Reply 1080 of 1093, by fluxrez
- Newbie
snipe3687 wrote on 2025-07-14, 20:53:I made the adjustments and uploaded to github. try it again. you shouldn't have any issues now 😀
It seems the vias are still an issue for PCBWay, and black was a no go:
1. Please see pic 1, there are some vias on pads, please confirm should we fill resin for them? If yes, please confirm should we fill for vias in pads or all vias.
2. Please see pic 2, some IC spacing is samller than 0.22 mm, we can not do black soldermask bridge for them. Please confirm if you need soldermask bridge. If yes, please modify file them send me new one. If not need, we will expose the position completely, okay? Or could you accept green, purple, blue, red? then we can do.
EDIT: Looks like the ZIPPED gerber file in the github was older than the extracted version of the files. I am resubmitting with PCBWay. Oops.
