Daniel4200 wrote on 2025-10-20, 05:55:
I have made some good progress with the Pentium 3 board and was going to have a look at the other two.
I have never re-capped anything before, I have a soldering iron so I was hoping ghat you might be able to advise on what capacitors are needed and if any are better quality?
Sorry for the late reply - I was away with my son visiting some significantly older vintage stuff in Roma.
Yes, capacitors have different specs and quality. For this sort of motherboard work, you need low-ESR caps. Quality is part brand (things like Panasonic, Nichicon and Rubycon generally good, pretty much anything on a 2000-era motherboard: bad) and part voltage and temperature spec. There are lots of topics on which caps to buy (like: What are good caps to buy? )
First step is to determine specs of the bad caps. If only one cap of a certain type is bulging, treat all of them as failed. The relevant specs are:
- capacitance (generally in uF)
- (theoretically) ESR
- pin spacing
- type (electrolytic can, tantalum or polymer)
- voltage (in V)
- temperature
Your replacement caps need to have the same (or really close) capacitance, ESR, type and pin spacing. Note that I call ESR "theoretical" - the reason is that poor caps probably never performed at nominal ESR even when new. So short-cut is just to go for generic 'low-ESR' caps of the same type with the same capacitance and pin spacing. The caps in your pics are all electrolytic cans.
Voltage and temperature rating must be at least the same as the original caps but may be higher. Going over original spec will generally give you more headroom, so more reliability and lifespan. However that generally also makes the caps physically bigger (possibly not available in the correct pins spacing) and can affect ESR as well - and cost more. So one voltage level up (i.e. 10V instead of 6.3V or 16V instead of 10V) is generally fine, as is one temperature level up (i.e. 100C instead of 80C), but don't go crazy: nothing on a motherboard goes over 12V, so you do't need 250V 300C caps.
