Seagate Tools for DOS not loading
Reply 20 of 39, by Harry Potter
I don't think there is one. Sorry! BTW, you said that Drive D: is funny. Does it work properly? If you try DIR on that drive, do you get a listing? If not, try using FORMAT to reformat the drive. A long time ago, I had a Win98SE tower and tried several times to partition and format the drive only to realize that the hard drive will only give me 2.1GB formatted when it was supposed to give me ~20GB. If you need help, try FORMAT /?.
Joseph Rose, a.k.a. Harry Potter
Working magic in the computer community
Reply 21 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 20:57:
Well, it's being funny as it was showing up twice in Windows. But I think I do need to reformat it. I just don't want to lose what's on there. I'll try creating an image file first, if I can, but failing that, I guess I will have to. But yeah, DIR works on it. It recognises the right capacity at least.
OS: Windows 98 SE
CPU: Slot 1 Pentium III Coppermine 933MHz (SL448)
RAM: Kingston 256MB 133MHz
GPU: Nvidia 16MB Riva TNT/128MB Geforce 4 Ti 4200
Motherboard: ABit AB-BE6-II Intel 440BX
HDD: C, D - IDE 1, CD-ROM - IDE 2, E - IDE 3
Reply 22 of 39, by Harry Potter
Well...if you can't image the drive, I recommend that you use a compression utility such as PKZip or DOSRAR to compress the contents of Drive D: that you want to preserve to another hard drive or removable media. This would take up less space than a full image of the drive. In the end, it might take more work, though.
Reply 23 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 22:08:
Ah. It's worth a shot though. But I guess it depends on how much work... ^^;
OS: Windows 98 SE
Reply 24 of 39, by Harry Potter
Probably not much more work, as either way, the work is probably pretty involved.
Reply 25 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 22:21:
Is it a similar process as making an image using GHOST?
OS: Windows 98 SE
Reply 26 of 39, by Harry Potter
I don't know, as I never imaged a drive nor did I ever use GHOST. Sorry.
Reply 27 of 39, by DustyShinigami
Anyway, I came back to the PC after leaving it for a couple of hours, and backing it up as an image isn't viable. It only completed 25%. It would be crazy big to back up. So compressing it would be the next best thing to try.
On the plus side, after quitting and loading back into Windows, the D drive is back to normal! It no longer has two showing. 😁
OS: Windows 98 SE
Reply 28 of 39, by Harry Potter
Good! 😁 Are you ready to try out my suggestions regarding DOS memory?
Reply 29 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 23:18:
Is that this one...?
When/if you reenable EMM386, you can try the "I=B000-B7FF" and "HIGHSCAN" switches: the former uses the VGA's mono graphics buffer for UMBs, as they're hardly ever used, and the latter performs an extra scan for more UMB space. I see you are using the normal mouse driver and have a reference to CuteMouse REMmed out. Try using CuteMouse instead. If you're still low on UMBs, you can Google QEMM: it has ways to significantly increase the amount of UMBs on your system and. if that's enough, has two Stealth ROM features where some ROMs can be replaced with RAM and switched back to ROM upon access and replace the RAM afterwards.
OS: Windows 98 SE
Reply 30 of 39, by Harry Potter
Yes. That's the one. 😀
Reply 31 of 39, by DustyShinigami
I'll give that a try now. 😀
I suppose one thing I could look into, regarding the backup of that hard drive's contents, is to get one of those USB to IDE cables and try and extract the data on my main PC.
OS: Windows 98 SE
Reply 32 of 39, by DustyShinigami
It just says EMM386 not installed.
OS: Windows 98 SE
Reply 33 of 39, by Harry Potter
Well...you could purchase an IOMEGA Zip100 drive. Its disks seem to support ~95.7MB. They come in IDE, Parallel, USB and SCSI interfaces. I used to have Parallel ones, but I broke them, and my mother, who holds the computers for me, is homeless. They should be available on eBay. If you get a Parallel one, you can find a better driver for it at https://dosprograms.info.tt/indexall.htm in the utilities section named Palmsys. It is much smaller than the default Guest driver included by default and is probably more compatible than Guest. On one of my computers, it only worked sometimes, but other people online didn't seem to have hat problem. The problem is that it probably won't work on modern computers--unless you get a USB one.
Reply 34 of 39, by Harry Potter
Well...reenable EMM386 and try the RAM switch. 😀
Reply 35 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 23:54:
Hmm. Not heard of or come across those before. It's something to look into, but I suspect it'll be faster accessing the contents on my main PC and (hopefully) copying them on there momentarily. The amount of space the images I had/have on there would take forever to transfer using older hardware, wouldn't it?
OS: Windows 98 SE
Reply 36 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-23, 23:56:
I believe it was. I've tried C:\WINDOWS\COMMAND\EMM386.EXE ON, DEVICE=C:\WINDOW\HIMEM.SYS and DOS=HIGH,UMB. I've also tried setting LASTDRIVE to E, G, C and D. But if I have the CD inserted on boot, and that loads up before my autoexec and config files are run, none of those commands are going to have any effect. ^^; I've tried running the CD after the command prompt has initialised everything, but I've not been able to get it to boot the utility up.
OS: Windows 98 SE
Reply 37 of 39, by DustyShinigami
Regarding an IDE to USB adapter - my fear, if I get one, is if my main PC will ask me to reformat the drive once I've plugged it in.
OS: Windows 98 SE
Reply 38 of 39, by Harry Potter
If you insert the CD after startup, does it work?
Reply 39 of 39, by DustyShinigami
Harry Potter wrote on 2025-10-24, 11:14:
I'll give it a try a bit later, but I seem to recall I wasn't able to for some reason. Usually when it gives me that error about the RAM drive, like the Windows 98 disc, it appears to create a temporary boot disk on drive A...? I couldn't seem to get anything working with that either.
Anyway, I've ordered myself one of those IDE to USB adapters. It's supposedly arriving today (the same day) at around 10pm, so I'll be able to test and see if it complains about needing to reformat.
OS: Windows 98 SE
