
Most boards even have through-holes; so you can even solder yourself a connector directly on the board... but that's advisable only IF you also have an AT case with a cut-out for the PS/2 port (which is about as rare as hen's teeth). But they DO exist.
Anyway, here are all the pinouts from the boards I measured so far:
(on your mobo's PS/2 pin-connector you only need to find the Vcc(+5V) and GND pins; and based on those, you can deduce the rest of your connector's pins from my diagram)
The attachment AT MOBO PS2 Mouse header ver.5.png is no longer available
GAMEPORT:
The attachment DB-15 GAMEPORT Connector.png is no longer available
USB Type-A:
The attachment USB type-A Pinout.jpg is no longer available
<<The UNIFIED Passive-Adapters Thread for Mice, Keyboards, Joysticks & more>>
Reply 1 of 6, by B24Fox
The attachment Mouse + adapter.jpg is no longer available
Pinout for this Microsoft Mouse's SERIAL to PS/2 adapter cable, is as follows:
SERIAL male con.__________PS/2 male connector
Pin1 ------------to----------Pin5 [Mouse Clock]
Pin5------------to----------Pin3 [GND]
Pin8------------to----------Pin4 [+5V]
Pin9------------to----------Pin1 [Mouse Data]
This adapter 100% works with the Mice that look like in the picture, that have a Motorola [SC88715DW] chip, and 8+1 wires in the cable.
Also recognizable by the following stickers (not 100% certain on 2nd sticker):
The attachment nice-vintage-microsoft-serial-ps-2-mouse-button-c3k5k5comb-roller-533.jpg is no longer available
The attachment Microsoft-24394-2-Button-Serial-Mouse_143835__60402.jpg is no longer available
Reply 2 of 6, by B24Fox
This "IntelliMouse Serial and PS/2 Compatible" wheel mouse [PN: X05-51688] WORKS with all 3 of these SERIAL adapters (tested on a VIA MVP3 Mobo with Win98SE)... Yet, they are NOT the same!
The attachment IntelliMouse Serial&PS2 with Wheel.jpg is no longer available
Here are their pinouts:
Grey Adapter:
SERIAL fem. con.__________PS/2 female connector
Pin1 N.C.(Not Connected)# # # # # Pin1 [M.Data] strapped to PS/2 Pin5 [M.Clock]
Pin2------------to----------Pin2 [K.Data]
Pin3------------to----------Pin6 [K.Clock]
Pin4[strapped to SERIAL Pin6]
Pin6[strapped to SERIAL Pin4]
Pin7------------to----------Pin4 [+5V]
Pin8 N.C.
Pin9 N.C.
Red Adapter (identical to Gray adapter, but missing the strap between PS/2 pins 1&5):
Pin1 N.C.
Pin2------------to----------Pin2 [Keyboard Data]
Pin3------------to----------Pin6 [Keyboard Clock]
Pin8 N.C.
Pin9 N.C.
Green Adapter:
Pin1 N.C.
Pin4[strapped to SER.Pin6]--to--Pin1 [M.Data]
Pin6[strapped to SER.Pin4]--to--Pin1 [M.Data]
Pin7------------to----------Pin5 [M.Clock]
Pin9 N.C.
The Gray Adapter pinout was also confirmed working (by @Jason21), on this other mouse model:
2-button "Microsoft Serial-Mouse Port Compatible Mouse 2.0" P/N 58264
The attachment Jason21's mouse 2-button (P.N.58264).jpg is no longer available
MICROSOFT branded adapter but with different pinout, found here on the forum. Comes in 2 different colors. No confirmation yet on what revision mouse it works with, but it did NOT work with the P/N 58264 mouse in the previous picture
Thanks to @Jason21 and @DaveDDS for their contributions!
Re: Microsoft Serial Compatible Mouse only works in PS/2 mode
Re: Microsoft Mouse 2.1A not recognized
The attachment DaveDDS' Microsoft 68666 Adapters.JPG is no longer available
Microsoft P.N.68666 Adapter(s):
Pin4[strapped to SER.Pin6]--to--Pin5 [Mouse Clock]
Pin6[strapped to SER.Pin4]--to--Pin5 [Mouse Clock]
An unconfirmed adapter, pinout from user @Jason21. Unknown what it works with.
Unknown-compatibility Adapter:
SERIAL fem. con.____________PS/2 female connector
Pin1------------to-------------Pin1 [M.Data]
Pin2[strapped to SER.Pins5,7]--to--Pin4 [+5V]
Pin3[strapped to SER.Pin9]----to--Pin3 [GND]
Pin5[strapped to SER.Pins2,7]--to--Pin4 [+5V]
Pin6 ------------to------------Pin5 [M.Clock]
Pin7[strapped to SER.Pins2,5]--to--Pin4 [+5V]
Pin9[strapped to SER.Pin3]----to--Pin3 [GND]
Another unconfirmed Blue Adapter, pinout from user @luRaichu. Unknown what it works with.
Unknown Blue Adapter (with possibly unmapped "strap" between pins)
Pin2------------to----------Pin1 [Mouse Data]
Pin4------------to----------Pin4 [+5V]
Pin7------------to----------Pin5 [Mouse Clock]
Reply 3 of 6, by B24Fox
This adapter is ONLY for the Microsoft SideWinder FreeStyle Pro and the SideWinder Precision Pro Joystick; and NOT for the SideWinder 3D Pro Plus(which looks absolutely identical), or the SideWinder 3D Pro, or anything else that didn't come bundled with it from the factory.
The attachment MS SideWinder Precision Pro Joystick ADAPTER.jpg is no longer available
This is the Pinout:
DB15 GamePort fem. con.______USB-A male connector
Pin1-------------to-----------Pin1 [+5V]
Pin14------------to-----------Pin2 [Data-]
Pin10------------to-----------Pin3 [Data+]
Pin4-------------to-----------Pin4 [GND]
Pin2[strapped to GamePort-Pin7]
Pinout for this other adapter will be added later
The attachment 1710924379.jpeg is no longer available
Reply 5 of 6, by B24Fox
Finally, thanks to a friend, I have managed to map the pinout of the infamous 3dfx Voodoo3 3500 monitor adapter dongle ....thing
The attachment Dongle.jpg is no longer available
The attachment ALL connectors.jpg is no longer available
The attachment Pinout.jpg is no longer available
Please be aware that some pins are electrically strapped together. I have listed them with a "+"between them.
Also everything marked "GND" is also electrically strapped together, along with all the metal outer-casings of all connectors.
Though from what I could see, the GND pins 1&2 on both S-VIDEO connectors, aren't soldered directly to their metal outer-casing, but are individually grounded all the way back inside the DVI connector (probably to reduce GROUND imbalances or interference).
TV-OUT Ports (multiple types)
This 15min. video from VWestlife, is chock-full of info on the different types and pinouts of numerous TV-out ports, and their respective adapters and/or breakout cables.
Video: That weird (S➙) port on 2000s laptops
The attachment Video Thumbnail.jpg is no longer available
