First post, by Alporik
Motherboard: Not sure, but the computer is a Dell XPS 420
Processor type and speed: Intel Core Duo E6850 @ 3MHz
Amount and type of RAM: 3 GB (not sure what is meant by type)
Video board w/ RAM amount and type: ATI Radeon HD 2600 XT (RAM amount and type is not listed in my device manager)
Sound board: It just says High Definition Audio Device/Controller
Operating system: Windows Vista
Game name (and version, if applicable): Lords of the Realm (first CD of the Lords Royal Collection - it is labeled MS-DOS)
Description of problem: Cannot install the program
Reproducibility of problem: always
Sound mode used: None, just trying to install at this point
Video mode: None, just trying to install
Version of emulator: DOSBox 0.72
Steps already attempted to solve the problem:
1. Autoplay will run in Vista, but when I click install (the only option given by the autoplay screen) the cursor gives the thinking graphic (circular motion next to pointer) for ten seconds and then nothing happens.
2. When I run setup.exe directly in Vista I get the same thinking graphic then nothing. This occurs even if I run it with administrator privileges.
3. When I mount the CD as D in DOSBox and run autoplay.exe, I am told that "This program cannot be run in DOS mode."
4. When I run setup.exe off the mounted CD, I get "Illegal command: win."
So far, I have not found a way to install the program in either Vista or DOSBox and I am not a DOSBox newbie, I have successfully installed Daggerfall and Wizardry in DOSBox and I use .conf files for each. Thank you for any help anyone can provide.
