Reply 2360 of 2663, by youtao62
Hello, I encountered a bug while using the BassMIDI VSTi plugin. First, I unchecked the "Use Sinc Interpolation" option in Windows (this was also due to the dull sound issue). Then I opened the Cubase software, used the VST MIDI Driver to load BassMIDI VSTi, and played the MusicBox soundfont directly—but the sound was still dull. The sound only becomes non-dull when I open the BassMIDI VSTi plugin, bring up the interface for loading SoundFont soundfonts (the "Use Sinc Interpolation" option in this interface is actually already unchecked), and then close this interface.
file.php?mode=view&id=229478
file.php?mode=view&id=229479
Reply 2361 of 2663, by Falcosoft
youtao62 wrote on 2025-10-25, 09:08:
It seems the plugin is not prepared that after loading the saved settings a new sample rate change VST event is sent again. In case of BassMidi a sample rate change reguires a new stream and it behaves as a reset.
So some Midi stream related settings are set to default again. This will be fixed in the next release.
BTW, be aware that in case of BassMidi VSTi the 'Use Interpolation' checkbox has 3 states and as the different label also suggests the unchecked state does not mean linear interpolation but no interpolation at all!
So for linear interpolation you should select the intermediate state:
The attachment linear_interpolation.png is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 2362 of 2663, by youtao62
The Use Sinc Interpolation option in bassmidi_vsti Version 1.6 has only two states: checked and unchecked.
file.php?mode=view&id=229569
file.php?mode=view&id=229570
file.php?mode=view&id=229571
Reply 2363 of 2663, by Falcosoft
youtao62 wrote on 2025-10-27, 01:14:
Hmm. It seems I have never uploaded version 1.6.1 that contained the modified option first 😀.
Anyway here is version 1.7 that contains this 3-state interpolation option and also fixes the problem of interpolation option not applied right after loading in case of some VST hosts.
https://falcosoft.hu/bassmidi_vsti.zip
version 1.7
1. Removed option to disable Sound Blaster hardware limits. New versions of BassMidi set this automatically based on soundfont attributes.
You can see if SB HW Limits are used for a sounfont in the file info extension of the file select dialog.
2. Added option to emulate SC-55 style drums/cymbals. This option enables e.g. DOOM/DOOM2 Midi files to sound properly.
3. Modified 'Use Interpolation' option. Now it has 3 states: No Interpolation -> Linear Interpolation -> 16-point Sinc Interpolation.
4. Fixed Interpolation option is not applied right after plugin loading problem in some VST hosts.
5. Updated BassMidi library.
Midi Player's 'Use Interpolation' option has been also modified to work the same way. It has a 3-state checkbox representing: No Interpolation -> Linear Interpolation -> 16-point Sinc Interpolation.
https://falcosoft.hu/midiplayer_66_test.zip
Website, Youtube
Reply 2364 of 2663, by youtao62
thanks!
Reply 2365 of 2663, by PoulpSquad
Howdy,
I'm getting lots of "Runtime error 231 at 000000000040D8C" errors using 86Box with Midi Player 6.5.
I think it always happens when I change plugin by sending a sysex with DUMP.EXE from within a PC DOS VM.
Here's the content of the batch I use (please find PRESET_1.SYX attached to this post for further decortication):
C:\MIDI\DUMP.EXE C:\MIDI\PRESET_1.SYX
About 30% of the time this will cause the error.
How can I fix this?
Reply 2366 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 09:36:
Howdy, […]
Howdy,
How can I fix this?
Unfortunately I do not know since I could not reproduce the problem. I used DosBox as the client that sends the SysEx messages and real Win10 as the OS that runs MidiPlayer. For me preset changing never results in Runtime Error 231.
The preset SysEx files you linked were created and shared by me and they contain only 5 bytes and do not contain any meaningful information regarding what the problem can be.
In this respect much more important are the preset files themselves in Midi Player's Preset folder since these contain the information what plugins, settings etc. are loaded.
Also besides the information that you used x86Box as a host it would be interesting to know what kind of operating system you used exactly.
