Reply 30280 of 31385, by tehsiggi
ubiq wrote on 2025-10-11, 16:44:
I ultimately ruled out the 9700 Pro as the issue and considered the PSU itself to be the problem. I also ruled out CPU thermals as well as the mainboard caps (I recapped the mobo when I got it - yes, it needed it). The powering off issue required physically toggling the physical power switch on the PSU to get it started again. It's a brand new PSU, but of course that doesn't mean it's good. For now, putting the 9700 on its own rail instead of the one driving the HDs seems to have fixed things.
In terms of 9700 Pro care - should I put heat sinks on the ram? If it came to it, I'm probably up to replacing the caps on the card, but the ram would be another story.
I'd always grant the memory on 9700s and 9800s memory heatsinks. The memory gets quite warm and the stock cooler already has bad airflow over the memory. Given that you are cooling it passively, I'd highly recommend additional heatsinks on the memory.
I'd leave the caps as is. Of all 9500s, 9700s and 9800s I had, none of them died / failed due to bad caps.
The 5V rail of your PSU is rated at 20A, which nowadays is sufficient, however that's only 100W. The 9700 will take around 20W of it's 60W from the 5V rail. That leaves you with 80W for the rest of the system. Given that socket 462 boards often rely on the 5V rail for CPU power, you might be a bit in a tight spot here under load. Not sure about your a7v8x-mx.
AGP Card Real Power Consumption
AGP Power monitor - diagnostic hardware tool
Graphics card repair collection
Reply 30281 of 31385, by ubiq
tehsiggi wrote on 2025-10-11, 18:30:
Awesome, thanks for bringing the numbers! Sounds like I'm right to suspect the PSU, even if I was completely off on the exact reasons. I have a X1950 Pro AGP that bluescreened but didn't trip the PSU off when I tested it in this system. I'm going to guess that means it pulls more on the 12V than the 9700, and that if (when) I build a system around it I'll probably be ok with a modern PSU.
Cool - yeah, none of them look like they've wet themselves so I'm happy to leave them alone.
Ok on it - I'll wait till I get that sorted to do any further kind of stress testing. Thanks!
Funny, last time I had a 9700 Pro (AIW), I was running it in a tiny Shuttle MiniPC with zero airflow (and a busted PSU in this pic):
The attachment newpsu.jpg is no longer available
Now I want to treat this one like precious cargo.
Reply 30282 of 31385, by PcBytes
Had to prep a new HDD for my upcoming "Childhood mashup" build. Its specs are basically the 700MHz Athlon-based Area 51 featured in the December 1999 issue of Maximum PC, with a few slight "twists":
- I'm using the case of my first PC as a kid - Keymouse/KMEX CX-6458/6459 (I hope to get around retrobriting the front bezel one day)
- ODD is a DVD-RW because most of the media I have at easy-n-ready use is... DVD-Rs.
- HDD is a 40GB WD Protege - this was mainly due to the weird azz HDD spec Alienware used - a 34GB IBM Deskstar. My WTH award goes to IBM rather than Alienware, though I'm not really surprised it's none other than IBM pulling this kind of stupid capacities.
- no MPEG decoder unfortunately (idek where I would find out anyways!)
Here's the issue of the said Maximum PC btw: https://archive.org/details/maximum-pc-magazi … e/n113/mode/2up
Huge thanks goes to @Socket3 for the GPU by the way - it's exactly the one from the magazine, and probably THE ONLY NVIDIA THAT ACTUALLY WORKS ON MSI'S 6167. I'm not even joking - this thing REFUSES to run any nVidia past 256. It'll run absolutely anything else (ATi, PowerVR, 3dfx, probably SiS stuff too!) except any nVidia newer than 256 period.
Oh, and possibly having the Dell Dimension 8300 cover part of the 2003-04 period. I'm super excited about the 9800 Pro in it being alive, and usually I've regarded Dell's stuff as high quality.
Reply 30283 of 31385, by Muckrake
Successfully patched Wasteland to run in 16 colors on an IBM PCjr.
