HDA Audio driver for Windows 3.1x
Reply 20 of 59, by Falcosoft
Here is a demonstration video about Lenovo Thinkpad T430 running Windows 3.11 and using Realtek HD audio + FullHD 1920x1080 desktop:
https://youtu.be/KWqJo5-6hnQ
The video also demonstrates that Midi is also working with the help of WinGroove. And at the end of the video a fast pace board game shows that latency is also more than acceptable.
I also attach the working configuration files for Realtek ALC1150 (Gigabyte Z97x-UDH5) and Realtek ALC3202 (T430).
The attachment Realtek_ALC3202.zip is no longer available
The attachment Realtek_ALC1150.zip is no longer available
Website, Youtube
VST Midi Driver Midi Mapper
Reply 21 of 59, by Lualb
Falcosoft wrote on 2025-10-30, 18:26:
What kind of hardware do you really have? The ICH10 and NFORCE fields in the driver dialog seem to be only placeholder text fiel […]
Lualb wrote on 2025-10-30, 16:08:
Hello everyone! After a long time, I have tried again to get the driver to work, but it seems that I have problems with the volume; nothing can be heard.
I also don't see that the HDAICOUT.HDA file has been created :'(
What kind of hardware do you really have? The ICH10 and NFORCE fields in the driver dialog seem to be only placeholder text fields.
HDAICOUT.HDA has to contain codec specific commands to initialize the hardware properly.
I have working configurations for Lenovo Thinkpad T430 with integrated Realtek ALC 3202 and Gigabyte Z97X-UD5H with integrated Realtek ALC1150.
I just looked at the hardware specifications, and I see that it is a UP Gamer H81M motherboard, Intel LGA 1150, with integrated Realtek (ALC662) 6-channel High Definition audio CODEC.
Reply 22 of 59, by Falcosoft
Lualb wrote on 2025-10-30, 19:34:
Then you should try my Realtek config files. Put both the .ini and the .hda files in your Win31 folder and give them a try. Try both sets since I do not know if ALC662 is more similar to ALC 3202 than to ALC1150 or the other way around.
@Edit:
Wait, I'm stupid. Sorry. You should not replace the ini file since your codec and my codec differ so the PCI id's will not match. So you should only copy/replace the relevant fields in the card's section! That is:
[HDA_1E208086,21F317AA] -> Do not overwrite, since this is specific to your card!
wait1=$010 -> copy this
wait2=$010 -> copy this
SleepingWidget=$02 -> copy this
VolumeWidget=$02 -> copy this
OutputWidget=$02 -> copy this
Website, Youtube
Reply 23 of 59, by Lualb
Falcosoft wrote on 2025-10-30, 19:39:
Then you should try my Realtek config files. Put both the .ini and the .hda files in your Win31 folder and give them a try. Try […]
@Edit:
Okay, I followed all the steps you indicated, I restarted Windows but I still can't hear any sound (Winplay3 and media Player play the sound files muted).
Reply 24 of 59, by Falcosoft
Lualb wrote on 2025-10-30, 21:21:
@Edit:
It seems the problem is that you have 2 HD audio devices present. The other is the Intel HDMI audio. This device is also present on my Gigabyte board ($0018=$0C0C8086) and unfortunately the driver selects this device as active by default.
I also had to manually tell the driver that this is NOT the device I would like to use. Look at my Realtek ALC1150 HDACFG.INI file. At the top there is the section where I tell the driver what device to use instead:
[HDA]
SEARCH=false
PCI_BUS=$00
PCI_DEVICE=$1B
PCI_FUNCTION=$00
TSR=TSR not found
PCI_VID=$8086
PCI_DID=$8CA0
Unfortunately this is system specific so you have to find out the Bus, Device, Function parameters yourself...
In your case the Intel HD audio device with the Realtek codec is $00D8=$8C208086. So:
PCI_VID=$8086
PCI_DID=$8C20
@Edit:
You can use e.g. RW everything to find the Bus, Device, Function parameters.
https://rweverything.com/download/
Look for 'Intel Corporation HD Audio Device' in the PCI devices section and then check that its Device/Vendor ID is 0x8C208086. The Bus, Device, Function parameters are shown in the selection.
The attachment RW1.png is no longer available
Website, Youtube
Reply 25 of 59, by Lualb
Falcosoft wrote on 2025-10-30, 21:33:
Hi, It seems the problem is that you have 2 HD audio devices present. The other is the Intel HDMI audio. This device is also pre […]
@Edit:
[HDA]
SEARCH=false
PCI_BUS=$00
PCI_DEVICE=$1B
PCI_FUNCTION=$00
TSR=TSR not found
PCI_VID=$8086
PCI_DID=$8CA0
PCI_VID=$8086
PCI_DID=$8C20
@Edit:
Hi! I've just started my vacation and have more time to dedicate to my hobbies! First of all, I'd like to tell you that all this time I was misled by the motherboard's integrated sound specifications, and it's not a Realtek ALC662 as stated in the manual, but rather a Realtek ALC897 according to more extensive hardware testing
Reply 26 of 59, by Falcosoft
Lualb wrote on 2025-11-04, 18:29:
Why have you removed your previous post? It was helpful since it clearly showed the PCI Bus, Device, Function parameters. If I remember correctly it was the same as on my Gigabyte board so you should try this in your HDACFG.INI file:
[HDA]
SEARCH=false
PCI_BUS=$00
PCI_DEVICE=$1B
PCI_FUNCTION=$00
PCI_VID=$8086
PCI_DID=$8C20
First time you should not use the HDAICOUT.HDA file, just check if you get any sound. If not then you should make a proper HDAICOUT.HDA file for yourself. As a starting point you should use my Realtek ALC1150 based one.
