First post, no Bios help
First post, by Totalgearhead
Good day all, I have been a long time user of this fabulous board for various things over the years. I enjoy tinkering with old hardware during the winter months in Canada. I have had this Progen TX430B motherboard for a couple of years and I am trying to get it going. The issue is that it came with no Bios. Looking online I can see the Bios String information, but nobody has uploaded a Bios file.
https://theretroweb.com/motherboards/s/progen … echnolog-tx430b
I have Tried, with the help of ChatGPT and persistence various bios' from PC Chips, PC Partner, ECS and versions that ChatGPT is "making" to test.
The best i get is on my PC Test card to 41/0D with constant beeping. I have tried different CPU/Ram combinations, the card has DIMM and SIMM, I tried both and currently have a combo that is validated in another machine.
In ChatGPT is gave me this prompt to post here, i just think its a little to un-human:
Looking for: Progen TX-430B (PCB code TX-430B T04015) BIOS
POST ID: 09/15/97-i430TX-2A59IA29C-00
Award 4.51PG, Version 1.04E, 128 KB (DIP-32)
Super I/O: SMSC FDC37M672
Southbridge: Intel 82371AB (PIIX4E)
My board loops 40→41/0D on newer 4.51PG images; blind-flash never seeks.
Need the original Progen A29C 1.04E dump (128 KB).
Any help is appreciated to help get me past this? I have checked and verified all capacitors, Voltages, Clock generator and with and without a video card. It doesn't get that far in posting yet. Thank you.
Currently have a PET, C64C, Numerous Socket 7 machines that include the AMD K6, my favorite CPU.
Reply 1 of 15, by Chkcpu
Hi Totalgearhead,
Welcome to Vogons!
This 09/15/97-i430TX-2A59IA29C-00 BIOS-ID identifies this BIOS as for an A-Trend ATC-5000 board. So Progen must have used an A-Trend BIOS for their TX430B board.
This makes sense because these boards are practically identical. Only the location of the SIMM and DIMM slots is different.
https://theretroweb.com/motherboards/s/a-trend-atc-5000#bios
I believe that an ATC-5000 BIOS should work fine on your TX430B, like the latest Ver. 1.08a.
Note that a 0D -> 41 POST code sequence means that the BIOS Bootblock detected a BIOS Checksum Error and entered the BIOS Recovery mode. You should be able to see this Error message when using an ISA Videocard.
Because these Award v4.51PG BIOSes are compressed, the Bootblock first checks the first Mbyte of RAM before it copies itself there to start the decompresses process. The Bootblock then performs a checksum check on the decompression engine and the still compressed Main System module in RAM. If these checks fail, the BIOS will enter Recovery mode.
After the BIOS decompression stage, an additional integrity check is done on the decompressed modules in RAM, before control is passed to them to continue POST. If this additional check fails, the BIOS will enter Recovery mode as well. The BIOS could have become corrupted.
But if you still get the 0D -> 41 POST code sequence with a freshly flashed 1.08a BIOS copy, and you flashed including Bootblock, then there is probably something wrong with your memory system. This can be the RAM sticks, the SIM/DIMM slots, broken motherboard traces of the memory address or datalines, or bad caps in the memory supply.
Hope this helps.
Cheers, Jan
Edit: Expanded the BIOS checksum logic write-up, to make the decisions to enter Recovery mode more clear.
CPU Identification utility
The Unofficial K6-2+ / K6-III+ page
Reply 2 of 15, by Totalgearhead
Chkcpu wrote on 2025-10-26, 15:45:
Hi Totalgearhead, […]
Hi Totalgearhead,
Welcome to Vogons!
Because these Award v4.51PG BIOSes are compressed, the Bootblock first checks the first Mbyte of RAM before it decompresses its modules there. If this memory check fails, the BIOS will enter Recovery mode.
Also, if this memory check passes, an additional integrity check is done on the decompressed modules in RAM, before control is passed to them to continue POST. If this additional check fails, the BIOS will enter Recovery mode as well. The BIOS could have become corrupted.
Hope this helps.