Reply 30284 of 31385, by RetroBus
Next step of the journey. on my Rescued Pentium 4 with Geforce FX card, getting Windows XP onto this think and some benchmarks, man I had a lot of issues with the optical drives lately, its hard enough finding an IDE drive, I had two on this and one was DOA the other was barely working.. is there a way to repair these or common faults? I have more broken IDE drives than working at the moment
https://www.youtube.com/watch?v=sWP-IeU5oZg
https://www.youtube.com/@ComputerRetroBus Computer Retro Bus - My Youtube Chanel
Reply 30285 of 31385, by tehsiggi
ubiq wrote on 2025-10-11, 20:23:
No need to guess. The 1950Pro on AGP usually has the same layout as the GT. Your assumption is completely right, here are the measurements:
https://tehsiggi.github.io/agp-power-monitor/ … deonx1950gt_256
Reply 30286 of 31385, by Nexxen
I reinstalled OS X 10.4 on a G4.
The DVD-ROM that came with it (original apple sticker) wasn't detected anymore.
After replacing it with another one I could complete the installation (to test the unit I used the installation dvd).
To find a good working dvd unit I found even more dead units in my stash.
Boring 30 minutes...
PC#1 Pentium 233 MMX - 98SE
PC#2 PIII-1Ghz - 98SE/W2K
- Bare metal ist krieg.
Reply 30287 of 31385, by AshleyPomeroy
Technically by "today" I mean "last month", but I have in my possession an old MOTU 2408 audio interface that came out in 2003:
It's tricky to get working nowadays. Back in 2003 it came with a PCI card that fit into the host computer - you plugged the PCI card into your Power Macintosh G4, then connected the card to the interface with a FireWire cable. A while back I bought a Power Macintosh G5 that had this card (technically it's 64-bit PCI-X), and the interface was cheap on eBay, so I picked it up. Alas the only Macintosh with PCI slots nowadays is the Mac Pro, and I have no idea if it's compatible with PCI-X, and in any case I thought it would be nice to use the interface with my Mac Mini.
Thankfully interface also has audio pass-through with ADAT lightpipe, but standalone ADAT interfaces with an input are fairly rare. However there's a company called MiniDSP that makes a device called the MCHStreamer (pictured on top of the interface). It's mostly designed so that you can connect speakers to your computer using an optical cable, but it also does ADAT, and it's two-way.
And so with a bit of messing around with drivers I've managed to get this old interface working again. It now goes Interface->ADAT->MCHStreamer->USB. It's like having a complicated USB adapter. It's also potentially useful if you ever need to run a PlayStation 3, but you only have a computer monitor. The PS3 didn't have a headphone output, so if you plug it into a computer monitor you don't get sound, but it does have SPDIF optical outputs.
I also have an old MOTU 828, which uses FireWire. Irritatingly the official Apple Thunderbolt-FireWire adapter dongle went out of production recently, and the price shot up from around £34 new (which was still very high) to something like £80 on the used market, because there's a small market of people who have FireWire equipment they still need to use.
Reply 30288 of 31385, by ubiq
tehsiggi wrote on 2025-10-12, 06:04:
Wow, you don't just have some numbers, you have all the numbers! 🫡
Reply 30289 of 31385, by ubiq
RetroBus wrote on 2025-10-12, 02:03:
In my experience, hard drives are wear items - when they die, they die, usually destructively (head crash). I think a lot of retro tinkerers don't bother with them and just stick to SD/CF to IDE adapters, or a SATA to IDE adapter and use a modern SSD. I prefer to make life difficult for myself and actually try to get spinning metal into my systems whenever possible. To that end, I've had luck buying new old stock IDE hard drives from eBay sellers in China. Not going to find anything older than mid 2000's drives, but that's plenty good for what I get up to.
Actually just had some Toshiba laptop HDs show up today that I'll be using to resurrect a system of mine that died - due to a head crash on a new old stock drive, so your milage may vary!
Reply 30290 of 31385, by lti
He's talking about optical drives, not hard drives. Every one of my IDE optical drives appears to have a weak or dead laser. There are "quick fixes" involving increasing the power to the laser, but it's temporary and most people don't have the equipment to properly set laser power (or the spec from the drive manufacturer). Aside from that, there are drives that stick open or closed due to old belts. I'm just using CD emulation through Daemon Tools now (making BIN/CUE images of my own CDs using an old version of Alcohol 120% on a computer that's still old enough to be considered retro, but new enough to have SATA).
Reply 30291 of 31385, by StriderTR
I'm going WAY back... to the vacuum tube era (1948'ish).