Realtek codecs work similar but unfortunately there are some differences.
The first thing you should do when preparing your HDAICOUT.HDA file is to determine the address of your codec since the 1st byte of the verbs in HDAICOUT.HDA denotes the most significant byte of the codec address.
I attach a DOS utility (UNMUTE.EXE) that can show you the right address. According to its result you should modify all the verbs in HDAICOUT.HDA by replacing the '02' values (to 00, 01 etc. depending on your codec address).
So if your address is 0x00000000 then your HDAICOUT.HDA verbs should look like this:
$001F7700; CODEC RESET
$000F0000;
$000F0002;
$000F0004;
$000F0006;
$00170500;Power up!
But if your address is 0x10000000 then your HDAICOUT.HDA verbs should look like this:
$101F7700; CODEC RESET
$100F0000;
$100F0002;
$100F0004;
$100F0006;
$10170500;Power up!
The attachment UNMUTE.zip is no longer available
The attachment unmute.jpg is no longer available
@Edit:
I forgot to mention but after you modified your HDACFG.INI to reference the right HD Audio device and run Win 3.x without HDAICOUT.HDA you should get a new section in your HDACFG.INI:
[HDA_8C208086,xxxxxxxx]
The 'x's are not literal 'x's but can vary depending on your system. The important is that HDA_8C208086 is your right device. Then in this section you should modify the relevant parts. That is:
SleepingWidget=$02
VolumeWidget=$02
OutputWidget=$02
AFAIK all common Realtek codecs work with these widget values.
PS:
If you still cannot get sound then I'm afraid I cannot help more since I do not have your hardware to experiment with.
Website, Youtube
Reply 27 of 59, by Lualb
Falcosoft wrote on 2025-11-05, 11:38:
Hi, Why have you removed your previous post? It was helpful since it clearly showed the PCI Bus, Device, Function parameters. […]
[HDA]
SEARCH=false
PCI_BUS=$00
PCI_DEVICE=$1B
PCI_FUNCTION=$00
PCI_VID=$8086
PCI_DID=$8C20
$000F0000;
$000F0002;
$000F0004;
$000F0006;
$00170500;Power up!
$100F0000;
$100F0002;
$100F0004;
$100F0006;
$10170500;Power up!
@Edit:
SleepingWidget=$02
VolumeWidget=$02
OutputWidget=$02
PS:
Hi! I wanted to let you know that I now have sound working on Windows, and as you told me, I modified HDAICOUT.HDA, whose codec address is 0x30000000... Yes, thank you!
Reply 28 of 59, by Falcosoft
Lualb wrote on 2025-11-05, 17:41:
Nice! I'm glad it worked.
Website, Youtube
Reply 29 of 59, by AM_PM
Falcosoft wrote on 2025-10-30, 07:54:
ddd […]
AM_PM wrote on 2025-10-30, 02:54:
... starting up Windows with the driver takes more than 45 seconds with a busy mouse cursor as it tries to load the audio until finally hearing the tada and seeing Program Manager. Ahow to fix this problem.
ddd
You can reduce the wait time by modifying the wait values in HDACFG.INI. E.g:
[HDA_8CA08086,A1821458]
cardmemregistersLO=$0000
cardmemregistersHI=$F743
Mytimer=1
Verbinterface=$1
wait1=$010
wait2=$010
This whole ordeal has been puzzling. HDADRV9J/K/L driver files have a lot of files in them that don't actually get used and that confused me as for why it's there.
Those other files are the Delphi/Pascal source files for the project(s). They are not needed for the driver to work but with the help of them you can modify the driver for your like. Delphi 1 is needed to compile them.
PS:
For better overall performance you should try PluMGMK's VESA video driver. The faster the GUI the better the audio performance.
https://github.com/PluMGMK/vbesvga.drv/releases
Thanks for the reply. Changing the wait1= values didn't make a difference. I tried some other values too but no luck.
Ahh I see, they were source files. Usually such compiling files are separate zipped downloads. It's not a problem that they were included but that it wasn't properly documented hence confusion!
Oh by the way I am already using the VBESVGA driver! Looks great to use 3.1 with it. But sadly it doesn't seem to have an effect on the audio issue here.