Cheers, Jan
Thank you Jan, I tried that Bios (again) and have been testing random bios files including that one as it has the same string and the 5030 to name a few. This particular BIOS re-test got stuck at the 41->0D still. I have tested and verified and or replaced all the caps in this board. I will get out my ISA video card to see what that shows me then I will check the voltages on the memory slots. I have looked over the board with a microscope and see no damage or missing traces? I have tried both SIMM and DIMM memory and its gives the same result. With No memory it halts before that at C1,C0 i believe. I appreciate the response and will report back. Thanks again.
Reply 3 of 15, by Totalgearhead
I have tested the voltages to both types of memory and they are correct. I am still getting the 0D/0C → 41/0D then constant beeps. I will verify the clock crystal and then start looking at the SMC fdc37m672 chip. If anybody has any guidance to troubleshoot the memory side of the board I would appreciate any input thank you.
Reply 4 of 15, by Chkcpu
Totalgearhead wrote on 2025-10-27, 11:38:
If you have an (E)EPROM programmer, can you make a copy of your present BIOS chip contents and sent it with your reply? So I can check if there is any corruption.
For further troubleshooting, a list of all POST codes from the first C0 to the last 41 would help. Most POST analyzer cards have a “step back” button to view all stored POST codes.
If you can get this POST sequence with the ATC-5000 v1.08a BIOS loaded, then I can compare it with the Bootblock code and see where it goes wrong.
Regards, Jan
Reply 5 of 15, by Totalgearhead
Thank you Jan, i have retrieved the codes during boot and working backwards they are: 41,0d,0c,01,c5,0c,c6,c1,00,c0
I have uploaded the BIOS from my chip that you recommended (ATC-5000 latest Ver. 1.08a) and gave the above codes. Thank you for the help, I appreciate it. I'm not at all able to decipher a BIOS or understand whats happening behind the curtain.
Reply 6 of 15, by Chkcpu
Totalgearhead wrote on 2025-10-27, 23:16:
Thanks for the BIOS dump and the POST sequence.
The BIOS EEPROM contents is identical to the ATC-5000 1.08a BIOS, so no problems there.
The POST code sequence needs some further investigation.
I do know that on the Award v4.51PG BIOS the POST steps 01, 0C, 0D, 41 are all part of the Recovery mode. So the decision to jump to recovery is made before that.
The first POST codes are also common to these Award BIOSes.
C0 – This first step is the early chipset initialization, including RTC, system ports, and DMA page registers.
00 is not a POST step, but just a spurious code emitted during reset of the DMA Page registers.
C1 - This step is all about testing RAM. First a RAM type detection is made, followed by a test of the first 256KB of memory. If this test fails, a beep code is emitted and POST is halted, exactly as you saw when no RAM was installed.
To see what the BIOS is doing in the subsequent steps C6, 0C, and C5, I will need to make a disassembly listing of this BIOS’s Bootblock and analyze it. I expect to have some time for that tomorrow.
Did you already try an ISA videocard to see if that works? The last POST step 41 is a search for a floppy drive and bootable media, and this step should be visible on screen. Note that if a bootable floppy is found, POST will cycle to step FF, indicating a successful transfer of control to the disk’s bootsector code. Please try that as well.
These checks will help with the troubleshooting.
Regards, Jan
Reply 7 of 15, by Totalgearhead
That is great information Jan, I started to read your post here regarding BIOS patching to start at least understanding it more. I have tried an ISA video card and it isnt giving anything to the screen to see. I have tried a floppy to the onboard controller and also an ISA controller and both do not give any floppy seek at all. I appreciate you looking into this. I am curious what you will find and await your response for the next task to troubleshoot. In the meantime I will try again on the ISA Video Card and also the floppy, as your explanation gives me some understanding of what is expected to happen around step 41. Thank you!
Reply 8 of 15, by Totalgearhead
Update, i had another ISA drive control card, i hooked the floppy up to that and I now have the floppy seeking!, the Analyzer Card is now displaying 41->FF, I have known good boot disk in there, it sounds like its reading it but i have no video still. I tried different slots with my ISA Video Card and I tried my PCI video cards also, no video. Thank you.
