Reply 57720 of 58209, by sunkindly
sunkindly wrote on 2025-10-21, 00:08:
IT'S ALIVE!!!!!! Holy heck, I can't believe it. My hands are red from clapping. […]
sunkindly wrote on 2025-10-16, 18:50:
Thermalwrong wrote on 2025-10-16, 03:46:
I wish you luck with getting your one working 😀
Thanks! If it doesn't work off the bat I'll likely open it up as you did yours and poke around.
Took a bit of digging to find the drivers but this post was super helpful:
https://retechvintage.blogspot.com/2025/08/an … -get-it-to.html
The attachment IMG_7558.JPG is no longer available
The attachment IMG_7559.jpg is no longer available
An update on the CDR-80: I'm assuming it's the Trantor T100 controller but connection to the drive on boot is inconsistent. Sometimes the host adapter isn't found, sometimes the device inquiry fails, sometimes the adapter is found yet the CD driver fails to load, sometimes the inquiry fails yet the CD drive still detects, and sometimes both the adapter and drive find each other with no problems. Even using a properly terminated cable didn't change the inconsistency. So I swapped out the Trantor CD driver for aspicd.sys and the CDR-80 accepts it so...I've ordered an Adaptec controller from 1990 and I'm *hoping* it'll resolve this issue.
SUN85: NEC PC-8801mkIIMR
SUN92: Northgate Elegance | 386DX-25 | Orchid Fahrenheit 1280 | SB 1.0
SUN97: QDI Titanium IE | Pentium MMX 200MHz | Tseng ET6000 | SB 16
SUN00: ABIT BF6 | Pentium III 1.1GHz | 3dfx Voodoo3 3000 | AU8830
Reply 57721 of 58209, by CharlieFoxtrot
Got these two Voodoo 1s for a very good price. The other is probably one of the most common V1 cards out there, Diamond Monster:
The attachment Diamond_Monster.jpg is no longer available
The other one is a little bit more peculiar one and I haven't bumped into one before: InnoVision 3DX5000TV. InnoVision Voodoos aren't that uncommon, but this one has TV out as an extra feature. Most of these InnoVision cards out there in the wild seem to lack the connectors and chip for TV out, so it was probably pretty much dropped at some point. Otherwise the design resembles the reference card:
The attachment 3DX5000TV.jpg is no longer available
Reply 57722 of 58209, by PcBytes
I got a Banshee 😁
Reply 57723 of 58209, by dukeofurl
dukeofurl wrote on 2025-09-25, 02:07:
I noticed the PC I got recently says Genius 1 Win 3.1 on the side.
Obviously windows is windows but I wonder what genius 1 refers to? A network name for the PC? The user's nickname? Some obscure software?
Just an update on this. I finally replaced the Dallas battery on this PC and it booted up on the original HDD. On the HDD in the main path were dos and windows 3.1 installations as well as a folder called genius1, which basically had all the previous user's files in it, mostly word processing stuff. So I guess it may have been the person's nickname for themselves/username.
Reply 57724 of 58209, by Ozzuneoj
dukeofurl wrote on 2025-11-02, 02:58:
I can't speak for anyone else, but in a small PC repair business ~20 years ago, each PC we used had a nickname and that was how we referred to that station. It's possible this was, at the time, the fastest or most advanced computer they had so they named it Genius, and added the 1 because they knew there'd inevitably be a faster computer some day. 😁
Reply 57725 of 58209, by TheIpex
My recent eBay/Gumtree purchases:
Unfortunately, the Asus SLI board is refusing to post; 1 long beep two short.
I've tried multiple VGA cards and RAM sticks but the result is the same. Hopefully it's just a bad cap but will need to investigate more.
Intel 486DX2 66MHz & Cirrus Logic GD5428 VLB
Intel Pentium MMX 233MHz & 3DFX Voodoo
Reply 57726 of 58209, by zuldan
TheIpex wrote on 2025-11-02, 06:35:
My recent eBay/Gumtree purchases: https://i.imgur.com/0q2THJbl.jpeg […]
That SLI board is nice. Maybe try some contact cleaner in the CPU socket? I use WD-40 Contact Cleaner.
