ITX-Llama (Vortex86EX ITX motherboard) - DONE!
Reply 720 of 735, by sdz
Duffman wrote on 2025-10-06, 10:31:
@sdz […]
@sdz
Nicely done!
I'm sure there will be many ITX llama users delighted that they can use Nvidia cards on their builds now.
On a topic of Nvidia cards - I have a Vortex86DX3 build of mine (using an ETX module and IP412 carier board), whenever I've tried to run an Nvidia Geforce FX 5500 PCI (no AGP on carrier board) and, even though I assign an IRQ to the card. I always got these strange artifacts when I tried to boot 98SE on it (after the nvidia driver install, the basic 16 color VGA driver still works).
The attachment 1000000105.jpg is no longer available
Did you ever encounter this kind of visual artifacting during your testing?
I can't say I've encountered that kind of visual artifacting (but I also can't say I really tested Nvidia cards before patching the BIOS 😀 )
Dothan Burger wrote on 2025-10-06, 10:40:
sdz wrote on 2025-10-06, 09:24:
However, it did fix it for other cards. Here is an unmodified AGP Nvidia Geforce FX5200 plugged into the Llama: […]
The attachment S11.jpg is no longer available
The attachment S12.jpg is no longer available
Both VGA and HDMI outputs work, as well as OpenGL and D3D:
The attachment S13.jpg is no longer available
The attachment S14.jpg is no longer available
The attachment S15.jpg is no longer available
Of course, more testing is needed (also need to ensure it doesn't break other things).
WOW! what a huge breakthrough SDZ. I'm huge nvidiot and was a little disappointed when the Llama wouldn't work with my GeForces.
They may work now 😀 I have only tested the FX5200, as I don't have other AGP Nvidia cards (maybe a TNT2 somwhere? ), but I expect other cards to work now (maybe not all of them).
Some updates regarding the S3 cards.
I have tried VBE9x with the S3 with Llama and the vanilla BIOS. It resulted in a garbled screen/frozen system.
With the patched BIOS VBE9x now works with the S3 Savage4 Pro:
The attachment S1.jpg is no longer available
The attachment S2.jpg is no longer available
Higher resolutions supported by VGA:
The attachment S3.jpg is no longer available
Now, VBE9x isn't ideal (compared to the S3 drivers) but it still beats 640x480@4 colors.
Reply 721 of 735, by sdz
Spent the whole day trying to get the S3 working on the Llama, doing stuff like this (among other things):
The attachment S1.png is no longer available
Basically exhausting all the sane options that I can think of. Until it occured to me, does the S3 Savage 4 Pro (that supports AGP 4x) actually support 66MHz operation when in PCI mode (which I assumed it did)?
The PCIe to PCI bridge on the Llama is configured for 66MHz operation. I changed the bridge config straps for 33MHz and:
The attachment S4.jpg is no longer available
The attachment S5.jpg is no longer available
Edit: Reverted the Llama to the default PCIe to PCI bridge configuration (PCI@66MHz) and strapped the S3 Savage4 Pro for AGP bus instead of PCI bus (AGP part of the bus still terminated on the card). With 1 resistor removed, it now works on the unmodified Llama (except the BIOS):
Reply 722 of 735, by sdz
Found a RIVA TNT2 64 /VANTA-16. It works fine with the patched BIOS:
The attachment 20251007_161729.jpg is no longer available
The attachment 20251007_161734.jpg is no longer available
The attachment 20251007_161743.jpg is no longer available
Reply 723 of 735, by thyrrestrup
That is amazing! Well done.
Reply 724 of 735, by Dothan Burger
sdz wrote on 2025-10-07, 13:57:
Just seeing the Nvidia control panel makes me happy. I look forward to your progress.
Reply 725 of 735, by sdz
I was never able to boot optical media from a SATA ODD (SATA HDD worked fine) so I spent a few days working on the BIOS. It now boots every single bootable disc I tried.
https://www.youtube.com/watch?v=gG5bPUfYKp0
If anyone want to try, I have attached two BIOS images:
BIOS_PIRQ_FIX.rom - Includes fix for Nvidia cards (and probably others)
BIOS_PIRQ_ATAPI_FIX.rom - Includes fix for Nvidia cards and for the Vortex86EX ATAPI issues
None of these roms contains VFDs. Flash as usual, with anybios w ****.rom .
It shouldn't brick anything, but test at your own risk.
If anyone wants to build the BIOS from source, I have attached the two patches with the changes, 0001-Fix_PIRQ_routing_for_devices_behind_PCIe_PCI_bridge.patch and 0002-Fix_Vortex86EX_ATAPI_boot.patch.
You can copy them in the ITX Llama BIOS src directory, apply with patch -p1 < ****.patch, and build as usual.
Reply 726 of 735, by Dothan Burger
sdz wrote on 2025-10-10, 22:06:
I was never able to boot optical media from a SATA ODD (SATA HDD worked fine) so I spent a few days working on the BIOS. It now […]
I flashed the nvidia fix but now when Installing 98SE it errors telling me I need at least 16mb or ram. I haven't used the Llama in a while so I'm not sure if there is something I'm missing.
EDIT:
Reflashing the original bios fixed the install process. Installed Windows and then flashed and it does fix the Nvidia graphics card issues but now the audio is broken. It just clicks and doesn't play windows or game sounds in windows.
I'm using a SATA SSD so I haven't tested the ATAPI fix.
Reply 727 of 735, by sdz
Dothan Burger wrote on 2025-10-11, 00:43:
I flashed the nvidia fix but now when Installing 98SE it errors telling me I need at least 16mb or ram. I haven't used the Llam […]
EDIT:
Thanks for testing!
Regarding audio, my bad. ISA interrupts are edge triggered, not level triggered. Can you try the attached BIOS? It contains the ATAPI fix as well, but it shouldn't cause any problems when booting from SATA SSD/HDD.
Not sure about the 98SE installation issues. I have installed 98SE a few times with this BIOS, and haven't encountered that yet.
Reply 728 of 735, by Dothan Burger
sdz wrote on 2025-10-11, 20:53:
Thanks for testing! Regarding audio, my bad. ISA interrupts are edge triggered, not level triggered. Can you try the attached B […]
EDIT:
Thanks for testing!
Just flashed that bios and it did fix the audio. The install situation is weird though, is there a way to toggle the nvidia fix in the bios. What is your installation process?
Edit: I used the slipstreamed install from Eivind. but without the VFD I was using various usb boot disks and went back to a Radeon and still no dice.
Reply 729 of 735, by sdz
Dothan Burger wrote on 2025-10-11, 21:12:
EDIT:
Thanks for testing!
Just did two fresh W98SE installs, on SD card and SATA SSD. I installed them as I usually do:
-connect SD/SATA SSD/HDD to modern Windows PC
-start Rufus, select the storage device, at Boot selection select MSDOS. Click start.
-when done, copy the W98SE setup files on a directory on that disk (I used the W98SE image with Llama slipstreamed drivers).
-unmount, boot storage device in the Llama. It boots into DOS. Change directory to where the setup files were copied, run setup.exe. Then proceed as usual.
I had no issues whatsoever, with an Nvidia FX5200 installed.
Edit: There isn't an option to disable the Nvidia fix in the BIOS (nor should it be needed).
I have attached the same BIOS but with the two MS-DOS VFDs included.
Reply 730 of 735, by sdz
Previous BIOS images were built on top of an older branch (2025-03), so I rebuilt on top of the latest one.
BIOS images based on 2025-06, with VFDs included.
-BIOS_PIRQ_FIX_VFD.rom contains the fix for Nvidia (and probably other) cards
-BIOS_PIRQ_ATAPI_FIX_VFD.rom contains the fix for Nvidia (and probably other) cards plus the ATAPI fix
Reply 731 of 735, by thyrrestrup
Any chance you could share something about your process for figuring this out? Any references, programs or docs?
Good work!
Reply 732 of 735, by snipe3687
sdz wrote on 2025-10-14, 08:39:
Previous BIOS images were built on top of an older branch (2025-03), so I rebuilt on top of the latest one. […]
this is great! I don't suppose you want to share the source code, do you? I have a custom build of the BIOS I use for some of my projects and would love to integrate your fixes into it!
Reply 733 of 735, by sdz
thyrrestrup wrote on 2025-10-14, 09:53:
Good work!
Thanks! I'm not really the person to give advice on these things. This is my second time using coreboot/SeaBIOS.
-for the Nvidia cards fix, I just noticed that no video cards were assigned an IRQ, and went the rabbit hole. No tools were used.
-for the ATAPI fix, the only program I used was a terminal emulator, to get serial output from SeaBIOS (to dump various registers).
snipe3687 wrote on 2025-10-16, 12:04:
What do you mean by source code? I already shared the two patches here, and over discord. What I haven't attached here yet is the PIRQ fix that doesn't break ISA IRQs, and I'll attach it now. As well as the other patch, which is unchanged.
Reply 734 of 735, by Dothan Burger
That bios worked great and it's cool that it has all those new startup sounds and VFD options. Thank you!
Weirdly though, now that all the things have been solved I'm left wondering what I'll actually use this thing for. It's just not powerful enough to play 3d games and I have other DOS only machines with better sound. Think it's time to ebay it, because every time I pull it out I waste way to much time.
Reply 735 of 735, by crusher
This product is outstanding!
Very professional and innovative made 😀
I hope there will be new batches available including the 3D-printed custom case.
