UMC8881/8886 Datasheet
Reply 80 of 86, by youxiaojie
youxiaojie wrote on 2025-02-18, 11:01:
perfect! I wanna to testing gentoo and archlinux32, coreboot is perfect! […]
the dx-9200i I own is not edo support, debug card loops, and octeck 12 vip is edo supported.
I try to take some picture and take a multimeter to trace the route.
I try to dump registers.
and I can read C code and modified some code, I want to try embedded C.
is the edo-support decided by bios or chipset?
does the bios update bring me edo support?
kernel 6.6 compile success, fail to run
Reply 81 of 86, by mbalmer
pc2005 wrote on 2025-02-07, 01:28:
Late 486 may have 8886BF, which does have a nonstandard IDE busmaster. It may be possible 8886N version have even more improved controller. I've found few different pins (keyboard) but I didn't bother to make pinout (the chip was dead and the southbridge doesn't have much configuration options). I agree there will be most likely changes for power management.
I've got a question along these lines -- I have a 486 VIP board with this chip (the 8886BF) that seems to have a problem where the RESET line is stuck high. I also measured the power-good pin on the PSU and it's seemingly being loaded down to the point where it's measuring about 4.6V instead of the usual +5, which seems really suspicious to me. With respect to the power management side of things, would the pinouts of the BF and N versions be the same here?
Reply 82 of 86, by pc2005
mbalmer wrote on 2025-03-13, 16:30:
RSTDRV line seems to be connected at pin 157 on both N and BF versions (goes to F244 buffer and to ISA RESETDRV pin)
I would make pinout too, but I don't have any free time to that 🙁.
Reply 83 of 86, by pc2005
youxiaojie wrote on 2025-02-24, 04:17:
You gonna need to add some ISA serial port card (if DX-9200I doesn't have any integrated) and log any errors via COM1 (115200 bauds .. I think)
Reply 84 of 86, by youxiaojie
dear friend, I am
confused about four simm72's arrangement. for double side memory, it need ras 13 ras 02, so how it did double side 32*4=128MB?
Reply 85 of 86, by mkarcher
youxiaojie wrote on 2025-10-28, 15:17:
dear friend, I am
Preferable don't ask nearly the same question in two threads, as this can lead to some answers here and some answers there. I decided to answer this question in your thread at Re: puzzle with 4* 32M double side 72simm and recommend to continue discussion about this specific topic over there, if required.
