First post, by 1strail
hi, does anyone have or know where I can get the bios version needed for use with a 1.4ghz Pentium III? I have a new old stock board and a 1400/512/133/1.45 CPU and have have read I need to flash the bios to enable the 1.4ghz chip, which I thought would work out of the box. I haven’t yet installed it into a box as I am trying to gather everything I need first. The exact name of the file is EA81510A.86A.0047.P16
Reply 1 of 12, by Babasha
I always think that Tualatin support depends on motherboard revision?
Whats revision on white sticker in corner of your board?
Need help? Begin with photo and model of your hardware 😉
Reply 2 of 12, by b_riera
It appears to be available on The Retro Web:
BIOS List: https://theretroweb.com/motherboards/s/intel- … 2-easton-2#bios
P16 BIOS: https://theretroweb.com/motherboard/bios/eaap … bd567349423.exe
As to whether or not a Tualatin will simply work with just a BIOS update? I don't know. I've never owned this board or known anybody with one. I have a 1.4GHz PIII-S in my Dell/Intel D815EEA but I had to pin mod it. It's definitely a requirement on the older revision board.
Reply 3 of 12, by b_riera
I just noticed that a portion of that file name you said is different. 0047 whereas the file I linked has 0030 but it's the listed BIOS for a D815EEA2 motherboard and it's version P16. I can't say I've paid that much attention to the BIOS string and tend to just YOLO it with BIOS updates myself... There's always the recovery mode option!
Reply 4 of 12, by 1strail
Babasha wrote on 2025-10-09, 05:27:
Here is the number on the white sticker, I took a picture, but not sure how to upload it.
IME221007537 AA A52399-803
Reply 5 of 12, by 1strail
b_riera wrote on 2025-10-10, 23:36:
It appears to be available on The Retro Web: […]
This is awesome! Because this is an executable, I assume I need to run it on the pc containing the MB and I’m thinking I need to use a different CPU (not the Tualatin chip) and once done, then slap it in.
Reply 6 of 12, by shevalier
For Tualatin support Intels matherboard has marking with "U" letter, i.e. D815EEA2U
https://web.archive.org/web/20241106110537/ht … .com/show/806/3
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 8 of 12, by Nexxen
1strail wrote on 2025-10-11, 01:45:
I have the same board. Supports Tualatin.
Last BIOS is P21-0039. Too bad it doesn't have DDR.
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 10 of 12, by 1strail
Nexxen wrote on 2025-10-11, 12:52:
I’m putting Windows 98 on it so even without DDR should be quite fast thank you for your help!
Reply 11 of 12, by shevalier
1strail wrote on 2025-10-11, 15:39:
shevalier wrote on 2025-10-11, 09:25:
Yay! Mine has the U. Do I still need to update the BIOS for it to work on first boot up?
yep, it`s Intel.
Their BIOS checks each processor, not the family.
Otherwise, you'll get "System halted. Contact technical support."
Reply 12 of 12, by 1strail
shevalier wrote on 2025-10-11, 15:51:
yep, it`s Intel. Their BIOS checks each processor, not the family. Otherwise, you'll get "System halted. Contact technical suppo […]
yep, it`s Intel.
Perfect, thanks very much!
