First post, by ruthan
Hello,
i wonder tried someone to solder DVI port to unoccupied holes on PCB? DVI cards are quite rare in this era.
I never fully understand why its normal to make PCB with unoccupied places, if it make sense, if it really save some money.. and if its cheaper than create more variants of PCB.
I checked my cards there seems that there are not unoccupied PCB places for components near DVI holes.. so it seems that only DVI port coudl be missing, not some RAMDAC, or other components.
I tried to solder DVI port to one of cards, Geforce 3 TI 2000, but its not working.
Im not sure if some special bios is needed, or really other unccopied component on more distant places from dvi port holes are needed.
Im old goal oriented goatman, i care about facts and freedom, not about egos+prejudices. Hoarding=sickness. If you want respect, gain it by your behavior. I hate stupid SW limits, SW=virtual world, everything should be possible if you have enough raw HW.
Reply 1 of 5, by The Serpent Rider
GeForce 3 is analog only. You need additional logic to output digital.
Reply 2 of 5, by shevalier
https://www.vgamuseum.info/index.php/cpu/item … geforce3-ti-200
compare the presence of parts on the bottom of the PСB
https://www.alldatasheet.com/datasheet-pdf/vi … SII164CT64.html
And something very unpleasant.
There's a strap resistor "enable DVI" on the board , and it could be located anywhere.
Without a schematic, this exercise is pretty pointless.
Aopen MX3S, PIII-S Tualatin 1133, Radeon 9800Pro@XT BIOS, Audigy 4 SB0610
JetWay K8T8AS, Athlon DH-E6 3000+, Radeon HD2600Pro AGP, Audigy 2 Value SB0400
Gigabyte Ga-k8n51gmf, Turion64 ML-30@2.2GHz , Radeon X800GTO PL16, Diamond monster sound MX300
Reply 3 of 5, by mockingbird
shevalier wrote on 2025-10-23, 11:47:
...or take two cards, one with DVI and one without and compare them.
(Decommissioned:)
Reply 4 of 5, by The Serpent Rider
Looking at the back of the reference GeForce 3 Ti 200 PCB, there's a placement for Silicon Image Sil164CT64 chip. Digital won't work without it.
Reply 5 of 5, by shevalier
mockingbird wrote on 2025-10-23, 12:48:
...or take two full identical cards, one with DVI and one without and compare them.
And even there, there are usually about ten strap-resistors (for example, whether to transmit sound via DVI or not), and even with a schematic, it's not always clear which one does what.
But, of course, it's a matter of persistence.