Reply 9 of 15, by Chkcpu
I’m glad to hear the floppy boot is working now, but the no-video issue is a bad one.
This is what you should see with an ISA videocard fitted, and an MSDOS 6.22 boot floppy in the drive.
Note that the bootimage I used has no AUTOEXEC.BAT, so I had to hit Enter twice to skip the request for the correct date and time.
The attachment Monitor_1_20251031-155441-305.png is no longer available
Before step 41, the Recovery BIOS searches for and initializes an ISA videocard in POST step 0D. If it can’t find a videocard, a beep is output to the speaker and it skips the rest of POST_0D, to continue with step 41 for a possible blind recovery.
Do you hear this beep?
Note that this beep is followed by a high/low chime when step 41 can’t find a bootable media.
I don’t know yet why the BIOS can’t find the videocard. Maybe there is a stuck address line on the ISA bus, or something else related to addressing the bus.
To learn more about the possible failure, a blind BIOS reflash by the Recovery BIOS may tell us something. We know that the BIOS in the flashchip is good, and it should stay that way if we reflash the same BIOS in the board. But if this scrambles the BIOS, there is a high chance there is an addressing problem on the board.
So try this; copy Awdflash.exe and the 5000108A.BIN BIOS on the bootable floppy, and create an AUTOEXEC.BAT with this command:
AWDFLASH 5000108A.BIN /Py /Sn /Cp /Cd /Cc
This command will execute the flash without any user interaction.
The three /C switches clear the PnP, DMI, and CMOS data.
During the flash, there should be changing codes on the POST analyzer card. These are not from the BIOS, but are progress codes generated by Awdflash.exe. The actual flash is indicated by code 1B. After this there are only 2 more steps, the verify phase (code 1C), and the flash complete phase (code 1D).
When Awdflash terminates, an FF code is shown.
When floppy activity stops and the drive light goes out, switch the power off. Remove and read the BIOS flashchip in your programmer and put it up here. I hope its contents will be educational. 😉
Here is a copy of Awdflash.exe that should work.
The attachment AWD795.zip is no longer available
This is Awdflash v7.95 I use for socket 7 boards. Works here on any socket 7 board with an Award BIOS, except Asus. (For Asus socket 7 boards with AWD BIOS I use Aflash v2.02).
I’ve completed the disassembly of the Bootblock now, and will continue to analyze POST steps C6, 0C, and C5 to see if I can find any clues there.
Cheers, Jan
Reply 10 of 15, by Totalgearhead
Thank you Jan for the followup. I woke in the middle of the night last night recalling where this missing BIOS chip may be? When i got the board the BIOS chip was installed backwards and by the time i realized that it was burnt. Not sure if the previous owner already turned it on or that was my fault for not checking first. So the original BIOS chip is an Intel 28F001BX and I bought to replace it an SST39SF010A. I looked right away and found incompatibility with the chip i bought!
I completed the task you gave above. the POST card did not update, no video out and the result of the floppy stopping is attached. This is likely pointless with the wrong chip. I am going to pull a compatible chip from another motherboard and try again, although I am sure I have done that? The other chip may not be a boot block chip though.
I am learning alot! Thank you
Reply 11 of 15, by Totalgearhead
further information was that i am able to read the 28F001BXT, pins 12,13 and 15 give errors, without pin detect i get the attached bin. It looks to be corrupt. I have no boot block chips, so i am looking online for a replacement. Thank you and sorry for wasting your time when its something i had missed. Thank you
Reply 12 of 15, by Chkcpu
Totalgearhead wrote on 2025-11-01, 13:08:
Nice that you found the original flashchip. This Intel P28F001BX-T is a 5V chip, but needs 12V for programming, and it has a Vpp connection at pin 1 for that.
The SST39SF010A only needs 5V for programming and its pin 1 is “No Connect” so it isn’t bothered by 12V on this pin. Also RP# at pin 30 on the Intel chip is a NC on the SST. The SST doesn’t need this reset signal.
All other pins on the SST39SF010A are the same as on the P28F001BX-T, so the SST chip should be a good replacement. Also the command set conforms to the JEDEC EEPROM flashchip standard.
