New versions of Fasttracker 2 for MS-DOS
Reply 140 of 144, by g2zer0
hmm, can i help? i'm a coder myself 😉
Reply 141 of 144, by 8bitbubsy
Well, you can join my Discord found at my website (16-bits.org), and then contact me there. I am not allowed to share FT2's whole source code, but I can give you the relevant source code files for the SB driver (if you have experience with low-level SB programming and Pascal/assembler).
386:
- CPU: 386DX-40 + 40MHz FPU + 128kB L1 cache
- RAM: 8MB (0 waitstates @ 40MHz)
- VGA: Diamond SpeedSTAR VGA (ET4000AX 1MB ISA)
- Audio: Sound Blaster Pro 2.0 + GUS 1MB
- ISA PS/2 mouse card
- MR BIOS
Reply 142 of 144, by 8bitbubsy
I just released FT2.13. It can as always be downloaded from here: https://16-bits.org/other.php
Changes in v2.13:
  • Fixed a possible song redrawing issue when loading a song as a command line parameter
  • Show a warning if GUS went out of sample RAM during song loading, as this can make the tracker unstable
386:
- MR BIOS
Reply 143 of 144, by drastikterror
8bitbubsy wrote on 2024-06-14, 15:30:
I just released FT2.13. It can as always be downloaded from here: https://16-bits.org/other.php […]
Changes in v2.13:
Great!!!
Reply 144 of 144, by 8bitbubsy
I just released FT2.14. It can as always be downloaded from here: https://16-bits.org/other.php
Changes in v2.14:
  • Fixed a bug where "16-bit mixing" would be forced enabled after using the harddisk recorder (saving song as WAV)
  • Some minor optimizations were done to different parts of the code
386:
- MR BIOS
