My retro build, win 98 machine
First post, by bitzu101
Hello to all în the community, this is my first post.
I have 4 retro computers and I will showcase all of them at some point.
For the moment I will start with the oldest pc I own, it took me 1 year to sort out all the parts but it s 99% done now...
So...
Cpu: p3 @ 866 MHz coppermine
Mb: abit bh6 v1. 1
Ram: srd 512mb samsung
Gpu: I have a few, but settled on a gf4 ti 4200 64mb.
Sound card: ess solo 1 for best dos compatibility.
HDD : 40gb seagate.
Psu: 300w non branded.
Floppy drive lite on
2x dvd drives, one Sony and one Philips ultra link.
It runs win 98 se and does work quite good, I would say it s a late win 98 machine... The motherboard I think it s one of the good ones, very rare...
Here are some pics as well...
Reply 1 of 28, by Turboblack
Congratulations, I have a similar configuration, good luck with your work
old.net.eu.org - CMS for downgraders /// w10.host - WEB 1.0 HOSTING (small web) /// elpis.ws - ZINE about small web
Reply 2 of 28, by bitzu101
Turboblack wrote on 2025-10-29, 10:38:
Thank you!
I think i misspelled the mobo name , it s a VH6 ver 1.1 , which i understand it pretty much a vh6 - 2...
I think Abit did some of the best boards in their time. As for the sound... I could not think of a better pci sound card than the Ess Solo 1.... I have a yamaha 724 sound card as well , but that is for another project.... I also own a ess 1868f isa card which I could use in the isa port , but i really cannot be bothered to disable a device irq just to enable the isa sound card , plus , all games that i would be playing , i will start from windows.
Reply 3 of 28, by RetroPCCupboard
Very nice build. I have the same removable drive caddy. Good choice of games on your desktop
Reply 4 of 28, by bitzu101
RetroPCCupboard wrote on 2025-10-29, 13:42:
Oh yea, i forgot about the caddy... that is actually brand new.
Reply 5 of 28, by bitzu101
Sry , just realised you cannot edit posts on this forum... so i will reply again.
X Com Apocalypse is by far my favourite. One of the best games period. So futuristic idea , and the way they done the future to look retro , like the 50's , pure brilliance.
Reply 6 of 28, by AlexZ
I would add an 8cm fan below the power supply to blow air out of case. Upgrade to 1Ghz CPU should be cheap.
Pentium III 900E,ECS P6BXT-A+,384MB,GeForce FX 5600, Voodoo 2,Yamaha SM718
Turion 64 MT-40@2.4Ghz,Gigabyte GA-K8NE,2GB,GeForce GTX 275,Audigy 2ZS
Phenom II X4 965,Gigabyte GA-MA770-UD3,8GB,GeForce GTX 780
Vishera FX-8370,Asus 990FX,32GB,GeForce GTX 980 Ti
Reply 7 of 28, by gerry
bitzu101 wrote on 2025-10-29, 09:55:
Hello to all în the community, this is my first post. […]
So...
Mb: abit bh6 v1. 1
HDD : 40gb seagate.
great machine, looks good and the specs are good realistic top end 98. I bet it does well with all the games shown, have any non game 'vintage' applications too?
Reply 8 of 28, by Matth79
Solid, my first time around Win98 system had an Athlon T-bird 1000, but way less GPU
Reply 9 of 28, by chinny22
We have the same case 😀
Slot A FIC SD11 Dumpter find
Agree its a very nice build but sound card is a bit basic for windows for my taste.
If it was me I'd have 2 cards. Dos card like your ESS and a second card for Windows. Either a Creative card that can do EAX or Aural Vortex 2 for A3D 2.0
but its your build so if your happy then doesn't matter what I think 😉
Reply 10 of 28, by bitzu101
AlexZ wrote on 2025-10-29, 16:28:
At full blast, the cpu is at 33 degrees. There is almost no hot air... I did however put in a noctua fan on the front, inside, a 1200 rpm silent fan.
I never bothered to look for another cpu, 866 is more than plenty for the games, except morrowind, but I have 3 more retro machines to run that on...
Reply 11 of 28, by bitzu101
gerry wrote on 2025-10-29, 19:08:
So...
Mb: abit bh6 v1. 1
HDD : 40gb seagate.
I think I have acdsee 3.0 installed on this pc, Aida 32 and Nero 7... I believe it also has office 2000 installed as well. Not really thought of other apps, I ve done it mainly for the games.
I recently bought a gf4 ti 4200 but with 64mb of ram, that I think will be a little bit more appropriate for this build... Current one is 128, think that s a little bit too much and will most likely go on the win me pc... I will probably do another topic on that pc when I get to it.