In the meantime you can try a few things:
1. Instead of DUMP.EXE you should try the attached MDF.EXE utility to send the SysEx messages.
2. Download and try the new test version of Midi Player.
3. Create and use such configuration presets that do not use any plugins or Bass/Bassmidi. Maybe the problem is related to Bass or the used plugins.
The attachment MDF.zip is no longer available
Website, Youtube
Reply 2367 of 2663, by PoulpSquad
Hello and thank you very much for your reply, I appreciate it!
Indeed, it works perfectly well with MDF.EXE. In fact, that's what I was using before DUMP, but I got annoyed by its output (the x bytes sent messages).
> NUL: didn't help, CTTY NUL: didn't help, and MDF has no /QUIET option...
So I guess I got my answer, just use MDF.
Thank you for your help!
Reply 2368 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 10:33:
Hello and thank you very much for your reply, I appreciate it! […]
Please, attach the exact verion of DUMP.EXE that you used and caused the errors. Maybe I can figure out what the problem is.
Website, Youtube
Reply 2369 of 2663, by PoulpSquad
Yes sir, here it is:
Reply 2370 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 11:10:
Unfortunately I could not reproduce the error event with your DUMP.EXE.
According to my debug session DUMP.EXE sends the exact same bytes as MDF.EXE...
Website, Youtube
Reply 2371 of 2663, by PoulpSquad
That's very odd...
I know for a fact DUMP works fine with DOSBox (at least with the Staging flavor).
I've been having trouble with 86Box and MIDI, for instance running Gunship 2000 (the CD version with the expansion included) will invariably bring the emulation down ("The virtual machine process has unexpectedly terminated with exit code 3") after the MPS logo if MT-32 is set as the sound device. It works fine with FM.
After 86Box author gave it a look, he concluded the culprit might be the virtual cable (I'm using loopMIDI), but the same happens with LoopBe1 (https://www.nerds.de/en/loopbe1.html in case someone is looking for an alternative to loopMIDI).
Anyway, MDF works well enough for the time being, it was very nice of you to spend the time looking into this issue!
One last thing, if I may!
Some games have a very loud MIDI and weak digitized audio, to the point it's barely audible.
For instance, in Ultima Underworld, the digitized voice in the intro is clobbered by the MIDI music (MT-32).
Is there a way to control Midi Player main volume through a sysex message?
Reply 2372 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 12:21:
... One last thing, if I may! […]
Yes, you can send GM Master Volume SysEx messages. But in this case make sure that in Device Settings 'Use SysEx for Volume/Balance' is NOT checked. Otherwise the player ignores/overwrites your sent messages.
GM Master Volume SysEx syntax:
F0 7F 7F 04 01 yy xx F7
where yy defines the lower byte of volume level from 0x00 to 0x7F.
where xx defines the upper byte of volume level from 0x00 to 0x7F.
If you do not want to use 14-bit resolution then you can ignore the lower byte.
Website, Youtube
Reply 2373 of 2663, by PoulpSquad
Awesome!
That should keep me busy until supper xD
Thanks mister!
Stalled again...
This works very well for SC VA, but how do I change the volume of the munt plugin?
Nevermind, I just read here that this isn't adequate for MT-32 devices MUNT - Pre-set initial volume.
Maybe there is an option to change Midi Player global volume from a sysex?
Reply 2374 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 13:36:
Awesome! […]
Awesome!
Thanks mister!
Stalled again...
There has not been such a SysEx message so far. But I have just added the option to the new test version:
Syntax:
F0 66 0A xx F7
where xx is the volume level from 0 to 100 in decimal but in the message you have to set the value in hexadecimal ( the range is: 0x00 - 0x64).
Website, Youtube
Reply 2375 of 2663, by PoulpSquad
Oh wow, x-mas came early this year!
Can't wait to check this out!
So there is the thing:
I copied the files from the test build to my current Midi Player folder, overwriting the existing ones.
