First post, by marxveix
At the moment i could fit Celeron 333 up to Celeron 1.4GHz with it.
Its old Compaq Presario case, GA-6WMMC7 rev 4.0 motherboard.
OS will be Windows 98 SE and RAM 256MB or up to 512MB PC100.
What resolution can this VGA handle and what CPU would be good?
Best ATi Rage3 drivers for 3DCIF / Direct3D / OpenGL / DVD : ATi RagePro drivers and software
30+MiniGL / OpenGL Win 9x dll files for all ATi Rage3 cards : Re: ATi RagePro OpenGL files
Reply 1 of 6, by Bobolaf
I think the GeForce FX range graphics cards were released in 2003. So your 1.4GHz chip is probably the closest you have there but still a little on the slow side to get the most from your graphics card. Probably a higher end Pentium 4 or Athlon XP would be a closer match. If I recall correctly it should be able to output QXGA (2048x1536) But for 3d games it will be much lower. If you were happy to turn all the eye candy off it could play games like Unreal Tournament 2003 at 1024x768 when paired with a quick CPU.
Reply 2 of 6, by pete8475
marxveix wrote on 2025-10-19, 19:18:
At the moment i could fit Celeron 333 up to Celeron 1.4GHz with it. Its old Compaq Presario case, GA-6WMMC7 rev 4.0 motherboard […]
I don't think that motherboard supports Tualatin processors, are you planning on using an adapter? I've got a Powerleap Tualatin adapter that works nicely in a lot of old boards but it adds some height so you have to be careful with the cooler you use.
Gigabyte says FCPGA processors here:
https://www.gigabyte.com/Motherboard/GA-6WMMC7-rev-4x/sp#sp
The retro web says everything before Tualatins here:
https://theretroweb.com/motherboards/s/gigaby … ga-6wmmc7#chips
Anyway if you can somehow get a 1.4 Celeron in there that should do a decent job with an FX5500, those cards are very slow.
aka pete4237.5
Reply 3 of 6, by marxveix
pete8475 wrote on 2025-10-19, 23:19:
I don't think that motherboard supports Tualatin processors, are you planning on using an adapter? I've got a Powerleap Tualati […]
No adapter!
Here i can see that Celeron Tualatins are supported with Rev 4.x boards.
https://www.gigabyte.com/Motherboard/GA-6WMMC … ort#support-cpu
Motherboard came with Celeron 700, i will find out what it takes. 😀
Reply 4 of 6, by marxveix
Bobolaf wrote on 2025-10-19, 23:06:
Thank you! So even with 64bit memory you all think that max cpu is the best for fx5500 pci.
Reply 5 of 6, by marxveix
Hello, my board is with F5 bios, can i force flash it to F9e?
https://theretroweb.com/motherboards/s/gigaby … a-6wmmc7-1#bios
Also what is the safest way to take Socket370 cooler off?
I need to push it down and push it away from cooler at the same time.
I have done it before, at the moment it harded somehow.
Reply 6 of 6, by pete8475
marxveix wrote on 2025-10-20, 08:26:
No adapter! […]
No adapter!
That chart is weird and you're right upon looking at it, it does seem to say P3-Celeron 1.4 is supported.
Good luck!
aka pete4237.5
