PowerVR Fun Thread
Reply 1100 of 1117, by leileilol
I also only know of motordemo_soft.exe and motordemo_3dfx.exe demos and IIRC they're more barebones prerelease demos.
The Motorhead I tested was a full version and that definitely has PowerSGL in there. It's an explicit choice apart from the Direct3D option offered.
(No idea if technically-related game Swedish Touring Car Championship has the same renderers)
Reply 1101 of 1117, by hornet1990
Fun fact, I used to work in the Graphics Products Division of STMicroelectronics who developed the Kyro chips. The plan was that the STG4k series (Kyro I & II) through to STG6k would use licensed PowerVR technology, but the STG7000 was going to be built using our own technology/IP. I was hired despite no professional graphics or C/C++ experience (only personal projects) to work on the OpenGL drivers.
When the whole industry took a downturn in 2001 the department was largely seconded to other projects in the business that would be more immediately profitable but I was kept on the small team keeping the STG7000 project alive; until it became clear the writing was on the wall for the division so I moved on. The division was officially shut down in 2002. Those were the days though...
We were all given a Kyro II card which I did use for quite some time but eventually sold a couple of years later, to my eternal regret.
I still have all the code and documentation I wrote (and more) from that time. I did have the somewhat crazy thought to get a Win2k development environment setup and get it all recompiled. Maybe even look at getting TempleMark to run on my recently acquired system with its Voodoo 4 (doesn't start due to lack of EMBM).
https://rogueone.uk Kyro and other things
Reply 1102 of 1117, by leileilol
hornet1990 wrote on 2024-03-31, 17:17:
That's probably one of the most interesting mysteries as it supposedly goes through SGL2, and that API hadn't been publicly documented or known to be supported on Kyro... (though to be fair SGL was very dead by 2001)
Even the PCX1/2's MiniGL is mysterious!
Reply 1103 of 1117, by JustJulião
leileilol wrote on 2024-03-31, 16:55:
I believe what I got on the other PC was the "newer demo" listed here https://community.fortunecity.ws/underworld/f … 8/motorhead.htm
Reply 1104 of 1117, by hornet1990
We didn't handle the Kyro drivers in-house, that was Imaginations territory. I was working on the drivers for what was going to be our technology so we were starting from scratch.
I've just had a look at the extracted drivers for Kyro II that I've got and run the GL ICD through Ghidra and depends. It doesn't directly import the SGL2.dll that is included in the distribution. However looking at the disassembly it does dynamically load it and setup pointers to sgl* functions. Interestingly, many of the functions which look drawing related e.g. sgl2_index_triangles are setup but apparently not called, the ones that are called after setup are texture management and other setup/admin tasks. The D3D dll doesn't contain any symbols for sgl so likely doesn't use it. Probably not telling you anything you didn't already know though...
Reply 1105 of 1117, by matze79
dexvx wrote on 2017-03-31, 05:11:
So far no drivers are working for Direct 3D. The Hercules drivers will load and 2D (Direct Draw) seems fine. But Direct3D never works, the screen just displays a bunch of garbage.
On a side note, DxDiag is reporting 24.5 MB video memory instead of 32 MB. I've searched and it seems that the card may be defective, but it varies on the symptons. Anyone got any ideas for a fix, if any?
Have the same issue, only with the PCI Cards, AGP Cards all work fine ??
Driver loads, 2D is fine, Direct3D non working..
Reply 1106 of 1117, by Apollonios
on which platform would the PCX2 be best? Kt133 or bx chiset over 1ghz or is 500mhz enough?
Reply 1107 of 1117, by auron
p3 500 should be more than enough for it.
Reply 1108 of 1117, by leileilol
the-p4-you-find-on-the-curb kind of computer is also fine for it. What's NOT fine for it are FPU-weak CPUs like 486s, earlier winchips, 6x86s and FPU-less like useless nexgens
Reply 1109 of 1117, by JustJulião
Apollonios wrote on 2025-04-04, 00:26:
If you are not into period correctness, the fastest and newest the better.
Reply 1110 of 1117, by Kahenraz
Although not strictly necessary, the PCX2 chip runs very hot and benefits from the addition of a heatsink and/or fan.
Reply 1111 of 1117, by anthony
BX is the best, all rest is transgressed.
BX is king in terms of PCI33 bus speed.
Reply 1112 of 1117, by envagyok
Hello
Someone know downloadable or FTP collection of pvr related games/patches/drivers?
Thank you
Reply 1113 of 1117, by vetz
envagyok wrote on 2025-07-08, 07:02:
Hello
Thank you
See my thread 3D Accelerated Games List (Proprietary APIs - No 3DFX/Direct3D) for supported games, patches and demos.
Reply 1114 of 1117, by envagyok
There no games, just patches.
Can someone shares matrox m3d both driver disc image?
Reply 1115 of 1117, by vetz
envagyok wrote on 2025-07-11, 07:06:
It also contain links to demos that support PowerSGL.
You can't ask for links to full version games here on VOGONS I'm afraid. The list should be all you need to find the games either as a purchase on Ebay or on the high seas.
Reply 1116 of 1117, by Dipshidian
When I first discovered that you could turn on real-time shadow volumes in A5/A-Train 5 in the original PowerVR version I was completely floored at how extensively it's used! Of course, it runs really poorly in complex scenes, which is why I guess I should feel lucky that it's only an urban planning simulator/city builder game and not something requiring fast reflexes. I haven't even tested all vehicles and structures to find out how shadows manifest themselves across all facets of the game. Been testing it out mostly within the starting preset towns/traffic routes.
I grabbed footage a while ago: https://www.youtube.com/watch?v=V2mu23t218A
It was compiled in late December 1996 and it's another early MMX optimized game (which might be used to speed up the 2D view window, maybe, based on my very limited testing), meaning it was likely sold around January 1997. It does technically work without a PowerVR PCX1 card but you get no 3D view/graphics that way!
Your friendly source for high quality video captures of period-correct hardware! Youtube: @dipshidian
Reply 1117 of 1117, by Dipshidian
I was crazy enough to go through all 5 stages of PureVex recently and captured the whole ordeal here: https://www.youtube.com/watch?v=py8EKrgIAKc
Unless I’ve overlooked something, I don’t think anyone had footage of the whole game online before the footage I grabbed. Of course, my footage isn’t maybe representing the game in its most ideal light seeing as how I was using a considerably older and slower Pentium PC to play it. This was mostly to help my reaction time thanks to some slow-down happening here and there.
Originally, the idea was to complete it on a Pentium Pro 200 + PVR PCX1 machine — and I got damn close to beating it at one point — but I could never consistently get through stage 5 with all my upgrades intact with some of the dodging you have to do, not helped by all the randomized enemy placements and shot patterns from start to end. It’s not an easy game to get used to!