Reply 12 of 28, by bitzu101
Matth79 wrote on 2025-10-29, 21:55:
You are correct, the gpu should be either a 32mb riva tnt 2 ultra or a geforce 256 or gf 2 gts...
That would be way more appropriate. However, i am not prepared to pay a premium for those.
The gf 4 ti cards are probably the most compatible without breaking the bank. Overkill for the games installed but still era correct, presuming that you would upgrade your pc... I mean, I remember using my win 98 machine back in the day with a geforce 6600gt...
Reply 13 of 28, by bitzu101
chinny22 wrote on 2025-10-30, 02:46:
We have the same case :) Slot A FIC SD11 Dumpter find […]
I do have a few sound cards... A yamaha 724 hardware opl chip... Very fancy... I have a maestro 2, I have a soudigy 2 zs and I have a sound blaster live, and those are the ones I can remember now...
I went with the ess solo because of best in class compatibility and also because I had one back in the day, so more nostalgia than reason.
I actually have 2 ess solo 1. The reason why I bought it back in the day was because x com apocalypse had direct support for ess audio drive... Yes, it s a little bit choppy in windows, but Don t really use it for playback or anything else besides the games...
Also, thankz for the input, always welcome... I do have a few isa cards, I can alway use 2 cards if I decide to.
Reply 14 of 28, by RandomStranger
bitzu101 wrote on 2025-10-30, 03:43:
MX440
Dirt cheap and always available. Has around the same performance and compatibility as a GF256.
Otherwise I'd do the same as chinny22. I'd add a sound card that handles Windows 98 era games better. A Sound Blaster Live SB0100 is a preferred choice of mine. Cheap and does the job.
Reply 15 of 28, by bitzu101
RandomStranger wrote on 2025-10-30, 05:15:
MX440 Dirt cheap and always available. Has around the same performance and compatibility as a GF256. […]
MX440
I thought the ess solo 1 was probably the best for dos compatibility...
I do have a es1868f isa card , maybe worth to put it in as well....
Reply 16 of 28, by RandomStranger
For DOS compatibility, yes. But you said you built a Windows 98 machine. Sure, it covers late DOS games, but how far are you planning to go back on an 866MHz Pentium, 512MB RAM and a GF4200? As a W98 sound card, the Solo-1 is not great.
Reply 17 of 28, by StriderTR
Nice build! I like it! I like that case as well, it looks period correct. Much more so than mine, sitting in a small modern mATX case. 🤣
I recently completed a Win 98 machine for myself as well. After a few different hardware config changes, I settled on an Athlon XP 3000+, a GeForce 4 Ti 4200 128MB I managed to snag for free from a PC someone gave me, and a Sound Blaster Audigy EAX Advanced HD SB0090 all on an Asus A7V8X-LA with 512MB of RAM. Nothing super special, but, it handles all the games I want to play from the era, at the resolutions and settings I want to play them at. For me, I call that a win!
Good luck with your build! Looks like a fun one! 😀
DOS, Win9x, General "Retro" Enthusiast. Professional Tinkerer. Technology Hobbyist. Expert at Nothing! Build, Create, Repair, Repeat!
This Old Man's Builds, Projects, and Other Retro Goodness: https://theclassicgeek.blogspot.com/
Reply 18 of 28, by bitzu101
RandomStranger wrote on 2025-10-30, 14:51:
dunno yet... this is only one pc out of 4 , with time , will make topics for the other 3 as well...
I know the solo 1 is not the best for win 98 , but it s what I had when i was growing up and i am kinda fond of it.
plus , the best feeling when i set up the sound in x com apocalypse and I do not have to select sound blaster but my own dedicated ess audio drive. i know it s probably petty , but it s a retro pc , it s meant to make u feel like a kid again.
early early dos games... i don t have that many that i play , if any. certainly not a fan of a p1 or a p2 computer and dos only.
Reply 19 of 28, by bitzu101
StriderTR wrote on 2025-10-30, 16:42:
Thank you , good luck to you as well.
The pc you presented above is extremly late win 98. i have something similar , another pc , with socket 462 , amd athlon xp at 1.4 ghz , 512 ram and a 4200 ti. i will make another topic for that one as well when i have time. however , i am running win me on that one.
I think , past 2 ghz , you won t really see a difference in win 9x , however , socket 462 is a brilliant choice because you can go either 9x or xp. i chose win9x because i also have a monster xp machine.
monitor wise , i use a dell fp 2007 , native 4:3 and 1600x1200....