I had this old NRI Professional Signal Tracer Model 34 given to me last year and it's been sitting on a shelf here ever since. I haven't seen one of these since I was a kid, my dad had one, he used to repair and collect old tube radios and equipment back in the 70's and into the 80's. No way I'm powering it up and risking damage to it ... or fire ... I just need to decide what to do with it. It's an amazing conversation piece, but beyond that I'm out of my depth in terms of repair/restoration with it. Might give it to a local museum if they take such things. I've even got the orignal manual for it. Not sure yet. It's all in such good cosmetic condition.
Just figured I'd share it here becasue it's so darn cool! 🤣
Found this cool video of one being repaired: https://www.youtube.com/watch?v=VGcAXWGQUDw
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 30292 of 31385, by ubiq
lti wrote on 2025-10-12, 20:14:
Ahh, misread that. Yeah, I have a stack of CDROM drives with sticky disc trays that I do not want to deal with. I also use Daemon Tools on systems that can afford the overhead. Just started messing with the PicoGUS's CDROM emulation and it's pretty impressive so far - redbook support and everything. Gives a really retro experience as it only emulates a roughly 2x drive - but appropriate for a 90's era system from when games mostly ran off the disc.
Reply 30293 of 31385, by CMB75
I’m currently trying to figure out how to restore my (5170) IBM floor-standing option without repainting it. The main challenges are removing acid stains, rust, cracks, and chips while keeping the original finish intact.
I want to preserve its authentic look — the surface wear that reflects its history — rather than make it look new. I’m exploring ways to neutralize the acid marks, lift rust, and stabilize small cracks without disturbing the paint or texture. Neutralizing the acid with vinegar works, but it doesn't remove the stains...
The attachment IBM-FSO-acid&rust-01.webp is no longer available
The attachment IBM-FSO-acid&rust-02.webp is no longer available
Reply 30294 of 31385, by aspiringnobody
Replaced the framebuffer I wasn’t able to repair due to too many loose pads today. Got all the legs soldered relatively easily; just a few bridges that I was able to sort out and a pin that bent into the next town over as soon as it got hit with the heat from the iron. I’m not sure how long it will last, but for now it’s working!
The attachment IMG_7777.jpeg is no longer available
Reply 30295 of 31385, by dr_st
Revived my old Win7 desktop for the umpteenth time.
Looks like the GPU (Zotac GTX 660) is finally toast. It won't POST in two different boards. Even prior to that, BSODs pointing to the nVidia driver were getting far too common.
Currently using a GT 710 just a a placeholder until I can get a proper GPU.
Reply 30296 of 31385, by myne
CMB75 wrote on 2025-10-13, 06:25:
I’m currently trying to figure out how to restore my (5170) IBM floor-standing option without repainting it. The main challenges […]
Try a big enough bucket and clothes washing powder/liquid.
Soak.
There's enzymes in there that eat things over time, but it's mild enough that it won't hurt anything real.
I built:
Reply 30297 of 31385, by BitWrangler
myne wrote on 2025-10-15, 11:13:
Try a big enough bucket and clothes washing powder/liquid. Soak. […]
Soak.
Might need a deep tote to make sure the whole thing is submerged. The brightening/whitening agents in it might get everything else a touch cleaner, so if you stood only one end in it, you'd get a two tone case with one end white and brighter.
Reply 30298 of 31385, by Lostdotfish
Today I was inspecting my NOS DFI 865PE Infinity board - deciding if I should build it or sell it. I noticed something concerning...
The attachment PXL_20251015_090522999.jpg is no longer available
Considering that this is a totally unused board I was not expecting this...
The attachment PXL_20251015_102455468.jpg is no longer available
The attachment PXL_20251015_102549229.jpg is no longer available
The attachment PXL_20251015_102540124.jpg is no longer available
All the 6.3v 1500uf caps were totally gone... I removed the 16v ones too as they were the same Chemi-Con KZG series. Now I need to dig out my polymer caps and see if I have the right ones to replace these with...
Reply 30299 of 31385, by aspiringnobody
Lostdotfish wrote on 2025-10-15, 14:55:
That’s fairly alarming, that’s a late 2003 board, I usually consider that to be after the capacitor plague.
I wonder if this board got hot at some point in storage?