Maybe the BIOS doesn’t recognize this chip when it wants to write the PnP data to the ESCD block, and then show an “Unknown flashchip” message at the and of POST. But this will not hamper a normal bootup.
But trying another flashchip may surprise us, who knows. 😉
When the POST card did not change from the FF 41 code when trying the blind flash, then this didn’t work and there was no flashchip programming.
Indeed the flashchip contents is still identical to the 5000108A.BIN BIOS.
Totalgearhead wrote on 2025-11-01, 14:40:
Oh boy, this 28F001BX-T chip is fried for sure!
Reading its contents, I see the general layout of a compressed Award BIOS. But every odd byte is the same as the even byte before it, and every byte has bits 0 and 2 set. This corresponds exactly with the errors on pin 12 (Address line A0) and pins 13 and 15 (Data lines D0 and D2). Must have happened when the board was powered-up with the chip installed backwards. 🙁
The BIOS is connected to the chipset southbrige and I sure hope that this mishap didn’t fry the southbridge as well. Let me think about this some more, maybe there is a way to test this. Do you have a scope or signal probe to test activity on address lines?
Cheers , Jan
Reply 13 of 15, by Totalgearhead
Hi Jan, I have tried all the tests with a at29c010a chip and also an older version of the BIOS (1.05). No change in that there is no update to the POST card and no video still. I have done the obvious, moving all the cards to different slots as well. Thank you.
Reply 14 of 15, by Chkcpu
Totalgearhead wrote on 2025-11-03, 16:26:
Hi T.,
Thanks for trying other EEPROM chips. So, BIOS chip incompatibility was not a factor.
Here is an idea.
When the old 28F001BX-T EEPROM was fitted backwards and probably got fried this way, the now failed pins 12, 13, and 15 were in contact with the EEPROM socket pins 28, 29, and 31 and could have damaged the motherboard circuits connect to these pins.
Pin 31 is Write-Enable and is used only during a BIOS flash. But pins 28 and 29 are Address lines A13 and A14.
If one or both of these Address lines are stuck high now, this would perfectly explain the present BIOS behavior. Reading the Bootblock still works because its memory addresses have A13 and A14 always high. But when reading other parts of the BIOS and performing checksums there, things go wrong, which causes the BIOS to jump to recovery mode.
Also the no-video issue can be explained this way, because when the Bootblock searches for the video ROM, it will never find it because the stuck address line causes the BIOS to look at the wrong addresses.
Reading the Intel 82371AB (PIIX4) southbridge datasheet, I see that it can directly control 5 ISA slots without buffering.
When I check this on my i430TX board with 4 ISA slots, I found that the address lines of all 4 ISA slots and the BIOS are interconnected and are probably directly controlled by the southbridge.
On your board with 3 ISA slot, I assume these connections are the same.
This brings me to the following check, that only requires a multimeter.
Switch the boards power off, remove the BIOS chip and set the multimeter to measure resistance.
On the DIP32 BIOS socket, measure the resistance between Vcc pin 32 and each of the Address pins. On my i430TX board I measure 8.1KOhm between each of the 17 address pins A0-A16 and Vcc.
The attachment EEPROM 128KB DIP32 pinout.png is no longer available
I hope you will find the same resistance on all address lines as well. If pin 28 or 29 give a much lower resistance, then we know that A13 or A14 is stuck high.
If your TX430B board doesn’t use a buffer IC between the southbridge and the BIOS/ISA bus, then you know the southbridge is toast. 🙁
This would be a bummer because the i430TX southbridge is a BGA chip that can only be replaced with specialized tools.
I will keep my fingers crossed for a positive outcome…
Jan
Reply 15 of 15, by Totalgearhead
Thank you for the step by step, made it super easy. so all the address pin are reading between 10.05 KOhm and 9.84 KOhm. pin 29 (A14) is reading 9.16 KOhm. So i have resistance across all address lines and VCC pin. I hope its within range still. I have circled back to the smc fdc37m672 chip? Does that have anything to do with the BIOS initializing? It not a very common I/O chip. Thank you again for all the help!
