Reply 57640 of 59579, by Ydee
- Oldbie
I couldn't resist and because as an AMD fan I didn't play with Intel's platform back then, I took a set of MB+CPU+RAM for $10 to compare the competition between s.754 and s.775 with single channel CPUs. Because I have a soft spot for outsiders, a choice was made on Via chipset - there is PM800 on MSI PM8M3-V H.
The seller said the board was taken from an mp3 jukebox because it previously had a business renting slot machines and jukeboxes. Guys, I've never before believed how hard can hold nicotine and cigarette smoke with dust on a board! Every capacitor (all Panasonic brands), slot, connector and board surface were covered with a thin, cuddly film that only went hard to remove.
And a surprise in the end - I assumed the CR2032 would need to be replaced because it would be dead (as the business seller ended 15 years ago and the coin cell didn't look new)), but no - when I pulled it out of the board, there was still a sticker underneath, preventing contact with the minus pole in the slot for the battery, so CMOS setting couldn't be backed up and the cell still has enough 2.93V.
Sellers set photo:
