Shponglefan wrote on Yesterday, 16:47:
sunkindly wrote on Yesterday, 00:08:
It only has line in, line out, SPDIF, and two USB-C ports in the back? I guess it's really only a mixer for devices connectable via Bluetooth and wifi then?
The lack of I/O is especially baffling when they claim it can, "Connect all your devices: PCs, laptops, mobile phones, tablets, gaming consoles. Plug in headphones, speakers, mics, instruments. "
Yet it lacks XLR for proper microphones and 1/4" ports for instrument cables. It's clearly not intended to compete with proper audio interfaces, yet they're still pitching it in a way that suggests it can.
What makes this even more puzzling is that customization of something like this would normally be done to fit a specific workflow. If I have developed muscle-memory to do a certain task efficiently, it helps to have a replacement device that operates similarly so it is an easy transition. This thing... is just it's own thing, it isn't laid out like any existing device and it only comes with one of each component. Soooo... there is practically no reason for it to be modular. If it wasn't modular, people could just learn to use it however it was designed.
I don't think the modularity of it even matters at all unless you are intending to buy extra modules for it (leaving some of the ones you started with unused, despite the huge price tag), because the differences in using it with the buttons\knob in slightly different locations has to be very small.
So, if the cost is very high, the modularity is kind of pointless out of the box and it lacks connectivity that professionals may need, couldn't someone use something like this for $50 US? It even has an XLR mic input...
https://www.amazon.com/MAONO-USB-Audio-Interf … o/dp/B0D9P3Y22C
Or this if you need lots of sliders and buttons... for $30...
https://www.amazon.com/PUPGSIS-Interface-Podc … h/dp/B0DPMCV3Y7
Or any of these, depending on your needs...
https://www.amazon.com/MAONO-Pro-preamp-Podca … O/dp/B0CZDPKPX5
https://www.amazon.com/Audio-Interface-Podcas … n/dp/B0B1DJP9KW
https://www.amazon.com/tenlamp-G10-Interface- … g/dp/B0DWSM9HXP
Or dozens of other options from established brands for $200 or less.
The issue isn't necessarily that this thing has no reason to exist... I'm sure someone would use it... it's just that it has a price tag that is two to ten times that of competing products that already exist.