I opened Notepad and wrote 10 values for 10 levels of volume:
10% = F0 66 0A 0A F7
20% = F0 66 0A 14 F7
30% = F0 66 0A 1E F7
40% = F0 66 0A 28 F7
50% = F0 66 0A 32 F7
60% = F0 66 0A 3C F7
70% = F0 66 0A 46 F7
80% = F0 66 0A 50 F7
90% = F0 66 0A 5A F7
100% = F0 66 0A 64 F7
I opened my favorite freeware hex editor, XVI32 (http://www.chmaas.handshake.de/delphi/freewar … xvi32/xvi32.htm);
I clicked on New File ;
I imported each one of these values (Edit - Insert String... - Copy/Paste value in the Hex String text box, OK);
I saved the file as MIDI10 through MIDI100, making sure I gave them a .SYX extension.
It was then a simple matter to feed Midi Player the desired sysex with MFD. Works flawlessly, thanks a lot for your badass program!
P.S.: I found out how to fix DUMP.EXE crashing Midi Player by adding a 2 seconds delay between DUMP statements.
For instance, for 4DOS users:
@ECHO OFF
C:\MIDI\DUMP.EXE PRESET_0.SYX
DELAY 2
C:\MIDI\DUMP.EXE GSRESET.SYX
DELAY 2
C:\MIDI\DUMP.EXE VOL100.SYX
You could also use CHOICE.COM from plain DOS:
C:\DOS\CHOICE.COM /N /T:Y,2
I checked 2 and 1,5 seconds. 1 second still crashes randomly.
I'm still trying to figure out why some games crash 86Box when using MT-32 (so far I found Gunship 2000+expansion after the MPS logo, and Rex Nebular during the intro).
Reply 2376 of 2663, by Falcosoft
PoulpSquad wrote on 2025-11-06, 15:03:
Oh wow, x-mas came early this year! […]
I'm glad it is working for you 😀
Website, Youtube
Reply 2377 of 2663, by Roland User
Hi ) PoulpSquad , all much easier) Zoltan created awesome plugin ) WinMMMultiport ) This not only for devide MIDI to ports , this can use for customize and layouts MIDI 4 channels to 4 synths and in summ 16 channels ) , but this plugin you can use for select volume level for any synthesizer ) thus this plugin helpen me solve problem with YAMAHA S-YXG2006LE )
Reply 2378 of 2663, by Roland User
Hi Zoltan )
What about WinMM MultiPort VSTi , I use this plugin not like that at all as this assumed you when make this plugin )
For me this :
1) MIDI mapper in style Windows 9x / XP
2) Volume changer for problem synths for example S-YXG2006LE
3) MIDI Router for play and write MIDI music from games to MIDI files , I to hear music on one port and translate for write to another port )
thats why I want extend functional this plugin ) I remember what you not want extend this plugin up to 16 ports on scheme 16x16 = 256 channels or one port - one synth channel , but I still think what this good idea ) , but I think so too , what will beter if add expand volume ranges from 0-127 up to 0-255 , what for this need ? For same as and current volume ranges , only now this work as volume leve froml 0% to 100% , and I offer expand from 0% to 200% for amplifer some very silent MIDI files
It happens what you make anything for one goals , and then you l find out , what this plugin use for other goals and new the goals was not planned at all )
Reply 2379 of 2663, by Falcosoft
Roland User wrote on 2025-11-19, 20:49:
...what will beter if add expand volume ranges from 0-127 up to 0-255 , what for this need ? For same as and current volume ranges , only now this work as volume leve froml 0% to 100% , and I offer expand from 0% to 200% for amplifer some very silent MIDI files.
I only respond to the part that is new. The other parts have been already discussed too many times.
You cannot expand the volume range from 0-127 t0 0-255 since the 0-127 range is part of the Midi protocol itself (it's 7-bit). No synths could interpret the extended range.
Be aware that the WinMM Multiport plugin is NOT a real synth or DSP plugin. It only sends/routes Midi messages to synths. It does not generate the audio samples itself so it cannot 'amplify' like a real synth since Midi Note/Volume messages cannot be amplified beyond the 7-bit range (0-127) defined by the Midi protocol.
Website, Youtube