Reply 30 of 59, by Falcosoft
AM_PM wrote on 2025-11-06, 01:52:
Changing the wait values should have an effect, but only in the right section.
As you can see in the posts above in case of multiple Intel HDA devices multiple sections are created by the driver. Make sure you modify the right one.
You can see in my test video how much the waiting time can be reduced:
Website, Youtube
Reply 31 of 59, by AM_PM
Falcosoft wrote on 2025-11-06, 04:08:
Changing the wait values should have an effect, but only in the right section. As you can see in the posts above in case of mul […]
Hmm I checked it (and compared it to yours, in the video description) and my one looks to have only one HDA device and only a single [HDA 123...] part in the config file. And yeah that's where I put the 'wait' values.
Reply 32 of 59, by Falcosoft
AM_PM wrote on 2025-11-06, 18:32:
And you get exactly the same waiting time when you modify from default wait1=$100, wait2=$100 to wait1=$010, wait2=$010 ?
That's strange and definitely not what I experienced.
Long waiting times can also be attributed to long list of verbs in HDAICOUT.HDA.
The verbs in default HDAICOUT.HDA aim blindly and try to enable all kinds of devices/nodes so the list is unnecessarily long. Try to shorten it according to your codec's documentation (or by trial and error).
Website, Youtube
Reply 33 of 59, by AM_PM
Falcosoft wrote on 2025-11-06, 18:58:
And you get exactly the same waiting time when you modify from default wait1=$100, wait2=$100 to wait1=$010, wait2=$010 ? That' […]
Interesting. Well I took a look at my HDAICOUT.HDA and there were so many "Power up!" lines. Comparing it with yours, clearly my output was very long.
So I blindly tried to make a change, deleting all but one of those lines, and it ended up in Windows not booting the Progman at all (after the busy cursor it turns to a normal cursor, but no sound and no GUI starting). I've since restored the original file.
Here I have pasted my HDAICOUT file as it is: https://pastebin.com/3xrrZnRn. Any clues in there?
Reply 34 of 59, by Falcosoft
AM_PM wrote on 2025-11-06, 19:48:
Interesting. Well I took a look at my HDAICOUT.HDA and there were so many "Power up!" lines. Comparing it with yours, clearly my […]
You have not mentioned so far what HD audio device you have. Anyway in the strict sense HDAICOUT.HDA is not required to load the driver. In the worst case it should result in no audio but no freezing.
So try to remove the HDAICOUT.HDA file temporarily from the Windows folder and compare the boot times. If it is the same long boot then it makes no sense to play with HDAICOUT.HDA.
Website, Youtube
Reply 35 of 59, by AM_PM
Falcosoft wrote on 2025-11-06, 20:03:
Realtek ALC272. I just did what you requested and it's the same long boot time! Sound still fine yeah, it's definitely loading the driver causing it.
Reply 36 of 59, by myne
onethirdxcubed wrote on 2025-06-21, 19:08:
Installing DirectX 8.1 after the Watler's driver seems to help a lot with the scratchiness of the sound in VirtualBox but there's still stability problems when I just leave it sitting idle for a bit.
I have in fact started working on a new WDM driver - see my github.
How's progress?
Has the 3.1 driver been helpful at all?
What have you read to learn how to do wdm drivers?
Curious what the best resources are
I built:
Reply 37 of 59, by onethirdxcubed
myne wrote on 2025-12-08, 16:35:
How's progress? Has the 3.1 driver been helpful at all? What have you read to learn how to do wdm drivers? Curious what the b […]
How's progress?
Progress has actually been quite good, I have enough put together for a usable output only driver on Intel chipsets with a Realtek codec, as well as VMware and VirtualBox. I just need to finish connecting the mixer controls up properly and it should be good enough to post a thread about.
The Windows 3.1 driver has been somewhat helpful but it's written in Pascal which I don't know well at all, so I found the simplest possible driver in a hobbyist OS, BleskOS, and worked from that mostly. Also referred to ALSA for the extensive list of controller & codec Quirks.
For WDM drivers Walter Oney's Programming the Windows Driver Model has been very helpful but doesn't cover miniports much so I have mostly been depending on MSDN, the DDK documentation, the sample drivers and the few other open source WDM sound driver examples, and also ChatGPT though I hate to admit that. It's not useful for directly writing driver code, but is invaluable for finding APIs documentation and explaining the purpose of code snippets. Still gets things completely wrong enough that I can't trust it without sources.
Reply 38 of 59, by myne
I gave it a crack in virtualbox and it seems better than the 3.1 driver already.
Admittedly i didn't run anything better than the start sound.
Nice work. I took a quick look at the code as well, and I might go through the inf properly.
I am decent with Infs. In my sig i figured out how to add things to 3.1
I built:
Reply 39 of 59, by onethirdxcubed
There is definitely some unnecessary stuff in the inf and the driver that is left over from the SB16 sample driver, also I need to change all the GUIDs to avoid the unlikely case where someone installs this driver on an industrial SBC with a real ISA SB16 in the system as well.