Btw, how do you search for retro boards on Guntree?
Reply 57727 of 58209, by TheIpex
zuldan wrote on 2025-11-02, 08:23:
Good idea.
I found the Asus board by searching "SLI". Otherwise, I generally just search using the socket name.
Reply 57728 of 58209, by dukeofurl
Ozzuneoj wrote on 2025-11-02, 03:08:
Hehe well, the previous user's files suggest the PC was used in a church, or as the personal computer of a reverend. It's full of sermons, calendars of church events, planning the church web page, contact info of parishioners circa 2000, etc. There was enough there to learn the previous owners name and sure enough, previous owner was a beloved reverend of a church in my state who passed away a few years ago. The interesting thing is the machine was used from 1993-2005 with no upgrades, no sound card, no CD-ROM, same under 200MB HDD. That's a long time to go with a 486, but I guess if you mainly use a PC for word processing there's no significant need to upgrade... Hope I don't get any bad juju when I eventually play Doom on this machine 😛
Reply 57729 of 58209, by chrismeyer6
When you tested the Asus board did you have a bios battery in it? I've had far to many boards either play dead or act weird/no post with a missing/dead/low bios battery.
Reply 57730 of 58209, by Karbist
That board is based on nforce 4 sli chipset, I had several nforce 4 boards that had the same issue, main pcie slot didn't work but the other 16x pcie slot worked, even I got picture from 1x pcie slots with a riser.
Reply 57731 of 58209, by TheIpex
chrismeyer6 wrote on 2025-11-02, 13:54:
Yes, a fresh battery.
Karbist wrote on 2025-11-02, 15:22:
I've since tested every single slot (even the PCI slots with an old GF4 card). I've also tried different CPUs, RAM and contact cleaner as suggested by Zuldan above. Sadly, the result is the same each time.
The CPU/GPU fans spin and the chipset heatsink gets warm, but no successful POST
Reply 57732 of 58209, by zuldan
TheIpex wrote on 2025-11-03, 01:48:
Maybe time to get a post card reader. They are pretty cheap. If you get post codes it means the CPU is working.
Reply 57734 of 58209, by Susanin79
Got this nice Asus V7700TI Delux 32MB AGP video card. Works well but fan is so noisy
Reply 57735 of 58209, by CharlieFoxtrot
Susanin79 wrote on 2025-11-04, 16:03:
I have "fixed" countless of these old noisy fans by lubricating them, bearings are most likely just dry. Considering how many hours these get in retro use, these fans will easily last easily another 10, 20 or 30 years more when they are just lubricated.
Couple of weeks ago I installed a rattling Socket 7 cooler, but after a drop of oil it was smooth sailing again.
Reply 57736 of 58209, by oldpcgeek5
Nice, love old 32MB AGP video cards-which graphics chipset?
Reply 57737 of 58209, by TheIpex
Nice card, look at all those outputs. I believe this card originally shipped with 3D Glasses?
Reply 57738 of 58209, by Linoleum
Just completed a full transplant of my 233MHz MMX CPU, 3D Monster Voodoo 1, Matrox Mystique 220, and AWE64 Value — all moved from a tired yellowed case into a freshly acquired InWin S500. Much more fitting for the build!
Also added a Yamaha MU50 to the mix. Honestly, I’m very impressed — it might even dethrone the SC-55 in a few games.
P3 866, V3, SB Audigy2
P2 400, TNT, V2, SB Audigy2 ZS
P233 MMX, Mystique220, V1, AWE64
P166, S3 Virge, SB32, PicoGus
486DX4 100, CLGD5424, SB32
Prolinea 4/50, ET4000, SB16
SC386SX 25, TVGA8900D, Audician32
286 10, ATI VGA, Forte16
PS2 30/286, SBP
Reply 57739 of 58209, by Susanin79
CharlieFoxtrot wrote on 2025-11-04, 18:14:
No, this didn't helped, it still noisy, too many dust were removed from outside. It looks that it was never cleaned. Should need to find a replacement.
