X800 agp and Windows 98se issues
Reply 20 of 22, by rotzgurke
Are there perhaps any BIOS settings to be made?
Reply 21 of 22, by aspiringnobody
rotzgurke wrote on 2025-10-20, 08:35:
Try turning off USB in the bios. Reset ESD Configuration and make sure PNP OS is set to YES.
Reply 22 of 22, by wiibur
Make sure your monitor is installed at least as a generic plug and play monitor and see if that helps. I've had issues with it getting reset to Default monitor when swapping cards or using a VGA switch/splitter and that has prevented me from changing resolution or refresh rate. I have gotten an X800 XL on the Catalyst 6.2 drivers to work fine under Windows98.
